Reboots/crashes - RRF ≤3.5.0-rc1
Another crash about 4 hours and 30minutes ago, one instance of DWC open on the desktop but with orcaslicer/other instances closed (printer idle).
This time it also reports a heater fault and 2000c on the hotend, so it seems like the toolboard don't get recognized after the crashes now.
debug:
2023-11-05 00:02:51 [warn] HTTP client 192.168.10.100 login succeeded (session key 328058056) power up + 00:00:03 [info] Event logging started at level debug power up + 00:00:03 [info] Running: Duet 3 Mini5plus WiFi: 3.5.0-rc.1+ (2023-11-01 10:29:03) power up + 00:00:03 [info] Event logging stopped power up + 00:00:03 [info] Event logging started at level debug power up + 00:00:03 [info] Running: Duet 3 Mini5plus WiFi: 3.5.0-rc.1+ (2023-11-01 10:29:03) power up + 00:00:03 [debug] Done! power up + 00:00:03 [debug] RepRapFirmware for Duet 3 Mini 5+ is up and running. power up + 00:00:04 [warn] Error: Heater 1 fault: failed to read sensor: notReady power up + 00:00:04 [info] M291: - Event notification - Heater 1 fault: failed to read sensor: notReady power up + 00:00:04 [debug] - Event notification - power up + 00:00:04 [debug] Heater 1 fault: failed to read sensor: notReady power up + 00:00:04 [warn] WiFi module started power up + 00:00:08 [warn] WiFi module is connected to access point RV32-IOT2G, IP address 192.168.10.x power up + 00:00:10 [warn] HTTP client 192.168.10.xx login succeeded (session key 987728275) 2023-11-05 06:19:22 [warn] Date and time set at power up + 00:00:10 M122 after crash:
=== Diagnostics === RepRapFirmware for Duet 3 Mini 5+ version 3.5.0-rc.1+ (2023-11-01 10:29:03) running on Duet 3 Mini5plus WiFi (standalone mode) Board ID: XNHXF-HR6KL-K65J0-409N2-K9W1Z-RV2MZ Used output buffers: 1 of 40 (34 max) === RTOS === Static ram: 102812 Dynamic ram: 123924 of which 0 recycled Never used RAM 11824, free system stack 182 words Tasks: NETWORK(1,ready,58.6%,203) HEAT(3,nWait,0.1%,331) Move(4,nWait,0.0%,356) CanReceiv(6,nWait,0.2%,774) CanSender(5,nWait,0.0%,336) CanClock(7,delaying,0.0%,350) TMC(4,nWait,2.3%,108) MAIN(1,running,35.2%,670) IDLE(0,ready,0.9%,29) AIN(4,delaying,2.7%,264), total 100.0% Owned mutexes: WiFi(NETWORK) === Platform === Last reset 04:30:58 ago, cause: software Last software reset at 2023-11-05 06:19, reason: HardFault invState, Gcodes spinning, available RAM 11236, slot 1 Software reset code 0x4063 HFSR 0x40000000 CFSR 0x00020000 ICSR 0x00000803 BFAR 0xe000ed38 SP 0x20011f88 Task NETW Freestk 482 ok Stack: 000001ae 00000002 200014e8 00000000 20032e1a 0009e9cd 00000000 600f0000 00000000 00000000 00000000 00000000 200303ec 00000800 20035928 2002c0e0 20018658 2002bf7d 20018658 2001e868 0002ff97 00000000 00000000 00000000 20012038 00000014 904c0824 Error status: 0x00 Aux0 errors 0,0,0 MCU revision 3, ADC conversions started 16258966, completed 16258966, timed out 0, errs 0 MCU temperature: min 36.2, current 37.2, max 39.2 Supply voltage: min 22.5, current 24.1, max 26.5, under voltage events: 0, over voltage events: 0, power good: yes Heap OK, handles allocated/used 99/33, heap memory allocated/used/recyclable 2048/716/280, gc cycles 756 Events: 1 queued, 1 completed Driver 0: standstill, SG min 16, read errors 0, write errors 1, ifcnt 69, reads 3742, writes 13, timeouts 0, DMA errors 0, CC errors 0 Driver 1: standstill, SG min 236, read errors 0, write errors 1, ifcnt 64, reads 3742, writes 13, timeouts 0, DMA errors 0, CC errors 0 Driver 2: standstill, SG min 0, read errors 0, write errors 1, ifcnt 193, reads 3742, writes 13, timeouts 0, DMA errors 0, CC errors 0 Driver 3: standstill, SG min 0, read errors 0, write errors 1, ifcnt 194, reads 3741, writes 13, timeouts 0, DMA errors 0, CC errors 0 Driver 4: standstill, SG min 0, read errors 0, write errors 1, ifcnt 196, reads 3742, writes 13, timeouts 0, DMA errors 0, CC errors 0 Driver 5: not present Driver 6: not present Date/time: 2023-11-05 10:50:10 Cache data hit count 4294967295 Slowest loop: 13.22ms; fastest: 0.13ms === Storage === Free file entries: 18 SD card 0 detected, interface speed: 22.5MBytes/sec SD card longest read time 7.2ms, write time 4.4ms, max retries 0 === Move === DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, height map offset 0.000, ebfmin 0.00, ebfmax 0.00 no step interrupt scheduled Moves shaped first try 0, on retry 0, too short 0, wrong shape 0, maybepossible 0 === DDARing 0 === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === DDARing 1 === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters 0 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0 === GCodes === Movement locks held by null, null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon is doing "G4 S1" in state(s) 0 0, running macro Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 File2 is idle in state(s) 0 Queue2 is idle in state(s) 0 Q0 segments left 0, axes/extruders owned 0x0000803 Code queue 0 is empty Q1 segments left 0, axes/extruders owned 0x0000000 Code queue 1 is empty === Filament sensors === check 0 clear 0 Extruder 0 sensor: no filament === CAN === Messages queued 146340, received 333359, lost 0, errs 0, boc 0 Longest wait 2ms for reply type 6053, peak Tx sync delay 270, free buffers 26 (min 25), ts 81295/81294/0 Tx timeouts 0,0,0,0,0,0 === Network === Slowest loop: 8.43ms; fastest: 0.00ms Responder states: MQTT(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) HTTP sessions: 2 of 8 === WiFi === Interface state: active Module is connected to access point Failed messages: pending 0, notrdy 0, noresp 0 Firmware version 2.1beta4 MAC address c4:5b:be:ce:91:93 Module reset reason: Power up, Vcc 3.38, flash size 2097152, free heap 42960 WiFi IP address 192.168.10.x Signal strength -49dBm, channel 6, mode 802.11n, reconnections 0 Clock register 00002001 Socket states: 0 0 0 0 0 0 0 0 And here is a M122 report from after restarting the board(s) with M999:
=== Diagnostics === RepRapFirmware for Duet 3 Mini 5+ version 3.5.0-rc.1+ (2023-11-01 10:29:03) running on Duet 3 Mini5plus WiFi (standalone mode) Board ID: XNHXF-HR6KL-K65J0-409N2-K9W1Z-RV2MZ Used output buffers: 4 of 40 (29 max) === RTOS === Static ram: 102812 Dynamic ram: 122012 of which 12 recycled Never used RAM 13724, free system stack 198 words Tasks: NETWORK(1,ready,11.8%,228) HEAT(3,nWait,0.0%,356) Move(4,nWait,0.0%,358) CanReceiv(6,nWait,0.0%,797) CanSender(5,nWait,0.0%,336) CanClock(7,delaying,0.0%,352) TMC(4,nWait,0.7%,116) MAIN(1,running,85.2%,670) IDLE(0,ready,1.4%,29) AIN(4,delaying,0.8%,272), total 100.0% Owned mutexes: === Platform === Last reset 00:00:21 ago, cause: software Last software reset at 2023-11-05 10:51, reason: User, Gcodes spinning, available RAM 11824, slot 2 Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0044f000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a Error status: 0x00 Aux0 errors 0,0,0 MCU revision 3, ADC conversions started 21884, completed 21884, timed out 0, errs 0 MCU temperature: min 37.0, current 37.2, max 40.1 Supply voltage: min 8.3, current 24.1, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes Heap OK, handles allocated/used 99/29, heap memory allocated/used/recyclable 2048/1692/1296, gc cycles 0 Events: 0 queued, 0 completed Driver 0: standstill, SG min 16, read errors 0, write errors 1, ifcnt 83, reads 1121, writes 13, timeouts 0, DMA errors 0, CC errors 0 Driver 1: standstill, SG min 236, read errors 0, write errors 1, ifcnt 78, reads 1121, writes 13, timeouts 0, DMA errors 0, CC errors 0 Driver 2: standstill, SG min 0, read errors 0, write errors 1, ifcnt 207, reads 1121, writes 13, timeouts 0, DMA errors 0, CC errors 0 Driver 3: standstill, SG min 0, read errors 0, write errors 1, ifcnt 208, reads 1120, writes 13, timeouts 0, DMA errors 0, CC errors 0 Driver 4: standstill, SG min 0, read errors 0, write errors 1, ifcnt 210, reads 1121, writes 13, timeouts 0, DMA errors 0, CC errors 0 Driver 5: not present Driver 6: not present Date/time: 2023-11-05 10:52:03 Cache data hit count 36913447 Slowest loop: 5.73ms; fastest: 0.14ms === Storage === Free file entries: 18 SD card 0 detected, interface speed: 22.5MBytes/sec SD card longest read time 3.8ms, write time 6.0ms, max retries 0 === Move === DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, height map offset 0.000, ebfmin 0.00, ebfmax 0.00 no step interrupt scheduled Moves shaped first try 0, on retry 0, too short 0, wrong shape 0, maybepossible 0 === DDARing 0 === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === DDARing 1 === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters 0 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0 Heater 1 is on, I-accum = 0.0 === GCodes === Movement locks held by null, null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon is doing "G4 S1" in state(s) 0 0, running macro Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 File2 is idle in state(s) 0 Queue2 is idle in state(s) 0 Q0 segments left 0, axes/extruders owned 0x0000803 Code queue 0 is empty Q1 segments left 0, axes/extruders owned 0x0000000 Code queue 1 is empty === Filament sensors === check 0 clear 0 Extruder 0 sensor: no filament === CAN === Messages queued 208, received 436, lost 0, errs 0, boc 0 Longest wait 2ms for reply type 6031, peak Tx sync delay 3, free buffers 26 (min 25), ts 109/108/0 Tx timeouts 0,0,0,0,0,0 === Network === Slowest loop: 8.47ms; fastest: 0.00ms Responder states: MQTT(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) HTTP sessions: 2 of 8 === WiFi === Interface state: active Module is connected to access point Failed messages: pending 0, notrdy 0, noresp 0 Firmware version 2.1beta4 MAC address c4:5b:be:ce:91:93 Module reset reason: Power up, Vcc 3.38, flash size 2097152, free heap 39880 WiFi IP address 192.168.10.x Signal strength -50dBm, channel 6, mode 802.11n, reconnections 0 Clock register 00002001 Socket states: 0 0 0 0 0 0 0 0
It should be noted that it's no recent wifi connections/disconnections leading up to any of the recent crashes in the logs, however it's been one or more connected session on each of them.
@Exerqtor said in Reboots/crashes - RRF 3.5.0-rc1:
I still maintain that swapping out your PSU might be a good. Early on you were showing min 22.9, max 26.1 when idle - that ain't normal. Now you have a minimum of 8.3V - that definitely ain't normal.
@Exerqtor thanks. Those last 2 M122 reports have some common features.
@deckingman said in Reboots/crashes - RRF 3.5.0-rc1:
Yeah i don't know if those readings can maybe (thinking out loud here now) off since i run the Duet3 of a 5v PSU? And the 24v PSU is switched off/on with relays each time the board reboots.
Just to be clear that's more of a question than a statement from my end.
@dc42 said in Reboots/crashes - RRF 3.5.0-rc1:
I just got home, and it litterlarly crashed a minute or two after i came home, this time it's also showing heaterfault & 2000c on the hotend
debug:
power up + 00:00:03 [info] Event logging started at level debug power up + 00:00:03 [info] Running: Duet 3 Mini5plus WiFi: 3.5.0-rc.1+ (2023-11-01 10:29:03) power up + 00:00:03 [info] Event logging stopped power up + 00:00:03 [info] Event logging started at level debug power up + 00:00:03 [info] Running: Duet 3 Mini5plus WiFi: 3.5.0-rc.1+ (2023-11-01 10:29:03) power up + 00:00:03 [debug] Done! power up + 00:00:03 [debug] RepRapFirmware for Duet 3 Mini 5+ is up and running. power up + 00:00:04 [warn] WiFi module started power up + 00:00:04 [warn] Error: Heater 1 fault: failed to read sensor: notReady power up + 00:00:04 [info] M291: - Event notification - Heater 1 fault: failed to read sensor: notReady power up + 00:00:04 [debug] - Event notification - power up + 00:00:04 [debug] Heater 1 fault: failed to read sensor: notReady power up + 00:00:08 [warn] WiFi module is connected to access point RV32-IOT2G, IP address 192.168.10.x power up + 00:00:08 [warn] HTTP client 192.168.10.xx login succeeded (session key 2917043153) 2023-11-06 15:53:21 [warn] Date and time set at power up + 00:00:08 M122 after crash:
=== Diagnostics === RepRapFirmware for Duet 3 Mini 5+ version 3.5.0-rc.1+ (2023-11-01 10:29:03) running on Duet 3 Mini5plus WiFi (standalone mode) Board ID: XNHXF-HR6KL-K65J0-409N2-K9W1Z-RV2MZ Used output buffers: 1 of 40 (40 max) === RTOS === Static ram: 102812 Dynamic ram: 123924 of which 0 recycled Never used RAM 11824, free system stack 186 words Tasks: NETWORK(1,ready,17.5%,234) HEAT(3,nWait,0.0%,352) Move(4,nWait,0.0%,358) CanReceiv(6,nWait,0.0%,797) CanSender(5,nWait,0.0%,336) CanClock(7,delaying,0.0%,350) TMC(4,nWait,0.7%,108) MAIN(1,running,80.7%,670) IDLE(0,ready,0.3%,29) AIN(4,delaying,0.8%,264), total 100.0% Owned mutexes: WiFi(NETWORK) === Platform === Last reset 00:13:58 ago, cause: software Last software reset at 2023-11-06 15:53, reason: HardFault invState, Platform spinning, available RAM 10940, slot 0 Software reset code 0x4060 HFSR 0x40000000 CFSR 0x00020000 ICSR 0x00000803 BFAR 0xe000ed38 SP 0x20011f88 Task NETW Freestk 482 ok Stack: 000001af 00000002 200014e8 00000000 20032e1b 0009e9cd 00000000 600f0000 00000000 00000000 00000000 00000000 200303ec 00000800 20035928 2002c0e0 20018658 2002bf7d 20018658 2001e868 0002ff97 00000000 00000000 00000000 20012038 00000014 b5dd8a35 Error status: 0x04 Aux0 errors 0,0,0 MCU revision 3, ADC conversions started 838810, completed 838810, timed out 0, errs 0 MCU temperature: min 36.2, current 36.6, max 39.2 Supply voltage: min 23.3, current 24.1, max 25.9, under voltage events: 0, over voltage events: 0, power good: yes Heap OK, handles allocated/used 99/33, heap memory allocated/used/recyclable 2048/1096/660, gc cycles 39 Events: 1 queued, 1 completed Driver 0: standstill, SG min 16, read errors 0, write errors 1, ifcnt 107, reads 44114, writes 13, timeouts 0, DMA errors 0, CC errors 0 Driver 1: standstill, SG min 244, read errors 0, write errors 1, ifcnt 102, reads 44114, writes 13, timeouts 0, DMA errors 0, CC errors 0 Driver 2: standstill, SG min 2, read errors 0, write errors 1, ifcnt 225, reads 44114, writes 13, timeouts 0, DMA errors 0, CC errors 0 Driver 3: standstill, SG min 2, read errors 0, write errors 1, ifcnt 226, reads 44113, writes 13, timeouts 0, DMA errors 0, CC errors 0 Driver 4: standstill, SG min 2, read errors 0, write errors 1, ifcnt 228, reads 44114, writes 13, timeouts 0, DMA errors 0, CC errors 0 Driver 5: not present Driver 6: not present Date/time: 2023-11-06 16:07:29 Cache data hit count 1443468903 Slowest loop: 12.56ms; fastest: 0.13ms === Storage === Free file entries: 18 SD card 0 detected, interface speed: 22.5MBytes/sec SD card longest read time 6.9ms, write time 4.4ms, max retries 0 === Move === DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, height map offset 0.000, ebfmin 0.00, ebfmax 0.00 no step interrupt scheduled Moves shaped first try 0, on retry 0, too short 0, wrong shape 0, maybepossible 0 === DDARing 0 === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === DDARing 1 === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters 0 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0 === GCodes === Movement locks held by null, null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon is doing "G4 S1" in state(s) 0 0, running macro Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 File2 is idle in state(s) 0 Queue2 is idle in state(s) 0 Q0 segments left 0, axes/extruders owned 0x0000803 Code queue 0 is empty Q1 segments left 0, axes/extruders owned 0x0000000 Code queue 1 is empty === Filament sensors === check 0 clear 0 Extruder 0 sensor: no filament === CAN === Messages queued 7558, received 17228, lost 0, errs 1, boc 0 Longest wait 3ms for reply type 6053, peak Tx sync delay 327, free buffers 26 (min 25), ts 4194/4193/0 Tx timeouts 0,0,0,0,0,0 === Network === Slowest loop: 6.64ms; fastest: 0.00ms Responder states: MQTT(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) HTTP sessions: 2 of 8 === WiFi === Interface state: active Module is connected to access point Failed messages: pending 0, notrdy 0, noresp 0 Firmware version 2.1beta4 MAC address c4:5b:be:ce:91:93 Module reset reason: Power up, Vcc 3.38, flash size 2097152, free heap 42952 WiFi IP address 192.168.10.x Signal strength -47dBm, channel 6, mode 802.11n, reconnections 0 Clock register 00002001 Socket states: 0 0 0 0 0 0 0 0 M122 after manual reboot with M999:
=== Diagnostics === RepRapFirmware for Duet 3 Mini 5+ version 3.5.0-rc.1+ (2023-11-01 10:29:03) running on Duet 3 Mini5plus WiFi (standalone mode) Board ID: XNHXF-HR6KL-K65J0-409N2-K9W1Z-RV2MZ Used output buffers: 1 of 40 (32 max) === RTOS === Static ram: 102812 Dynamic ram: 122024 of which 0 recycled Never used RAM 13724, free system stack 198 words Tasks: NETWORK(1,ready,13.4%,238) HEAT(3,nWait,0.0%,360) Move(4,nWait,0.0%,358) CanReceiv(6,nWait,0.0%,797) CanSender(5,nWait,0.0%,336) CanClock(7,delaying,0.0%,352) TMC(4,nWait,0.7%,116) MAIN(1,running,84.0%,670) IDLE(0,ready,1.0%,29) AIN(4,delaying,0.8%,272), total 100.0% Owned mutexes: WiFi(NETWORK) === Platform === Last reset 00:00:32 ago, cause: software Last software reset at 2023-11-06 16:08, reason: User, Gcodes spinning, available RAM 11824, slot 1 Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a Error status: 0x00 Aux0 errors 0,0,0 MCU revision 3, ADC conversions started 32518, completed 32518, timed out 0, errs 0 MCU temperature: min 36.3, current 36.8, max 39.2 Supply voltage: min 8.3, current 24.1, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes Heap OK, handles allocated/used 99/29, heap memory allocated/used/recyclable 2048/904/508, gc cycles 1 Events: 0 queued, 0 completed Driver 0: standstill, SG min 16, read errors 0, write errors 1, ifcnt 121, reads 1681, writes 13, timeouts 0, DMA errors 0, CC errors 0 Driver 1: standstill, SG min 244, read errors 0, write errors 1, ifcnt 116, reads 1681, writes 13, timeouts 0, DMA errors 0, CC errors 0 Driver 2: standstill, SG min 2, read errors 0, write errors 1, ifcnt 239, reads 1680, writes 13, timeouts 0, DMA errors 0, CC errors 0 Driver 3: standstill, SG min 2, read errors 0, write errors 1, ifcnt 240, reads 1680, writes 13, timeouts 0, DMA errors 0, CC errors 0 Driver 4: standstill, SG min 2, read errors 0, write errors 1, ifcnt 242, reads 1681, writes 13, timeouts 0, DMA errors 0, CC errors 0 Driver 5: not present Driver 6: not present Date/time: 2023-11-06 16:08:19 Cache data hit count 54882292 Slowest loop: 8.47ms; fastest: 0.13ms === Storage === Free file entries: 18 SD card 0 detected, interface speed: 22.5MBytes/sec SD card longest read time 3.6ms, write time 4.1ms, max retries 0 === Move === DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, height map offset 0.000, ebfmin 0.00, ebfmax 0.00 no step interrupt scheduled Moves shaped first try 0, on retry 0, too short 0, wrong shape 0, maybepossible 0 === DDARing 0 === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === DDARing 1 === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters 0 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0 Heater 1 is on, I-accum = 0.0 === GCodes === Movement locks held by null, null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon is doing "G4 S1" in state(s) 0 0, running macro Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 File2 is idle in state(s) 0 Queue2 is idle in state(s) 0 Q0 segments left 0, axes/extruders owned 0x0000803 Code queue 0 is empty Q1 segments left 0, axes/extruders owned 0x0000000 Code queue 1 is empty === Filament sensors === check 0 clear 0 Extruder 0 sensor: no filament === CAN === Messages queued 304, received 651, lost 0, errs 1, boc 0 Longest wait 3ms for reply type 6013, peak Tx sync delay 189, free buffers 26 (min 25), ts 163/162/0 Tx timeouts 0,0,0,0,0,0 === Network === Slowest loop: 8.45ms; fastest: 0.00ms Responder states: MQTT(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) HTTP sessions: 2 of 8 === WiFi === Interface state: active Module is connected to access point Failed messages: pending 0, notrdy 0, noresp 0 Firmware version 2.1beta4 MAC address c4:5b:be:ce:91:93 Module reset reason: Power up, Vcc 3.38, flash size 2097152, free heap 42944 WiFi IP address 192.168.10.x Signal strength -49dBm, channel 6, mode 802.11n, reconnections 0 Clock register 00002001 Socket states: 0 0 0 0 0 0 0 0 -
Haven't had much time to derp with the printer this week/weekend, plus my damn desktop computer is starting to slowly bite the dust (rejecting RAM, wohoo).
Anywho, had a couple minutes to check the loggs now while doing som other stuff, and the wifi controller ain't happy.
debug:
power up + 00:00:03 [info] Event logging started at level debug power up + 00:00:03 [info] Running: Duet 3 Mini5plus WiFi: 3.5.0-rc.1+ (2023-11-01 10:29:03) power up + 00:00:03 [info] Event logging stopped power up + 00:00:03 [info] Event logging started at level debug power up + 00:00:03 [info] Running: Duet 3 Mini5plus WiFi: 3.5.0-rc.1+ (2023-11-01 10:29:03) power up + 00:00:03 [debug] Done! power up + 00:00:03 [debug] RepRapFirmware for Duet 3 Mini 5+ is up and running. power up + 00:00:04 [warn] WiFi module started power up + 00:00:06 [warn] Error: WiFi module reported: no known networks found power up + 00:00:06 [warn] WiFi module is idle power up + 00:00:08 [warn] Error: WiFi module reported: no known networks found power up + 00:00:08 [warn] WiFi module is idle power up + 00:00:10 [warn] Error: WiFi module reported: no known networks found power up + 00:00:10 [warn] WiFi module is idle power up + 00:00:12 [warn] Error: WiFi module reported: no known networks found power up + 00:00:12 [warn] WiFi module is idle power up + 00:00:14 [warn] Error: WiFi module reported: no known networks found power up + 00:00:14 [warn] WiFi module is idle power up + 00:00:17 [warn] Error: WiFi module reported: no known networks found power up + 00:00:17 [warn] WiFi module is idle power up + 00:00:19 [warn] Error: WiFi module reported: no known networks found power up + 00:00:19 [warn] WiFi module is idle power up + 00:00:21 [warn] Error: WiFi module reported: no known networks found power up + 00:00:21 [warn] WiFi module is idle power up + 00:00:23 [warn] Error: WiFi module reported: no known networks found power up + 00:00:23 [warn] WiFi module is idle power up + 00:00:25 [warn] Error: WiFi module reported: no known networks found power up + 00:00:25 [warn] WiFi module is idle power up + 00:00:28 [warn] Error: WiFi module reported: no known networks found power up + 00:00:28 [warn] WiFi module is idle power up + 00:00:30 [warn] Error: WiFi module reported: no known networks found power up + 00:00:30 [warn] WiFi module is idle power up + 00:00:32 [warn] Error: WiFi module reported: no known networks found power up + 00:00:32 [warn] WiFi module is idle power up + 00:00:34 [warn] Error: WiFi module reported: no known networks found power up + 00:00:34 [warn] WiFi module is idle power up + 00:00:36 [warn] Error: WiFi module reported: no known networks found power up + 00:00:36 [warn] WiFi module is idle power up + 00:00:39 [warn] Error: WiFi module reported: Failed to load credentials power up + 00:00:39 [warn] WiFi module is idle power up + 00:00:41 [warn] Error: WiFi module reported: no known networks found power up + 00:00:41 [warn] WiFi module is idle power up + 00:00:43 [warn] Error: WiFi module reported: no known networks found power up + 00:00:43 [warn] WiFi module is idle power up + 00:00:45 [warn] Error: WiFi module reported: no known networks found power up + 00:00:45 [warn] WiFi module is idle power up + 00:00:47 [warn] Error: WiFi module reported: no known networks found power up + 00:00:47 [warn] WiFi module is idle power up + 00:00:50 [warn] Error: WiFi module reported: no known networks found power up + 00:00:50 [warn] WiFi module is idle power up + 00:00:52 [warn] Error: WiFi module reported: no known networks found power up + 00:00:52 [warn] WiFi module is idle power up + 00:00:54 [warn] Error: WiFi module reported: no known networks found power up + 00:00:54 [warn] WiFi module is idle power up + 00:00:56 [warn] Error: WiFi module reported: no known networks found power up + 00:00:56 [warn] WiFi module is idle power up + 00:00:58 [warn] Error: WiFi module reported: no known networks found power up + 00:00:58 [warn] WiFi module is idle power up + 00:01:01 [warn] Error: WiFi module reported: no known networks found power up + 00:01:01 [warn] WiFi module is idle power up + 00:01:03 [warn] Error: WiFi module reported: no known networks found power up + 00:01:03 [warn] WiFi module is idle power up + 00:01:05 [warn] Error: WiFi module reported: no known networks found power up + 00:01:05 [warn] WiFi module is idle power up + 00:01:07 [warn] Error: WiFi module reported: no known networks found power up + 00:01:07 [warn] WiFi module is idle power up + 00:01:09 [warn] Error: WiFi module reported: no known networks found power up + 00:01:09 [warn] WiFi module is idle power up + 00:01:12 [warn] Error: WiFi module reported: no known networks found power up + 00:01:12 [warn] WiFi module is idle power up + 00:01:14 [warn] Error: WiFi module reported: no known networks found power up + 00:01:14 [warn] WiFi module is idle power up + 00:01:16 [warn] Error: WiFi module reported: no known networks found power up + 00:01:16 [warn] WiFi module is idle power up + 00:01:18 [warn] Error: WiFi module reported: no known networks found power up + 00:01:18 [warn] WiFi module is idle power up + 00:01:20 [warn] Error: WiFi module reported: no known networks found power up + 00:01:20 [warn] WiFi module is idle power up + 00:01:23 [warn] Error: WiFi module reported: no known networks found power up + 00:01:23 [warn] WiFi module is idle power up + 00:01:25 [warn] Error: WiFi module reported: no known networks found power up + 00:01:25 [warn] WiFi module is idle power up + 00:01:27 [warn] Error: WiFi module reported: no known networks found power up + 00:01:27 [warn] WiFi module is idle power up + 00:01:29 [warn] Error: WiFi module reported: no known networks found power up + 00:01:29 [warn] WiFi module is idle power up + 00:01:32 [warn] Error: WiFi module reported: no known networks found power up + 00:01:32 [warn] WiFi module is idle power up + 00:01:34 [warn] Error: WiFi module reported: no known networks found power up + 00:01:34 [warn] WiFi module is idle power up + 00:01:36 [warn] Error: WiFi module reported: no known networks found power up + 00:01:36 [warn] WiFi module is idle power up + 00:01:38 [warn] Error: WiFi module reported: no known networks found power up + 00:01:38 [warn] WiFi module is idle power up + 00:01:40 [warn] Error: WiFi module reported: no known networks found power up + 00:01:40 [warn] WiFi module is idle power up + 00:01:43 [warn] Error: WiFi module reported: no known networks found power up + 00:01:43 [warn] WiFi module is idle power up + 00:01:45 [warn] Error: WiFi module reported: no known networks found power up + 00:01:45 [warn] WiFi module is idle power up + 00:01:47 [warn] Error: WiFi module reported: no known networks found power up + 00:01:47 [warn] WiFi module is idle power up + 00:01:49 [warn] Error: WiFi module reported: no known networks found power up + 00:01:49 [warn] WiFi module is idle power up + 00:01:51 [warn] Error: WiFi module reported: no known networks found power up + 00:01:51 [warn] WiFi module is idle power up + 00:01:54 [warn] Error: WiFi module reported: no known networks found power up + 00:01:54 [warn] WiFi module is idle power up + 00:01:56 [warn] Error: WiFi module reported: no known networks found power up + 00:01:56 [warn] WiFi module is idle power up + 00:01:58 [warn] Error: WiFi module reported: no known networks found power up + 00:01:58 [warn] WiFi module is idle power up + 00:02:00 [warn] Error: WiFi module reported: no known networks found power up + 00:02:00 [warn] WiFi module is idle power up + 00:02:02 [warn] Error: WiFi module reported: no known networks found power up + 00:02:02 [warn] WiFi module is idle power up + 00:02:05 [warn] Error: WiFi module reported: no known networks found power up + 00:02:05 [warn] WiFi module is idle power up + 00:02:07 [warn] Error: WiFi module reported: no known networks found power up + 00:02:07 [warn] WiFi module is idle power up + 00:02:09 [warn] Error: WiFi module reported: no known networks found power up + 00:02:09 [warn] WiFi module is idle power up + 00:02:11 [warn] Error: WiFi module reported: no known networks found power up + 00:02:11 [warn] WiFi module is idle power up + 00:02:15 [warn] WiFi module is connected to access point RV32-IOT2G, IP address 192.168.10.x power up + 00:03:04 [warn] Error: WiFi module reported: Lost connection, auto reconnecting power up + 00:03:04 [warn] Error: WiFi module reported: Auto reconnect succeeded power up + 00:00:03 [info] Event logging started at level debug power up + 00:00:03 [info] Running: Duet 3 Mini5plus WiFi: 3.5.0-rc.1+ (2023-11-01 10:29:03) power up + 00:00:03 [info] Event logging stopped power up + 00:00:03 [info] Event logging started at level debug power up + 00:00:03 [info] Running: Duet 3 Mini5plus WiFi: 3.5.0-rc.1+ (2023-11-01 10:29:03) power up + 00:00:03 [debug] Done! power up + 00:00:03 [debug] RepRapFirmware for Duet 3 Mini 5+ is up and running. power up + 00:00:04 [warn] WiFi module started power up + 00:00:06 [warn] Error: WiFi module reported: Failed to load credentials power up + 00:00:06 [warn] WiFi module is idle power up + 00:00:08 [warn] Error: WiFi module reported: Failed to load credentials power up + 00:00:08 [warn] WiFi module is idle power up + 00:00:10 [warn] Error: WiFi module reported: no known networks found power up + 00:00:10 [warn] WiFi module is idle power up + 00:00:13 [warn] Error: WiFi module reported: no known networks found power up + 00:00:13 [warn] WiFi module is idle power up + 00:00:15 [warn] Error: WiFi module reported: no known networks found power up + 00:00:15 [warn] WiFi module is idle power up + 00:00:17 [warn] Error: WiFi module reported: no known networks found power up + 00:00:17 [warn] WiFi module is idle power up + 00:00:19 [warn] Error: WiFi module reported: no known networks found power up + 00:00:19 [warn] WiFi module is idle power up + 00:00:21 [warn] Error: WiFi module reported: no known networks found power up + 00:00:21 [warn] WiFi module is idle power up + 00:00:24 [warn] Error: WiFi module reported: no known networks found power up + 00:00:24 [warn] WiFi module is idle power up + 00:00:26 [warn] Error: WiFi module reported: no known networks found power up + 00:00:26 [warn] WiFi module is idle power up + 00:00:28 [warn] Error: WiFi module reported: no known networks found power up + 00:00:28 [warn] WiFi module is idle power up + 00:00:30 [warn] Error: WiFi module reported: no known networks found power up + 00:00:30 [warn] WiFi module is idle power up + 00:00:32 [warn] Error: WiFi module reported: no known networks found power up + 00:00:32 [warn] WiFi module is idle power up + 00:00:35 [warn] Error: WiFi module reported: no known networks found power up + 00:00:35 [warn] WiFi module is idle power up + 00:00:37 [warn] Error: WiFi module reported: no known networks found power up + 00:00:37 [warn] WiFi module is idle power up + 00:00:39 [warn] Error: WiFi module reported: no known networks found power up + 00:00:39 [warn] WiFi module is idle power up + 00:00:41 [warn] Error: WiFi module reported: no known networks found power up + 00:00:41 [warn] WiFi module is idle power up + 00:00:43 [warn] Error: WiFi module reported: no known networks found power up + 00:00:43 [warn] WiFi module is idle power up + 00:00:46 [warn] Error: WiFi module reported: no known networks found power up + 00:00:46 [warn] WiFi module is idle power up + 00:00:48 [warn] Error: WiFi module reported: no known networks found power up + 00:00:48 [warn] WiFi module is idle power up + 00:00:50 [warn] Error: WiFi module reported: no known networks found power up + 00:00:50 [warn] WiFi module is idle power up + 00:00:52 [warn] Error: WiFi module reported: no known networks found power up + 00:00:52 [warn] WiFi module is idle power up + 00:00:55 [warn] Error: WiFi module reported: no known networks found power up + 00:00:55 [warn] WiFi module is idle power up + 00:00:57 [warn] Error: WiFi module reported: no known networks found power up + 00:00:57 [warn] WiFi module is idle power up + 00:00:59 [warn] Error: WiFi module reported: no known networks found power up + 00:00:59 [warn] WiFi module is idle power up + 00:01:01 [warn] Error: WiFi module reported: no known networks found power up + 00:01:01 [warn] WiFi module is idle power up + 00:01:03 [warn] Error: WiFi module reported: no known networks found power up + 00:01:03 [warn] WiFi module is idle power up + 00:01:06 [warn] Error: WiFi module reported: no known networks found power up + 00:01:06 [warn] WiFi module is idle power up + 00:01:08 [warn] Error: WiFi module reported: no known networks found power up + 00:01:08 [warn] WiFi module is idle power up + 00:01:10 [warn] Error: WiFi module reported: no known networks found power up + 00:01:10 [warn] WiFi module is idle power up + 00:01:12 [warn] Error: WiFi module reported: no known networks found power up + 00:01:12 [warn] WiFi module is idle power up + 00:01:15 [warn] Error: WiFi module reported: no known networks found power up + 00:01:15 [warn] WiFi module is idle power up + 00:01:17 [warn] Error: WiFi module reported: no known networks found power up + 00:01:17 [warn] WiFi module is idle power up + 00:01:19 [warn] Error: WiFi module reported: no known networks found power up + 00:01:19 [warn] WiFi module is idle power up + 00:01:21 [warn] Error: WiFi module reported: no known networks found power up + 00:01:21 [warn] WiFi module is idle power up + 00:01:24 [warn] Error: WiFi module reported: no known networks found power up + 00:01:24 [warn] WiFi module is idle power up + 00:01:26 [warn] Error: WiFi module reported: no known networks found power up + 00:01:26 [warn] WiFi module is idle power up + 00:01:28 [warn] Error: WiFi module reported: no known networks found power up + 00:01:28 [warn] WiFi module is idle power up + 00:01:30 [warn] Error: WiFi module reported: no known networks found power up + 00:01:30 [warn] WiFi module is idle power up + 00:01:32 [warn] Error: WiFi module reported: no known networks found power up + 00:01:32 [warn] WiFi module is idle power up + 00:01:35 [warn] Error: WiFi module reported: no known networks found power up + 00:01:35 [warn] WiFi module is idle power up + 00:01:37 [warn] Error: WiFi module reported: no known networks found power up + 00:01:37 [warn] WiFi module is idle power up + 00:01:39 [warn] Error: WiFi module reported: no known networks found power up + 00:01:39 [warn] WiFi module is idle power up + 00:01:41 [warn] Error: WiFi module reported: no known networks found power up + 00:01:41 [warn] WiFi module is idle power up + 00:01:44 [warn] Error: WiFi module reported: no known networks found power up + 00:01:44 [warn] WiFi module is idle power up + 00:01:46 [warn] Error: WiFi module reported: no known networks found power up + 00:01:46 [warn] WiFi module is idle power up + 00:01:48 [warn] Error: WiFi module reported: no known networks found power up + 00:01:48 [warn] WiFi module is idle power up + 00:01:50 [warn] Error: WiFi module reported: no known networks found power up + 00:01:50 [warn] WiFi module is idle power up + 00:01:53 [warn] Error: WiFi module reported: no known networks found power up + 00:01:53 [warn] WiFi module is idle power up + 00:01:55 [warn] Error: WiFi module reported: no known networks found power up + 00:01:55 [warn] WiFi module is idle power up + 00:01:57 [warn] Error: WiFi module reported: Failed to load credentials power up + 00:01:57 [warn] WiFi module is idle power up + 00:01:59 [warn] Error: WiFi module reported: no known networks found power up + 00:01:59 [warn] WiFi module is idle power up + 00:02:01 [warn] Error: WiFi module reported: no known networks found power up + 00:02:01 [warn] WiFi module is idle power up + 00:02:04 [warn] Error: WiFi module reported: no known networks found power up + 00:02:06 [warn] Error: WiFi module reported: no known networks found power up + 00:02:06 [warn] WiFi module is idle power up + 00:02:08 [warn] Error: WiFi module reported: no known networks found power up + 00:02:08 [warn] WiFi module is idle power up + 00:02:10 [warn] Error: WiFi module reported: no known networks found power up + 00:02:10 [warn] WiFi module is idle power up + 00:02:13 [warn] Error: WiFi module reported: no known networks found power up + 00:02:13 [warn] WiFi module is idle power up + 00:02:15 [warn] Error: WiFi module reported: Failed to load credentials power up + 00:02:15 [warn] WiFi module is idle power up + 00:02:18 [warn] WiFi module is connected to access point RV32-IOT2G, IP address 192.168.10.x power up + 00:02:48 [warn] Error: WiFi module reported: Lost connection, auto reconnecting power up + 00:02:49 [warn] Error: WiFi module reported: Auto reconnect succeeded power up + 69:32:47 [warn] HTTP client 192.168.10.xx login succeeded (session key 1481405628) 2023-11-10 15:27:24 [warn] Date and time set at power up + 69:32:47 Continued on the next reply
M122;
=== Diagnostics === RepRapFirmware for Duet 3 Mini 5+ version 3.5.0-rc.1+ (2023-11-01 10:29:03) running on Duet 3 Mini5plus WiFi (standalone mode) Board ID: XNHXF-HR6KL-K65J0-409N2-K9W1Z-RV2MZ Used output buffers: 22 of 40 (40 max) === RTOS === Static ram: 102812 Dynamic ram: 122036 of which 12 recycled Never used RAM 13700, free system stack 180 words Tasks: NETWORK(2,nWait,53.7%,213) HEAT(3,nWait,2.2%,327) Move(4,nWait,0.2%,344) CanReceiv(6,nWait,4.3%,772) CanSender(5,nWait,0.0%,336) CanClock(7,delaying,0.7%,341) TMC(4,nWait,61.6%,108) MAIN(1,running,111.9%,670) IDLE(0,ready,22.0%,29) AIN(4,delaying,71.9%,264), total 328.3% Owned mutexes: WiFi(NETWORK) === Platform === Last reset 123:52:45 ago, cause: power up Last software reset at 2023-11-06 16:08, reason: User, Gcodes spinning, available RAM 11824, slot 1 Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a Error status: 0x04 Aux0 errors 0,0,0 MCU revision 3, ADC conversions started 445965944, completed 445965943, timed out 0, errs 0 MCU temperature: min 24.4, current 36.2, max 36.6 Supply voltage: min 0.2, current 24.1, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes Heap OK, handles allocated/used 99/29, heap memory allocated/used/recyclable 2048/980/584, gc cycles 20101 Events: 0 queued, 0 completed Driver 0: standstill, SG min 0, read errors 0, write errors 0, ifcnt 13, reads 9948, writes 13, timeouts 0, DMA errors 0, CC errors 0 Driver 1: standstill, SG min 0, read errors 0, write errors 0, ifcnt 13, reads 9948, writes 13, timeouts 0, DMA errors 0, CC errors 0 Driver 2: standstill, SG min 0, read errors 0, write errors 0, ifcnt 13, reads 9947, writes 13, timeouts 0, DMA errors 0, CC errors 0 Driver 3: standstill, SG min 0, read errors 0, write errors 0, ifcnt 13, reads 9947, writes 13, timeouts 0, DMA errors 0, CC errors 0 Driver 4: standstill, SG min 0, read errors 0, write errors 0, ifcnt 13, reads 9948, writes 13, timeouts 0, DMA errors 0, CC errors 0 Driver 5: not present Driver 6: not present Date/time: 2023-11-12 21:47:22 Cache data hit count 4294967295 Slowest loop: 11.70ms; fastest: 0.13ms === Storage === Free file entries: 18 SD card 0 detected, interface speed: 22.5MBytes/sec SD card longest read time 7.0ms, write time 4.5ms, max retries 0 === Move === DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, height map offset 0.000, ebfmin 0.00, ebfmax 0.00 no step interrupt scheduled Moves shaped first try 0, on retry 0, too short 0, wrong shape 0, maybepossible 0 === DDARing 0 === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === DDARing 1 === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters 0 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0 Heater 1 is on, I-accum = 0.0 === GCodes === Movement locks held by null, null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon is doing "G4 S1" in state(s) 0 0, running macro Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 File2 is idle in state(s) 0 Queue2 is idle in state(s) 0 Q0 segments left 0, axes/extruders owned 0x0000803 Code queue 0 is empty Q1 segments left 0, axes/extruders owned 0x0000000 Code queue 1 is empty === Filament sensors === check 0 clear 0 Extruder 0 sensor: no filament === CAN === Messages queued 4013705, received 9142508, lost 0, errs 3539, boc 0 Longest wait 3ms for reply type 6053, peak Tx sync delay 11386, free buffers 26 (min 25), ts 2229830/2229826/0 Tx timeouts 0,0,3,0,0,0 last cancelled message type 30 dest 127 === Network === Slowest loop: 19.15ms; fastest: 0.00ms Responder states: MQTT(0) HTTP(2) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) HTTP sessions: 2 of 8 === WiFi === Interface state: active Module is connected to access point Failed messages: pending 0, notrdy 0, noresp 0 Firmware version 2.1beta4 MAC address c4:5b:be:ce:91:93 Module reset reason: Power up, Vcc 3.38, flash size 2097152, free heap 39508 WiFi IP address 192.168.10.x Signal strength -53dBm, channel 6, mode 802.11n, reconnections 1 Clock register 00002001 Socket states: 0 0 0 0 0 0 0 0 Should be noted that on this crash it didn't fail to connect to the toolboard, so it wasn't any heater faults etc.
@Exerqtor please remind me: did this issue also occur when using firmware 3.4.x, or is it specific to 3.5.x?
I've created https://github.com/Duet3D/RepRapFirmware/issues/935 t track and summarise this, but please continue to post M122 reports in this thread.
@Exerqtor please install the firmware at https://www.dropbox.com/scl/fo/nta4k70rxl6n0bsv8q4q0/h?rlkey=1oq6j3jrvoxa6uaofyn9re3nn&dl=0 and post the M122 report when it next crashes. I have added some extra debug in the area where I think it is crashing.
IF it happened in 3.4.5 it must have been so Intermittent that i didn't catch it happening. If we put it that way.
Okok i will do it later today
The printer has been sitting idle since i updated to the "special" firmware you compiled, and it's been running for about 24hr with one instance of DWC open but the PC not being used (used stood there ).
Now i've been sitting on the PC working for 10min, with the printer idle and in that time the printer has crashed. This time again it's not connecting to the 1LC after the crash and it's throwing a heater fault & 2000C.
debuglog:
2023-11-15 20:35:24 [warn] HTTP client 192.168.10.xx disconnected 2023-11-15 20:35:27 [warn] HTTP client 192.168.10.xx login succeeded (session key 55059692) 2023-11-15 20:35:31 [warn] HTTP client 192.168.10.xx disconnected 2023-11-15 20:35:36 [warn] HTTP client 192.168.10.xx login succeeded (session key 1424224561) power up + 00:00:03 [info] Event logging started at level debug power up + 00:00:03 [info] Running: Duet 3 Mini5plus WiFi: 3.5.0-rc.1+ (2023-11-14 10:45:05) power up + 00:00:03 [info] Event logging stopped power up + 00:00:03 [info] Event logging started at level debug power up + 00:00:03 [info] Running: Duet 3 Mini5plus WiFi: 3.5.0-rc.1+ (2023-11-14 10:45:05) power up + 00:00:03 [debug] Done! power up + 00:00:03 [debug] RepRapFirmware for Duet 3 Mini 5+ is up and running. power up + 00:00:04 [warn] Error: Heater 1 fault: failed to read sensor: notReady power up + 00:00:04 [info] M291: - Event notification - Heater 1 fault: failed to read sensor: notReady power up + 00:00:04 [debug] - Event notification - power up + 00:00:04 [debug] Heater 1 fault: failed to read sensor: notReady power up + 00:00:04 [warn] WiFi module started power up + 00:00:08 [warn] WiFi module is connected to access point RV32-IOT2G, IP address 192.168.10.x power up + 00:00:08 [warn] HTTP client 192.168.10.xx login succeeded (session key 740842430) 2023-11-15 20:37:48 [warn] Date and time set at power up + 00:00:08 M122:
=== Diagnostics === RepRapFirmware for Duet 3 Mini 5+ version 3.5.0-rc.1+ (2023-11-14 10:45:05) running on Duet 3 Mini5plus WiFi (standalone mode) Board ID: XNHXF-HR6KL-K65J0-409N2-K9W1Z-RV2MZ Used output buffers: 1 of 40 (30 max) === RTOS === Static ram: 102812 Dynamic ram: 123820 of which 0 recycled Never used RAM 11928, free system stack 188 words Tasks: NETWORK(1,ready,17.6%,209) HEAT(3,nWait,0.0%,352) Move(4,nWait,0.0%,358) CanReceiv(6,nWait,0.0%,797) CanSender(5,nWait,0.0%,336) CanClock(7,delaying,0.0%,350) TMC(4,nWait,0.7%,108) MAIN(1,running,80.6%,670) IDLE(0,ready,0.3%,29) AIN(4,delaying,0.8%,264), total 100.0% Owned mutexes: === Platform === Last reset 00:15:57 ago, cause: software Last software reset at 2023-11-15 20:37, reason: AssertionFailed, Gcodes spinning, available RAM 6020, slot 0 Software reset code 0x4123 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x20011fbc Task NETW Freestk 495 ok Stack: 000008fe 000af1c8 0002dd83 2002beb4 2002be01 000001a8 2002c0e0 20030b90 2002c0f8 2001e868 a5a5a5a5 a5a5a5a5 00000000 00000000 00000000 00000000 20030b9c 00000800 200358c0 2002c0e0 20018658 2002bf7d 20018658 2001e868 00030023 00000000 00000000 Error status: 0x00 Aux0 errors 0,0,0 MCU revision 3, ADC conversions started 958328, completed 958328, timed out 0, errs 0 MCU temperature: min 35.1, current 35.5, max 38.2 Supply voltage: min 22.7, current 24.1, max 26.3, under voltage events: 0, over voltage events: 0, power good: yes Heap OK, handles allocated/used 99/33, heap memory allocated/used/recyclable 2048/1932/1496, gc cycles 44 Events: 1 queued, 1 completed Driver 0: standstill, SG min 0, read errors 0, write errors 1, ifcnt 118, reads 50392, writes 13, timeouts 0, DMA errors 0, CC errors 0 Driver 1: standstill, SG min 2, read errors 0, write errors 1, ifcnt 118, reads 50392, writes 13, timeouts 0, DMA errors 0, CC errors 0 Driver 2: standstill, SG min 0, read errors 0, write errors 1, ifcnt 81, reads 50391, writes 13, timeouts 0, DMA errors 0, CC errors 0 Driver 3: standstill, SG min 0, read errors 0, write errors 1, ifcnt 79, reads 50391, writes 13, timeouts 0, DMA errors 0, CC errors 0 Driver 4: standstill, SG min 0, read errors 0, write errors 1, ifcnt 80, reads 50392, writes 13, timeouts 0, DMA errors 0, CC errors 0 Driver 5: not present Driver 6: not present Date/time: 2023-11-15 20:53:37 Cache data hit count 1623656227 Slowest loop: 12.73ms; fastest: 0.13ms === Storage === Free file entries: 18 SD card 0 detected, interface speed: 22.5MBytes/sec SD card longest read time 6.5ms, write time 4.6ms, max retries 0 === Move === DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, height map offset 0.000, ebfmin 0.00, ebfmax 0.00 no step interrupt scheduled Moves shaped first try 0, on retry 0, too short 0, wrong shape 0, maybepossible 0 === DDARing 0 === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === DDARing 1 === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters 0 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0 === GCodes === Movement locks held by null, null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon is doing "G4 S1" in state(s) 0 0, running macro Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 File2 is idle in state(s) 0 Queue2 is idle in state(s) 0 Q0 segments left 0, axes/extruders owned 0x0000803 Code queue 0 is empty Q1 segments left 0, axes/extruders owned 0x0000000 Code queue 1 is empty === Filament sensors === in 0 notIn 0 Extruder 0 sensor: no filament === CAN === Messages queued 8631, received 19678, lost 0, errs 1, boc 0 Longest wait 2ms for reply type 6053, peak Tx sync delay 299, free buffers 26 (min 25), ts 4790/4789/0 Tx timeouts 0,0,0,0,0,0 === Network === Slowest loop: 9.16ms; fastest: 0.00ms Responder states: MQTT(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) HTTP sessions: 1 of 8 === WiFi === Interface state: active Module is connected to access point Failed messages: pending 0, notrdy 0, noresp 0 Firmware version 2.1beta4 MAC address c4:5b:be:ce:91:93 Module reset reason: Power up, Vcc 3.38, flash size 2097152, free heap 43136 WiFi IP address 192.168.10.x Signal strength -52dBm, channel 6, mode 802.11n, reconnections 0 Clock register 00002001 Socket states: 0 0 0 0 0 0 0 0 -
@Exerqtor thanks, that's just what I needed to confirm the area of the code that's going wrong.
To help pin it down further, please install the new version of firmware from https://www.dropbox.com/scl/fo/nta4k70rxl6n0bsv8q4q0/h?rlkey=1oq6j3jrvoxa6uaofyn9re3nn&dl=0 and send a M122 report when it resets again. I don't need a second M122 after a manual reboot.
@dc42 copy, just installed it.
I will post a new M122 report ASAP
Here we go:
debuglog:
2023-11-16 03:59:44 [warn] HTTP client 192.168.10.xx login succeeded (session key 1771356456) power up + 00:00:03 [info] Event logging started at level debug power up + 00:00:03 [info] Running: Duet 3 Mini5plus WiFi: 3.5.0-rc.1+ (2023-11-15 20:11:19) power up + 00:00:03 [info] Event logging stopped power up + 00:00:03 [info] Event logging started at level debug power up + 00:00:03 [info] Running: Duet 3 Mini5plus WiFi: 3.5.0-rc.1+ (2023-11-15 20:11:19) power up + 00:00:03 [debug] Done! power up + 00:00:03 [debug] RepRapFirmware for Duet 3 Mini 5+ is up and running. power up + 00:00:04 [warn] WiFi module started power up + 00:00:04 [warn] Error: Heater 1 fault: failed to read sensor: notReady power up + 00:00:04 [info] M291: - Event notification - Heater 1 fault: failed to read sensor: notReady power up + 00:00:04 [debug] - Event notification - power up + 00:00:04 [debug] Heater 1 fault: failed to read sensor: notReady power up + 00:00:06 [warn] Error: WiFi module reported: Failed to load credentials power up + 00:00:06 [warn] WiFi module is idle power up + 00:00:08 [warn] Error: WiFi module reported: Failed to load credentials power up + 00:00:08 [warn] WiFi module is idle power up + 00:00:11 [warn] Error: WiFi module reported: Failed to load credentials power up + 00:00:11 [warn] WiFi module is idle power up + 00:00:13 [warn] Error: WiFi module reported: Failed to load credentials power up + 00:00:13 [warn] WiFi module is idle power up + 00:00:15 [warn] Error: WiFi module reported: Failed to load credentials power up + 00:00:15 [warn] WiFi module is idle power up + 00:00:18 [warn] Error: WiFi module reported: Failed to load credentials power up + 00:00:18 [warn] WiFi module is idle power up + 00:00:20 [warn] Error: WiFi module reported: Failed to load credentials power up + 00:00:20 [warn] WiFi module is idle power up + 00:00:22 [warn] Error: WiFi module reported: Failed to load credentials power up + 00:00:22 [warn] WiFi module is idle power up + 00:00:25 [warn] Error: WiFi module reported: Failed to load credentials power up + 00:00:25 [warn] WiFi module is idle power up + 00:00:27 [warn] Error: WiFi module reported: Failed to load credentials power up + 00:00:27 [warn] WiFi module is idle power up + 00:00:30 [warn] Error: WiFi module reported: Failed to load credentials power up + 00:00:30 [warn] WiFi module is idle power up + 00:00:32 [warn] Error: WiFi module reported: Failed to load credentials power up + 00:00:32 [warn] WiFi module is idle power up + 00:00:34 [warn] Error: WiFi module reported: Failed to load credentials power up + 00:00:34 [warn] WiFi module is idle power up + 00:00:37 [warn] Error: WiFi module reported: Failed to load credentials power up + 00:00:37 [warn] WiFi module is idle power up + 00:00:41 [warn] WiFi module is connected to access point RV32-IOT2G, IP address 192.168.10.x power up + 00:00:42 [warn] HTTP client 192.168.10.xx login succeeded (session key 1408720838) 2023-11-16 09:15:05 [warn] Date and time set at power up + 00:00:42 M122:
=== Diagnostics === RepRapFirmware for Duet 3 Mini 5+ version 3.5.0-rc.1+ (2023-11-15 20:11:19) running on Duet 3 Mini5plus WiFi (standalone mode) Board ID: XNHXF-HR6KL-K65J0-409N2-K9W1Z-RV2MZ Used output buffers: 1 of 40 (29 max) === RTOS === Static ram: 102844 Dynamic ram: 123820 of which 0 recycled Never used RAM 11896, free system stack 186 words Tasks: NETWORK(1,ready,3212.5%,232) HEAT(3,nWait,4.5%,327) Move(4,nWait,0.5%,352) CanReceiv(6,nWait,9.0%,774) CanSender(5,nWait,0.0%,336) CanClock(7,delaying,1.4%,350) TMC(4,nWait,129.2%,108) MAIN(1,running,1199.1%,670) IDLE(0,ready,45.8%,29) AIN(4,delaying,153.3%,264), total 4755.3% Owned mutexes: WiFi(NETWORK) === Platform === Last reset 06:23:49 ago, cause: software Last software reset at 2023-11-16 09:14, reason: AssertionFailed, Gcodes spinning, available RAM 10964, slot 2 Software reset code 0x4123 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00487000 BFAR 0xe000ed38 SP 0x20011fbc Task NETW Freestk 495 ok Stack: 00000904 000af288 0002ddbf 2002bed4 2002be01 000001a8 2002c100 20031c40 2002c118 2001e888 00000000 a5a5a5a5 00000000 00000000 00000000 00000000 20031c4c 00000800 20035940 2002c100 20018668 2002bf9d 20018668 2001e888 00030037 00000000 00000000 Error status: 0x00 Aux0 errors 0,0,0 MCU revision 3, ADC conversions started 23029641, completed 23029641, timed out 0, errs 0 MCU temperature: min 34.7, current 35.1, max 37.8 Supply voltage: min 23.0, current 24.1, max 26.0, under voltage events: 0, over voltage events: 0, power good: yes Heap OK, handles allocated/used 99/33, heap memory allocated/used/recyclable 2048/716/280, gc cycles 1071 Events: 1 queued, 1 completed Driver 0: standstill, SG min 16, read errors 0, write errors 1, ifcnt 170, reads 32406, writes 13, timeouts 0, DMA errors 0, CC errors 0 Driver 1: standstill, SG min 222, read errors 0, write errors 1, ifcnt 170, reads 32406, writes 13, timeouts 0, DMA errors 0, CC errors 0 Driver 2: standstill, SG min 2, read errors 0, write errors 1, ifcnt 127, reads 32406, writes 13, timeouts 0, DMA errors 0, CC errors 0 Driver 3: standstill, SG min 2, read errors 0, write errors 1, ifcnt 125, reads 32406, writes 13, timeouts 0, DMA errors 0, CC errors 0 Driver 4: standstill, SG min 2, read errors 0, write errors 1, ifcnt 126, reads 32406, writes 13, timeouts 0, DMA errors 0, CC errors 0 Driver 5: not present Driver 6: not present Date/time: 2023-11-16 15:38:13 Cache data hit count 4294967295 Slowest loop: 12.92ms; fastest: 0.14ms === Storage === Free file entries: 18 SD card 0 detected, interface speed: 22.5MBytes/sec SD card longest read time 7.2ms, write time 4.1ms, max retries 0 === Move === DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, height map offset 0.000, ebfmin 0.00, ebfmax 0.00 no step interrupt scheduled Moves shaped first try 0, on retry 0, too short 0, wrong shape 0, maybepossible 0 === DDARing 0 === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === DDARing 1 === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters 0 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0 === GCodes === Movement locks held by null, null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon is doing "G4 S1" in state(s) 0 0, running macro Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 File2 is idle in state(s) 0 Queue2 is idle in state(s) 0 Q0 segments left 0, axes/extruders owned 0x0000803 Code queue 0 is empty Q1 segments left 0, axes/extruders owned 0x0000000 Code queue 1 is empty === Filament sensors === in 0 notIn 0 Extruder 0 sensor: no filament === CAN === Messages queued 207276, received 472154, lost 0, errs 1, boc 0 Longest wait 2ms for reply type 6057, peak Tx sync delay 275, free buffers 26 (min 25), ts 115148/115147/0 Tx timeouts 0,0,0,0,0,0 === Network === Slowest loop: 5.98ms; fastest: 0.00ms Responder states: MQTT(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) HTTP sessions: 1 of 8 === WiFi === Interface state: active Module is connected to access point Failed messages: pending 0, notrdy 0, noresp 0 Firmware version 2.1beta4 MAC address c4:5b:be:ce:91:93 Module reset reason: Power up, Vcc 3.38, flash size 2097152, free heap 42960 WiFi IP address 192.168.10.x Signal strength -52dBm, channel 6, mode 802.11n, reconnections 0 Clock register 00002001 Socket states: 0 0 0 0 0 0 0 0 -
@Exerqtor thanks, that's just what I needed to pinpoint what's going on. A DMA transfer is overwriting the return address on the stack. Unless I can spot the reason, I'll need to add some more debug to the firmware and ask you to run in again to find out why.
@dc42 Thats great news! Starting to get the feeling it might be some light breaking through the clouds now
Just put in what ever you might need and i'll give it a go, can't really use the printer in this state anyways lol.
@Exerqtor thanks, I've had to work on other things today but I'll come back to this very soon. I'm still puzzled that it's not reported more widely.
@dc42 No problem! Yeah it's struck me as odd too
@dc42 New crash:
debug:2023-11-17 21:01:32 [warn] HTTP client 192.168.10.xx login succeeded (session key 3428338341) power up + 00:00:03 [info] Event logging started at level debug power up + 00:00:03 [info] Running: Duet 3 Mini5plus WiFi: 3.5.0-rc.1+ (2023-11-15 20:11:19) power up + 00:00:03 [info] Event logging stopped power up + 00:00:03 [info] Event logging started at level debug power up + 00:00:03 [info] Running: Duet 3 Mini5plus WiFi: 3.5.0-rc.1+ (2023-11-15 20:11:19) power up + 00:00:03 [debug] Done! power up + 00:00:03 [debug] RepRapFirmware for Duet 3 Mini 5+ is up and running. power up + 00:00:04 [warn] Error: Heater 1 fault: failed to read sensor: notReady power up + 00:00:04 [info] M291: - Event notification - Heater 1 fault: failed to read sensor: notReady power up + 00:00:04 [debug] - Event notification - power up + 00:00:04 [debug] Heater 1 fault: failed to read sensor: notReady power up + 00:00:04 [warn] WiFi module started power up + 00:00:06 [warn] Error: WiFi module reported: Failed to load credentials power up + 00:00:06 [warn] WiFi module is idle power up + 00:00:08 [warn] Error: WiFi module reported: Failed to load credentials power up + 00:00:08 [warn] WiFi module is idle power up + 00:00:11 [warn] Error: WiFi module reported: Failed to load credentials power up + 00:00:11 [warn] WiFi module is idle power up + 00:00:13 [warn] Error: WiFi module reported: Failed to load credentials power up + 00:00:13 [warn] WiFi module is idle power up + 00:00:16 [warn] Error: WiFi module reported: Failed to load credentials power up + 00:00:16 [warn] WiFi module is idle power up + 00:00:18 [warn] Error: WiFi module reported: Failed to load credentials power up + 00:00:18 [warn] WiFi module is idle power up + 00:00:20 [warn] Error: WiFi module reported: Failed to load credentials power up + 00:00:20 [warn] WiFi module is idle power up + 00:00:23 [warn] Error: WiFi module reported: Failed to load credentials power up + 00:00:23 [warn] WiFi module is idle power up + 00:00:25 [warn] Error: WiFi module reported: Failed to load credentials power up + 00:00:25 [warn] WiFi module is idle power up + 00:00:27 [warn] Error: WiFi module reported: Failed to load credentials power up + 00:00:27 [warn] WiFi module is idle power up + 00:00:30 [warn] Error: WiFi module reported: Failed to load credentials power up + 00:00:30 [warn] WiFi module is idle power up + 00:00:32 [warn] Error: WiFi module reported: Failed to load credentials power up + 00:00:32 [warn] WiFi module is idle power up + 00:00:36 [warn] WiFi module is connected to access point RV32-IOT2G, IP address 192.168.10.x power up + 00:00:36 [warn] HTTP client 192.168.10.xx login succeeded (session key 2751057796) 2023-11-18 07:01:07 [warn] Date and time set at power up + 00:00:36 M122:
=== Diagnostics === RepRapFirmware for Duet 3 Mini 5+ version 3.5.0-rc.1+ (2023-11-15 20:11:19) running on Duet 3 Mini5plus WiFi (standalone mode) Board ID: XNHXF-HR6KL-K65J0-409N2-K9W1Z-RV2MZ Used output buffers: 1 of 40 (34 max) === RTOS === Static ram: 102844 Dynamic ram: 123844 of which 0 recycled Never used RAM 11872, free system stack 186 words Tasks: NETWORK(1,ready,16.7%,219) HEAT(3,nWait,0.0%,352) Move(4,nWait,0.0%,358) CanReceiv(6,nWait,0.0%,797) CanSender(5,nWait,0.0%,336) CanClock(7,delaying,0.0%,350) TMC(4,nWait,0.7%,108) MAIN(1,running,81.1%,670) IDLE(0,ready,0.6%,29) AIN(4,delaying,0.8%,264), total 100.0% Owned mutexes: === Platform === Last reset 00:22:02 ago, cause: software Last software reset at 2023-11-18 07:00, reason: AssertionFailed, Gcodes spinning, available RAM 11268, slot 1 Software reset code 0x4123 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x20011fbc Task NETW Freestk 495 ok Stack: 00000904 000af288 0002ddbf 2002bed4 2002be01 000001a8 2002c100 200303f8 2002c118 2001e888 00000000 a5a5a5a5 00000000 00000000 00000000 00000000 20030404 00000800 20035940 2002c100 20018668 2002bf9d 20018668 2001e888 00030037 00000000 00000000 Error status: 0x00 Aux0 errors 0,0,0 MCU revision 3, ADC conversions started 1322550, completed 1322550, timed out 0, errs 0 MCU temperature: min 34.8, current 35.1, max 35.3 Supply voltage: min 24.0, current 24.1, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes Heap OK, handles allocated/used 99/33, heap memory allocated/used/recyclable 2048/1856/1420, gc cycles 61 Events: 1 queued, 1 completed Driver 0: standstill, SG min 16, read errors 0, write errors 0, ifcnt 207, reads 965, writes 0, timeouts 0, DMA errors 0, CC errors 0 Driver 1: standstill, SG min 240, read errors 0, write errors 0, ifcnt 207, reads 965, writes 0, timeouts 0, DMA errors 0, CC errors 0 Driver 2: standstill, SG min 0, read errors 0, write errors 0, ifcnt 160, reads 965, writes 0, timeouts 0, DMA errors 0, CC errors 0 Driver 3: standstill, SG min 0, read errors 0, write errors 0, ifcnt 157, reads 966, writes 0, timeouts 0, DMA errors 0, CC errors 0 Driver 4: standstill, SG min 0, read errors 0, write errors 0, ifcnt 158, reads 965, writes 0, timeouts 0, DMA errors 0, CC errors 0 Driver 5: not present Driver 6: not present Date/time: 2023-11-18 07:22:32 Cache data hit count 2212461605 Slowest loop: 10.21ms; fastest: 0.13ms === Storage === Free file entries: 18 SD card 0 detected, interface speed: 22.5MBytes/sec SD card longest read time 3.6ms, write time 4.2ms, max retries 0 === Move === DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, height map offset 0.000, ebfmin 0.00, ebfmax 0.00 no step interrupt scheduled Moves shaped first try 0, on retry 0, too short 0, wrong shape 0, maybepossible 0 === DDARing 0 === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === DDARing 1 === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters 0 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0 === GCodes === Movement locks held by null, null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon is doing "G4 S1" in state(s) 0 0, running macro Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 File2 is idle in state(s) 0 Queue2 is idle in state(s) 0 Q0 segments left 0, axes/extruders owned 0x0000803 Code queue 0 is empty Q1 segments left 0, axes/extruders owned 0x0000000 Code queue 1 is empty === Filament sensors === in 0 notIn 0 Extruder 0 sensor: no filament === CAN === Messages queued 165, received 379, lost 0, errs 0, boc 0 Longest wait 0ms for reply type 0, peak Tx sync delay 3, free buffers 26 (min 26), ts 92/92/0 Tx timeouts 0,0,0,0,0,0 === Network === Slowest loop: 20.33ms; fastest: 0.06ms Responder states: MQTT(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) HTTP sessions: 1 of 8 === WiFi === Interface state: active Module is connected to access point Failed messages: pending 0, notrdy 0, noresp 0 Firmware version 2.1beta4 MAC address c4:5b:be:ce:91:93 Module reset reason: Power up, Vcc 3.38, flash size 2097152, free heap 43120 WiFi IP address 192.168.10.x Signal strength -53dBm, channel 6, mode 802.11n, reconnections 0 Clock register 00002001 Socket states: 0 0 0 0 0 0 0 0
But just out of curiosity, as I've understood it it's some DMA transfer between the CPU and WiFi-module that's causing the crashes.
Does this mean that if I've got a print I need/want to do I could just:
- Upload print job.
- Turn off the WiFi module with
M552 S-1
. - Start the print from PanelDue, and let it complete.
- Once the job is done, turn on networking again from PanelDue with
M552 S1
Or will the DMA transfers still happen or try to happen, potentially causing a crash even if the WiFi-module is disabled?
@Exerqtor yes I think the crash will only occur when the WiFi module is enabled, because it's the code that talks to the WiFi module that is crashing.
@dc42 Ok, good to know if I want to run a larger more time consuming print.
