    Reboots/crashes - RRF ≤3.5.0-rc1
    Beta Firmware
    13
    137
    10.0k
    • Exerqtorundefined
      Exerqtor @dc42
      @dc42 Ok, good to know if I want to run a larger more time consuming print.
        dc42 administrators @Exerqtor
        @Exerqtor please install the firmware at https://www.dropbox.com/scl/fo/nta4k70rxl6n0bsv8q4q0/h?rlkey=1oq6j3jrvoxa6uaofyn9re3nn&dl=0 and post the M122 after it next resets.
        Exerqtorundefined 1 Reply Last reply Reply Quote 1
        • Exerqtorundefined
          Exerqtor @dc42
          @dc42 said in Reboots/crashes - RRF 3.5.0-rc1:
          Will do!
          ClockWatchdogundefined 1 Reply Last reply Reply Quote 0
          • ClockWatchdogundefined
            ClockWatchdog @Exerqtor
            @Exerqtor I had the same errors with 3.4.5 - 3.4.6 and 3.5 Rc 1 with a duet 2 wifi.
            I never had this kind of errors, it started to happen when i used a smartphone as a router. I suspected from the beginning, that the error was caused due to the continuous connect/reconnect. I "solved" (it is a workaround not a fix) using a PC as an Hotspot instead the phone and the crash never happened again. Later i inspected a bit, and with almost every phone or pad i used as an hotspot will cause connection-disconnection-reconnection continously and crashes.
              dc42 administrators @ClockWatchdog
              @ClockWatchdog thanks, that's useful information. We know that the crash happens when something goes wrong during a transaction between the Duet and the WiFi module, but we haven't pinned it down yet.
              Exerqtorundefined ClockWatchdogundefined 2 Replies Last reply Reply Quote 1
              • Exerqtorundefined
                Exerqtor @dc42
                @dc42 new crash!
                RepRapFirmware for Duet 3 Mini 5+ version 3.5.0-rc.1+ (2023-11-20 10:16:40) running on Duet 3 Mini5plus WiFi (standalone mode)
                Board ID: XNHXF-HR6KL-K65J0-409N2-K9W1Z-RV2MZ
                Used output buffers: 1 of 40 (40 max)
                Static ram: 102844
                Dynamic ram: 123844 of which 0 recycled
                Never used RAM 11872, free system stack 186 words
                Tasks: NETWORK(1,ready,17.4%,234) HEAT(3,nWait,0.0%,352) Move(4,nWait,0.0%,358) CanReceiv(6,nWait,0.0%,774) CanSender(5,nWait,0.0%,336) CanClock(7,delaying,0.0%,350) TMC(4,nWait,0.7%,108) MAIN(1,running,80.8%,670) IDLE(0,ready,0.3%,29) AIN(4,delaying,0.8%,264), total 100.0%
                Owned mutexes: WiFi(NETWORK)
                Last reset 01:06:22 ago, cause: software
                Last software reset at 2023-11-21 16:39, reason: AssertionFailed, Gcodes spinning, available RAM 10964, slot 0
                Software reset code 0x4123 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00446000 BFAR 0xe000ed38 SP 0x20011fbc Task NETW Freestk 495 ok
                Stack: 00000905 000af288 0002ddb7 2002bed4 2002be01 000001a8 2002c100 20030c10 2002c118 2001e888 a5a5a5a5 a5a5a5a5 00000000 00000000 00000000 00000000 20030c1c 00000800 00000002 2002c100 00000002 2002bf9d 20018668 2001e888 0003002f 00000000 00000000
                Error status: 0x04
                Aux0 errors 0,0,0
                MCU revision 3, ADC conversions started 3983208, completed 3983208, timed out 0, errs 0
                MCU temperature: min 34.8, current 35.3, max 38.2
                Supply voltage: min 22.9, current 24.1, max 26.1, under voltage events: 0, over voltage events: 0, power good: yes
                Heap OK, handles allocated/used 99/33, heap memory allocated/used/recyclable 2048/1400/964, gc cycles 185
                Events: 1 queued, 1 completed
                Driver 0: standstill, SG min 16, read errors 0, write errors 1, ifcnt 30, reads 12987, writes 13, timeouts 0, DMA errors 0, CC errors 0
                Driver 1: standstill, SG min 246, read errors 0, write errors 1, ifcnt 30, reads 12987, writes 13, timeouts 0, DMA errors 0, CC errors 0
                Driver 2: standstill, SG min 0, read errors 0, write errors 1, ifcnt 218, reads 12986, writes 13, timeouts 0, DMA errors 0, CC errors 0
                Driver 3: standstill, SG min 0, read errors 0, write errors 1, ifcnt 216, reads 12986, writes 13, timeouts 0, DMA errors 0, CC errors 0
                Driver 4: standstill, SG min 0, read errors 0, write errors 1, ifcnt 216, reads 12987, writes 13, timeouts 0, DMA errors 0, CC errors 0
                Driver 5: not present
                Driver 6: not present
                Date/time: 2023-11-21 17:45:13
                Slowest loop: 15.72ms; fastest: 0.14ms
                === Storage ===
                Free file entries: 18
                SD card longest read time 6.1ms, write time 4.5ms, max retries 0
                DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, height map offset 0.000, ebfmin 0.00, ebfmax 0.00
                no step interrupt scheduled
                Moves shaped first try 0, on retry 0, too short 0, wrong shape 0, maybepossible 0
                === DDARing 0 ===
                === DDARing 1 ===
                HTTP is idle in state(s) 0
                Telnet is idle in state(s) 0
                File is idle in state(s) 0
                USB is idle in state(s) 0
                Aux is idle in state(s) 0
                Trigger is idle in state(s) 0
                Queue is idle in state(s) 0
                LCD is idle in state(s) 0
                SBC is idle in state(s) 0
                Daemon is doing "G4 S1" in state(s) 0 0, running macro
                Aux2 is idle in state(s) 0
                File2 is idle in state(s) 0
                Queue2 is idle in state(s) 0
                Q0 segments left 0, axes/extruders owned 0x0000803
                Code queue 0 is empty
                Code queue 1 is empty
                === Filament sensors ===
                in 0 notIn 0
                Extruder 0 sensor: no filament
                === CAN ===
                Messages queued 35855, received 81685, lost 0, errs 0, boc 0
                Longest wait 2ms for reply type 6053, peak Tx sync delay 264, free buffers 26 (min 25), ts 19914/19913/0
                Tx timeouts 0,0,0,0,0,0
                === Network ===
                Slowest loop: 6.22ms; fastest: 0.00ms
                Responder states: MQTT(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
                HTTP sessions: 1 of 8
                === WiFi ===
                Interface state: active
                Module is connected to access point
                Failed messages: pending 0, notrdy 0, noresp 0
                Firmware version 2.1beta4
                MAC address c4:5b:be:ce:91:93
                Module reset reason: Power up, Vcc 3.38, flash size 2097152, free heap 41332
                WiFi IP address 192.168.10.x
                Signal strength -55dBm, channel 6, mode 802.11n, reconnections 0
                Clock register 00002001
                  ClockWatchdog @dc42
                  @dc42 I wondered, is it possible that the error is not exactly an error? I mean, when this disconnection-reconnection routine starts, is the number of interactions it performs too high and too concentrated? What if we reduced the speed of reconnection attempts and the number of attempts?
                  • NeoDueundefined
                    NeoDue
                    Hm. Reading through all this what your effort yielded, I wonder if whatever @dc42 might find here could also affect the (much smaller) issues I have on my Duet 3 6HC with wifi module
                    • dwell of about 5...10s required during boot prior to activating the module, otherwise the the module takes up to 10...15min to connect to the Wifi network
                    • random disconnects and
                    • very infrequent spontaneous reboots which I did not post here since I could not find anything useful about them yet.
                    I blamed the latter two on the web server and the firmware being beta in general - but who knows...?
                      @Exerqtor please try the firmware at https://www.dropbox.com/scl/fo/9hum0skl7rew21go56q7z/h?rlkey=mh1wx7mi72oz0dmk86c7uf4un&dl=0.
                      @NeoDue if you get any more spontaneous reboots of the Duet, please run M122 and post the output here.
                      Exerqtorundefined 3 Replies Last reply Reply Quote 1
                      • Exerqtorundefined
                        Exerqtor @dc42
                        @dc42 New binaries installed, saw you did some changes to the WiFi interface in this fork.
                        Guess that means you're on to something? wishfull thinking 🙈
                        Just a little feedback after running the fw above for a while i've tried running a couple prints with a couple DWC instances open, and so far it haven't crashed at least. I'll try to have the printer printing for as many hours i can today with a bunch of DWC instances open to see if anything happens.
                        • Exerqtorundefined
                          Exerqtor @dc42
                          @dc42 There she came, new crash:
                          RepRapFirmware for Duet 3 Mini 5+ version 3.5.0-rc.1+ (2023-11-24 09:09:58) running on Duet 3 Mini5plus WiFi (standalone mode)
                          Used output buffers: 10 of 40 (40 max)
                          Static ram: 102844
                          Dynamic ram: 124692 of which 12 recycled
                          Never used RAM 10388, free system stack 138 words
                          Tasks: NETWORK(2,nWait,17.0%,221) HEAT(3,nWait,0.0%,352) Move(4,nWait,0.0%,244) CanReceiv(6,nWait,0.0%,797) CanSender(5,nWait,0.0%,336) CanClock(7,delaying,0.0%,341) TMC(4,delaying,0.7%,80) MAIN(1,running,80.8%,670) IDLE(0,ready,0.6%,29) AIN(4,delaying,0.8%,264), total 100.0%
                          Last reset 00:08:14 ago, cause: software
                          Last software reset at 2023-11-25 16:29, reason: AssertionFailed, Gcodes spinning, available RAM 5228, slot 0
                          Software reset code 0x4923 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00487000 BFAR 0xe000ed38 SP 0x20011fbc Task NETW Freestk 495 ok
                          Stack: 00000907 000af288 0002dde9 2002bed4 2002be01 000001ae 2002c100 200303e0 2002c118 2001e888 0d362e30 a5a5a5a5 0a0d312e 00000000 00000000 00000000 200303ec 00000800 20035928 2002c100 20018668 2002bf9d 20018668 2001e888 0003007b 00000000 00000000
                          Error status: 0x04
                          Aux0 errors 0,0,0
                          MCU revision 3, ADC conversions started 494787, completed 494785, timed out 0, errs 0
                          MCU temperature: min 45.3, current 45.3, max 45.8
                          Supply voltage: min 24.0, current 24.0, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes
                          Heap OK, handles allocated/used 99/34, heap memory allocated/used/recyclable 2048/520/64, gc cycles 28
                          Events: 0 queued, 0 completed
                          Driver 0: standstill, SG min 0, read errors 0, write errors 0, ifcnt 34, reads 863, writes 0, timeouts 0, DMA errors 0, CC errors 0
                          Driver 1: standstill, SG min 2, read errors 0, write errors 0, ifcnt 34, reads 863, writes 0, timeouts 0, DMA errors 0, CC errors 0
                          Driver 2: standstill, SG min 2, read errors 0, write errors 0, ifcnt 26, reads 862, writes 0, timeouts 0, DMA errors 0, CC errors 0
                          Driver 3: standstill, SG min 2, read errors 0, write errors 0, ifcnt 27, reads 862, writes 0, timeouts 0, DMA errors 0, CC errors 0
                          Driver 4: standstill, SG min 2, read errors 0, write errors 0, ifcnt 27, reads 863, writes 0, timeouts 0, DMA errors 0, CC errors 0
                          Date/time: 2023-11-25 16:37:43
                          Cache data hit count 846895387
                          Slowest loop: 10.63ms; fastest: 0.14ms
                          === Storage ===
                          SD card longest read time 3.6ms, write time 4.0ms, max retries 0
                          DMs created 83, segments created 26, maxWait 0ms, bed compensation in use: none, height map offset 0.000, ebfmin 0.00, ebfmax 0.00
                          === DDARing 0 ===
                          Scheduled moves 43, completed 43, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
                          === DDARing 1 ===
                          Heater 1 is on, I-accum = 0.0
                          Q0 segments left 0, axes/extruders owned 0x0000807
                          in 0 notIn 0
                          === CAN ===
                          Messages queued 147, received 333, lost 0, errs 0, boc 0
                          Longest wait 0ms for reply type 0, peak Tx sync delay 6, free buffers 26 (min 26), ts 82/82/0
                          === Network ===
                          Slowest loop: 20.10ms; fastest: 0.07ms
                          HTTP sessions: 2 of 8
                          === WiFi ===
                          Module reset reason: Power up, Vcc 3.38, flash size 2097152, free heap 42968
                          Signal strength -49dBm, channel 6, mode 802.11n, reconnections 0
                          EDIT 28.11.2023:
                          Was it any helpfull info in the M122 report @dc42? The printer has been idle since that crash, without any new ones.
                          • Exerqtorundefined
                            Exerqtor @dc42
                            @dc42 New crash:
                            M122
                            Static ram: 102844
                            Dynamic ram: 123356 of which 0 recycled
                            Never used RAM 12360, free system stack 188 words
                            Tasks: NETWORK(1,ready,16.7%,219) HEAT(3,nWait,0.0%,327) Move(4,nWait,0.0%,348) CanReceiv(6,nWait,0.0%,774) CanSender(5,nWait,0.0%,336) CanClock(7,delaying,0.0%,350) TMC(4,nWait,0.7%,108) MAIN(1,running,81.5%,670) IDLE(0,ready,0.3%,29) AIN(4,delaying,0.8%,264), total 100.0%
                            Last reset 00:29:56 ago, cause: software
                            Last software reset at 2023-11-29 18:54, reason: HardFault imprec, Gcodes spinning, available RAM 10104, slot 1
                            Software reset code 0x4063 HFSR 0x40000000 CFSR 0x00000400 ICSR 0x00000803 BFAR 0xe000ed38 SP 0x20011fe8 Task NETW Freestk 506 ok
                            Stack: 2002c118 20030c48 200014e8 00000000 20032e7d 0002fef5 0002ffb4 610ff200 00034731 2002bed0 2002bed0 00000004 0002f635 200014e8 e000e000 00000020 0009fc25 00000000 20034fa8 00000000 20034fa8 00000000 df0bd10a e000e000 2001e888 a5a5a5a5 a5a5a5a5
                            Error status: 0x04
                            Aux0 errors 0,0,0
                            MCU revision 3, ADC conversions started 1796796, completed 1796794, timed out 0, errs 0
                            MCU temperature: min 32.9, current 33.3, max 36.5
                            Supply voltage: min 22.0, current 24.1, max 27.2, under voltage events: 0, over voltage events: 0, power good: yes
                            Heap OK, handles allocated/used 99/33, heap memory allocated/used/recyclable 2048/456/20, gc cycles 84
                            Driver 0: standstill, SG min 0, read errors 0, write errors 1, ifcnt 49, reads 29006, writes 13, timeouts 0, DMA errors 0, CC errors 0
                            Driver 1: standstill, SG min 2, read errors 0, write errors 1, ifcnt 49, reads 29006, writes 13, timeouts 0, DMA errors 0, CC errors 0
                            Driver 2: standstill, SG min 0, read errors 0, write errors 1, ifcnt 43, reads 29006, writes 13, timeouts 0, DMA errors 0, CC errors 0
                            Driver 3: standstill, SG min 0, read errors 0, write errors 1, ifcnt 44, reads 29005, writes 13, timeouts 0, DMA errors 0, CC errors 0
                            Driver 4: standstill, SG min 0, read errors 0, write errors 1, ifcnt 44, reads 29006, writes 13, timeouts 0, DMA errors 0, CC errors 0
                            Date/time: 2023-11-29 19:24:40
                            Cache data hit count 3045378646
                            Slowest loop: 12.84ms; fastest: 0.13ms
                            === Storage ===
                            SD card longest read time 6.7ms, write time 4.5ms, max retries 0
                            === DDARing 0 ===
                            === DDARing 1 ===
                            in 0 notIn 0
                            === CAN ===
                            Messages queued 16181, received 36876, lost 0, errs 1, boc 0
                            Longest wait 2ms for reply type 6053, peak Tx sync delay 357, free buffers 26 (min 25), ts 8984/8983/0
                            === Network ===
                            Slowest loop: 6.04ms; fastest: 0.00ms
                            === WiFi ===
                            Module reset reason: Power up, Vcc 3.38, flash size 2097152, free heap 42796
                            Signal strength -47dBm, channel 6, mode 802.11n, reconnections 0
                            MaxGyverundefined 1 Reply Last reply Reply Quote 0
                            • MaxGyverundefined
                              MaxGyver @Exerqtor
                              @Exerqtor @dc42
                              I can contribute some crash reports as well. My printer just rebooted mid print, this has never happend in one of the previous 3.5 betas.
                              Duet 3 6HC with SBC on RRF 3.5-rc.1
                              2.12.2023, 17:11:57: Verbindung zu duet3.local hergestellt
                              2.12.2023, 17:12:14: M201: Accelerations (mm/sec^2): X: 20000.0, Y: 20000.0, Z: 250.0, E: 20000.0
                              2.12.2023, 17:20:49: : Warning: SPI connection has been reset
                              2.12.2023, 17:20:51: : Error: Expansion board 123 reconnected
                              2.12.2023, 17:20:51: : Error: Expansion board 124 reconnected
                              2.12.2023, 17:20:52: : Error: Expansion board 126 reconnected
                              2.12.2023, 17:20:52: : Error: Expansion board 125 reconnected
                              2.12.2023, 17:20:55: : Warning: M307: Heater 0 predicted maximum temperature at full power is 321°C
                              2.12.2023, 17:20:55: : Warning: M307: Heater 1 predicted maximum temperature at full power is 534°C
                              2.12.2023, 17:20:56: : Warning: M307: Heater 1 predicted maximum temperature at full power is 534°C
                              2.12.2023, 17:21:07: M122: === Diagnostics ===
                              RepRapFirmware for Duet 3 MB6HC version 3.5.0-rc.1 (2023-08-31 16:19:24) running on Duet 3 MB6HC v1.0 or earlier (SBC mode)
                              Board ID: 08DJM-956L2-G43S8-6J1F2-3SN6N-1U0LG
                              Used output buffers: 1 of 40 (18 max)
                              Static ram: 154852
                              Dynamic ram: 87280 of which 0 recycled
                              Never used RAM 3604, free system stack 204 words
                              Tasks: SBC(2,ready,1.7%,441) HEAT(3,nWait,0.0%,363) Move(4,nWait,0.0%,340) CanReceiv(6,nWait,0.0%,796) CanSender(5,nWait,0.0%,335) CanClock(7,delaying,0.0%,344) TMC(4,nWait,7.9%,61) MAIN(2,running,87.3%,137) IDLE(0,ready,3.1%,30), total 100.0%
                              Owned mutexes: HTTP(MAIN)
                              Last reset 00:00:17 ago, cause: software
                              Last software reset at 2023-12-02 16:20, reason: OutOfMemory, Gcodes spinning, available RAM 4, slot 0
                              Software reset code 0x41c3 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0x00000000 SP 0x20421688 Task Move Freestk 319 ok
                              Stack: 2041808c 00419f11 00000000 00000000 2045d0e0 0044a07d 204216f8 00442d47 2045d0e0 00000001 2045d0fc 00445b09 00000000 2045a200 204322a4 204296b6 204251bc 204296b8 00000000 00000002 00000000 20425cbc 00000001 00000001 20432418 00000000 00000001
                              Error status: 0x00
                              MCU temperature: min 34.5, current 34.8, max 35.2
                              Supply voltage: min 3.9, current 24.0, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes
                              12V rail voltage: min 0.9, current 12.1, max 12.2, under voltage events: 0
                              Heap OK, handles allocated/used 99/8, heap memory allocated/used/recyclable 2048/120/0, gc cycles 0
                              Events: 4 queued, 4 completed
                              Driver 0: standstill, SG min 0, mspos 8, reads 27152, writes 16 timeouts 0
                              Driver 1: standstill, SG min 0, mspos 8, reads 27153, writes 16 timeouts 0
                              Driver 2: standstill, SG min 0, mspos 8, reads 27153, writes 16 timeouts 0
                              Driver 3: standstill, SG min 0, mspos 8, reads 27153, writes 16 timeouts 0
                              Driver 4: standstill, SG min 0, mspos 8, reads 27151, writes 18 timeouts 0
                              Driver 5: standstill, SG min 0, mspos 8, reads 27158, writes 11 timeouts 0
                              Date/time: 2023-12-02 16:21:05
                              Slowest loop: 1.71ms; fastest: 0.07ms
                              === Storage ===
                              Free file entries: 20
                              DMs created 250, segments created 0, maxWait 0ms, bed compensation in use: none, height map offset 0.000, ebfmin 0.00, ebfmax 0.00
                              === DDARing 0 ===
                              === DDARing 1 ===
                              Bed heaters 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0
                              Daemon is idle in state(s) 0
                              Q0 segments left 0, axes/extruders owned 0x80000003
                              === CAN ===
                              Messages queued 166, received 566, lost 0, boc 0
                              Longest wait 56ms for reply type 6041, peak Tx sync delay 38032, free buffers 50 (min 49), ts 90/86/0
                              Tx timeouts 0,0,3,0,0,0 last cancelled message type 30 dest 127
                              === SBC interface ===
                              Transfer state: 5, failed transfers: 0, checksum errors: 0
                              RX/TX seq numbers: 24333/3400
                              SPI underruns 0, overruns 0
                              State: 5, disconnects: 0, timeouts: 0 total, 0 by SBC, IAP RAM available 0x25a98
                              Buffer RX/TX: 0/0-0, open files: 0
                              === Duet Control Server ===
                              Duet Control Server version 3.5.0-rc.1 (2023-09-01 07:16:31)
                              Code buffer space: 4096
                              Configured SPI speed: 8000000Hz, TfrRdy pin glitches: 2
                              Full transfers per second: 49.12, max time between full transfers: 303.3ms, max pin wait times: 280.8ms/15.6ms
                              Codes per second: 65.98
                              Maximum length of RX/TX data transfers: 4456/1680
                                dc42 administrators @MaxGyver
                                @MaxGyver please can you take regular M122 reports next tike you.run this print. An out of memory error on a 6HC is very unusual and suggests that your print may be doing something that is triggering a memory leak in RRF.
                                  dc42 administrators @dc42
                                  @Exerqtor are you using the USB port on that Duet 3 Mini?
                                  dc42undefined Exerqtorundefined 2 Replies Last reply Reply Quote 0
                                    @Exerqtor please try the firmware at https://www.dropbox.com/scl/fo/1r49rb2x3jsn1az0jdu1j/h?rlkey=xke2yefix0hyp5dioxa58pgtp&dl=0 and post a M122 after any crash.
                                    Exerqtorundefined 1 Reply Last reply Reply Quote 0
                                    • Exerqtorundefined
                                      Exerqtor @dc42
                                      Nope the USB port haven't got anything plugged in.
                                      OK, i'll install it right away.
                                      • Exerqtorundefined
                                        Exerqtor @dc42
                                        Hopefully this shines some more light on it:
                                        M122
                                        RepRapFirmware for Duet 3 Mini 5+ version 3.5.0-rc.1+ (2023-12-04 12:12:17) running on Duet 3 Mini5plus WiFi (standalone mode)
                                        Static ram: 102844
                                        Dynamic ram: 123360 of which 0 recycled
                                        Never used RAM 12356, free system stack 188 words
                                        Tasks: NETWORK(1,ready,18.8%,239) HEAT(3,nWait,0.0%,336) Move(4,nWait,0.0%,343) CanReceiv(6,nWait,0.0%,797) CanSender(5,nWait,0.0%,336) CanClock(7,delaying,0.0%,350) TMC(4,nWait,0.7%,114) MAIN(1,running,79.3%,670) IDLE(0,ready,0.3%,29) AIN(4,delaying,0.8%,264), total 100.0%
                                        Owned mutexes:
                                        Last reset 00:26:31 ago, cause: software
                                        Last software reset at 2023-12-05 09:59, reason: HardFault imprec ibus, Gcodes spinning, available RAM 10968, slot 1
                                        Software reset code 0x4063 HFSR 0x40000000 CFSR 0x00000500 ICSR 0x00000803 BFAR 0xe000ed38 SP 0x20011f48 Task NETW Freestk 466 ok
                                        Stack: 0d362e30 20032dec 000001bf 00000001 0d362e30 20032dec 000043ae 010f0200 00000001 200117a4 2002bed0 000001bf 000001bf 00000004 0002dd0f 2002bed4 2002be01 000001bf 2002c138 20031db0 2002c150 2001e888 a5a5a5a5 a5a5a5a5 0002ff15 00000000 00000000
                                        Error status: 0x04
                                        Aux0 errors 0,0,0
                                        MCU revision 3, ADC conversions started 1591912, completed 1591912, timed out 0, errs 0
                                        MCU temperature: min 33.2, current 34.0, max 36.2
                                        Supply voltage: min 22.0, current 24.1, max 27.0, under voltage events: 0, over voltage events: 0, power good: yes
                                        Heap OK, handles allocated/used 99/33, heap memory allocated/used/recyclable 2048/1172/736, gc cycles 74
                                        Driver 0: standstill, SG min 0, read errors 0, write errors 1, ifcnt 227, reads 18224, writes 13, timeouts 0, DMA errors 0, CC errors 0
                                        Driver 1: standstill, SG min 16, read errors 0, write errors 1, ifcnt 227, reads 18224, writes 13, timeouts 0, DMA errors 0, CC errors 0
                                        Driver 2: standstill, SG min 2, read errors 0, write errors 1, ifcnt 150, reads 18224, writes 13, timeouts 0, DMA errors 0, CC errors 0
                                        Driver 3: standstill, SG min 0, read errors 0, write errors 1, ifcnt 149, reads 18223, writes 13, timeouts 0, DMA errors 0, CC errors 0
                                        Driver 4: standstill, SG min 0, read errors 0, write errors 1, ifcnt 149, reads 18224, writes 13, timeouts 0, DMA errors 0, CC errors 0
                                        Date/time: 2023-12-05 10:26:25
                                        Cache data hit count 2710632535
                                        Slowest loop: 9.77ms; fastest: 0.13ms
                                        === Storage ===
                                        SD card longest read time 7.1ms, write time 4.5ms, max retries 0
                                        === DDARing 0 ===
                                        === DDARing 1 ===
                                        in 0 notIn 0
                                        === CAN ===
                                        Messages queued 14337, received 32674, lost 0, errs 1, boc 0
                                        Longest wait 2ms for reply type 6053, peak Tx sync delay 260, free buffers 26 (min 25), ts 7960/7959/0
                                        === Network ===
                                        Slowest loop: 7.91ms; fastest: 0.00ms
                                        HTTP sessions: 3 of 8
                                        === WiFi ===
                                        Module reset reason: Power up, Vcc 3.38, flash size 2097152, free heap 42972
                                          @Exerqtor interesting, that one is a different sort of reset but in the same function. Please send M122 P500 S0, then wait for it to reset again and send the M122 report as usual.
                                          • Exerqtorundefined
                                            Exerqtor @dc42
                                            Here you go ( i did a print or two after sending M122 P500 S0, hope that don't mess anything up):
                                            Used output buffers: 6 of 40 (40 max)
                                            Static ram: 102844
                                            Never used RAM 12356, free system stack 196 words
                                            Tasks: NETWORK(1,ready,19.1%,239) HEAT(3,nWait,0.0%,353) Move(4,nWait,0.0%,357) CanReceiv(6,nWait,0.0%,797) CanSender(5,nWait,0.0%,336) CanClock(7,delaying,0.0%,350) TMC(4,nWait,0.7%,108) MAIN(1,running,79.0%,670) IDLE(0,ready,0.3%,29) AIN(4,delaying,0.8%,264), total 100.0%
                                            Last reset 01:09:12 ago, cause: software
                                            Last software reset at 2023-12-06 08:16, reason: AssertionFailed, Gcodes spinning, available RAM 5824, slot 2
                                            Software reset code 0x4123 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x20011fbc Task NETW Freestk 495 ok
                                            Stack: 0000090f 000af3c8 0002de29 2002bed4 2002be01 000001b0 2002c100 20031550 2002c118 2001e888 a5a5a5a5 a5a5a5a5 312e303d 00000000 00000000 00000000 2003155c 00000800 20035a68 2002c100 20018678 2002bf9d 20018678 2001e888 000300af 00000000 00000000
                                            Error status: 0x04
                                            Aux0 errors 0,0,0
                                            MCU revision 3, ADC conversions started 4152839, completed 4152837, timed out 0, errs 0
                                            MCU temperature: min 33.8, current 34.0, max 36.9
                                            Supply voltage: min 22.5, current 24.1, max 26.5, under voltage events: 0, over voltage events: 0, power good: yes
                                            Heap OK, handles allocated/used 99/33, heap memory allocated/used/recyclable 2048/1248/812, gc cycles 193
                                            Driver 0: standstill, SG min 16, read errors 0, write errors 1, ifcnt 89, reads 21918, writes 13, timeouts 0, DMA errors 0, CC errors 0
                                            Driver 1: standstill, SG min 248, read errors 0, write errors 1, ifcnt 88, reads 21918, writes 13, timeouts 0, DMA errors 0, CC errors 0
                                            Driver 2: standstill, SG min 2, read errors 0, write errors 1, ifcnt 52, reads 21917, writes 13, timeouts 0, DMA errors 0, CC errors 0
                                            Driver 3: standstill, SG min 2, read errors 0, write errors 1, ifcnt 51, reads 21917, writes 13, timeouts 0, DMA errors 0, CC errors 0
                                            Driver 4: standstill, SG min 0, read errors 0, write errors 1, ifcnt 50, reads 21918, writes 13, timeouts 0, DMA errors 0, CC errors 0
                                            Date/time: 2023-12-06 09:25:54
                                            Slowest loop: 12.98ms; fastest: 0.13ms
                                            === Storage ===
                                            SD card longest read time 6.9ms, write time 4.8ms, max retries 0
                                            === DDARing 0 ===
                                            === DDARing 1 ===
                                            in 0 notIn 0
                                            === CAN ===
                                            Messages queued 37382, received 85164, lost 0, errs 1, boc 0
                                            Longest wait 2ms for reply type 6053, peak Tx sync delay 270, free buffers 26 (min 25), ts 20763/20762/0
                                            === Network ===
                                            Slowest loop: 5.88ms; fastest: 0.00ms
                                            === WiFi ===
