    Jerk & acceleration value change after Resume APF
    Beta Firmware
    592
      T3P3Tony administrators @R006
      @R006 to be clear, the reported values after a restore after power failure are the ones you have set in config.g?
      R006undefined 1 Reply Last reply Reply Quote 0
      • R006undefined
        R006 @T3P3Tony
        @T3P3Tony
        no in config Acceleration is 3000mm/s2 and jerk is 300mm/s.
          @R006 ok so are the values that are restored related to anything in your settings or gcode file?
          JayTundefined 1 Reply Last reply Reply Quote 0
          • JayTundefined
            JayT @T3P3Tony
            @T3P3Tony :
            I use this version too and have observed same problems. The value of acceleration on resume is not something I am able to trace from gcode file or config. Its some random very high value like 20000 or 50000. even jerk changes.
            I have also observed, that despite setting max acceleration & speeds in config, its not limited on resume after power failure. Can you check this?
              dc42 administrators @JayT
              @JayT @R006 in the forthcoming 3.5.0-rc.4 the M204 acceleration settings are restored when resuming after power fail.
              JayTundefined R006undefined 2 Replies Last reply Reply Quote 1
              • JayTundefined
                JayT @dc42
                @dc42 :
                Noted.
                However, there are 2 more errors that appear on resume:
                a) tool0 was not driven because its heater temperature were not high enough. heater fault. Yet it resumes, but why this error?
                b) Loading the heightmap before setting duetZ0 - warning,
                  @JayT regarding (a) it's your responsibility to use M116 or a similar command in your resurrect-prologue.g file to wait for temperatures to be reached. Are you doing that?
                  • JayTundefined
                    JayT @dc42
                    @dc42 :
                    My resurrect-prologue.g file is as below, it has M116 to wait.
                    ;rel
                    G91
                    G1 Z2
                    G28 X Y
                    ;wait
                    M116
                    ;rel
                    M83
                    M21 P1
                    G1 E5 F500
                    ;mesh
                    G29 S1
                    ;Buzz
                    M300 S600 P100
                    ;Buzz
                    M300 S700 P1200
                    ;Buzz
                    M300 S500 P300
                    ;Abs
                    G90
                    • R006undefined
                      R006 @dc42
                      @dc42 hey,
                      After upgrading to the latest firmware version 3.5.0rc4, we observed improvement in print acceleration settings. However, the travel acceleration is taking random value: while print acceleration seems to be functioning correctly, travel acceleration values are fluctuating unexpectedly.
                        dc42 administrators @R006
                        @R006 please check whether the M204 command in resurrect.g is setting the correct travel acceleration for resuming the print.
                        • JayTundefined
                          JayT @dc42
                          @dc42 :
                          with RC4, sometimes it resumes fine with minimal offset. Whereas sometimes it shift by 5-8mm in Y direction for me on resume after power failure. Mostly it shifting by >5mm happens when print height is <5mm. So i disabled meshbed compensation & tried. It still has the same problem.
                          There are instances when even at height 3mm, it resumes fine.
                          skew in YZ is included. Does that have any effect?
                          What should I check for ?
                          Shift is always in Y axis & amount of shift is more w.r.t X axis.
                          • JayTundefined JayT referenced this topic
