    PID Tuning Procedure
    2.8k
    • CarlBossonundefined
      CarlBosson @Phaedrux
      @Phaedrux Here are my attempts to restart the wifi below
      • WiFi -
        Network state is starting2
        WiFi module is disabled
        Failed messages: pending 0, notready 1, noresp 0
        ok
        M552
        WiFi module is being started
        ok
        M552
        ok
        M552
        ok
        M552 S-1
        WiFi module stopped
        ok
        M552
        ok
        M552 S0
        ok
        M552
        ok
        M587
        Failed to retrieve network list: another SPI transfer is pending
        ok
      There is no box!
        Try sending these commands to reflash the wifi module as it sounds like it may have failed on 3.3 which has happened before. Make sure you have the wifiserver bin file in the new firmwares folder.
        M552 S-1
        M552 S0
        M997 S1
        M552 S1
        CarlBossonundefined 1 Reply Last reply Reply Quote 0
          @Phaedrux I am sorry, I did not see that you posted yesterday. I will work on this this afternoon and supply feedback.
          I also completed the RepRap firrmwareconfigtool you suggested and have it saved but not yet installed. do I upload that into the system folder the same way as the firmware updates?
          Carl
          There is no box!
            Yes at the end of the config tool process you can download your config files as a zip file. Upload that zip file to the system tab in DWC to install them. Backup your SD card first if you want to preserve your existing configuration files.
            CarlBossonundefined 2 Replies Last reply Reply Quote 0
              @Phaedrux
              I have connected via YAT and USB. Keyed in M552 S0 and get the following:
              M552 S1
              Turn off the current WiFi mode before selecting a new one
              ok
              I backed up the SD Card yesterday in preparation.
              There is no box!
                @Phaedrux
                I am still at a complete stand still here. Were you waiting for input from me?
                Carl
                There is no box!
                  Phaedrux Moderator @CarlBosson
                  @CarlBosson said in PID Tuning Procedure:
                  Yes. Have you sent these commands and what is the output of each?
                  M552 S-1
                  M552 S0
                  M552 S1
                  M997 S1
                  CarlBossonundefined 3 Replies Last reply Reply Quote 0
                    @Phaedrux
                    I sent the first command in the list M552 S1 and the response was as follows, see below. In this case I stopped at this point because this seemed to be a problem. Tonight when I get home I will enter each command and post each response. I feel like if we could get the Wi-fi working that would be 90% of the battle. Thank you for your help.
                    "M552 S1
                    Turn off the current Wi-Fi mode before selecting a new one
                    ok"
                    Carl
                    There is no box!
                    • oliofundefined
                      oliof @CarlBosson
                      @CarlBosson the first command in the list is
                      M552 S-1 (S minus one)
                      that disables the wifi
                        @Phaedrux said in PID Tuning Procedure:
                        M552 S-1
                        WiFi Module stopped
                        ok
                        M552 S0
                        ok
                        M552 S1
                        WiFi module stopped
                        ok
                        M997 S1
                        Error: M997: File 0:/firmware/duetwifiServer.bin not found
                        ok
                        Here are the responses to the commands you asked me to send. Se above.
                        There is no box!
                          @Phaedrux
                          I think I am going to buy a Panel Due i7. At least for now this will eliminate the issues with the wi-fi. Can you support this decision?
                          There is no box!
                          • oliofundefined
                            oliof @CarlBosson
                            @CarlBosson have you tried putting the DuetWifiServer.bin file in to the right directory? It looks like the module reacts and you have a way to submit the right commands.
                            A PanelDue will allow you to use the machine, but you will lose a lot of convenience compared to using DuetWebControl the least being able to upload files for printing and remote control.
                              CarlBosson @oliof
                              @oliof Ok well I will listen to advice :). I do very much like the DWC setup. are you saying it's either panel due , or DWC? They can not be used together? meaning can I heat up the printer and up load .gcode files at my PC, then walk over to the printer and use the panel due to move axis and run macros?
                              The only problem I have with the DWC is this frustrating wi-fi connection. It is due to my ignorance for sure. If I could get this setup to connect reliably to my work and home network I would be a happy guy!
                              Carl
                              There is no box!
                                T3P3Tony administrators @CarlBosson
                                @CarlBosson they can be used together. The PanelDue gives you an interface directly connected to the machine but its more limited that DWC
                                  M997 S1
                                  Place this file in the firmware folder on the SD card and send M997 S1 again.
                                  https://github.com/Duet3D/RepRapFirmware/releases/download/3.3/DuetWiFiServer.bin
                                    @Phaedrux
                                    Here is what I get.
                                    M997 S1
                                    Error: M997: File 0:/firmware/DuetWiFiServer.bin not found
                                    ok
                                    There is no box!
                                      And you're sure the file is present in the folder?
                                      Is it also present in the sys folder?
                                      Is DWC also updated to 3.3?
                                      It wouldn't hurt to re-download the 3.3 zip file and upload it via DWC again and have it attempt to reflash and update everything. Don't extract it first.
                                      https://github.com/Duet3D/RepRapFirmware/releases/download/3.3/Duet2and3Firmware-3.3.zip
                                        @Phaedrux
                                        My biggest problem right now is that without Wi-Fi access I have no access to the DWC. It is getting late tonight. i will look at all this again in the morning. Sorry to be a bother. Thank you for the help.
                                        Carl
                                        There is no box!
                                          @Phaedrux
                                          I backed up the SD card from the control board on 3/2/24 and these are the directories that were on it:
                                          GCodes
                                          macros
                                          sys
                                          www
                                          DuetDriverFiles.zip
                                          Yesterday when you asked me to "Place this file in the firmware folder on the SD card and send M997 S1 again." I did not see a "firmware folder" so I placed the file on the SD card with these other directories. When that failed, I looked a little deeper and found some firmware files in the SYS directory. So the second time I placed this file in the sys directory. This still failed.
                                          See below a screen shot of the directories on the SD Card, and a screen shot of the files and directories in the SYS directory.
                                          There is no box!
                                            Create a folder named firmware and put the file there. Then send M997 S1 again.
                                            CarlBossonundefined 1 Reply Last reply Reply Quote 1
