    cannot connect to duet 2 Wi-Fi or board
    5.5k
    • Blunt2007undefined
      Blunt2007 @droftarts
      @droftarts I'm sorry I'm just so frustrated I just wanted to work
        T3P3Tony administrators @Blunt2007
        @Blunt2007 sorry you have been having issues with the configuration. We already provided a warranty replacement and this makes it clear its not a hardware issue but a issue with configuration. Please review the documentation, for example you asked about changing WIFI channel:
        https://docs.duet3d.com/en/User_manual/Troubleshooting/WiFi_troubleshooting
        As you can see, a wifi router sets the wifi channel in use, not the client:
        • Try changing the channel on your WiFi router. Most routers default to Auto, but can be set to use a fixed channel instead. The channels overlap, so it is common to use channel 1, 6 or 11. This may also help if another device is causing interference.
        • Particularly if using channel 1, change the router WiFi channel. Duets with onboard WiFi antennas may be more susceptible to interference from the Duet itself at this frequency. Try channel 6 or 11.
        Blunt2007undefined 2 Replies Last reply Reply Quote 0
          Blunt2007 @T3P3Tony
          @T3P3Tony yeah I know you guys replaced the previous board and this board was working good for a while but now it will not connect to the Wi-Fi and from the beginning it wouldn't connect to USB if I turn the machine off and then turn it back on it loses its Wi-Fi if I reload runonce.g it will connect to the Wi-Fi again but if I turn the machine off it will not reconnect to Wi-Fi unless I reload runonce.g then it will reconnect to Wi-Fi but as soon as I turn the machine off it will not connect to Wi-Fi this board was not working properly from the beginning because it would not connect to USB this board was working correctly except it would not connect to USB from the beginning so this board is messed up it is a default board from the beginning because it would not connect USB so clearly this board is a default board from the beginning it will connect to USB if I push the reset button but as soon as I disconnect it and try reconnecting it it will not connect to USB unless I push the reset button so clearly this board was default from the beginning and I was trying to work with you guys to get this going and it did work for a little while but now it's not connecting to you to Wi-Fi are you guys going to back up your product or not
            Blunt2007 @T3P3Tony
            @T3P3Tony I am willing to look into buying a new router what router do you recommend that works with this product just to make sure that it is not my hardware
              droftarts administrators @Blunt2007
              @Blunt2007 We're a bit confused about the board replacement. We don't have any record of you submitting a warranty request, at least not from the name and email address you registered with. From where and when did you buy the original board?
              If you did replace the board, I find it very unlikely that you would get two boards that exhibit exactly the same problem. Did you send back the original board before receiving the replacement, or is it possible you could have kept the original board by mistake?
              Please can you post a picture of the whole board, if possible.
              What make and model of router are you currently using? It may be that there is a setting that continually tries to force the Duet to use 5GHz WiFi, but the Duet can only do 2.5GHz WiFi.
              Blunt2007undefined 3 Replies Last reply Reply Quote 0
                ![17079268194356958301088299834109.jpg](Request Entity Too Large) ![17079264559383776398370068987908.jpg](Request Entity Too Large) @droftarts The new board would not connect by USB from the beginning so I did load runonce.g to the system file and I was able to connect buy Wi-Fi to the board and I was configuring the board but just recently I was not able to connect by Wi-Fi it was working fine but now it will not connect by Wi-Fi to the board I mailed the old board on June 28th 2024 I will include a picture of the drop off slip. The new board is set to channel 10 and it is running at 2.4 G and I'm still not able to connect via Wi-Fi! I purchased the original board from printed![1707926955140444270627850315521.jpg](Request Entity Too Large) solid
                [17079263815565014596051133997642.jpg](Request Entity Too Large)
                  @droftarts I purchased the original board from printedsolid
                    @Blunt2007 said in cannot connect to duet 2 Wi-Fi or board:
                    Okay, I'll ask @Phaedrux to check that.
                    When connected via USB, do you still see the Duet in the device manager? If so, can you right click on it, and take a screenshot of the properties?
                    For the WiFi, have you set the router channel to 10 on the router? It is not something that the Duet can force, it has to come from the router. When you try to connect via WiFi, does it just not connect and result in a blank screen, or do you get some other message? Again, a screenshot may be useful.
                    Blunt2007undefined 1 Reply Last reply Reply Quote 0
                      @droftarts Yes on the router it is set to channel 10 at 2.4 I sent you a picture of the router connection and yes via USB it comes up in the Device Manager as duet![17079303616003203406867574172911.jpg](Request Entity Too Large)
                        Blunt2007 @Blunt2007
                        @Blunt2007 ![1707930945074619340256192983025.jpg](Request Entity Too Large)
                          @Blunt2007 please repost your pictures in a size <4mbs so they upload.
                            Blunt2007 @T3P3Tony
                            @T3P3Tony The resolution that I'm uploading them with is the lowest that's my phone will take the photo in I uploaded them before with some help I don't have a photo editor
                            Sorry that's the best I can do right this time
                            • oliofundefined
                              oliof @Blunt2007
                              @Blunt2007 take a screenshot and post that
                                @droftarts I'm sorry My misunderstanding I did not know I needed to open a new ticket with this new board so I contacted printed solid to open a new ticket 42307
                                  Did Printed Solid replace your board already?
                                  • Phaedruxundefined Phaedrux referenced this topic
                                    Blunt2007 @Phaedrux
                                    @Phaedrux Yes Prince solutions already replaced the board this is a new board and I'm still not able to connect USB and the Wi-Fi will not connect to duet web connect and if I do connect it loses signal and will not reconnect
                                      Blunt2007 @Phaedrux
                                      @Phaedrux wow it's connected today so I'm going to try running some updates and level in my bed with a BL touch
                                        Blunt2007 @Phaedrux
                                        @Phaedrux having problem connecting to duet Web connect it was working fine for the 2 weeks and I printed a calibration cube and it came out pretty good I had to take two weeks off to take care of my dad and now I'm trying to reconnect to duet web connect and now it will not connect I tried turning off the board turning it back on I tried turning off the computer rebooting the computer several times I tried turning off Wi-Fi and turn it back on no matter what I do it will not connect to the wet web connect
                                          Can you remind me if you were able to get a USB terminal connection going through the YAT software?
                                          https://docs.duet3d.com/en/How_to_guides/Getting_connected/Getting_connected_to_your_Duet#h-2-connect-your-duet-via-usb
                                            Blunt2007 @Phaedrux
                                            @Phaedrux no I had never had been able to connect via USB since I got the board I had to add a file to systems with my Wi-Fi information I haven't tried that yet this time I figured it was working fine when I last used it but now it doesn't work at all no matter what I do I cannot connect to duet web connect
