    New firmware 1.20 Release Candidate 2 - please try it!
    Firmware installation
    30
    97
    15.5k
      @Iirai:
      When I try to connect to DWC I get this error:
      Could not establish a connection to the Duet firmware! Please check your settings and try again.
      I'm able to ping the DuetWiFi, wifi signal is -59, it's on a static Ip and I confirmed that the mac address is correct . Am I missing something obvious?
      Firmware: 1.20-RC2
      DuetWiFiServer: 1.20beta10
      DWC: 1.20-RC3
      1. Did you install DuetWiFiServer.bin twice as suggested in the upgrade notes?
      2. If you send M552 S1 from USB or PanelDue then it will report success/failure of the attempt to connect to your router.
        @Gone2Far:
        Admittedly I do not stress the Duet much, but FWIW, RC2 is working well for me.
        Thanks for the feedback! Which Duet do you have?
          @Forgvn77:
          Pause print and resume failed for me from the PanelDue. The hot end resumed extruding a couple layers above the print. Running 1.20RC2 and latest DWC release candidate,
          Thanks for the feedback. I'll test pause/resume again.
            @Gosu:
            i updated from RC1 to RC2 then it stopped running with wifi and i used the new www file to fix the problem
            now i can only control my printer via wifi for 5 minutes(with constant disconnects) and i was able to start a print
            but the printer stopped beeing able to connect via webhost
            only seldomly beeing able to connect
            i would love to post my current version but it wont let me connect
            its FW RC2
            Wifi Beta10 i believe
            and RC3 Webclient
            Did you install DuetWiFiFirmware twice as recommended in the upgrade notes?
            • AS-3D Druckundefined
              AS-3D Druck
              The Dark Theme on the new Webcontol is a little bit wrong. πŸ˜‰
              Screenshot:
              https://gyazo.com/5d01aed4163234081552f63a99b2f76c
              Best regards
              AS-3D Druck / Andre
                @AS-3D:
                Screenshot:
                Try updating DWC to 1.20RC3.
                  AS-3D Druck
                  @dc42:
                  @AS-3D:
                  Screenshot:
                  There is no DWC 1.20RC3 here: https://github.com/dc42/RepRapFirmware/tree/dev/Release/Duet-WiFi/Edge
                  or here: https://github.com/chrishamm/DuetWebControl
                  //Edite
                  THX now i found it (Duet Wifi): https://github.com/dc42/RepRapFirmware/blob/dev/Release/Duet-WiFi/Edge/DuetWebControl-1.20-RC3.zip
                  Best regards
                  AS-3D Druck / Andre
                    I've just released 1.20RC3. This has only minor changes from 1.20RC2.
                    The following have been reported in this thread:
                    1. "Starting with Beta11, with the M584 changes, with the U axis hidden if I run G29 the printer starts probing, but after the first row the U drive, which is my second Z motor starts moving up rather than down."
                    I thought I had asked for more detail about this issue, but it looks like I didn't. Has anyone else seens a similar issue? Hiding the U axis should make no difference to the behaviour of the Z axis, but it will prevent explicit U moves being made.
                    2. Various WiFi disconnection issues. Please note the instructions to install DuetWiFiServer-1.20b10 twice. You can use older DuetWiFiServer versions with RRF 1.20RC3 if necessary, but if you do then the M587 command to list configured wifi networks may not work. I expect to have DuetWiFiServer 1.20beta11 available early next week.
                    3. A report that pause/resume caused the print to resume too high. I have tested this on 2 printers and I can't reproduce it.
                    4. Various DWC issues, which I believed are resolved in DWC 1.20-RC3.
                      AS-3D Druck
                      I got a Problem to open a Directory on G-Code Files:
                      [[language]]
                      A JavaScript error has occurred so the web interface has closed the connection to your board. It is recommended to reload the web interface now. If this happens again, please contact the author and share this error message:
                      Version: 1.20-RC3
                      Message: Uncaught TypeError: Cannot read property 'match' of undefined
                      URL: http://d-bot.local/js/dwc.js
                      Line: 2015:27
                      Error object: {}
                      Only this Directory makes Problemes everything else works.
                      Best regards
                      AS-3D Druck / Andre
                        deckingman
                        @dc42:
                        Some have been resolved but the extruder position issue that I reported above is still outstanding.
                        • Gone2Farundefined
                          Gone2Far
                          @dc42:
                          @Gone2Far:
                          Duet WiFi, with smart effector and 7" panel due.
                          Original Prusa i3 MK2S
                          Large Kossel Homebrew
                            @AS-3D:
                            [[language]]
                            Version: 1.20-RC3
                            Line: 2015:27
                            Error object: {}
                            Is there anything unusual about that directory, for example its name?
                            • Dougal1957undefined
                              Dougal1957
                              @dc42:
                              I've just released 1.20RC3. This has only minor changes from 1.20RC3.
                              David
                              A Couple of Typos first in this post first line V1.20RC3 has minor changes to 1.20RC3
                              And in the changeling latest release titled as 1.20RC2
                              Doug
                              • T-Printerundefined
                                T-Printer
                                I still have at lot of Communication Error (before with 1.18, ther was no problems with the WiFi)
                                DuetWiFiServer ver. 1.20B10 Install twice as DC42 say πŸ™‚
                                Web Interface ver. 1.20-RC3
                                Duet FirmWare ver. 1.20RC3
                                My Wifi ruter is a ASUS RT-AC87U, and is firmware is up to date. good signal -55
                                It just go on and off. On the Paneldue is say Wifi Reported Error Lost Connection Auto Reconnect, and Auto Reconnect Succeeded about every 1 - 2 min
                                On the webinterface most of the time, I have Communication Error, then I can reconect, but after Max 1min I am off aging..
                                Anny solution to this?
                                Kent
                                  AS-3D Druck
                                  @dc42:
                                  @AS-3D:
                                  [[language]]
                                  Version: 1.20-RC3
                                  Line: 2015:27
                                  Error object: {}
                                  Got it, i used letters like Àüß and he converted that to strange Symbols.
                                  After renaming everything works again.
                                  Best regards
                                  AS-3D Druck / Andre
                                    @Dougal1957:
                                    Doug
                                    Thanks, I've corrected those.
                                      @T-Printer:
                                      Kent
                                      Please can you and anyone else experiencing WiFi disconnection issues do this. Connect a PC via USB and send M111 S1 P14 to enable the WiFi debugging feature. You will get a few WiFi debug messages during startup and initial connection to your router, but there should be no more after that. If the disconnect occurs again, look at the console on the PC to see whether any more debug messages have been received, and report what you find.
                                      • vpundefined
                                        vp
                                        When i type M915 in the g-code console in the web interface
                                        only the 1st 3 drivers are listed, see below. I have 9 drivers. Is that the way it should be ?
                                        M915
                                        Driver 0: stall threshold -10, filter on, steps/sec 200, coolstep 0, action: none
                                        Driver 1: stall threshold -10, filter on, steps/sec 200, coolstep 0, action: none
                                        Driver 2: stall threshold -10, filter on, steps/sec 200, coolstep 0, action: none
                                        Driver 3:
                                          T-Printer
                                          HI DC42
                                          This from my WiFi debug.
                                          Connecting…
                                          Printer is now online.
                                          M111 S1 P14
                                          SENDING:M111 S1 P14
                                          Debugging enabled for modules: WiFi(14)
                                          Debugging disabled for modules: Platform(0) Network(1) Webserver(2) GCodes(3) Move(4) Heat(5) DDA(6) Roland(7) Scanner(8) PrintMonitor(9) Storage(10) PortControl(11) DuetExpansion(12) FilamentSensors(13)
                                          WiFi: bcn_timout,ap_probe_send_start
                                          WiFi reported error: Lost connection, auto reconnecting
                                          WiFi: ap_probe_send over, rest wifi status to disassoc
                                          WiFi: state: 5 -> 0 (1)
                                          WiFi: rm 0
                                          WiFi: pm close 7
                                          WiFi: scandone
                                          WiFi: state: 0 -> 2 (b0)
                                          WiFi: state: 2 -> 3 (0)
                                          WiFi: state: 3 -> 5 (10)
                                          WiFi: add 0
                                          WiFi: aid 9
                                          WiFi: cnt
                                          WiFi:
                                          WiFi: connected with Nordbygaard, channel 1
                                          WiFi: dhcp client start...
                                          WiFi reported error: Auto reconnect succeeded
                                          WiFi: ip:192.168.1.162,mask:255.255.255.0,gw:192.168.1.1
                                          WiFi: pm open,type:2 0
                                          WiFi: rm 0
                                          WiFi: pm close 7
                                          WiFi: scandone
                                          WiFi: add 0
                                          WiFi: aid 9
                                          WiFi: cnt
                                          WiFi:
                                          WiFi: rm 0
                                          WiFi: pm close 7
                                          WiFi: scandone
                                          WiFi: add 0
                                          WiFi: aid 9
                                          WiFi: cnt
                                          WiFi:
                                          WiFi: rm 0
                                          WiFi: pm close 7
                                          WiFi: scandone
                                          WiFi: add 0
                                          WiFi: aid 9
                                          WiFi: cnt
                                          WiFi:
                                          WiFi: rm 0
                                          WiFi: scandone
                                          WiFi: add 0
                                          WiFi: aid 9
                                          WiFi: cnt
                                          WiFi:
                                          WiFi: rm 0
                                          WiFi: pm close 7
                                          WiFi: scandone
                                          WiFi: add 0
                                          WiFi: aid 9
                                          WiFi: cnt
                                          WiFi:
                                          WiFi: rm 0
                                          WiFi: scandone
                                          WiFi: add 0
                                          WiFi: aid 9
                                          WiFi: cnt
                                          WiFi:
                                          WiFi: rm 0
                                          WiFi: scandone
                                          WiFi: add 0
                                          WiFi: aid 9
                                          WiFi: cnt
                                          WiFi:
                                          WiFi: rm 0
                                          WiFi: scandone
                                          WiFi: add 0
                                          WiFi: aid 9
                                          WiFi: cnt
                                          WiFi:
                                          WiFi: rm 0
                                          WiFi: pm close 7
                                          WiFi: scandone
                                          WiFi: add 0
                                          WiFi: aid 9
                                          WiFi: cnt
                                          WiFi:
                                          WiFi: rm 0
                                          WiFi: scandone
                                          WiFi: add 0
                                          WiFi: aid 9
                                          WiFi: cnt
                                          WiFi:
                                          WiFi: rm 0
                                          WiFi: pm close 7
                                          WiFi: scandone
                                          WiFi: add 0
                                          WiFi: aid 9
                                          WiFi: cnt
                                          WiFi:
                                          WiFi: rm 0
                                          WiFi: pm close 7
                                          WiFi: scandone
                                          WiFi: add 0
                                          WiFi: aid 9
                                          WiFi: cnt
                                          WiFi:
                                            @vp:
                                            M915
                                            Driver 3:
                                            There is a limit on the response length for normal replies. You can use M915 D0, M915 D1 etc. to get status for individual drives.
