    New firmware 1.20 Release Candidate 2 - please try it!
    Firmware installation
    30
    97
    15.4k
    • T-Printerundefined
      T-Printer
      I still have at lot of Communication Error (before with 1.18, ther was no problems with the WiFi)
      DuetWiFiServer ver. 1.20B10 Install twice as DC42 say 🙂
      Web Interface ver. 1.20-RC3
      Duet FirmWare ver. 1.20RC3
      My Wifi ruter is a ASUS RT-AC87U, and is firmware is up to date. good signal -55
      It just go on and off. On the Paneldue is say Wifi Reported Error Lost Connection Auto Reconnect, and Auto Reconnect Succeeded about every 1 - 2 min
      On the webinterface most of the time, I have Communication Error, then I can reconect, but after Max 1min I am off aging..
      Anny solution to this?
      Kent
      • AS-3D Druckundefined
        AS-3D Druck
        @dc42:
        @AS-3D:
        I got a Problem to open a Directory on G-Code Files:
        [[language]]
        A JavaScript error has occurred so the web interface has closed the connection to your board. It is recommended to reload the web interface now. If this happens again, please contact the author and share this error message:
        Version: 1.20-RC3
        Message: Uncaught TypeError: Cannot read property 'match' of undefined
        URL: http://d-bot.local/js/dwc.js
        Line: 2015:27
        Error object: {}
        Only this Directory makes Problemes everything else works.
        Is there anything unusual about that directory, for example its name?
        Got it, i used letters like äüß and he converted that to strange Symbols.
        After renaming everything works again.
        Best regards
        AS-3D Druck / Andre
          @Dougal1957:
          A Couple of Typos first in this post first line V1.20RC3 has minor changes to 1.20RC3
          And in the changeling latest release titled as 1.20RC2
          Doug
          Thanks, I've corrected those.
            @T-Printer:
            Kent
            Please can you and anyone else experiencing WiFi disconnection issues do this. Connect a PC via USB and send M111 S1 P14 to enable the WiFi debugging feature. You will get a few WiFi debug messages during startup and initial connection to your router, but there should be no more after that. If the disconnect occurs again, look at the console on the PC to see whether any more debug messages have been received, and report what you find.
            • vpundefined
              vp
              When i type M915 in the g-code console in the web interface
              only the 1st 3 drivers are listed, see below. I have 9 drivers. Is that the way it should be ?
              M915
              Driver 0: stall threshold -10, filter on, steps/sec 200, coolstep 0, action: none
              Driver 1: stall threshold -10, filter on, steps/sec 200, coolstep 0, action: none
              Driver 2: stall threshold -10, filter on, steps/sec 200, coolstep 0, action: none
              Driver 3:
                T-Printer
                HI DC42
                This from my WiFi debug.
                Connecting…
                Printer is now online.
                M111 S1 P14
                SENDING:M111 S1 P14
                Debugging enabled for modules: WiFi(14)
                Debugging disabled for modules: Platform(0) Network(1) Webserver(2) GCodes(3) Move(4) Heat(5) DDA(6) Roland(7) Scanner(8) PrintMonitor(9) Storage(10) PortControl(11) DuetExpansion(12) FilamentSensors(13)
                WiFi: bcn_timout,ap_probe_send_start
                WiFi reported error: Lost connection, auto reconnecting
                WiFi: ap_probe_send over, rest wifi status to disassoc
                WiFi: state: 5 -> 0 (1)
                WiFi: rm 0
                WiFi: pm close 7
                WiFi: scandone
                WiFi: state: 0 -> 2 (b0)
                WiFi: state: 2 -> 3 (0)
                WiFi: state: 3 -> 5 (10)
                WiFi: add 0
                WiFi: aid 9
                WiFi: cnt
                WiFi:
                WiFi: connected with Nordbygaard, channel 1
                WiFi: dhcp client start...
                WiFi reported error: Auto reconnect succeeded
                WiFi: ip:192.168.1.162,mask:255.255.255.0,gw:192.168.1.1
                WiFi: pm open,type:2 0
                WiFi: rm 0
                WiFi: pm close 7
                WiFi: scandone
                WiFi: add 0
                WiFi: aid 9
                WiFi: cnt
                WiFi:
                WiFi: rm 0
                WiFi: pm close 7
                WiFi: scandone
                WiFi: add 0
                WiFi: aid 9
                WiFi: cnt
                WiFi:
                WiFi: rm 0
                WiFi: pm close 7
                WiFi: scandone
                WiFi: add 0
                WiFi: aid 9
                WiFi: cnt
                WiFi:
                WiFi: rm 0
                WiFi: scandone
                WiFi: add 0
                WiFi: aid 9
                WiFi: cnt
                WiFi:
                WiFi: rm 0
                WiFi: pm close 7
                WiFi: scandone
                WiFi: add 0
                WiFi: aid 9
                WiFi: cnt
                WiFi:
                WiFi: rm 0
                WiFi: scandone
                WiFi: add 0
                WiFi: aid 9
                WiFi: cnt
                WiFi:
                WiFi: rm 0
                WiFi: scandone
                WiFi: add 0
                WiFi: aid 9
                WiFi: cnt
                WiFi:
                WiFi: rm 0
                WiFi: scandone
                WiFi: add 0
                WiFi: aid 9
                WiFi: cnt
                WiFi:
                WiFi: rm 0
                WiFi: pm close 7
                WiFi: scandone
                WiFi: add 0
                WiFi: aid 9
                WiFi: cnt
                WiFi:
                WiFi: rm 0
                WiFi: scandone
                WiFi: add 0
                WiFi: aid 9
                WiFi: cnt
                WiFi:
                WiFi: rm 0
                WiFi: pm close 7
                WiFi: scandone
                WiFi: add 0
                WiFi: aid 9
                WiFi: cnt
                WiFi:
                WiFi: rm 0
                WiFi: pm close 7
                WiFi: scandone
                WiFi: add 0
                WiFi: aid 9
                WiFi: cnt
                WiFi:
                  @vp:
                  M915
                  Driver 3:
                  There is a limit on the response length for normal replies. You can use M915 D0, M915 D1 etc. to get status for individual drives.
                    @T-Printer:
                    HI DC42
                    Connecting…
                    M111 S1 P14
                    SENDING:M111 S1 P14
                    WiFi: rm 0
                    WiFi: pm close 7
                    WiFi: scandone
                    WiFi: add 0
                    WiFi: aid 9
                    WiFi: cnt
                    WiFi:
                    Thanks. Apart from an unusual number of disconnections, i don't see anything wrong in those messages. Can you try changing your WiFi router to a different channel? There were some reports a while ago that channel 1 didn't work very well.
                      deckingman
                      I just ran simulation mode on a 2MB file that will use 473,819.3mm of filament. It was sliced with a 0,9mm nozzle, 0.7mm layer height at 20mm/sec print speed. The simulation reckons it'll be printed in 1 minute and 1 second. (I wish).
                      Firmware Name: RepRapFirmware for Duet Ethernet
                      Firmware Electronics: Duet Ethernet 1.0 + DueX5
                      Firmware Version: 1.20RC2 (2017-12-13)
                      Web Interface Version: 1.20-RC3
                      Edit. Ignore all that - it was me being stupid (no change there then) 🙂
                        T-Printer
                        Hi Dc42
                        I have try most of the channel on the WiFi router, but still the same, Some time after 1 hour, but then to go into a loop on / off. We dont have Any problems with other WiFi equipment on the 2.4G
                        Kent
                        • Iiraiundefined
                          Iirai
                          @dc42:
                          @Iirai:
                          When I try to connect to DWC I get this error:
                          Could not establish a connection to the Duet firmware! Please check your settings and try again.
                          I'm able to ping the DuetWiFi, wifi signal is -59, it's on a static Ip and I confirmed that the mac address is correct . Am I missing something obvious?
                          1. Did you install DuetWiFiServer.bin twice as suggested in the upgrade notes?
                          2. If you send M552 S1 from USB or PanelDue then it will report success/failure of the attempt to connect to your router.
                          M552 S1 from USB and PanelDue says connection the router. As far as I can tell everything sees each other and I can get on to DWC but it will not connect. 😞
                          DuetWiFiServer ver. 1.20B10 Installed twice(+)
                          DuetWifi HardWare ver. 1.0
                          Computer Engineering Student
                          Duet Wifi Delta 560mm W x 1000mm H; ; Print area 400mm circle by 300-360mm height
                          • StevenLundefined
                            StevenL
                            my Z height is now messed up. Yes I ran the macro to do a mesh level. even AFTER that, any print starts at a negative Z.
                            I try to raise the Z, but it gets delayed and then over compensated by me because of the delay.
                            • BMMalundefined
                              BMMal
                              This morning was the first time I've used M916. I had a heater fault due to a bad thermistor connection. After investigating, and clearing the faults, M916 worked as expected. I had to pause the print to fix something else and it did not run my pause.g (which would move the print head away, nor resume.g, which would rehome all axes etc. The machine stopped moving but only in the last position. Ultimately, I canceled the print and cancel.g was not run either. It seems that it is ignoring certain system files after M916.
                              Duet Ethernet - Most likely the most recent Edge firmware
                              Duet X5
                              7" Panel Due V2
                              Cartesian, 4 Nozzles with Flex3Drives, Heated Chamber, Simple Switch Filament Sensing
                              • Teilchenundefined
                                Teilchen
                                Does anybody else use FW1.20 with Duet 0.85 and DueX4?
                                With my hardware configuration FW1.20 doesn't even start up (it seem Duet is struggling to get an IP).
                                FW 1.19 runs with occasional resets (can happen even midprint).
                                FW 1.18.1 runs with no problems at all.
                                DC42 was mentioning too low memory with my config, but I have no idea what exactly is causing this issues.
                                • BMMalundefined
                                  BMMal
                                  Anyone using interpolation for the drivers notice a difference? I swear my machine is much louder now but I did move it so it's hard to tell for sure.
                                  Duet X5
                                  7" Panel Due V2
                                  • chrishammundefined
                                    chrishamm administrators
                                    @AS-3D:
                                    @dc42:
                                    @AS-3D:
                                    [[language]]
                                    Version: 1.20-RC3
                                    Line: 2015:27
                                    Error object: {}
                                    What browser were you using when this happened? I cannot reproduce it with Firefox and Chromium.
                                    Edit: Just found a possible cause for this, I'll fix that in the final v1.20.
                                    Duet software engineer
                                      @deckingman:
                                      @dc42:
                                      4. Various DWC issues, which I believed are resolved in DWC 1.20-RC3.
                                      Some have been resolved but the extruder position issue that I reported above is still outstanding.
                                      Ian, we're not sure whether this is a DWC issue or a RRF issue. So please can you set up a situation in which this issue is visible. Then send M408 S2 and M408 S3 and report the responses. Also report what DWC is displaying and what you think it should display instead.
                                      • o_lampeundefined
                                        o_lampe
                                        Just wanted to download 1.20RC3 but got confused, because all the directories are named 1.19RC3….
                                          @o_lampe:
                                          Which directories?
                                          • DaveAundefined
                                            DaveA
                                            @dc42:
                                            @o_lampe:
                                            Which directories?
                                            It can be a bit confusing:
                                            https://github.com/dc42/RepRapFirmware/tree/dev/Release/Duet-Ethernet/Edge
                                            Filename is DuetEthernetFirmware-1.20RC3.bin Version says: 1.19RC3
