    input shaping
    • Fireflyundefined
      Firefly
      So I had this printer all set up and now I came back to it months later and it says
      Input Shaping is not configured. Record a new Motion Profile to set it up
      but I do see these,
      so what happened? and how do I prevent losing it again, is there a way to back it up?
      I would have to reinstall the accelerometer to do this again.
      • Duet2d Maestro in Flash Forge Creator Pro (Cartesian)
      • Duet Web Control 3.4.5
      • prior post : https://forum.duet3d.com/topic/33243/which-input-shaping/10
        droftarts administrators @Firefly
        @Firefly Looks like you can use the numbers it generated in your linked image here: https://forum.duet3d.com/post/321407
        Put the M593 command in config.g. Check the notes on https://docs.duet3d.com/User_manual/Reference/Gcodes#m593-configure-input-shaping depending on the firmware version you are using.
        Fireflyundefined 2 Replies Last reply Reply Quote 0
        • Fireflyundefined
          Firefly @droftarts
          @droftarts Thank you.
          • Fireflyundefined
            Firefly @droftarts
            @droftarts how does it know to apply it X or Y?
              @Firefly It applies it to both. See https://docs.duet3d.com/en/User_manual/Tuning/Input_shaping#why-we-dont-support-different-shaping-for-the-x-and-y-axes
