    Continuous rotational axis
    CNC
    495
    • MaxGyverundefined
      MaxGyver @o_lampe
      @o_lampe
      Thank you for your suggestions. Unfortunately, I need a way to quickly adjust coolant flow during machining. Typing commands in the command line is just not practical. Furthermore, I would like to automatically adjust the coolant flow rate depending on the loaded tool.
      I have ordered another peristaltic pump that uses a 24V DC-Motor instead of a Stepper. My plan is to set it up as a fan in the firmware. This way I have can use the fanslider in DWC to manually adjust coolant flow as well as using gcode to set the flow dependent on the tool.
        Phaedrux Moderator @MaxGyver
        @MaxGyver said in Continuous rotational axis:
        how bout a macro?
        soare0undefined 1 Reply Last reply Reply Quote 0
        • soare0undefined
          soare0 @Phaedrux
          @Phaedrux Would a macro do it in ”real time”? He needs to use a flow sensor I guess, so probably the 24V DC motor is the best option, and the easiest, too, as the tacho input may be used for the flow sensor...
          I think that implementing this for a stepper, would be a nice addon to RRF.
          MaxGyverundefined 1 Reply Last reply Reply Quote 0
          • MaxGyverundefined
            MaxGyver @soare0
            Unfortunately, the DC peristaltic pump I ordered has far too high flow rate even at the slowest achievable speed. I recon this is why peristaltic pumps with stepper motors exist. The latter allows for super fine and repeatable dosing of fluids... exactly what I need for my minimal lubrication system.
            @Phaedrux
            I have tried setting up a simple while loop that would constantly progress the stepper axis while the coolant output is active. But the while loop blocks all other moves and commands until it is completed...
            while state.gpOut[2].pwm>0 & iterations<=50
                G91              ; relative
                G0 W{iterations} ; progress W-axis
                G90              ; absolute
                echo iterations
            It would be super handy if there was a command to just rotate a set a stepper at a certain Speed or RPM. The G0 command for the W axis could be something like G0 Waaa where aaa is the axis max speed set in M203.
            droftartsundefined soare0undefined o_lampeundefined 3 Replies Last reply Reply Quote 1
              droftarts administrators @MaxGyver
              @MaxGyver If you've got a Duet 3 and running latest RRF 3.5.0-rc.3, you can use the second motion queue for this. See
              https://docs.duet3d.com/en/User_manual/RepRapFirmware/Multiple_motion_systems
              https://docs.duet3d.com/en/User_manual/Reference/Gcodes#m596-select-movement-queue-number
              • soare0undefined
                soare0 @MaxGyver
                @MaxGyver
                1.You may try to use a 3 way valve to regulate the flow ratio? One way , of course would be a return flow, and the other, the working one.
                2.Still, the fact that actual flow is so high already, would not help too much to such a setup. In fact, one single flow regulator, and a free return path, may be a better idea.
                • MaxGyverundefined
                  MaxGyver @soare0
                  @soare0
                  Thats a good idea, I could just use the option to choose between for example "Flood" and "Mist" coolant in Fusion CAM to trigger different coolant flow rates for different tools.
                  My Plan B was to add a needle valve to the coolant line that can be adjusted by a RC-Servo... but the constant clogging problems with the needle valve of my FogBuster send me on this path in the first place. 😁
                  @droftarts
                  I have got a Duet 3 6XD and running RRF 3.5.0-rc.3, but did not manage to get the macro working on the second movement queue. The macro is supposed to run when the air solenoid is active -> state.gpOut[2].pwm>0 but it only stops when the maximum number of iterations is reached.
                  M596 P1              ; select movement queue number
                  M595 Q1 P10          ; lengthen movement queue to 10 elements
                  M564 H0              ; allow movement of axis that have not been homed
                  while state.gpOut[2].pwm>0 & iterations<=30
                      G91              ; relative
                      G90              ; absolute
                      G4 P100
                      echo iterations
                  soare0undefined T3P3Tonyundefined 2 Replies Last reply Reply Quote 0
                  • soare0undefined
                    soare0 @MaxGyver
                    I think a return path is mandatory, unless you adjust the motor speed, especially working with a needle valve. But as this depends on your pump configuration and such stuff...
                    I do not get how valve clogs, as usually one has some filtering system in place in front of the pump (and maybe another after), but the world is full of wonders...!
                    Tinkery weekend then....
                      T3P3Tony administrators @MaxGyver
                      @MaxGyver I have updated the FR for this with a reference to this thread:
                      https://github.com/Duet3D/RepRapFirmware/issues/780
                      T3P3 created this issue in Duet3D/RepRapFirmware
                      open Support configuring an axis as "continuous rotary" #780
                      • o_lampeundefined
                        o_lampe @MaxGyver
                        @MaxGyver I believe the most time consuming part in your macro is the echo iterations line?
                        //edit Just cobbled together my version of your macro, which I made bulletproof with brackets (CNC-mode expressions are different)
                        Also placed G91/G90 outside of the loop. No need to repeat those lines 30 times, I guess?
                        G91              ; relative
                        while {(iterations<=30)}
                        	if {(state.gpOut[2].pwm>0 )}
                        	     break
                            G4 P100
                         G90              ; absolute
                        • MaxGyverundefined MaxGyver referenced this topic
