    Reboots/crashes - RRF ≤3.5.0-rc1
    Beta Firmware
    13
    137
    10.2k
      deckingman @Exerqtor
      @Exerqtor said in Reboots/crashes - RRF 3.5.0-rc1:
      Supply voltage: min 8.3, current 24.1, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
      I still maintain that swapping out your PSU might be a good. Early on you were showing min 22.9, max 26.1 when idle - that ain't normal. Now you have a minimum of 8.3V - that definitely ain't normal.
      Exerqtorundefined 1 Reply Last reply Reply Quote 2
        dc42 administrators @Exerqtor
        @Exerqtor thanks. Those last 2 M122 reports have some common features.
        • Exerqtorundefined
          Exerqtor @deckingman
          @deckingman said in Reboots/crashes - RRF 3.5.0-rc1:
          Yeah i don't know if those readings can maybe (thinking out loud here now) off since i run the Duet3 of a 5v PSU? And the 24v PSU is switched off/on with relays each time the board reboots. 🤷‍♂️ Just to be clear that's more of a question than a statement from my end.
          @dc42 said in Reboots/crashes - RRF 3.5.0-rc1:
          I just got home, and it litterlarly crashed a minute or two after i came home, this time it's also showing heaterfault & 2000c on the hotend
          debug:
          power up + 00:00:03 [info] Event logging started at level debug
          power up + 00:00:03 [info] Running: Duet 3 Mini5plus WiFi: 3.5.0-rc.1+ (2023-11-01 10:29:03)
          power up + 00:00:03 [info] Event logging stopped
          power up + 00:00:03 [debug] Done!
          power up + 00:00:03 [debug] RepRapFirmware for Duet 3 Mini 5+ is up and running.
          power up + 00:00:04 [warn] WiFi module started
          power up + 00:00:04 [warn] Error: Heater 1 fault: failed to read sensor: notReady
          power up + 00:00:04 [info] M291: - Event notification - Heater 1 fault: failed to read sensor: notReady
          power up + 00:00:04 [debug] - Event notification -
          power up + 00:00:04 [debug] Heater 1 fault: failed to read sensor: notReady
          power up + 00:00:08 [warn] WiFi module is connected to access point RV32-IOT2G, IP address 192.168.10.x
          power up + 00:00:08 [warn] HTTP client 192.168.10.xx login succeeded (session key 2917043153)
          2023-11-06 15:53:21 [warn] Date and time set at power up + 00:00:08
          M122 after crash:
          RepRapFirmware for Duet 3 Mini 5+ version 3.5.0-rc.1+ (2023-11-01 10:29:03) running on Duet 3 Mini5plus WiFi (standalone mode)
          Board ID: XNHXF-HR6KL-K65J0-409N2-K9W1Z-RV2MZ
          Used output buffers: 1 of 40 (40 max)
          Static ram: 102812
          Dynamic ram: 123924 of which 0 recycled
          Never used RAM 11824, free system stack 186 words
          Tasks: NETWORK(1,ready,17.5%,234) HEAT(3,nWait,0.0%,352) Move(4,nWait,0.0%,358) CanReceiv(6,nWait,0.0%,797) CanSender(5,nWait,0.0%,336) CanClock(7,delaying,0.0%,350) TMC(4,nWait,0.7%,108) MAIN(1,running,80.7%,670) IDLE(0,ready,0.3%,29) AIN(4,delaying,0.8%,264), total 100.0%
          Owned mutexes: WiFi(NETWORK)
          Last reset 00:13:58 ago, cause: software
          Last software reset at 2023-11-06 15:53, reason: HardFault invState, Platform spinning, available RAM 10940, slot 0
          Software reset code 0x4060 HFSR 0x40000000 CFSR 0x00020000 ICSR 0x00000803 BFAR 0xe000ed38 SP 0x20011f88 Task NETW Freestk 482 ok
          Stack: 000001af 00000002 200014e8 00000000 20032e1b 0009e9cd 00000000 600f0000 00000000 00000000 00000000 00000000 200303ec 00000800 20035928 2002c0e0 20018658 2002bf7d 20018658 2001e868 0002ff97 00000000 00000000 00000000 20012038 00000014 b5dd8a35
          Error status: 0x04
          Aux0 errors 0,0,0
          MCU revision 3, ADC conversions started 838810, completed 838810, timed out 0, errs 0
          MCU temperature: min 36.2, current 36.6, max 39.2
          Supply voltage: min 23.3, current 24.1, max 25.9, under voltage events: 0, over voltage events: 0, power good: yes
          Heap OK, handles allocated/used 99/33, heap memory allocated/used/recyclable 2048/1096/660, gc cycles 39
          Events: 1 queued, 1 completed
          Driver 0: standstill, SG min 16, read errors 0, write errors 1, ifcnt 107, reads 44114, writes 13, timeouts 0, DMA errors 0, CC errors 0
          Driver 1: standstill, SG min 244, read errors 0, write errors 1, ifcnt 102, reads 44114, writes 13, timeouts 0, DMA errors 0, CC errors 0
          Driver 2: standstill, SG min 2, read errors 0, write errors 1, ifcnt 225, reads 44114, writes 13, timeouts 0, DMA errors 0, CC errors 0
          Driver 3: standstill, SG min 2, read errors 0, write errors 1, ifcnt 226, reads 44113, writes 13, timeouts 0, DMA errors 0, CC errors 0
          Driver 4: standstill, SG min 2, read errors 0, write errors 1, ifcnt 228, reads 44114, writes 13, timeouts 0, DMA errors 0, CC errors 0
          Driver 5: not present
          Driver 6: not present
          Date/time: 2023-11-06 16:07:29
          Cache data hit count 1443468903
          Slowest loop: 12.56ms; fastest: 0.13ms
          === Storage ===
          Free file entries: 18
          SD card longest read time 6.9ms, write time 4.4ms, max retries 0
          DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, height map offset 0.000, ebfmin 0.00, ebfmax 0.00
          no step interrupt scheduled
          Moves shaped first try 0, on retry 0, too short 0, wrong shape 0, maybepossible 0
          === DDARing 0 ===
          === DDARing 1 ===
          HTTP is idle in state(s) 0
          Telnet is idle in state(s) 0
          File is idle in state(s) 0
          USB is idle in state(s) 0
          Aux is idle in state(s) 0
          Trigger is idle in state(s) 0
          Queue is idle in state(s) 0
          LCD is idle in state(s) 0
          SBC is idle in state(s) 0
          Daemon is doing "G4 S1" in state(s) 0 0, running macro
          Aux2 is idle in state(s) 0
          File2 is idle in state(s) 0
          Queue2 is idle in state(s) 0
          Q0 segments left 0, axes/extruders owned 0x0000803
          Code queue 0 is empty
          Code queue 1 is empty
          === Filament sensors ===
          check 0 clear 0
          Extruder 0 sensor: no filament
          === CAN ===
          Messages queued 7558, received 17228, lost 0, errs 1, boc 0
          Longest wait 3ms for reply type 6053, peak Tx sync delay 327, free buffers 26 (min 25), ts 4194/4193/0
          Tx timeouts 0,0,0,0,0,0
          === Network ===
          Slowest loop: 6.64ms; fastest: 0.00ms
          Responder states: MQTT(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
          HTTP sessions: 2 of 8
          === WiFi ===
          Interface state: active
          Module is connected to access point
          Failed messages: pending 0, notrdy 0, noresp 0
          Firmware version 2.1beta4
          MAC address c4:5b:be:ce:91:93
          Module reset reason: Power up, Vcc 3.38, flash size 2097152, free heap 42952
          WiFi IP address 192.168.10.x
          Signal strength -47dBm, channel 6, mode 802.11n, reconnections 0
          Clock register 00002001
          M122 after manual reboot with M999:
          Used output buffers: 1 of 40 (32 max)
          Static ram: 102812
          Dynamic ram: 122024 of which 0 recycled
          Never used RAM 13724, free system stack 198 words
          Tasks: NETWORK(1,ready,13.4%,238) HEAT(3,nWait,0.0%,360) Move(4,nWait,0.0%,358) CanReceiv(6,nWait,0.0%,797) CanSender(5,nWait,0.0%,336) CanClock(7,delaying,0.0%,352) TMC(4,nWait,0.7%,116) MAIN(1,running,84.0%,670) IDLE(0,ready,1.0%,29) AIN(4,delaying,0.8%,272), total 100.0%
          Last reset 00:00:32 ago, cause: software
          Last software reset at 2023-11-06 16:08, reason: User, Gcodes spinning, available RAM 11824, slot 1
          Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a
          Error status: 0x00
          Aux0 errors 0,0,0
          MCU revision 3, ADC conversions started 32518, completed 32518, timed out 0, errs 0
          MCU temperature: min 36.3, current 36.8, max 39.2
          Heap OK, handles allocated/used 99/29, heap memory allocated/used/recyclable 2048/904/508, gc cycles 1
          Events: 0 queued, 0 completed
          Driver 0: standstill, SG min 16, read errors 0, write errors 1, ifcnt 121, reads 1681, writes 13, timeouts 0, DMA errors 0, CC errors 0
          Driver 1: standstill, SG min 244, read errors 0, write errors 1, ifcnt 116, reads 1681, writes 13, timeouts 0, DMA errors 0, CC errors 0
          Driver 2: standstill, SG min 2, read errors 0, write errors 1, ifcnt 239, reads 1680, writes 13, timeouts 0, DMA errors 0, CC errors 0
          Driver 3: standstill, SG min 2, read errors 0, write errors 1, ifcnt 240, reads 1680, writes 13, timeouts 0, DMA errors 0, CC errors 0
          Driver 4: standstill, SG min 2, read errors 0, write errors 1, ifcnt 242, reads 1681, writes 13, timeouts 0, DMA errors 0, CC errors 0
          Date/time: 2023-11-06 16:08:19
          Cache data hit count 54882292
          Slowest loop: 8.47ms; fastest: 0.13ms
          === Storage ===
          SD card longest read time 3.6ms, write time 4.1ms, max retries 0
          === DDARing 0 ===
          === DDARing 1 ===
          Heater 1 is on, I-accum = 0.0
          check 0 clear 0
          === CAN ===
          Messages queued 304, received 651, lost 0, errs 1, boc 0
          Longest wait 3ms for reply type 6013, peak Tx sync delay 189, free buffers 26 (min 25), ts 163/162/0
          === Network ===
          Slowest loop: 8.45ms; fastest: 0.00ms
          === WiFi ===
          Module reset reason: Power up, Vcc 3.38, flash size 2097152, free heap 42944
          Signal strength -49dBm, channel 6, mode 802.11n, reconnections 0
          Exerqtorundefined 1 Reply Last reply Reply Quote 0
          • Exerqtorundefined
            Exerqtor @Exerqtor
            Haven't had much time to derp with the printer this week/weekend, plus my damn desktop computer is starting to slowly bite the dust (rejecting RAM, wohoo).
            Anywho, had a couple minutes to check the loggs now while doing som other stuff, and the wifi controller ain't happy.
            debug:
            power up + 00:00:06 [warn] Error: WiFi module reported: no known networks found
            power up + 00:00:06 [warn] WiFi module is idle
            power up + 00:00:08 [warn] Error: WiFi module reported: no known networks found
            power up + 00:00:08 [warn] WiFi module is idle
            power up + 00:00:10 [warn] Error: WiFi module reported: no known networks found
            power up + 00:00:10 [warn] WiFi module is idle
            power up + 00:00:12 [warn] Error: WiFi module reported: no known networks found
            power up + 00:00:12 [warn] WiFi module is idle
            power up + 00:00:14 [warn] Error: WiFi module reported: no known networks found
            power up + 00:00:14 [warn] WiFi module is idle
            power up + 00:00:17 [warn] Error: WiFi module reported: no known networks found
            power up + 00:00:17 [warn] WiFi module is idle
            power up + 00:00:19 [warn] Error: WiFi module reported: no known networks found
            power up + 00:00:19 [warn] WiFi module is idle
            power up + 00:00:21 [warn] Error: WiFi module reported: no known networks found
            power up + 00:00:21 [warn] WiFi module is idle
            power up + 00:00:23 [warn] Error: WiFi module reported: no known networks found
            power up + 00:00:23 [warn] WiFi module is idle
            power up + 00:00:25 [warn] Error: WiFi module reported: no known networks found
            power up + 00:00:25 [warn] WiFi module is idle
            power up + 00:00:28 [warn] Error: WiFi module reported: no known networks found
            power up + 00:00:28 [warn] WiFi module is idle
            power up + 00:00:30 [warn] Error: WiFi module reported: no known networks found
            power up + 00:00:30 [warn] WiFi module is idle
            power up + 00:00:32 [warn] Error: WiFi module reported: no known networks found
            power up + 00:00:32 [warn] WiFi module is idle
            power up + 00:00:34 [warn] Error: WiFi module reported: no known networks found
            power up + 00:00:34 [warn] WiFi module is idle
            power up + 00:00:36 [warn] Error: WiFi module reported: no known networks found
            power up + 00:00:36 [warn] WiFi module is idle
            power up + 00:00:39 [warn] Error: WiFi module reported: Failed to load credentials
            power up + 00:00:39 [warn] WiFi module is idle
            power up + 00:00:41 [warn] Error: WiFi module reported: no known networks found
            power up + 00:00:41 [warn] WiFi module is idle
            power up + 00:00:43 [warn] Error: WiFi module reported: no known networks found
            power up + 00:00:43 [warn] WiFi module is idle
            power up + 00:00:45 [warn] Error: WiFi module reported: no known networks found
            power up + 00:00:45 [warn] WiFi module is idle
            power up + 00:00:47 [warn] Error: WiFi module reported: no known networks found
            power up + 00:00:47 [warn] WiFi module is idle
            power up + 00:00:50 [warn] Error: WiFi module reported: no known networks found
            power up + 00:00:50 [warn] WiFi module is idle
            power up + 00:00:52 [warn] Error: WiFi module reported: no known networks found
            power up + 00:00:52 [warn] WiFi module is idle
            power up + 00:00:54 [warn] Error: WiFi module reported: no known networks found
            power up + 00:00:54 [warn] WiFi module is idle
            power up + 00:00:56 [warn] Error: WiFi module reported: no known networks found
            power up + 00:00:56 [warn] WiFi module is idle
            power up + 00:00:58 [warn] Error: WiFi module reported: no known networks found
            power up + 00:00:58 [warn] WiFi module is idle
            power up + 00:01:01 [warn] Error: WiFi module reported: no known networks found
            power up + 00:01:01 [warn] WiFi module is idle
            power up + 00:01:03 [warn] Error: WiFi module reported: no known networks found
            power up + 00:01:03 [warn] WiFi module is idle
            power up + 00:01:05 [warn] Error: WiFi module reported: no known networks found
            power up + 00:01:05 [warn] WiFi module is idle
            power up + 00:01:07 [warn] Error: WiFi module reported: no known networks found
            power up + 00:01:07 [warn] WiFi module is idle
            power up + 00:01:09 [warn] Error: WiFi module reported: no known networks found
            power up + 00:01:09 [warn] WiFi module is idle
            power up + 00:01:12 [warn] Error: WiFi module reported: no known networks found
            power up + 00:01:12 [warn] WiFi module is idle
            power up + 00:01:14 [warn] Error: WiFi module reported: no known networks found
            power up + 00:01:14 [warn] WiFi module is idle
            power up + 00:01:16 [warn] Error: WiFi module reported: no known networks found
            power up + 00:01:16 [warn] WiFi module is idle
            power up + 00:01:18 [warn] Error: WiFi module reported: no known networks found
            power up + 00:01:18 [warn] WiFi module is idle
            power up + 00:01:20 [warn] Error: WiFi module reported: no known networks found
            power up + 00:01:20 [warn] WiFi module is idle
            power up + 00:01:23 [warn] Error: WiFi module reported: no known networks found
            power up + 00:01:23 [warn] WiFi module is idle
            power up + 00:01:25 [warn] Error: WiFi module reported: no known networks found
            power up + 00:01:25 [warn] WiFi module is idle
            power up + 00:01:27 [warn] Error: WiFi module reported: no known networks found
            power up + 00:01:27 [warn] WiFi module is idle
            power up + 00:01:29 [warn] Error: WiFi module reported: no known networks found
            power up + 00:01:29 [warn] WiFi module is idle
            power up + 00:01:32 [warn] Error: WiFi module reported: no known networks found
            power up + 00:01:32 [warn] WiFi module is idle
            power up + 00:01:34 [warn] Error: WiFi module reported: no known networks found
            power up + 00:01:34 [warn] WiFi module is idle
            power up + 00:01:36 [warn] Error: WiFi module reported: no known networks found
            power up + 00:01:36 [warn] WiFi module is idle
            power up + 00:01:38 [warn] Error: WiFi module reported: no known networks found
            power up + 00:01:38 [warn] WiFi module is idle
            power up + 00:01:40 [warn] Error: WiFi module reported: no known networks found
            power up + 00:01:40 [warn] WiFi module is idle
            power up + 00:01:43 [warn] Error: WiFi module reported: no known networks found
            power up + 00:01:43 [warn] WiFi module is idle
            power up + 00:01:45 [warn] Error: WiFi module reported: no known networks found
            power up + 00:01:45 [warn] WiFi module is idle
            power up + 00:01:47 [warn] Error: WiFi module reported: no known networks found
            power up + 00:01:47 [warn] WiFi module is idle
            power up + 00:01:49 [warn] Error: WiFi module reported: no known networks found
            power up + 00:01:49 [warn] WiFi module is idle
            power up + 00:01:51 [warn] Error: WiFi module reported: no known networks found
            power up + 00:01:51 [warn] WiFi module is idle
            power up + 00:01:54 [warn] Error: WiFi module reported: no known networks found
            power up + 00:01:54 [warn] WiFi module is idle
            power up + 00:01:56 [warn] Error: WiFi module reported: no known networks found
            power up + 00:01:56 [warn] WiFi module is idle
            power up + 00:01:58 [warn] Error: WiFi module reported: no known networks found
            power up + 00:01:58 [warn] WiFi module is idle
            power up + 00:02:00 [warn] Error: WiFi module reported: no known networks found
            power up + 00:02:00 [warn] WiFi module is idle
            power up + 00:02:02 [warn] Error: WiFi module reported: no known networks found
            power up + 00:02:02 [warn] WiFi module is idle
            power up + 00:02:05 [warn] Error: WiFi module reported: no known networks found
            power up + 00:02:05 [warn] WiFi module is idle
            power up + 00:02:07 [warn] Error: WiFi module reported: no known networks found
            power up + 00:02:07 [warn] WiFi module is idle
            power up + 00:02:09 [warn] Error: WiFi module reported: no known networks found
            power up + 00:02:09 [warn] WiFi module is idle
            power up + 00:02:11 [warn] Error: WiFi module reported: no known networks found
            power up + 00:02:11 [warn] WiFi module is idle
            power up + 00:02:15 [warn] WiFi module is connected to access point RV32-IOT2G, IP address 192.168.10.x
            power up + 00:03:04 [warn] Error: WiFi module reported: Lost connection, auto reconnecting
            power up + 00:03:04 [warn] Error: WiFi module reported: Auto reconnect succeeded
            power up + 00:00:06 [warn] Error: WiFi module reported: Failed to load credentials
            power up + 00:00:08 [warn] Error: WiFi module reported: Failed to load credentials
            power up + 00:00:13 [warn] Error: WiFi module reported: no known networks found
            power up + 00:00:13 [warn] WiFi module is idle
            power up + 00:00:15 [warn] Error: WiFi module reported: no known networks found
            power up + 00:00:15 [warn] WiFi module is idle
            power up + 00:00:24 [warn] Error: WiFi module reported: no known networks found
            power up + 00:00:24 [warn] WiFi module is idle
            power up + 00:00:26 [warn] Error: WiFi module reported: no known networks found
            power up + 00:00:26 [warn] WiFi module is idle
            power up + 00:00:35 [warn] Error: WiFi module reported: no known networks found
            power up + 00:00:35 [warn] WiFi module is idle
            power up + 00:00:37 [warn] Error: WiFi module reported: no known networks found
            power up + 00:00:37 [warn] WiFi module is idle
            power up + 00:00:39 [warn] Error: WiFi module reported: no known networks found
            power up + 00:00:46 [warn] Error: WiFi module reported: no known networks found
            power up + 00:00:46 [warn] WiFi module is idle
            power up + 00:00:48 [warn] Error: WiFi module reported: no known networks found
            power up + 00:00:48 [warn] WiFi module is idle
            power up + 00:00:55 [warn] Error: WiFi module reported: no known networks found
            power up + 00:00:55 [warn] WiFi module is idle
            power up + 00:00:57 [warn] Error: WiFi module reported: no known networks found
            power up + 00:00:57 [warn] WiFi module is idle
            power up + 00:00:59 [warn] Error: WiFi module reported: no known networks found
            power up + 00:00:59 [warn] WiFi module is idle
            power up + 00:01:06 [warn] Error: WiFi module reported: no known networks found
            power up + 00:01:06 [warn] WiFi module is idle
            power up + 00:01:08 [warn] Error: WiFi module reported: no known networks found
            power up + 00:01:08 [warn] WiFi module is idle
            power up + 00:01:10 [warn] Error: WiFi module reported: no known networks found
            power up + 00:01:10 [warn] WiFi module is idle
            power up + 00:01:15 [warn] Error: WiFi module reported: no known networks found
            power up + 00:01:15 [warn] WiFi module is idle
            power up + 00:01:17 [warn] Error: WiFi module reported: no known networks found
            power up + 00:01:17 [warn] WiFi module is idle
            power up + 00:01:19 [warn] Error: WiFi module reported: no known networks found
            power up + 00:01:19 [warn] WiFi module is idle
            power up + 00:01:21 [warn] Error: WiFi module reported: no known networks found
            power up + 00:01:21 [warn] WiFi module is idle
            power up + 00:01:24 [warn] Error: WiFi module reported: no known networks found
            power up + 00:01:24 [warn] WiFi module is idle
            power up + 00:01:26 [warn] Error: WiFi module reported: no known networks found
            power up + 00:01:26 [warn] WiFi module is idle
            power up + 00:01:28 [warn] Error: WiFi module reported: no known networks found
            power up + 00:01:28 [warn] WiFi module is idle
            power up + 00:01:30 [warn] Error: WiFi module reported: no known networks found
            power up + 00:01:30 [warn] WiFi module is idle
            power up + 00:01:35 [warn] Error: WiFi module reported: no known networks found
            power up + 00:01:35 [warn] WiFi module is idle
            power up + 00:01:37 [warn] Error: WiFi module reported: no known networks found
            power up + 00:01:37 [warn] WiFi module is idle
            power up + 00:01:39 [warn] Error: WiFi module reported: no known networks found
            power up + 00:01:39 [warn] WiFi module is idle
            power up + 00:01:41 [warn] Error: WiFi module reported: no known networks found
            power up + 00:01:41 [warn] WiFi module is idle
            power up + 00:01:44 [warn] Error: WiFi module reported: no known networks found
            power up + 00:01:44 [warn] WiFi module is idle
            power up + 00:01:46 [warn] Error: WiFi module reported: no known networks found
            power up + 00:01:46 [warn] WiFi module is idle
            power up + 00:01:48 [warn] Error: WiFi module reported: no known networks found
            power up + 00:01:48 [warn] WiFi module is idle
            power up + 00:01:50 [warn] Error: WiFi module reported: no known networks found
            power up + 00:01:50 [warn] WiFi module is idle
            power up + 00:01:53 [warn] Error: WiFi module reported: no known networks found
            power up + 00:01:53 [warn] WiFi module is idle
            power up + 00:01:55 [warn] Error: WiFi module reported: no known networks found
            power up + 00:01:55 [warn] WiFi module is idle
            power up + 00:01:57 [warn] Error: WiFi module reported: Failed to load credentials
            power up + 00:01:57 [warn] WiFi module is idle
            power up + 00:01:59 [warn] Error: WiFi module reported: no known networks found
            power up + 00:01:59 [warn] WiFi module is idle
            power up + 00:02:01 [warn] Error: WiFi module reported: no known networks found
            power up + 00:02:01 [warn] WiFi module is idle
            power up + 00:02:04 [warn] Error: WiFi module reported: no known networks found
            power up + 00:02:06 [warn] Error: WiFi module reported: no known networks found
            power up + 00:02:06 [warn] WiFi module is idle
            power up + 00:02:08 [warn] Error: WiFi module reported: no known networks found
            power up + 00:02:08 [warn] WiFi module is idle
            power up + 00:02:10 [warn] Error: WiFi module reported: no known networks found
            power up + 00:02:10 [warn] WiFi module is idle
            power up + 00:02:13 [warn] Error: WiFi module reported: no known networks found
            power up + 00:02:13 [warn] WiFi module is idle
            power up + 00:02:15 [warn] Error: WiFi module reported: Failed to load credentials
            power up + 00:02:15 [warn] WiFi module is idle
            power up + 00:02:18 [warn] WiFi module is connected to access point RV32-IOT2G, IP address 192.168.10.x
            power up + 00:02:48 [warn] Error: WiFi module reported: Lost connection, auto reconnecting
            power up + 00:02:49 [warn] Error: WiFi module reported: Auto reconnect succeeded
            power up + 69:32:47 [warn] HTTP client 192.168.10.xx login succeeded (session key 1481405628)
            2023-11-10 15:27:24 [warn] Date and time set at power up + 69:32:47
            Continued on the next reply
            • Exerqtorundefined
              Exerqtor @Exerqtor
              M122;
              Used output buffers: 22 of 40 (40 max)
              Static ram: 102812
              Dynamic ram: 122036 of which 12 recycled
              Never used RAM 13700, free system stack 180 words
              Tasks: NETWORK(2,nWait,53.7%,213) HEAT(3,nWait,2.2%,327) Move(4,nWait,0.2%,344) CanReceiv(6,nWait,4.3%,772) CanSender(5,nWait,0.0%,336) CanClock(7,delaying,0.7%,341) TMC(4,nWait,61.6%,108) MAIN(1,running,111.9%,670) IDLE(0,ready,22.0%,29) AIN(4,delaying,71.9%,264), total 328.3%
              Last reset 123:52:45 ago, cause: power up
              Error status: 0x04
              Aux0 errors 0,0,0
              MCU revision 3, ADC conversions started 445965944, completed 445965943, timed out 0, errs 0
              MCU temperature: min 24.4, current 36.2, max 36.6
              Supply voltage: min 0.2, current 24.1, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes
              Heap OK, handles allocated/used 99/29, heap memory allocated/used/recyclable 2048/980/584, gc cycles 20101
              Driver 0: standstill, SG min 0, read errors 0, write errors 0, ifcnt 13, reads 9948, writes 13, timeouts 0, DMA errors 0, CC errors 0
              Driver 1: standstill, SG min 0, read errors 0, write errors 0, ifcnt 13, reads 9948, writes 13, timeouts 0, DMA errors 0, CC errors 0
              Driver 2: standstill, SG min 0, read errors 0, write errors 0, ifcnt 13, reads 9947, writes 13, timeouts 0, DMA errors 0, CC errors 0
              Driver 3: standstill, SG min 0, read errors 0, write errors 0, ifcnt 13, reads 9947, writes 13, timeouts 0, DMA errors 0, CC errors 0
              Driver 4: standstill, SG min 0, read errors 0, write errors 0, ifcnt 13, reads 9948, writes 13, timeouts 0, DMA errors 0, CC errors 0
              Date/time: 2023-11-12 21:47:22
              Slowest loop: 11.70ms; fastest: 0.13ms
              === Storage ===
              SD card longest read time 7.0ms, write time 4.5ms, max retries 0
              === DDARing 0 ===
              === DDARing 1 ===
              check 0 clear 0
              === CAN ===
              Messages queued 4013705, received 9142508, lost 0, errs 3539, boc 0
              Longest wait 3ms for reply type 6053, peak Tx sync delay 11386, free buffers 26 (min 25), ts 2229830/2229826/0
              Tx timeouts 0,0,3,0,0,0 last cancelled message type 30 dest 127
              === Network ===
              Slowest loop: 19.15ms; fastest: 0.00ms
              Responder states: MQTT(0) HTTP(2) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
              === WiFi ===
              Module reset reason: Power up, Vcc 3.38, flash size 2097152, free heap 39508
              Signal strength -53dBm, channel 6, mode 802.11n, reconnections 1
              Should be noted that on this crash it didn't fail to connect to the toolboard, so it wasn't any heater faults etc.
                @Exerqtor please remind me: did this issue also occur when using firmware 3.4.x, or is it specific to 3.5.x?
                I've created https://github.com/Duet3D/RepRapFirmware/issues/935 t track and summarise this, but please continue to post M122 reports in this thread.
                dc42 created this issue in Duet3D/RepRapFirmware
                closed Regular crashes on Duet 3 Mini WiFi #935
                dc42undefined Exerqtorundefined 2 Replies Last reply Reply Quote 0
                  dc42 administrators @dc42
                  @Exerqtor please install the firmware at https://www.dropbox.com/scl/fo/nta4k70rxl6n0bsv8q4q0/h?rlkey=1oq6j3jrvoxa6uaofyn9re3nn&dl=0 and post the M122 report when it next crashes. I have added some extra debug in the area where I think it is crashing.
                  • Exerqtorundefined
                    Exerqtor @dc42
                    IF it happened in 3.4.5 it must have been so Intermittent that i didn't catch it happening. If we put it that way.
                    Okok i will do it later today 👌☺️
                    • Exerqtorundefined
                      Exerqtor @Exerqtor
                      The printer has been sitting idle since i updated to the "special" firmware you compiled, and it's been running for about 24hr with one instance of DWC open but the PC not being used (used stood there ).
                      Now i've been sitting on the PC working for 10min, with the printer idle and in that time the printer has crashed. This time again it's not connecting to the 1LC after the crash and it's throwing a heater fault & 2000C.
                      debuglog:
                      2023-11-15 20:35:24 [warn] HTTP client 192.168.10.xx disconnected
                      2023-11-15 20:35:27 [warn] HTTP client 192.168.10.xx login succeeded (session key 55059692)
                      2023-11-15 20:35:31 [warn] HTTP client 192.168.10.xx disconnected
                      2023-11-15 20:35:36 [warn] HTTP client 192.168.10.xx login succeeded (session key 1424224561)
                      power up + 00:00:03 [info] Running: Duet 3 Mini5plus WiFi: 3.5.0-rc.1+ (2023-11-14 10:45:05)
                      power up + 00:00:08 [warn] HTTP client 192.168.10.xx login succeeded (session key 740842430)
                      2023-11-15 20:37:48 [warn] Date and time set at power up + 00:00:08
                      M122:
                      RepRapFirmware for Duet 3 Mini 5+ version 3.5.0-rc.1+ (2023-11-14 10:45:05) running on Duet 3 Mini5plus WiFi (standalone mode)
                      Used output buffers: 1 of 40 (30 max)
                      Static ram: 102812
                      Dynamic ram: 123820 of which 0 recycled
                      Never used RAM 11928, free system stack 188 words
                      Tasks: NETWORK(1,ready,17.6%,209) HEAT(3,nWait,0.0%,352) Move(4,nWait,0.0%,358) CanReceiv(6,nWait,0.0%,797) CanSender(5,nWait,0.0%,336) CanClock(7,delaying,0.0%,350) TMC(4,nWait,0.7%,108) MAIN(1,running,80.6%,670) IDLE(0,ready,0.3%,29) AIN(4,delaying,0.8%,264), total 100.0%
                      Owned mutexes:
                      Last reset 00:15:57 ago, cause: software
                      Last software reset at 2023-11-15 20:37, reason: AssertionFailed, Gcodes spinning, available RAM 6020, slot 0
                      Software reset code 0x4123 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x20011fbc Task NETW Freestk 495 ok
                      Stack: 000008fe 000af1c8 0002dd83 2002beb4 2002be01 000001a8 2002c0e0 20030b90 2002c0f8 2001e868 a5a5a5a5 a5a5a5a5 00000000 00000000 00000000 00000000 20030b9c 00000800 200358c0 2002c0e0 20018658 2002bf7d 20018658 2001e868 00030023 00000000 00000000
                      Error status: 0x00
                      Aux0 errors 0,0,0
                      MCU revision 3, ADC conversions started 958328, completed 958328, timed out 0, errs 0
                      MCU temperature: min 35.1, current 35.5, max 38.2
                      Supply voltage: min 22.7, current 24.1, max 26.3, under voltage events: 0, over voltage events: 0, power good: yes
                      Heap OK, handles allocated/used 99/33, heap memory allocated/used/recyclable 2048/1932/1496, gc cycles 44
                      Driver 0: standstill, SG min 0, read errors 0, write errors 1, ifcnt 118, reads 50392, writes 13, timeouts 0, DMA errors 0, CC errors 0
                      Driver 1: standstill, SG min 2, read errors 0, write errors 1, ifcnt 118, reads 50392, writes 13, timeouts 0, DMA errors 0, CC errors 0
                      Driver 2: standstill, SG min 0, read errors 0, write errors 1, ifcnt 81, reads 50391, writes 13, timeouts 0, DMA errors 0, CC errors 0
                      Driver 3: standstill, SG min 0, read errors 0, write errors 1, ifcnt 79, reads 50391, writes 13, timeouts 0, DMA errors 0, CC errors 0
                      Driver 4: standstill, SG min 0, read errors 0, write errors 1, ifcnt 80, reads 50392, writes 13, timeouts 0, DMA errors 0, CC errors 0
                      Date/time: 2023-11-15 20:53:37
                      Cache data hit count 1623656227
                      Slowest loop: 12.73ms; fastest: 0.13ms
                      === Storage ===
                      SD card longest read time 6.5ms, write time 4.6ms, max retries 0
                      === DDARing 0 ===
                      === DDARing 1 ===
                      in 0 notIn 0
                      === CAN ===
                      Messages queued 8631, received 19678, lost 0, errs 1, boc 0
                      Longest wait 2ms for reply type 6053, peak Tx sync delay 299, free buffers 26 (min 25), ts 4790/4789/0
                      === Network ===
                      Slowest loop: 9.16ms; fastest: 0.00ms
                      HTTP sessions: 1 of 8
                      === WiFi ===
                      Module reset reason: Power up, Vcc 3.38, flash size 2097152, free heap 43136
                      Signal strength -52dBm, channel 6, mode 802.11n, reconnections 0
                        @Exerqtor thanks, that's just what I needed to confirm the area of the code that's going wrong.
                        To help pin it down further, please install the new version of firmware from https://www.dropbox.com/scl/fo/nta4k70rxl6n0bsv8q4q0/h?rlkey=1oq6j3jrvoxa6uaofyn9re3nn&dl=0 and send a M122 report when it resets again. I don't need a second M122 after a manual reboot.
                        Exerqtorundefined 1 Reply Last reply Reply Quote 1
                        • Exerqtorundefined
                          Exerqtor @dc42
                          @dc42 copy, just installed it.
                          I will post a new M122 report ASAP 👍
                          • Exerqtorundefined
                            Exerqtor @Exerqtor
                            Here we go:
                            debuglog:
                            2023-11-16 03:59:44 [warn] HTTP client 192.168.10.xx login succeeded (session key 1771356456)
                            power up + 00:00:03 [info] Running: Duet 3 Mini5plus WiFi: 3.5.0-rc.1+ (2023-11-15 20:11:19)
                            power up + 00:00:11 [warn] Error: WiFi module reported: Failed to load credentials
                            power up + 00:00:11 [warn] WiFi module is idle
                            power up + 00:00:13 [warn] Error: WiFi module reported: Failed to load credentials
                            power up + 00:00:15 [warn] Error: WiFi module reported: Failed to load credentials
                            power up + 00:00:18 [warn] Error: WiFi module reported: Failed to load credentials
                            power up + 00:00:18 [warn] WiFi module is idle
                            power up + 00:00:20 [warn] Error: WiFi module reported: Failed to load credentials
                            power up + 00:00:20 [warn] WiFi module is idle
                            power up + 00:00:22 [warn] Error: WiFi module reported: Failed to load credentials
                            power up + 00:00:22 [warn] WiFi module is idle
                            power up + 00:00:25 [warn] Error: WiFi module reported: Failed to load credentials
                            power up + 00:00:27 [warn] Error: WiFi module reported: Failed to load credentials
                            power up + 00:00:27 [warn] WiFi module is idle
                            power up + 00:00:30 [warn] Error: WiFi module reported: Failed to load credentials
                            power up + 00:00:32 [warn] Error: WiFi module reported: Failed to load credentials
                            power up + 00:00:34 [warn] Error: WiFi module reported: Failed to load credentials
                            power up + 00:00:37 [warn] Error: WiFi module reported: Failed to load credentials
                            power up + 00:00:41 [warn] WiFi module is connected to access point RV32-IOT2G, IP address 192.168.10.x
                            power up + 00:00:42 [warn] HTTP client 192.168.10.xx login succeeded (session key 1408720838)
                            2023-11-16 09:15:05 [warn] Date and time set at power up + 00:00:42
                            M122:
                            RepRapFirmware for Duet 3 Mini 5+ version 3.5.0-rc.1+ (2023-11-15 20:11:19) running on Duet 3 Mini5plus WiFi (standalone mode)
                            Used output buffers: 1 of 40 (29 max)
                            Static ram: 102844
                            Never used RAM 11896, free system stack 186 words
                            Tasks: NETWORK(1,ready,3212.5%,232) HEAT(3,nWait,4.5%,327) Move(4,nWait,0.5%,352) CanReceiv(6,nWait,9.0%,774) CanSender(5,nWait,0.0%,336) CanClock(7,delaying,1.4%,350) TMC(4,nWait,129.2%,108) MAIN(1,running,1199.1%,670) IDLE(0,ready,45.8%,29) AIN(4,delaying,153.3%,264), total 4755.3%
                            Last reset 06:23:49 ago, cause: software
                            Last software reset at 2023-11-16 09:14, reason: AssertionFailed, Gcodes spinning, available RAM 10964, slot 2
                            Software reset code 0x4123 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00487000 BFAR 0xe000ed38 SP 0x20011fbc Task NETW Freestk 495 ok
                            Stack: 00000904 000af288 0002ddbf 2002bed4 2002be01 000001a8 2002c100 20031c40 2002c118 2001e888 00000000 a5a5a5a5 00000000 00000000 00000000 00000000 20031c4c 00000800 20035940 2002c100 20018668 2002bf9d 20018668 2001e888 00030037 00000000 00000000
                            Error status: 0x00
                            Aux0 errors 0,0,0
                            MCU revision 3, ADC conversions started 23029641, completed 23029641, timed out 0, errs 0
                            MCU temperature: min 34.7, current 35.1, max 37.8
                            Supply voltage: min 23.0, current 24.1, max 26.0, under voltage events: 0, over voltage events: 0, power good: yes
                            Heap OK, handles allocated/used 99/33, heap memory allocated/used/recyclable 2048/716/280, gc cycles 1071
                            Driver 0: standstill, SG min 16, read errors 0, write errors 1, ifcnt 170, reads 32406, writes 13, timeouts 0, DMA errors 0, CC errors 0
                            Driver 1: standstill, SG min 222, read errors 0, write errors 1, ifcnt 170, reads 32406, writes 13, timeouts 0, DMA errors 0, CC errors 0
                            Driver 2: standstill, SG min 2, read errors 0, write errors 1, ifcnt 127, reads 32406, writes 13, timeouts 0, DMA errors 0, CC errors 0
                            Driver 3: standstill, SG min 2, read errors 0, write errors 1, ifcnt 125, reads 32406, writes 13, timeouts 0, DMA errors 0, CC errors 0
                            Driver 4: standstill, SG min 2, read errors 0, write errors 1, ifcnt 126, reads 32406, writes 13, timeouts 0, DMA errors 0, CC errors 0
                            Date/time: 2023-11-16 15:38:13
                            Slowest loop: 12.92ms; fastest: 0.14ms
                            === Storage ===
                            SD card longest read time 7.2ms, write time 4.1ms, max retries 0
                            === DDARing 0 ===
                            === DDARing 1 ===
                            in 0 notIn 0
                            === CAN ===
                            Messages queued 207276, received 472154, lost 0, errs 1, boc 0
                            Longest wait 2ms for reply type 6057, peak Tx sync delay 275, free buffers 26 (min 25), ts 115148/115147/0
                            === Network ===
                            Slowest loop: 5.98ms; fastest: 0.00ms
                            === WiFi ===
                            Module reset reason: Power up, Vcc 3.38, flash size 2097152, free heap 42960
                              @Exerqtor thanks, that's just what I needed to pinpoint what's going on. A DMA transfer is overwriting the return address on the stack. Unless I can spot the reason, I'll need to add some more debug to the firmware and ask you to run in again to find out why.
                              • Exerqtorundefined
                                Exerqtor @dc42
                                @dc42 Thats great news! Starting to get the feeling it might be some light breaking through the clouds now 🤣
                                Just put in what ever you might need and i'll give it a go, can't really use the printer in this state anyways lol.
                                  @Exerqtor thanks, I've had to work on other things today but I'll come back to this very soon. I'm still puzzled that it's not reported more widely.
                                  • Exerqtorundefined
                                    Exerqtor @dc42
                                    @dc42 No problem! Yeah it's struck me as odd too 🤷‍♂️
                                    • Exerqtorundefined
                                      Exerqtor @dc42
                                      @dc42 New crash:
                                      debug:
                                      2023-11-17 21:01:32 [warn] HTTP client 192.168.10.xx login succeeded (session key 3428338341)
                                      power up + 00:00:16 [warn] Error: WiFi module reported: Failed to load credentials
                                      power up + 00:00:16 [warn] WiFi module is idle
                                      power up + 00:00:23 [warn] Error: WiFi module reported: Failed to load credentials
                                      power up + 00:00:36 [warn] WiFi module is connected to access point RV32-IOT2G, IP address 192.168.10.x
                                      power up + 00:00:36 [warn] HTTP client 192.168.10.xx login succeeded (session key 2751057796)
                                      2023-11-18 07:01:07 [warn] Date and time set at power up + 00:00:36
                                      M122:
                                      Used output buffers: 1 of 40 (34 max)
                                      Static ram: 102844
                                      Dynamic ram: 123844 of which 0 recycled
                                      Never used RAM 11872, free system stack 186 words
                                      Tasks: NETWORK(1,ready,16.7%,219) HEAT(3,nWait,0.0%,352) Move(4,nWait,0.0%,358) CanReceiv(6,nWait,0.0%,797) CanSender(5,nWait,0.0%,336) CanClock(7,delaying,0.0%,350) TMC(4,nWait,0.7%,108) MAIN(1,running,81.1%,670) IDLE(0,ready,0.6%,29) AIN(4,delaying,0.8%,264), total 100.0%
                                      Owned mutexes:
                                      Last reset 00:22:02 ago, cause: software
                                      Last software reset at 2023-11-18 07:00, reason: AssertionFailed, Gcodes spinning, available RAM 11268, slot 1
                                      Stack: 00000904 000af288 0002ddbf 2002bed4 2002be01 000001a8 2002c100 200303f8 2002c118 2001e888 00000000 a5a5a5a5 00000000 00000000 00000000 00000000 20030404 00000800 20035940 2002c100 20018668 2002bf9d 20018668 2001e888 00030037 00000000 00000000
                                      Error status: 0x00
                                      Aux0 errors 0,0,0
                                      MCU revision 3, ADC conversions started 1322550, completed 1322550, timed out 0, errs 0
                                      MCU temperature: min 34.8, current 35.1, max 35.3
                                      Supply voltage: min 24.0, current 24.1, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes
                                      Heap OK, handles allocated/used 99/33, heap memory allocated/used/recyclable 2048/1856/1420, gc cycles 61
                                      Driver 0: standstill, SG min 16, read errors 0, write errors 0, ifcnt 207, reads 965, writes 0, timeouts 0, DMA errors 0, CC errors 0
                                      Driver 1: standstill, SG min 240, read errors 0, write errors 0, ifcnt 207, reads 965, writes 0, timeouts 0, DMA errors 0, CC errors 0
                                      Driver 2: standstill, SG min 0, read errors 0, write errors 0, ifcnt 160, reads 965, writes 0, timeouts 0, DMA errors 0, CC errors 0
                                      Driver 3: standstill, SG min 0, read errors 0, write errors 0, ifcnt 157, reads 966, writes 0, timeouts 0, DMA errors 0, CC errors 0
                                      Driver 4: standstill, SG min 0, read errors 0, write errors 0, ifcnt 158, reads 965, writes 0, timeouts 0, DMA errors 0, CC errors 0
                                      Date/time: 2023-11-18 07:22:32
                                      Cache data hit count 2212461605
                                      Slowest loop: 10.21ms; fastest: 0.13ms
                                      === Storage ===
                                      SD card longest read time 3.6ms, write time 4.2ms, max retries 0
                                      === DDARing 0 ===
                                      === DDARing 1 ===
                                      in 0 notIn 0
                                      === CAN ===
                                      Messages queued 165, received 379, lost 0, errs 0, boc 0
                                      Longest wait 0ms for reply type 0, peak Tx sync delay 3, free buffers 26 (min 26), ts 92/92/0
                                      === Network ===
                                      Slowest loop: 20.33ms; fastest: 0.06ms
                                      === WiFi ===
                                      Module reset reason: Power up, Vcc 3.38, flash size 2097152, free heap 43120
                                      Signal strength -53dBm, channel 6, mode 802.11n, reconnections 0
                                      But just out of curiosity, as I've understood it it's some DMA transfer between the CPU and WiFi-module that's causing the crashes.
                                      Does this mean that if I've got a print I need/want to do I could just:
                                      • Upload print job.
                                      • Turn off the WiFi module with M552 S-1.
                                      • Start the print from PanelDue, and let it complete.
                                      • Once the job is done, turn on networking again from PanelDue with M552 S1.
                                      Or will the DMA transfers still happen or try to happen, potentially causing a crash even if the WiFi-module is disabled?
                                        @Exerqtor yes I think the crash will only occur when the WiFi module is enabled, because it's the code that talks to the WiFi module that is crashing.
                                        • Exerqtorundefined
                                          Exerqtor @dc42
                                          @dc42 Ok, good to know if I want to run a larger more time consuming print.
                                            @Exerqtor please install the firmware at https://www.dropbox.com/scl/fo/nta4k70rxl6n0bsv8q4q0/h?rlkey=1oq6j3jrvoxa6uaofyn9re3nn&dl=0 and post the M122 after it next resets.
