    Software bundle 3.5.0rc.4 now available
    Firmware installation
    16
    41
    1.9k
    • CrazyCreatorundefined
      CrazyCreator @chrishamm
      @chrishamm
      Unfortunately, I can't find how to flash the firmware from the Pi onto the board. Can access the Pi via VNC...
      And next strange problem. In the Docu is writing:
      Erase the firmware on the Duet by either:
      Pressing the Erase button (next to the reset button on older Duets); or Jumpering the erase jumper
      Remove the erase jumper once the Diag LED lights up.
      But i can't find this Pins for jumper it.
      Maybe this is the reason for this:
      But what's much stranger is that when I connect the board to the USB on the PC, nothing happens.
      Neither on the Mac nor on the Windows PC... The board does not appear.
      Do I have to disconnect all cables (Motor, Endstops, heater etc) beforehand and only the USB cable can be plugged in?
      All other cables are of course without power, the main switch of the printer is turned off.
      http://www.crazycreatorcube.com
        droftarts administrators @CrazyCreator
        @CrazyCreator I expect the firmware flash got part way through and failed. Using the erase jumper should get it back to a state where it will be recognised and firmware can be flashed via USB. This can be done from the Raspberry Pi, usually by sending the command:
        ~/BOSSA/bin/bossac -e -w -v -b /opt/dsf/sd/firmware/Duet3Firmware_MB6HC.bin
        Erase jumper is here:
        CrazyCreatorundefined 1 Reply Last reply Reply Quote 1
          CrazyCreator @droftarts
          @droftarts Mhhhh ... Thanks all for the helping, but i don't have a erase jumper ๐Ÿ˜ž
            jay_s_uk @CrazyCreator
            @CrazyCreator looks like a cloned board. best ask Fysetc...
            CrazyCreatorundefined 1 Reply Last reply Reply Quote 0
              CrazyCreator @jay_s_uk
              @jay_s_uk The board came with the printer... No idea if it's a clone or not. But the clones are also made according to the specifications, aren't they?
                @CrazyCreator well its black, so its a clone.
                And I know some Fysetc "clones" don't 100% match duet boards
                  @jay_s_uk
                  What kind of rubbish is that?
                  Well then I'll try to bridge the two pins.
                  If the board wears out, then at least an original one comes in ๐Ÿ˜‰
                  btw
                  Here is a picture of a board from Filafarm (official seller in Germany), there is no erase jumper at this position. However, that is a 0.6 board in the picture.
                  infiniteloopundefined 1 Reply Last reply Reply Quote 1
                  • infiniteloopundefined
                    infiniteloop @CrazyCreator
                    @CrazyCreator
                    Here you are:
                      CrazyCreator @infiniteloop
                      @infiniteloop
                      I know... I saw that.
                      I just wanted to show that there are also duet boards where the jumper is in a different place. So it's quite possible that this is the case on my board too.
                        @CrazyCreator clones are based on the v1, not the 0.6
                          @jay_s_uk
                          But ... My Erase Button is on Position from v0.6 and on the Board itself is writing v1.01 ... it's a little bit funnny ๐Ÿ˜‰
                            3.5 is now released
                            https://github.com/Duet3D/RepRapFirmware/releases/tag/3.5.0
                            • Phaedruxundefined Phaedrux locked this topic
                              @CrazyCreator said in Software bundle 3.5.0rc.4 now available:
                              Yup, itโ€™s stuff like that that means we donโ€™t support clones. And they donโ€™t pay us to. Or make it easy for their customers to get support.
