    Laser filament monitor
    Filament Monitor
    73
    179
    42.1k
    • kelchmundefined
      kelchm
      Great news! I'd definitely be interested in assisting with testing.
      My Prusa MK3 arrives on Monday, so happy to both compare how both implementations work in practice.
        Testing so far indicates that the laser sensor is reasonably accurate with several filament types when the filament moves at low speed, but at high speeds it under-reads with some filaments. We may be able to get round this by changing the housing. If not, then one option would be to use it to monitor printing moves only, ignoring retractions and un-retractions.
        • botundefined
          bot
          Can we have the option to enable or disable retraction monitoring? I only retract 0.37 mm at 5 mm/s so I don't think it would become a problem for me.
          *not actually a robot
          • claustroundefined
            claustro
            Only for let you know ,I have a printing time of more than 60 hours from the time I mounted the filament sensor, and after some problem during the configuration time it is proving to be very reliable.
            I tested the sensor in both direct and in bowden machine without any sort of problem
            What improvements are expected form a laser option?
            • DjDemonDundefined
              DjDemonD
              I didn't have quite so much success with it, whether it was the mount which flexed somewhat, the inability to use the nimble as it is currently designed to fix an input bowden tube, or the housing allowing the rollers to move laterally, which changes the effective diameter of the filament monitor hobbed gear, or moves the magnet away from the sensor chip, all of these issues at times occurred. I did also get some true positives, where filament snagged or ran out and this was extremely useful.
              So the usefulness of a filament monitor of any sort is for me very clear, its just this current design seems overly complex, fragile and mechanical compared to Prusa's extremely neat, simple solution whether it actually works well we are about to find out.
              www.precisionpiezo.co.uk
                @claustro:
                What improvements are expected from a laser option?
                • It's mechanically much simpler. The housing just needs to clamp 2 pieces of PTFE tubing in place so as to guide the filament in front of the sensor.
                • The simplicity may make it more reliable. [OTOH the sensor may be affected by dust.]
                • We could potentially make it smaller than the current 25 x 22.5mm
                • If we find it reproducible enough, it may need no calibration - which also means it could calibrate the extruder steps/mm.
                • DR8undefined
                  DR8
                  That's awesome. I'll love to test this. Can I suggest to yo something guys? Make sure that the mechanism where the laser sensor is integrated will allow the filament to be unloaded. For example when I made my first prototype and I clicked the unload filament button, the filament got stuck in the mecanism and the extruder gear start to grind into the filament. So the filament should run smooth backward in the mechanism when unloaded.
                    deckingman
                    @dc42:
                    …...................... If we find it reproducible enough, it may need no calibration - which also means it could calibrate the extruder steps/mm.
                    Oooo - now there is a use that I never thought about.
                    I just need the next gen Duet as I'd need 5 of them and I've only got 3 spare end stops on the Duex5 (the Duet is already full). My cable chain is about full too. 🙂
                    • DjDemonDundefined
                      DjDemonD
                      I wouldn't open the bottle of champagne yet though. Whilst it could offer gross calibration, precise calibration would require some manual input such as filament average diameter in order to get close to exact correct steps/mm. But its a big step in the right direction. A laser sensor to measure filament diameter and roundness and you'd be a lot closer to an auto-calibrating extruder.
                        deckingman
                        @DjDemonD:
                        Simon,
                        Sadly, I'm not able to drink alcohol any more so the champagne is still on the super market shelf 🙂
                        I wasn't thinking so much about compensation for filament diameter (can't see how it would be able to do that) but just thinking that it would be a lot easier than measuring and marking the filament to get the initial steps per mm. That's always a bit of a PITA trying to hold the filament straight while measuring and/or marking it.
                        In theory you only need to do that once (or 5 times in my case due to me having 5 extruders) but I get variations between PLA and PETG which I suspect is to do with hobbed bolt biting deeper into one than the other. Having 5 extruders to calibrate, I can't be ar**ed to measure every filament, so simply use an extrusion multiplier to compensate in a hit and miss sort of fashion. But if the filament monitor would give me the amount of filament that has passed through the extruder, that would make life a lot easier and I could fine tune it from there if need be.
                        Cheers
                          @DjDemonD:
                          I don't agree. The extruder steps/mm should be exactly what comes out of the extruder, and as such can be measured by the filament monitor. If the extrusion amount needs to be compensated for the filament diameter not being quote what not should be, IMO that is best compensated for in the slicer settings or the extrusion factor, not by setting the extruder steps/mm to a deliberately wrong value.
                          • fmaundefined
                            fma
                            I think there are so many parameters influencing extrusion that steps/mm does not have to be that precise. I don't bother anymore to have a perfect match: I prefer printing a small part, check the top layer, and adjust extrusion ratio. And this ratio can have large variations with the extrusion temperature, speed and so (depending on the part I'm printing, and the final aspect and/or mechanical properties I need, I often change the printing temperature within 25°C range, and speed in a factor of 2).
                            However, the sensor output should be reproductible, and always give the same steps/mm value for a given filament.
                            Frédéric
                              @fma:
                              However, the sensor output should be reproducible, and always give the same steps/mm value for a given filament.
                              Quite so. I find that the optimum extrusion factor depends on the filament - and not just because of variations in the the diameter.
                              I am hoping that the laser filament sensor will show the correct movement amount regardless of filament type, at least at low speeds. But more testing will be needed to confirm that, which will be easier when we have the prototypes.
                              • DjDemonDundefined
                                DjDemonD
                                I agree that it will enable you to set steps/mm if you're measuring mm moving past it accurately and consistently. But this is only the relationship between motor steps and linear filament movement, not filament extruded volumetrically, which is actually what we need to measure, albeit no scheme for doing so has proved fruitful.
                                As to whether you should use an extrusion multiplier in a slicer or change your steps/mm to compensate for variations in filament diameter (the cross-sectional area is obviously what you really need to measure) is semantic in that what is physically happening is that one motor turns pushing filament through a nozzle, you just need to know how much to turn the extruder to get the right amount of material out, any and all settings that contribute to this are all just different ways to label the same thing.
                                If the filament is softer and the drive gear bites into it harder reducing it's effective diameter then the filament monitor should be able to compensate for this automatically, so that great news.
                                If you want to make a genuinely autocalibrating extruder (not necessary for us enthusiasts/pros who've been printing for years, but quite important for a true consumer 3D printer) then you need to measure the cross-sectional area to cope with any filament you chose to load.
                                  If you want to calibrate volumetric extrusion, then I agree, in principle you need to measure filament diameter too. But standard practice is to calibrate linear extrusion. If the filament is of high quality, then the diameter will be tightly controlled so it will also give you sufficiently accurate volumetric extrusion too. Nevertheless, different filaments swell by different amounts after extrusion, so even accurate volumetric extrusion doesn't guarantee that you won't need to adjust the extrusion factor.
                                  • DjDemonDundefined
                                    DjDemonD
                                    Sure measuring die-swell would be hard. The only idea that might be feasible for true auto calibration of the extruder would be to extrude onto a glass section at the side of the bed, from a precise z-height, and measure using a CCD scanner sensor, or something similar the width of filament extruded then change the steps/mm and extrude again. In theory it would account for all necessary factors.
                                      deckingman
                                      IMO, even with a perfectly calibrated extruder there may still be a need to alter the extrusion multiplier to compensate for say models which have a lot of short slow moves vs models which have predominantly long fast moves. Another factor which is related to that is temperature and by that I mean the temperature throughout the filament from outside edge to the core. The filament itself is a very poor thermal conductor so when printing at high(ish) speed, there is less time in the melt chamber so the inner core may be significantly cooler than the outer surface. So even measuring die swell at one fixed speed/temperature combination might not be a practical solution.
                                      • veng1undefined
                                        veng1
                                        The schematic for Prusa's laser sensor has been published in his github. The part number on the print is PAT9125SEL
                                        https://github.com/prusa3d/PRUSA_Laser_filament_sensor/blob/master/rev.02/laser-sensor.pdf
                                        Slightly off topic but he has also published the power panic circuit. From the picture, I think it may need a slot routed in the pcb between L and N to meet UL creep distance.
                                          Thanks, that confirms that the sensor we chose is the same one.
                                          • elmoretundefined
                                            elmoret
                                            @veng1:
                                            Can confirm slot! Just received MK3.
