    Jerk & acceleration value change after Resume APF
    Beta Firmware
    707
    • R006undefined
      R006 @Phaedrux
      @Phaedrux We have already verified with 3.4.6 and 3.4beta3, and same thing is happening.
        dc42 administrators @R006
        @R006 the generated resurrect.g file does not currently restore the M204 acceleration settings or the jerk settings. Feel free to create an issue at https://github.com/Duet3D/RepRapFirmware/issues.
          T3P3Tony administrators @R006
          @R006 to be clear, the reported values after a restore after power failure are the ones you have set in config.g?
          R006undefined 1 Reply Last reply Reply Quote 0
          • R006undefined
            R006 @T3P3Tony
            @T3P3Tony
            no in config Acceleration is 3000mm/s2 and jerk is 300mm/s.
              @R006 ok so are the values that are restored related to anything in your settings or gcode file?
              JayTundefined 1 Reply Last reply Reply Quote 0
              • JayTundefined
                JayT @T3P3Tony
                @T3P3Tony :
                I use this version too and have observed same problems. The value of acceleration on resume is not something I am able to trace from gcode file or config. Its some random very high value like 20000 or 50000. even jerk changes.
                I have also observed, that despite setting max acceleration & speeds in config, its not limited on resume after power failure. Can you check this?
                  dc42 administrators @JayT
                  @JayT @R006 in the forthcoming 3.5.0-rc.4 the M204 acceleration settings are restored when resuming after power fail.
                  JayTundefined R006undefined 2 Replies Last reply Reply Quote 1
                  • JayTundefined
                    JayT @dc42
                    @dc42 :
                    Noted.
                    However, there are 2 more errors that appear on resume:
                    a) tool0 was not driven because its heater temperature were not high enough. heater fault. Yet it resumes, but why this error?
                    b) Loading the heightmap before setting duetZ0 - warning,
                      @JayT regarding (a) it's your responsibility to use M116 or a similar command in your resurrect-prologue.g file to wait for temperatures to be reached. Are you doing that?
                      • JayTundefined
                        JayT @dc42
                        @dc42 :
                        My resurrect-prologue.g file is as below, it has M116 to wait.
                        ;rel
                        G91
                        G1 Z2
                        G28 X Y
                        ;wait
                        M116
                        ;rel
                        M83
                        M21 P1
                        G1 E5 F500
                        ;mesh
                        G29 S1
                        ;Buzz
                        M300 S600 P100
                        ;Buzz
                        M300 S700 P1200
                        ;Buzz
                        M300 S500 P300
                        ;Abs
                        G90
                        • R006undefined
                          R006 @dc42
                          @dc42 hey,
                          After upgrading to the latest firmware version 3.5.0rc4, we observed improvement in print acceleration settings. However, the travel acceleration is taking random value: while print acceleration seems to be functioning correctly, travel acceleration values are fluctuating unexpectedly.
                            @R006 please check whether the M204 command in resurrect.g is setting the correct travel acceleration for resuming the print.
                            • JayTundefined
                              JayT @dc42
                              @dc42 :
                              with RC4, sometimes it resumes fine with minimal offset. Whereas sometimes it shift by 5-8mm in Y direction for me on resume after power failure. Mostly it shifting by >5mm happens when print height is <5mm. So i disabled meshbed compensation & tried. It still has the same problem.
                              There are instances when even at height 3mm, it resumes fine.
                              skew in YZ is included. Does that have any effect?
                              What should I check for ?
                              Shift is always in Y axis & amount of shift is more w.r.t X axis.
                              • JayTundefined JayT referenced this topic
