    Software 3.5.1 released
    Firmware installation
    13
    20
    1.1k
      On behalf of the Duet3D team I am very pleased to announce the availability of stable version 3.5.1. This fixes a bug in the 3.5.0 release that was triggered by using M400 in the deployprobe.g or retractprobe.g. file. We have now withdrawn release 3.5.0.
      Highlights of this release compared to 3.4.6 include:
      • Support for multiple motion systems and our new scanning Z-probe
      • Input shaping support on axes driven by CAN-connected expansion boards
      • New WiFi firmware version 2.1 featuring (partial) WPA enterprise support
      • Modern code editor in DWC based on the VSCode editor (Monaco)
      • Transition of DWC code files from JavaScript to TypeScript and upgrade from Webpack 4 to 5
      • Input Shaping plugin now integrated in DWC
      • New DSF HTTP compatibility layer for RepRapFirmware rr_ HTTP requests
      • DSF suppot for new Debian Bookworm images (for new DuetPi images)
      • New ConfigTool with many more improvements
      As with every stable release, we highly recommend reading the upgrade notes or using the ReleaseMgr plugin in order to avoid upgrade issues for:
      • RepRapFirmware
      • DuetWebControl
      • DuetSoftwareFramework
      Users in standalone mode can obtain the upgrade bundle here.
      New stable DuetPi images based on the latest Raspberry Pi OS (Debian Bookworm) including upgrade instructions are now available here. Users in SBC mode should consider upgrading to that DuetPi version because the current version will reach its EOL soon (Debian Buster's EOL is scheduled for June 30th, 2024). If you're in SBC mode and don't want to upgrade, you can update the packages as always using the regular apt update/upgrade method. This upgrade method will be surperseded by M997 S2 in the new image to simplify the update process.
      If you see "Incompatible Software Versions" in your browser upon first launch, press Ctrl+Shift+R to reload the cached version in your browser. In case you encounter other problems, please open a new thread with [3.5.1] in the title.
      ctilley79undefined 1 Reply Last reply Reply Quote 10
      • Alex.crundefined
        Alex.cr
        Everything seems to be working well.
        Are there any plans to update the motionwebcamserver plugin to allow it to work with 3.5?
        https://github.com/Duet3D/DSF-Plugins/releases
        Voron2.4/Duet3 SBC+6HC+3HC+1LC+1HCL(x2) - Delta/Duet2 Wifi - CubePro/Duet2 Wifi+Duex5 - Laser/Duet3 Mini5+ - Cel Robox - U̶p̶3̶0̶0̶+/D̶u̶e̶t̶3̶ ̶6̶H̶C̶+̶LC1̶ - F̶T̶-̶5̶/̶D̶u̶e̶t̶2̶ ̶W̶i̶f̶i̶ - S̶o̶l̶i̶d̶o̶o̶d̶l̶e̶
        jay_s_ukundefined chrishammundefined JayTundefined 3 Replies Last reply Reply Quote 0
          jay_s_uk @Alex.cr
          @Alex-cr I think they've moved on to using spyglass instead
          • chrishammundefined
            chrishamm administrators @Alex.cr
            @Alex-cr Yes, available here: https://github.com/Duet3D/MotionWebcamServerPlugin
            @jay_s_uk Spyglass is better suited for RPi camera modules but Motion is still an option for USB cams.
            Duet software engineer
            • PDBealundefined
              PDBeal
              Will there be a PanelDue release to coincide with 3.5.1, or is it only ever going to be release candidates from this point forward?
              It appears as though the PanelDue has been left behind in leu of running a SBC these days. I'm actually wondering about doing exactly this with all my other machines based on how it seems to work with the newest one I am building now.
              oliofundefined dc42undefined 2 Replies Last reply Reply Quote 0
              • oliofundefined
                oliof @PDBeal
                @PDBeal I am still using the 12864 displays because I avoid SBC as an unnecessary complication
                  dc42 administrators @PDBeal
                  @PDBeal yes we will release PanelDue 3.5 soon, based on the existing RC. We also have a new, more capable screen under development and that will eventually replace PanelDue in our product range.
                  Exerqtorundefined 1 Reply Last reply Reply Quote 4
                  • Exerqtorundefined
                    Exerqtor @dc42
                    @dc42 said in Software 3.5.1 released:
                    Finally! Looking forrward to hearing & seeing more about that! 😁😁
                    • ctilley79undefined
                      ctilley79 @dc42
                      @dc42 Onto 3.6!! What’s next on the feature roadmap? Any hints?
                      • JayTundefined
                        JayT @Alex.cr
                        @Alex-cr : I have tried this release. I face a lot of bad command errors suddenly while printing. When I check Gcode line, it is fine. If i revert to 3.4.6, I don't face much bad command errors while printing. Did you face anything like that?
                          Phaedrux Moderator @JayT
                          @JayT said in Software 3.5.1 released:
                          Can you give some more detail about what exactly you're seeing and where you see it?
                          JayTundefined 1 Reply Last reply Reply Quote 0
                          • Notepadundefined
                            Notepad
                            Wooo, Lets goo!
                            A lot of nice changes across the board. I especially like the DWC change for the text editor. Applying input shaping to smaller segments has also produced a noticeable increase in print quality, very nice indeed.
                            I have however noticed a weird behaviour with the resume.g, which I have made a seperate thread for(https://forum.duet3d.com/topic/35544/resume-g-activating-twice-with-fw3-5?_=1713890021060)
                            The real bamboo printer manufacturer
                            • JayTundefined
                              JayT @Phaedrux
                              @Phaedrux :
                              If i simulate the gcode, I get some errors like bad command or message box stating expected integer after Y.
                              Sometimes error says "C1 " instead of G1. When I look back at the line number in Gcode, Line looks ok.
                              Is it a problem with Slicer & after error Reprap fixes it ?
                              Because when I run it the second time, or simulate second time, bad command error either does not come at all, or it comes at a different line.
                              My problems are similar as posted in the thread :
                              https://forum.duet3d.com/topic/35553/bad-command-error-using-rrf-3-5-0-and-3-5-1-using-duet2-wifi/2
                              gloomyandyundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
                              • gloomyandyundefined
                                gloomyandy @JayT
                                @JayT What board are you using?
                                • JayTundefined
                                  JayT @gloomyandy
                                  @gloomyandy :
                                  I have duet2-wifi.
                                    @Phaedrux :
                                    Can you start a thread for your issue and include as much detail as possible?
                                    • alwaysomundefined
                                      alwaysom
                                      Hello
                                      got this message"Error in start-up file macro line 5: in file macro line 5 column 17: M307: expected number after 'K'" " on startup after updating to 3.5.1.
                                      I first thought it was a problem in config-override or config file but in my config ther is no M307 with K and this is my Config-override:
                                      ; config-override.g file generated in response to M500 at 2024-04-20 19:05
                                      M307 H0 R0.123 K0.236:0.000 D11.52 E1.35 S1.00 B0
                                      M307 H1 R2.660 K0.303:0.000 D5.15 E1.35 S0.75 B0 V23.9
                                      ; Probed axis limits
                                      M208 S0 Z359.81
                                      ; Z probe parameters
                                      G31 K0 P25 X42.0 Y21.0 Z2.40
                                      The Printer is working good but message on startup is boring.
                                      Can someone tell me where i have to search for the M307 command?
                                        Phaedrux Moderator @alwaysom
                                        @alwaysom said in Software 3.5.1 released:
                                        Can you identify exactly where line5 column17 is in this instance?
                                        • JayTundefined
                                          JayT @Phaedrux
                                          @Phaedrux : done.
                                            I'm going to lock this thread now. If you're experiencing issues after upgrading to 3.5.1, please create a new thread with your issue and please include as much detail as possible.
                                            • Phaedruxundefined Phaedrux locked this topic
