input shaping
    Firefly
    So I had this printer all set up and now I came back to it months later and it says
    Input Shaping is not configured. Record a new Motion Profile to set it up
    but I do see these,
    so what happened? and how do I prevent losing it again, is there a way to back it up?
    I would have to reinstall the accelerometer to do this again.
    • Duet2d Maestro in Flash Forge Creator Pro (Cartesian)
    • Duet Web Control 3.4.5
    • prior post : https://forum.duet3d.com/topic/33243/which-input-shaping/10
    undefined 1 Reply Last reply 26 Jan 2024, 17:04 Reply Quote 0
      droftarts administrators @Firefly
      @Firefly Looks like you can use the numbers it generated in your linked image here: https://forum.duet3d.com/post/321407
      Put the M593 command in config.g. Check the notes on https://docs.duet3d.com/User_manual/Reference/Gcodes#m593-configure-input-shaping depending on the firmware version you are using.
      undefined 2 Replies Last reply 26 Jan 2024, 19:40 Reply Quote 0
        Firefly @droftarts
        @droftarts Thank you.
          Firefly @droftarts
          @droftarts how does it know to apply it X or Y?
          undefined 1 Reply Last reply 26 Jan 2024, 21:21 Reply Quote 0
            @Firefly It applies it to both. See https://docs.duet3d.com/en/User_manual/Tuning/Input_shaping#why-we-dont-support-different-shaping-for-the-x-and-y-axes
            5 out of 5
