    Reboots/crashes - RRF ≤3.5.0-rc1
    Beta Firmware
    13
    137
    10.1k
    • Exerqtorundefined
      Exerqtor @dc42
      @dc42 copy, just installed it.
      I will post a new M122 report ASAP 👍
      Exerqtorundefined 1 Reply Last reply Reply Quote 0
      • Exerqtorundefined
        Exerqtor @Exerqtor
        Here we go:
        debuglog:
        2023-11-16 03:59:44 [warn] HTTP client 192.168.10.xx login succeeded (session key 1771356456)
        power up + 00:00:03 [info] Event logging started at level debug
        power up + 00:00:03 [info] Running: Duet 3 Mini5plus WiFi: 3.5.0-rc.1+ (2023-11-15 20:11:19)
        power up + 00:00:03 [info] Event logging stopped
        power up + 00:00:03 [debug] Done!
        power up + 00:00:03 [debug] RepRapFirmware for Duet 3 Mini 5+ is up and running.
        power up + 00:00:04 [warn] WiFi module started
        power up + 00:00:04 [warn] Error: Heater 1 fault: failed to read sensor: notReady
        power up + 00:00:04 [info] M291: - Event notification - Heater 1 fault: failed to read sensor: notReady
        power up + 00:00:04 [debug] - Event notification -
        power up + 00:00:04 [debug] Heater 1 fault: failed to read sensor: notReady
        power up + 00:00:06 [warn] Error: WiFi module reported: Failed to load credentials
        power up + 00:00:06 [warn] WiFi module is idle
        power up + 00:00:08 [warn] Error: WiFi module reported: Failed to load credentials
        power up + 00:00:08 [warn] WiFi module is idle
        power up + 00:00:11 [warn] Error: WiFi module reported: Failed to load credentials
        power up + 00:00:11 [warn] WiFi module is idle
        power up + 00:00:13 [warn] Error: WiFi module reported: Failed to load credentials
        power up + 00:00:13 [warn] WiFi module is idle
        power up + 00:00:15 [warn] Error: WiFi module reported: Failed to load credentials
        power up + 00:00:15 [warn] WiFi module is idle
        power up + 00:00:18 [warn] Error: WiFi module reported: Failed to load credentials
        power up + 00:00:18 [warn] WiFi module is idle
        power up + 00:00:20 [warn] Error: WiFi module reported: Failed to load credentials
        power up + 00:00:20 [warn] WiFi module is idle
        power up + 00:00:22 [warn] Error: WiFi module reported: Failed to load credentials
        power up + 00:00:22 [warn] WiFi module is idle
        power up + 00:00:25 [warn] Error: WiFi module reported: Failed to load credentials
        power up + 00:00:25 [warn] WiFi module is idle
        power up + 00:00:27 [warn] Error: WiFi module reported: Failed to load credentials
        power up + 00:00:27 [warn] WiFi module is idle
        power up + 00:00:30 [warn] Error: WiFi module reported: Failed to load credentials
        power up + 00:00:30 [warn] WiFi module is idle
        power up + 00:00:32 [warn] Error: WiFi module reported: Failed to load credentials
        power up + 00:00:32 [warn] WiFi module is idle
        power up + 00:00:34 [warn] Error: WiFi module reported: Failed to load credentials
        power up + 00:00:34 [warn] WiFi module is idle
        power up + 00:00:37 [warn] Error: WiFi module reported: Failed to load credentials
        power up + 00:00:37 [warn] WiFi module is idle
        power up + 00:00:41 [warn] WiFi module is connected to access point RV32-IOT2G, IP address 192.168.10.x
        power up + 00:00:42 [warn] HTTP client 192.168.10.xx login succeeded (session key 1408720838)
        2023-11-16 09:15:05 [warn] Date and time set at power up + 00:00:42
        M122:
        RepRapFirmware for Duet 3 Mini 5+ version 3.5.0-rc.1+ (2023-11-15 20:11:19) running on Duet 3 Mini5plus WiFi (standalone mode)
        Board ID: XNHXF-HR6KL-K65J0-409N2-K9W1Z-RV2MZ
        Used output buffers: 1 of 40 (29 max)
        Static ram: 102844
        Dynamic ram: 123820 of which 0 recycled
        Never used RAM 11896, free system stack 186 words
        Tasks: NETWORK(1,ready,3212.5%,232) HEAT(3,nWait,4.5%,327) Move(4,nWait,0.5%,352) CanReceiv(6,nWait,9.0%,774) CanSender(5,nWait,0.0%,336) CanClock(7,delaying,1.4%,350) TMC(4,nWait,129.2%,108) MAIN(1,running,1199.1%,670) IDLE(0,ready,45.8%,29) AIN(4,delaying,153.3%,264), total 4755.3%
        Owned mutexes: WiFi(NETWORK)
        Last reset 06:23:49 ago, cause: software
        Last software reset at 2023-11-16 09:14, reason: AssertionFailed, Gcodes spinning, available RAM 10964, slot 2
        Software reset code 0x4123 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00487000 BFAR 0xe000ed38 SP 0x20011fbc Task NETW Freestk 495 ok
        Stack: 00000904 000af288 0002ddbf 2002bed4 2002be01 000001a8 2002c100 20031c40 2002c118 2001e888 00000000 a5a5a5a5 00000000 00000000 00000000 00000000 20031c4c 00000800 20035940 2002c100 20018668 2002bf9d 20018668 2001e888 00030037 00000000 00000000
        Error status: 0x00
        Aux0 errors 0,0,0
        MCU revision 3, ADC conversions started 23029641, completed 23029641, timed out 0, errs 0
        MCU temperature: min 34.7, current 35.1, max 37.8
        Supply voltage: min 23.0, current 24.1, max 26.0, under voltage events: 0, over voltage events: 0, power good: yes
        Heap OK, handles allocated/used 99/33, heap memory allocated/used/recyclable 2048/716/280, gc cycles 1071
        Events: 1 queued, 1 completed
        Driver 0: standstill, SG min 16, read errors 0, write errors 1, ifcnt 170, reads 32406, writes 13, timeouts 0, DMA errors 0, CC errors 0
        Driver 1: standstill, SG min 222, read errors 0, write errors 1, ifcnt 170, reads 32406, writes 13, timeouts 0, DMA errors 0, CC errors 0
        Driver 2: standstill, SG min 2, read errors 0, write errors 1, ifcnt 127, reads 32406, writes 13, timeouts 0, DMA errors 0, CC errors 0
        Driver 3: standstill, SG min 2, read errors 0, write errors 1, ifcnt 125, reads 32406, writes 13, timeouts 0, DMA errors 0, CC errors 0
        Driver 4: standstill, SG min 2, read errors 0, write errors 1, ifcnt 126, reads 32406, writes 13, timeouts 0, DMA errors 0, CC errors 0
        Driver 5: not present
        Driver 6: not present
        Date/time: 2023-11-16 15:38:13
        Slowest loop: 12.92ms; fastest: 0.14ms
        === Storage ===
        Free file entries: 18
        SD card longest read time 7.2ms, write time 4.1ms, max retries 0
        DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, height map offset 0.000, ebfmin 0.00, ebfmax 0.00
        no step interrupt scheduled
        Moves shaped first try 0, on retry 0, too short 0, wrong shape 0, maybepossible 0
        === DDARing 0 ===
        === DDARing 1 ===
        HTTP is idle in state(s) 0
        Telnet is idle in state(s) 0
        File is idle in state(s) 0
        USB is idle in state(s) 0
        Aux is idle in state(s) 0
        Trigger is idle in state(s) 0
        Queue is idle in state(s) 0
        LCD is idle in state(s) 0
        SBC is idle in state(s) 0
        Daemon is doing "G4 S1" in state(s) 0 0, running macro
        Aux2 is idle in state(s) 0
        File2 is idle in state(s) 0
        Queue2 is idle in state(s) 0
        Q0 segments left 0, axes/extruders owned 0x0000803
        Code queue 0 is empty
        Code queue 1 is empty
        === Filament sensors ===
        in 0 notIn 0
        Extruder 0 sensor: no filament
        === CAN ===
        Messages queued 207276, received 472154, lost 0, errs 1, boc 0
        Longest wait 2ms for reply type 6057, peak Tx sync delay 275, free buffers 26 (min 25), ts 115148/115147/0
        Tx timeouts 0,0,0,0,0,0
        === Network ===
        Slowest loop: 5.98ms; fastest: 0.00ms
        Responder states: MQTT(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
        HTTP sessions: 1 of 8
        === WiFi ===
        Interface state: active
        Module is connected to access point
        Failed messages: pending 0, notrdy 0, noresp 0
        Firmware version 2.1beta4
        MAC address c4:5b:be:ce:91:93
        Module reset reason: Power up, Vcc 3.38, flash size 2097152, free heap 42960
        WiFi IP address 192.168.10.x
        Signal strength -52dBm, channel 6, mode 802.11n, reconnections 0
        Clock register 00002001
          dc42 administrators @Exerqtor
          @Exerqtor thanks, that's just what I needed to pinpoint what's going on. A DMA transfer is overwriting the return address on the stack. Unless I can spot the reason, I'll need to add some more debug to the firmware and ask you to run in again to find out why.
          • Exerqtorundefined
            Exerqtor @dc42
            @dc42 Thats great news! Starting to get the feeling it might be some light breaking through the clouds now 🤣
            Just put in what ever you might need and i'll give it a go, can't really use the printer in this state anyways lol.
              @Exerqtor thanks, I've had to work on other things today but I'll come back to this very soon. I'm still puzzled that it's not reported more widely.
              Exerqtorundefined 2 Replies Last reply Reply Quote 0
              • Exerqtorundefined
                Exerqtor @dc42
                @dc42 No problem! Yeah it's struck me as odd too 🤷‍♂️
                • Exerqtorundefined
                  Exerqtor @dc42
                  @dc42 New crash:
                  debug:
                  2023-11-17 21:01:32 [warn] HTTP client 192.168.10.xx login succeeded (session key 3428338341)
                  power up + 00:00:16 [warn] Error: WiFi module reported: Failed to load credentials
                  power up + 00:00:16 [warn] WiFi module is idle
                  power up + 00:00:23 [warn] Error: WiFi module reported: Failed to load credentials
                  power up + 00:00:23 [warn] WiFi module is idle
                  power up + 00:00:36 [warn] WiFi module is connected to access point RV32-IOT2G, IP address 192.168.10.x
                  power up + 00:00:36 [warn] HTTP client 192.168.10.xx login succeeded (session key 2751057796)
                  2023-11-18 07:01:07 [warn] Date and time set at power up + 00:00:36
                  M122:
                  Used output buffers: 1 of 40 (34 max)
                  Static ram: 102844
                  Dynamic ram: 123844 of which 0 recycled
                  Never used RAM 11872, free system stack 186 words
                  Tasks: NETWORK(1,ready,16.7%,219) HEAT(3,nWait,0.0%,352) Move(4,nWait,0.0%,358) CanReceiv(6,nWait,0.0%,797) CanSender(5,nWait,0.0%,336) CanClock(7,delaying,0.0%,350) TMC(4,nWait,0.7%,108) MAIN(1,running,81.1%,670) IDLE(0,ready,0.6%,29) AIN(4,delaying,0.8%,264), total 100.0%
                  Owned mutexes:
                  Last reset 00:22:02 ago, cause: software
                  Last software reset at 2023-11-18 07:00, reason: AssertionFailed, Gcodes spinning, available RAM 11268, slot 1
                  Software reset code 0x4123 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x20011fbc Task NETW Freestk 495 ok
                  Stack: 00000904 000af288 0002ddbf 2002bed4 2002be01 000001a8 2002c100 200303f8 2002c118 2001e888 00000000 a5a5a5a5 00000000 00000000 00000000 00000000 20030404 00000800 20035940 2002c100 20018668 2002bf9d 20018668 2001e888 00030037 00000000 00000000
                  Error status: 0x00
                  Aux0 errors 0,0,0
                  MCU revision 3, ADC conversions started 1322550, completed 1322550, timed out 0, errs 0
                  MCU temperature: min 34.8, current 35.1, max 35.3
                  Supply voltage: min 24.0, current 24.1, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes
                  Heap OK, handles allocated/used 99/33, heap memory allocated/used/recyclable 2048/1856/1420, gc cycles 61
                  Driver 0: standstill, SG min 16, read errors 0, write errors 0, ifcnt 207, reads 965, writes 0, timeouts 0, DMA errors 0, CC errors 0
                  Driver 1: standstill, SG min 240, read errors 0, write errors 0, ifcnt 207, reads 965, writes 0, timeouts 0, DMA errors 0, CC errors 0
                  Driver 2: standstill, SG min 0, read errors 0, write errors 0, ifcnt 160, reads 965, writes 0, timeouts 0, DMA errors 0, CC errors 0
                  Driver 3: standstill, SG min 0, read errors 0, write errors 0, ifcnt 157, reads 966, writes 0, timeouts 0, DMA errors 0, CC errors 0
                  Driver 4: standstill, SG min 0, read errors 0, write errors 0, ifcnt 158, reads 965, writes 0, timeouts 0, DMA errors 0, CC errors 0
                  Date/time: 2023-11-18 07:22:32
                  Cache data hit count 2212461605
                  Slowest loop: 10.21ms; fastest: 0.13ms
                  === Storage ===
                  SD card longest read time 3.6ms, write time 4.2ms, max retries 0
                  === DDARing 0 ===
                  === DDARing 1 ===
                  in 0 notIn 0
                  === CAN ===
                  Messages queued 165, received 379, lost 0, errs 0, boc 0
                  Longest wait 0ms for reply type 0, peak Tx sync delay 3, free buffers 26 (min 26), ts 92/92/0
                  === Network ===
                  Slowest loop: 20.33ms; fastest: 0.06ms
                  === WiFi ===
                  Module reset reason: Power up, Vcc 3.38, flash size 2097152, free heap 43120
                  Signal strength -53dBm, channel 6, mode 802.11n, reconnections 0
                  But just out of curiosity, as I've understood it it's some DMA transfer between the CPU and WiFi-module that's causing the crashes.
                  Does this mean that if I've got a print I need/want to do I could just:
                  • Upload print job.
                  • Turn off the WiFi module with M552 S-1.
                  • Start the print from PanelDue, and let it complete.
                  • Once the job is done, turn on networking again from PanelDue with M552 S1.
                  Or will the DMA transfers still happen or try to happen, potentially causing a crash even if the WiFi-module is disabled?
                    @Exerqtor yes I think the crash will only occur when the WiFi module is enabled, because it's the code that talks to the WiFi module that is crashing.
                    Exerqtorundefined 1 Reply Last reply Reply Quote 1
                    • Exerqtorundefined
                      Exerqtor @dc42
                      @dc42 Ok, good to know if I want to run a larger more time consuming print.
                        @Exerqtor please install the firmware at https://www.dropbox.com/scl/fo/nta4k70rxl6n0bsv8q4q0/h?rlkey=1oq6j3jrvoxa6uaofyn9re3nn&dl=0 and post the M122 after it next resets.
                        • Exerqtorundefined
                          Exerqtor @dc42
                          @dc42 said in Reboots/crashes - RRF 3.5.0-rc1:
                          Will do!
                          ClockWatchdogundefined 1 Reply Last reply Reply Quote 0
                          • ClockWatchdogundefined
                            ClockWatchdog @Exerqtor
                            @Exerqtor I had the same errors with 3.4.5 - 3.4.6 and 3.5 Rc 1 with a duet 2 wifi.
                            I never had this kind of errors, it started to happen when i used a smartphone as a router. I suspected from the beginning, that the error was caused due to the continuous connect/reconnect. I "solved" (it is a workaround not a fix) using a PC as an Hotspot instead the phone and the crash never happened again. Later i inspected a bit, and with almost every phone or pad i used as an hotspot will cause connection-disconnection-reconnection continously and crashes.
                              dc42 administrators @ClockWatchdog
                              @ClockWatchdog thanks, that's useful information. We know that the crash happens when something goes wrong during a transaction between the Duet and the WiFi module, but we haven't pinned it down yet.
                              Exerqtorundefined ClockWatchdogundefined 2 Replies Last reply Reply Quote 1
                              • Exerqtorundefined
                                Exerqtor @dc42
                                @dc42 new crash!
                                RepRapFirmware for Duet 3 Mini 5+ version 3.5.0-rc.1+ (2023-11-20 10:16:40) running on Duet 3 Mini5plus WiFi (standalone mode)
                                Used output buffers: 1 of 40 (40 max)
                                Static ram: 102844
                                Tasks: NETWORK(1,ready,17.4%,234) HEAT(3,nWait,0.0%,352) Move(4,nWait,0.0%,358) CanReceiv(6,nWait,0.0%,774) CanSender(5,nWait,0.0%,336) CanClock(7,delaying,0.0%,350) TMC(4,nWait,0.7%,108) MAIN(1,running,80.8%,670) IDLE(0,ready,0.3%,29) AIN(4,delaying,0.8%,264), total 100.0%
                                Last reset 01:06:22 ago, cause: software
                                Last software reset at 2023-11-21 16:39, reason: AssertionFailed, Gcodes spinning, available RAM 10964, slot 0
                                Software reset code 0x4123 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00446000 BFAR 0xe000ed38 SP 0x20011fbc Task NETW Freestk 495 ok
                                Stack: 00000905 000af288 0002ddb7 2002bed4 2002be01 000001a8 2002c100 20030c10 2002c118 2001e888 a5a5a5a5 a5a5a5a5 00000000 00000000 00000000 00000000 20030c1c 00000800 00000002 2002c100 00000002 2002bf9d 20018668 2001e888 0003002f 00000000 00000000
                                Error status: 0x04
                                Aux0 errors 0,0,0
                                MCU revision 3, ADC conversions started 3983208, completed 3983208, timed out 0, errs 0
                                MCU temperature: min 34.8, current 35.3, max 38.2
                                Supply voltage: min 22.9, current 24.1, max 26.1, under voltage events: 0, over voltage events: 0, power good: yes
                                Heap OK, handles allocated/used 99/33, heap memory allocated/used/recyclable 2048/1400/964, gc cycles 185
                                Driver 0: standstill, SG min 16, read errors 0, write errors 1, ifcnt 30, reads 12987, writes 13, timeouts 0, DMA errors 0, CC errors 0
                                Driver 1: standstill, SG min 246, read errors 0, write errors 1, ifcnt 30, reads 12987, writes 13, timeouts 0, DMA errors 0, CC errors 0
                                Driver 2: standstill, SG min 0, read errors 0, write errors 1, ifcnt 218, reads 12986, writes 13, timeouts 0, DMA errors 0, CC errors 0
                                Driver 3: standstill, SG min 0, read errors 0, write errors 1, ifcnt 216, reads 12986, writes 13, timeouts 0, DMA errors 0, CC errors 0
                                Driver 4: standstill, SG min 0, read errors 0, write errors 1, ifcnt 216, reads 12987, writes 13, timeouts 0, DMA errors 0, CC errors 0
                                Date/time: 2023-11-21 17:45:13
                                Slowest loop: 15.72ms; fastest: 0.14ms
                                === Storage ===
                                SD card longest read time 6.1ms, write time 4.5ms, max retries 0
                                === DDARing 0 ===
                                === DDARing 1 ===
                                in 0 notIn 0
                                === CAN ===
                                Messages queued 35855, received 81685, lost 0, errs 0, boc 0
                                Longest wait 2ms for reply type 6053, peak Tx sync delay 264, free buffers 26 (min 25), ts 19914/19913/0
                                === Network ===
                                Slowest loop: 6.22ms; fastest: 0.00ms
                                === WiFi ===
                                Module reset reason: Power up, Vcc 3.38, flash size 2097152, free heap 41332
                                Signal strength -55dBm, channel 6, mode 802.11n, reconnections 0
                                  ClockWatchdog @dc42
                                  @dc42 I wondered, is it possible that the error is not exactly an error? I mean, when this disconnection-reconnection routine starts, is the number of interactions it performs too high and too concentrated? What if we reduced the speed of reconnection attempts and the number of attempts?
                                  • NeoDueundefined
                                    NeoDue
                                    Hm. Reading through all this what your effort yielded, I wonder if whatever @dc42 might find here could also affect the (much smaller) issues I have on my Duet 3 6HC with wifi module
                                    • dwell of about 5...10s required during boot prior to activating the module, otherwise the the module takes up to 10...15min to connect to the Wifi network
                                    • random disconnects and
                                    • very infrequent spontaneous reboots which I did not post here since I could not find anything useful about them yet.
                                    I blamed the latter two on the web server and the firmware being beta in general - but who knows...?
                                      @Exerqtor please try the firmware at https://www.dropbox.com/scl/fo/9hum0skl7rew21go56q7z/h?rlkey=mh1wx7mi72oz0dmk86c7uf4un&dl=0.
                                      @NeoDue if you get any more spontaneous reboots of the Duet, please run M122 and post the output here.
                                      Exerqtorundefined 3 Replies Last reply Reply Quote 1
                                      • Exerqtorundefined
                                        Exerqtor @dc42
                                        @dc42 New binaries installed, saw you did some changes to the WiFi interface in this fork.
                                        Guess that means you're on to something? wishfull thinking 🙈
                                        Just a little feedback after running the fw above for a while i've tried running a couple prints with a couple DWC instances open, and so far it haven't crashed at least. I'll try to have the printer printing for as many hours i can today with a bunch of DWC instances open to see if anything happens.
                                        • Exerqtorundefined
                                          Exerqtor @dc42
                                          @dc42 There she came, new crash:
                                          RepRapFirmware for Duet 3 Mini 5+ version 3.5.0-rc.1+ (2023-11-24 09:09:58) running on Duet 3 Mini5plus WiFi (standalone mode)
                                          Used output buffers: 10 of 40 (40 max)
                                          Static ram: 102844
                                          Dynamic ram: 124692 of which 12 recycled
                                          Never used RAM 10388, free system stack 138 words
                                          Tasks: NETWORK(2,nWait,17.0%,221) HEAT(3,nWait,0.0%,352) Move(4,nWait,0.0%,244) CanReceiv(6,nWait,0.0%,797) CanSender(5,nWait,0.0%,336) CanClock(7,delaying,0.0%,341) TMC(4,delaying,0.7%,80) MAIN(1,running,80.8%,670) IDLE(0,ready,0.6%,29) AIN(4,delaying,0.8%,264), total 100.0%
                                          Last reset 00:08:14 ago, cause: software
                                          Last software reset at 2023-11-25 16:29, reason: AssertionFailed, Gcodes spinning, available RAM 5228, slot 0
                                          Software reset code 0x4923 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00487000 BFAR 0xe000ed38 SP 0x20011fbc Task NETW Freestk 495 ok
                                          Stack: 00000907 000af288 0002dde9 2002bed4 2002be01 000001ae 2002c100 200303e0 2002c118 2001e888 0d362e30 a5a5a5a5 0a0d312e 00000000 00000000 00000000 200303ec 00000800 20035928 2002c100 20018668 2002bf9d 20018668 2001e888 0003007b 00000000 00000000
                                          Error status: 0x04
                                          Aux0 errors 0,0,0
                                          MCU revision 3, ADC conversions started 494787, completed 494785, timed out 0, errs 0
                                          MCU temperature: min 45.3, current 45.3, max 45.8
                                          Supply voltage: min 24.0, current 24.0, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes
                                          Heap OK, handles allocated/used 99/34, heap memory allocated/used/recyclable 2048/520/64, gc cycles 28
                                          Events: 0 queued, 0 completed
                                          Driver 0: standstill, SG min 0, read errors 0, write errors 0, ifcnt 34, reads 863, writes 0, timeouts 0, DMA errors 0, CC errors 0
                                          Driver 1: standstill, SG min 2, read errors 0, write errors 0, ifcnt 34, reads 863, writes 0, timeouts 0, DMA errors 0, CC errors 0
                                          Driver 2: standstill, SG min 2, read errors 0, write errors 0, ifcnt 26, reads 862, writes 0, timeouts 0, DMA errors 0, CC errors 0
                                          Driver 3: standstill, SG min 2, read errors 0, write errors 0, ifcnt 27, reads 862, writes 0, timeouts 0, DMA errors 0, CC errors 0
                                          Driver 4: standstill, SG min 2, read errors 0, write errors 0, ifcnt 27, reads 863, writes 0, timeouts 0, DMA errors 0, CC errors 0
                                          Date/time: 2023-11-25 16:37:43
                                          Cache data hit count 846895387
                                          Slowest loop: 10.63ms; fastest: 0.14ms
                                          === Storage ===
                                          SD card longest read time 3.6ms, write time 4.0ms, max retries 0
                                          DMs created 83, segments created 26, maxWait 0ms, bed compensation in use: none, height map offset 0.000, ebfmin 0.00, ebfmax 0.00
                                          === DDARing 0 ===
                                          Scheduled moves 43, completed 43, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
                                          === DDARing 1 ===
                                          Heater 1 is on, I-accum = 0.0
                                          Q0 segments left 0, axes/extruders owned 0x0000807
                                          in 0 notIn 0
                                          === CAN ===
                                          Messages queued 147, received 333, lost 0, errs 0, boc 0
                                          Longest wait 0ms for reply type 0, peak Tx sync delay 6, free buffers 26 (min 26), ts 82/82/0
                                          === Network ===
                                          Slowest loop: 20.10ms; fastest: 0.07ms
                                          HTTP sessions: 2 of 8
                                          === WiFi ===
                                          Module reset reason: Power up, Vcc 3.38, flash size 2097152, free heap 42968
                                          Signal strength -49dBm, channel 6, mode 802.11n, reconnections 0
                                          EDIT 28.11.2023:
                                          Was it any helpfull info in the M122 report @dc42? The printer has been idle since that crash, without any new ones.
                                          • Exerqtorundefined
                                            Exerqtor @dc42
                                            @dc42 New crash:
                                            M122
                                            Static ram: 102844
                                            Dynamic ram: 123356 of which 0 recycled
                                            Never used RAM 12360, free system stack 188 words
                                            Tasks: NETWORK(1,ready,16.7%,219) HEAT(3,nWait,0.0%,327) Move(4,nWait,0.0%,348) CanReceiv(6,nWait,0.0%,774) CanSender(5,nWait,0.0%,336) CanClock(7,delaying,0.0%,350) TMC(4,nWait,0.7%,108) MAIN(1,running,81.5%,670) IDLE(0,ready,0.3%,29) AIN(4,delaying,0.8%,264), total 100.0%
                                            Last reset 00:29:56 ago, cause: software
                                            Last software reset at 2023-11-29 18:54, reason: HardFault imprec, Gcodes spinning, available RAM 10104, slot 1
                                            Software reset code 0x4063 HFSR 0x40000000 CFSR 0x00000400 ICSR 0x00000803 BFAR 0xe000ed38 SP 0x20011fe8 Task NETW Freestk 506 ok
                                            Stack: 2002c118 20030c48 200014e8 00000000 20032e7d 0002fef5 0002ffb4 610ff200 00034731 2002bed0 2002bed0 00000004 0002f635 200014e8 e000e000 00000020 0009fc25 00000000 20034fa8 00000000 20034fa8 00000000 df0bd10a e000e000 2001e888 a5a5a5a5 a5a5a5a5
                                            Error status: 0x04
                                            Aux0 errors 0,0,0
                                            MCU revision 3, ADC conversions started 1796796, completed 1796794, timed out 0, errs 0
                                            MCU temperature: min 32.9, current 33.3, max 36.5
                                            Supply voltage: min 22.0, current 24.1, max 27.2, under voltage events: 0, over voltage events: 0, power good: yes
                                            Heap OK, handles allocated/used 99/33, heap memory allocated/used/recyclable 2048/456/20, gc cycles 84
                                            Driver 0: standstill, SG min 0, read errors 0, write errors 1, ifcnt 49, reads 29006, writes 13, timeouts 0, DMA errors 0, CC errors 0
                                            Driver 1: standstill, SG min 2, read errors 0, write errors 1, ifcnt 49, reads 29006, writes 13, timeouts 0, DMA errors 0, CC errors 0
                                            Driver 2: standstill, SG min 0, read errors 0, write errors 1, ifcnt 43, reads 29006, writes 13, timeouts 0, DMA errors 0, CC errors 0
                                            Driver 3: standstill, SG min 0, read errors 0, write errors 1, ifcnt 44, reads 29005, writes 13, timeouts 0, DMA errors 0, CC errors 0
                                            Driver 4: standstill, SG min 0, read errors 0, write errors 1, ifcnt 44, reads 29006, writes 13, timeouts 0, DMA errors 0, CC errors 0
                                            Date/time: 2023-11-29 19:24:40
                                            Cache data hit count 3045378646
                                            Slowest loop: 12.84ms; fastest: 0.13ms
                                            === Storage ===
                                            SD card longest read time 6.7ms, write time 4.5ms, max retries 0
                                            === DDARing 0 ===
                                            === DDARing 1 ===
                                            in 0 notIn 0
                                            === CAN ===
                                            Messages queued 16181, received 36876, lost 0, errs 1, boc 0
                                            Longest wait 2ms for reply type 6053, peak Tx sync delay 357, free buffers 26 (min 25), ts 8984/8983/0
                                            === Network ===
                                            Slowest loop: 6.04ms; fastest: 0.00ms
                                            === WiFi ===
                                            Module reset reason: Power up, Vcc 3.38, flash size 2097152, free heap 42796
                                            Signal strength -47dBm, channel 6, mode 802.11n, reconnections 0
                                            MaxGyverundefined 1 Reply Last reply Reply Quote 0
