    Storing temperature values to log file?
    Using Duet Controllers
    1.5k
    • whopping pochardundefined
      whopping pochard @T3P3Tony
      @T3P3Tony brilliant!! Thanks so much!
        whopping pochard
        Thanks for your help, everyone! We have automated heatbreak profiling! Woo!!
        Adamfilipundefined 1 Reply Last reply Reply Quote 2
        • Adamfilipundefined
          Adamfilip @whopping pochard
          @T3P3Tony anyway to log temps when printer is sitting idle?, not running a gcode file?
            T3P3Tony administrators @Adamfilip
            @adamfilip you could use daemon.g with a while loop to log in the same manner as above. make sure you have a G4 P500 each time the loop goes round to hand control back to the main process.
            Adamfilipundefined 1 Reply Last reply Reply Quote 1
              Adamfilip @T3P3Tony
              @t3p3tony Thank you
              • stefundefined
                stef @T3P3Tony
                @T3P3Tony Just to confirm both the M929 and M118 lines would be added to config.g, correct?
                  T3P3Tony administrators @stef
                  @stef M929 sets up logging and that makes sense to be in config.g assuming you want to log the whole time the printer is on.
                  M118 is the command to write explicitly to the log so that needs to be wherever you want to take the measutrement and insert into the log.
                  If you want it to happen every <n> seconds no matter what else is happening you can use deamon.g (with a while loop with G4 P500 or longer in between to ensure control is passed back).
                  stefundefined 1 Reply Last reply Reply Quote 0
                  • stefundefined
                    stef @T3P3Tony
                    @T3P3Tony Got it, thank you
                    Dizzwoldundefined 1 Reply Last reply Reply Quote 0
                    • Dizzwoldundefined
                      Dizzwold @stef
                      @stef @T3P3Tony @Adamfilip @engikeneer @jay_s_uk @whopping-pochard
                      M122
                      RepRapFirmware for Duet 3 MB6HC version 3.4.6 (2023-07-21 14:11:38) running on Duet 3 MB6HC v1.01 (standalone mode)
                      Board ID: 0JD2M-999AL-D25SW-6J9D0-3SD6M-9PY70
                      Used output buffers: 1 of 40 (20 max)
                      Hi Guys,
                      I appreciate this is an old thread and I'd like to do something similar, but not sure I fully understand it.
                      What I would like to do is take temperature readings every 20 seconds (or so), from a thermistor on (temp1), for the duration of a print and save them to a log/file or something like the heightmap.csv to look over at a later date. I only really need the temperatures.
                      I've tried putting both the suggested lines above in Config.g but all that seamed to do when I clicked save was immediately creat the file in /sys then start then stop a log.
                      Can I ask for your advice of what should actually go where or if there's another method to use?
                      Dizzwold.
                        jay_s_uk @Dizzwold
                        @Dizzwold
                        M929 P"mytemplog.txt" S1 ; start logging and only log warnings by default
                        would go in config.g
                        something like
                        while true && state.status == "processing"
                            M118 S{"Temp 1: " ^ sensors.analog[1].lastReading ^ " C"} L1
                            G4 S20
                        would go in daemon.g
                        That would only log the temperature while printing a file
                        Alternatively, BtnCMD allows you to setup a graph and export whatever it reports to a log file
                          T3P3Tony administrators @jay_s_uk
                          @Dizzwold as @jay_s_uk outlines uses the built in logging function. Alternatively if you want just the temperatures and never want any other warnings or other things that could be logged you can echo to a file from daemon.g in the same way:
                          https://docs.duet3d.com/en/User_manual/Reference/Gcode_meta_commands#echo-command
                              echo >>"templog.csv" {"Temp 1: " ^ sensors.analog[1].lastReading^ " C"} L1
                              G4 S20
                          (Or similar, not checked)
                          Dizzwoldundefined 1 Reply Last reply Reply Quote 1
                          • Dizzwoldundefined
                            Dizzwold @T3P3Tony
                            @T3P3Tony @jay_s_uk
                            Hi Guys,
                            Thank you for your direction I'll give them a try.
                            I'd already promised previously to look into the BtnCMD, but I really just haven't had the time. This is actually going to be my first print with the Cast Toolplate I've been on about for the last 2 if not 3 years.
                            Daemon.g;
                            I know very little about this, but with a quick goggle I understand it's to do with running a clock from the MCU in the background.
                            So this has to be called "daemon.g in the /sys directory?
                            Can you have more than one daemon.g in the /sys directory as I've seen it mentioned before with something else I read, and would you just number them?
                            daemon1.g
                            daemon2.g
                            etc
                            I don't even know if your need more than one to be fair, just asking?
                              jay_s_uk @Dizzwold
                              @Dizzwold you can only have one daemon.g file
                              • Dizzwoldundefined
                                Dizzwold @jay_s_uk
                                @jay_s_uk
                                Okay, thank you.
                                Hmm, It's working but seems to be reading the wrong sensor. Temp1, which is what it is reading and documenting, is this T1 in my config.g?
                                It's basically reading the nozzle temp in the log at around 203˚C. I have the sensor I want to read in-between the fan and the heatsink on my Matrix extruder, "(he chamber heater below). In the graph it shows as around 40 ish ˚C ?
                                I have the following in my config.g on my 6HC board;
                                M308 S0 P"temp0" Y"thermistor" T100000 B4138       ; configure sensor 0 as thermistor on pin temp0
                                M950 H0 C"out0" T0                                 ; create bed heater output on out0 and map it to sensor 0
                                M307 H0 R0.187 K0.192:0.000 D1.89 E1.35 S1.00 B0   ; disable bang-bang mode for the bed heater and set PWM limit
                                M140 H0                                            ; map heated bed to heater 0
                                M143 H0 S120                                       ; set temperature limit for heater 0 to 120C
                                M308 S1 P"121.temp0" Y"thermistor" T100000 B4138       ; configure sensor 1 as thermistor on pin temp1
                                M950 H1 C"121.out0" T1                                 ; create nozzle heater output on out1 and map it to sensor 1
                                M307 H1 R2.498 K0.275:0.349 D6.79 E1.35 S1.00 B0 V24.0  ; disable bang-bang mode for heater  and set PWM limit
                                M143 H1 S280                                       ; set temperature limit for heater 1 to 280C
                                ; Sensors
                                M308 S2 P"temp1" Y"thermistor" A"Chamber Temp"T100000 B4138
                                The very bottom "sensor" temp1 chamber heater is what I'd like to read.
                                But hey, I'm printing again and with my cast toolplate with pei sheet and mains heater. Hip-Hip-Hooray
                                It is printing so sweet.
                                It's not fully trammed yet, as I can't afford the new framework yet to enable doing so, but it's the best I can do for now.
                                ![Screen Shot 2024-02-28 at 11.00.20.png](Request Entity Too Large)
                                Dizzwold
                                jay_s_ukundefined T3P3Tonyundefined 2 Replies Last reply Reply Quote 0
                                  jay_s_uk @Dizzwold
                                  @Dizzwold you can check which sensor is what in the object model using the object model plugin
                                    T3P3Tony administrators @Dizzwold
                                    @Dizzwold said in Storing temperature values to log file?:
                                    thats temperature sensor number 2
                                    • Dizzwoldundefined
                                      Dizzwold @T3P3Tony
                                      @T3P3Tony @jay_s_uk
                                      Hi Guys,
                                      Thank you for that.
                                      Ah, okay, so I'm taking the information for the sensor from the S2 part of the config.g rather than the actual board input connection "Temp1".
                                      Edit.
                                      Which I beleieve means changing;
                                      M118 S{"Message to Show: " ^ sensors.analog[1].lastReading ^ " C"} L1
                                      to
                                      M118 S{"Temp 2: " ^ sensors.analog[2].lastReading ^ " C"} L1
                                      Thank you again for your help and advice.
                                      Dizzwold.
