    New firmware 1.20 Release Candidate 2 - please try it!
    Firmware installation
    30
    97
    15.5k
      @Forgvn77:
      Pause print and resume failed for me from the PanelDue. The hot end resumed extruding a couple layers above the print. Running 1.20RC2 and latest DWC release candidate,
      Thanks for the feedback. I'll test pause/resume again.
        @Gosu:
        i updated from RC1 to RC2 then it stopped running with wifi and i used the new www file to fix the problem
        now i can only control my printer via wifi for 5 minutes(with constant disconnects) and i was able to start a print
        but the printer stopped beeing able to connect via webhost
        only seldomly beeing able to connect
        i would love to post my current version but it wont let me connect
        its FW RC2
        Wifi Beta10 i believe
        and RC3 Webclient
        Did you install DuetWiFiFirmware twice as recommended in the upgrade notes?
        • AS-3D Druckundefined
          AS-3D Druck
          The Dark Theme on the new Webcontol is a little bit wrong. 😉
          Screenshot:
          https://gyazo.com/5d01aed4163234081552f63a99b2f76c
          Best regards
          AS-3D Druck / Andre
            @AS-3D:
            Screenshot:
            Try updating DWC to 1.20RC3.
              AS-3D Druck
              @dc42:
              @AS-3D:
              Screenshot:
              There is no DWC 1.20RC3 here: https://github.com/dc42/RepRapFirmware/tree/dev/Release/Duet-WiFi/Edge
              or here: https://github.com/chrishamm/DuetWebControl
              //Edite
              THX now i found it (Duet Wifi): https://github.com/dc42/RepRapFirmware/blob/dev/Release/Duet-WiFi/Edge/DuetWebControl-1.20-RC3.zip
              Best regards
              AS-3D Druck / Andre
                I've just released 1.20RC3. This has only minor changes from 1.20RC2.
                The following have been reported in this thread:
                1. "Starting with Beta11, with the M584 changes, with the U axis hidden if I run G29 the printer starts probing, but after the first row the U drive, which is my second Z motor starts moving up rather than down."
                I thought I had asked for more detail about this issue, but it looks like I didn't. Has anyone else seens a similar issue? Hiding the U axis should make no difference to the behaviour of the Z axis, but it will prevent explicit U moves being made.
                2. Various WiFi disconnection issues. Please note the instructions to install DuetWiFiServer-1.20b10 twice. You can use older DuetWiFiServer versions with RRF 1.20RC3 if necessary, but if you do then the M587 command to list configured wifi networks may not work. I expect to have DuetWiFiServer 1.20beta11 available early next week.
                3. A report that pause/resume caused the print to resume too high. I have tested this on 2 printers and I can't reproduce it.
                4. Various DWC issues, which I believed are resolved in DWC 1.20-RC3.
                  AS-3D Druck
                  I got a Problem to open a Directory on G-Code Files:
                  [[language]]
                  A JavaScript error has occurred so the web interface has closed the connection to your board. It is recommended to reload the web interface now. If this happens again, please contact the author and share this error message:
                  Version: 1.20-RC3
                  Message: Uncaught TypeError: Cannot read property 'match' of undefined
                  URL: http://d-bot.local/js/dwc.js
                  Line: 2015:27
                  Error object: {}
                  Only this Directory makes Problemes everything else works.
                  Best regards
                  AS-3D Druck / Andre
                    deckingman
                    @dc42:
                    Some have been resolved but the extruder position issue that I reported above is still outstanding.
                    • Gone2Farundefined
                      Gone2Far
                      @dc42:
                      @Gone2Far:
                      Admittedly I do not stress the Duet much, but FWIW, RC2 is working well for me.
                      Thanks for the feedback! Which Duet do you have?
                      Duet WiFi, with smart effector and 7" panel due.
                      Original Prusa i3 MK2S
                      Large Kossel Homebrew
                        @AS-3D:
                        [[language]]
                        Version: 1.20-RC3
                        Line: 2015:27
                        Error object: {}
                        Is there anything unusual about that directory, for example its name?
                        • Dougal1957undefined
                          Dougal1957
                          @dc42:
                          I've just released 1.20RC3. This has only minor changes from 1.20RC3.
                          David
                          A Couple of Typos first in this post first line V1.20RC3 has minor changes to 1.20RC3
                          And in the changeling latest release titled as 1.20RC2
                          Doug
                          • T-Printerundefined
                            T-Printer
                            I still have at lot of Communication Error (before with 1.18, ther was no problems with the WiFi)
                            DuetWiFiServer ver. 1.20B10 Install twice as DC42 say 🙂
                            Web Interface ver. 1.20-RC3
                            Duet FirmWare ver. 1.20RC3
                            My Wifi ruter is a ASUS RT-AC87U, and is firmware is up to date. good signal -55
                            It just go on and off. On the Paneldue is say Wifi Reported Error Lost Connection Auto Reconnect, and Auto Reconnect Succeeded about every 1 - 2 min
                            On the webinterface most of the time, I have Communication Error, then I can reconect, but after Max 1min I am off aging..
                            Anny solution to this?
                            Kent
                              AS-3D Druck
                              @dc42:
                              @AS-3D:
                              [[language]]
                              Version: 1.20-RC3
                              Line: 2015:27
                              Error object: {}
                              Got it, i used letters like äüß and he converted that to strange Symbols.
                              After renaming everything works again.
                              Best regards
                              AS-3D Druck / Andre
                                @Dougal1957:
                                Doug
                                Thanks, I've corrected those.
                                  @T-Printer:
                                  Kent
                                  Please can you and anyone else experiencing WiFi disconnection issues do this. Connect a PC via USB and send M111 S1 P14 to enable the WiFi debugging feature. You will get a few WiFi debug messages during startup and initial connection to your router, but there should be no more after that. If the disconnect occurs again, look at the console on the PC to see whether any more debug messages have been received, and report what you find.
                                  • vpundefined
                                    vp
                                    When i type M915 in the g-code console in the web interface
                                    only the 1st 3 drivers are listed, see below. I have 9 drivers. Is that the way it should be ?
                                    M915
                                    Driver 0: stall threshold -10, filter on, steps/sec 200, coolstep 0, action: none
                                    Driver 1: stall threshold -10, filter on, steps/sec 200, coolstep 0, action: none
                                    Driver 2: stall threshold -10, filter on, steps/sec 200, coolstep 0, action: none
                                    Driver 3:
                                      T-Printer
                                      HI DC42
                                      This from my WiFi debug.
                                      Connecting…
                                      Printer is now online.
                                      M111 S1 P14
                                      SENDING:M111 S1 P14
                                      Debugging enabled for modules: WiFi(14)
                                      Debugging disabled for modules: Platform(0) Network(1) Webserver(2) GCodes(3) Move(4) Heat(5) DDA(6) Roland(7) Scanner(8) PrintMonitor(9) Storage(10) PortControl(11) DuetExpansion(12) FilamentSensors(13)
                                      WiFi: bcn_timout,ap_probe_send_start
                                      WiFi reported error: Lost connection, auto reconnecting
                                      WiFi: ap_probe_send over, rest wifi status to disassoc
                                      WiFi: state: 5 -> 0 (1)
                                      WiFi: rm 0
                                      WiFi: pm close 7
                                      WiFi: scandone
                                      WiFi: state: 0 -> 2 (b0)
                                      WiFi: state: 2 -> 3 (0)
                                      WiFi: state: 3 -> 5 (10)
                                      WiFi: add 0
                                      WiFi: aid 9
                                      WiFi: cnt
                                      WiFi:
                                      WiFi: connected with Nordbygaard, channel 1
                                      WiFi: dhcp client start...
                                      WiFi reported error: Auto reconnect succeeded
                                      WiFi: ip:192.168.1.162,mask:255.255.255.0,gw:192.168.1.1
                                      WiFi: pm open,type:2 0
                                      WiFi: rm 0
                                      WiFi: pm close 7
                                      WiFi: scandone
                                      WiFi: add 0
                                      WiFi: aid 9
                                      WiFi: cnt
                                      WiFi:
                                      WiFi: rm 0
                                      WiFi: pm close 7
                                      WiFi: scandone
                                      WiFi: add 0
                                      WiFi: aid 9
                                      WiFi: cnt
                                      WiFi:
                                      WiFi: rm 0
                                      WiFi: pm close 7
                                      WiFi: scandone
                                      WiFi: add 0
                                      WiFi: aid 9
                                      WiFi: cnt
                                      WiFi:
                                      WiFi: rm 0
                                      WiFi: scandone
                                      WiFi: add 0
                                      WiFi: aid 9
                                      WiFi: cnt
                                      WiFi:
                                      WiFi: rm 0
                                      WiFi: pm close 7
                                      WiFi: scandone
                                      WiFi: add 0
                                      WiFi: aid 9
                                      WiFi: cnt
                                      WiFi:
                                      WiFi: rm 0
                                      WiFi: scandone
                                      WiFi: add 0
                                      WiFi: aid 9
                                      WiFi: cnt
                                      WiFi:
                                      WiFi: rm 0
                                      WiFi: scandone
                                      WiFi: add 0
                                      WiFi: aid 9
                                      WiFi: cnt
                                      WiFi:
                                      WiFi: rm 0
                                      WiFi: scandone
                                      WiFi: add 0
                                      WiFi: aid 9
                                      WiFi: cnt
                                      WiFi:
                                      WiFi: rm 0
                                      WiFi: pm close 7
                                      WiFi: scandone
                                      WiFi: add 0
                                      WiFi: aid 9
                                      WiFi: cnt
                                      WiFi:
                                      WiFi: rm 0
                                      WiFi: scandone
                                      WiFi: add 0
                                      WiFi: aid 9
                                      WiFi: cnt
                                      WiFi:
                                      WiFi: rm 0
                                      WiFi: pm close 7
                                      WiFi: scandone
                                      WiFi: add 0
                                      WiFi: aid 9
                                      WiFi: cnt
                                      WiFi:
                                      WiFi: rm 0
                                      WiFi: pm close 7
                                      WiFi: scandone
                                      WiFi: add 0
                                      WiFi: aid 9
                                      WiFi: cnt
                                      WiFi:
                                        @vp:
                                        M915
                                        Driver 3:
                                        There is a limit on the response length for normal replies. You can use M915 D0, M915 D1 etc. to get status for individual drives.
                                          @T-Printer:
                                          HI DC42
                                          Connecting…
                                          M111 S1 P14
                                          SENDING:M111 S1 P14
                                          WiFi: rm 0
                                          WiFi: pm close 7
                                          WiFi: scandone
                                          WiFi: add 0
                                          WiFi: aid 9
                                          WiFi: cnt
                                          WiFi:
                                          Thanks. Apart from an unusual number of disconnections, i don't see anything wrong in those messages. Can you try changing your WiFi router to a different channel? There were some reports a while ago that channel 1 didn't work very well.
                                            deckingman
                                            I just ran simulation mode on a 2MB file that will use 473,819.3mm of filament. It was sliced with a 0,9mm nozzle, 0.7mm layer height at 20mm/sec print speed. The simulation reckons it'll be printed in 1 minute and 1 second. (I wish).
                                            Firmware Name: RepRapFirmware for Duet Ethernet
                                            Firmware Electronics: Duet Ethernet 1.0 + DueX5
                                            Firmware Version: 1.20RC2 (2017-12-13)
                                            Web Interface Version: 1.20-RC3
                                            Edit. Ignore all that - it was me being stupid (no change there then) 🙂
