    Software 3.5.1 released
    Firmware installation
    13
    20
    1.2k
      dc42 administrators @PDBeal
      @PDBeal yes we will release PanelDue 3.5 soon, based on the existing RC. We also have a new, more capable screen under development and that will eventually replace PanelDue in our product range.
      Exerqtorundefined 1 Reply Last reply Reply Quote 4
      • Exerqtorundefined
        Exerqtor @dc42
        @dc42 said in Software 3.5.1 released:
        Finally! Looking forrward to hearing & seeing more about that! ๐Ÿ˜๐Ÿ˜
        • ctilley79undefined
          ctilley79 @dc42
          @dc42 Onto 3.6!! Whatโ€™s next on the feature roadmap? Any hints?
          • JayTundefined
            JayT @Alex.cr
            @Alex-cr : I have tried this release. I face a lot of bad command errors suddenly while printing. When I check Gcode line, it is fine. If i revert to 3.4.6, I don't face much bad command errors while printing. Did you face anything like that?
              Phaedrux Moderator @JayT
              @JayT said in Software 3.5.1 released:
              Can you give some more detail about what exactly you're seeing and where you see it?
              JayTundefined 1 Reply Last reply Reply Quote 0
              • Notepadundefined
                Notepad
                Wooo, Lets goo!
                A lot of nice changes across the board. I especially like the DWC change for the text editor. Applying input shaping to smaller segments has also produced a noticeable increase in print quality, very nice indeed.
                I have however noticed a weird behaviour with the resume.g, which I have made a seperate thread for(https://forum.duet3d.com/topic/35544/resume-g-activating-twice-with-fw3-5?_=1713890021060)
                The real bamboo printer manufacturer
                • JayTundefined
                  JayT @Phaedrux
                  @Phaedrux :
                  If i simulate the gcode, I get some errors like bad command or message box stating expected integer after Y.
                  Sometimes error says "C1 " instead of G1. When I look back at the line number in Gcode, Line looks ok.
                  Is it a problem with Slicer & after error Reprap fixes it ?
                  Because when I run it the second time, or simulate second time, bad command error either does not come at all, or it comes at a different line.
                  My problems are similar as posted in the thread :
                  https://forum.duet3d.com/topic/35553/bad-command-error-using-rrf-3-5-0-and-3-5-1-using-duet2-wifi/2
                  gloomyandyundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
                  • gloomyandyundefined
                    gloomyandy @JayT
                    @JayT What board are you using?
                    • JayTundefined
                      JayT @gloomyandy
                      @gloomyandy :
                      I have duet2-wifi.
                        @Phaedrux :
                        Can you start a thread for your issue and include as much detail as possible?
                        • alwaysomundefined
                          alwaysom
                          Hello
                          got this message"Error in start-up file macro line 5: in file macro line 5 column 17: M307: expected number after 'K'" " on startup after updating to 3.5.1.
                          I first thought it was a problem in config-override or config file but in my config ther is no M307 with K and this is my Config-override:
                          ; config-override.g file generated in response to M500 at 2024-04-20 19:05
                          M307 H0 R0.123 K0.236:0.000 D11.52 E1.35 S1.00 B0
                          M307 H1 R2.660 K0.303:0.000 D5.15 E1.35 S0.75 B0 V23.9
                          ; Probed axis limits
                          M208 S0 Z359.81
                          ; Z probe parameters
                          G31 K0 P25 X42.0 Y21.0 Z2.40
                          The Printer is working good but message on startup is boring.
                          Can someone tell me where i have to search for the M307 command?
                            Phaedrux Moderator @alwaysom
                            @alwaysom said in Software 3.5.1 released:
                            Can you identify exactly where line5 column17 is in this instance?
                            • JayTundefined
                              JayT @Phaedrux
                              @Phaedrux : done.
                                I'm going to lock this thread now. If you're experiencing issues after upgrading to 3.5.1, please create a new thread with your issue and please include as much detail as possible.
                                • Phaedruxundefined Phaedrux locked this topic
