    My printer reboots alone…. 3.5.1
    Beta Firmware
    reboot error update
    10
    32
    1.5k
    • CorvoConVundefined
      CorvoConV
      Hi. Since i upgrade to 3.5.1 my printer reboots alone in mid print… i have the Duet 3 mini 5 wifi. I active the log file in S3 mode but nothing its on there out of normal, just i put a print and, some times, not ever, the printer reboot and the extruder it stopped on the print at the moment of the reboot.
      In the console, panel due or log only puts a power on aleatory.
      jay_s_ukundefined 1 Reply Last reply Reply Quote 1
        jay_s_uk @CorvoConV
        @CorvoConV post an M122 output from after the board has rebooted
        CorvoConVundefined 1 Reply Last reply Reply Quote 0
          CorvoConV @jay_s_uk
          @jay_s_uk said in My printer reboots alone….:
          I will try, thanks a lot.
            CorvoConV
            Hi.
            Here is my M122 report about the last reboot:
            Static ram: 103232
            Dynamic ram: 125008 of which 12 recycled
            Never used RAM 9612, free system stack 128 words
            Tasks: NETWORK(2,nWait 7,13.7%,204) HEAT(3,nWait 6,0.1%,326) Move(4,nWait 6,0.0%,235) CanReceiv(6,nWait 1,0.1%,772) CanSender(5,nWait 7,0.0%,327) CanClock(7,delaying,0.0%,348) TMC(4,delaying,1.4%,102) MAIN(1,running,83.8%,617) IDLE(0,ready,0.0%,30) AIN(4,delaying,0.9%,260), total 100.0%
            Owned mutexes: WiFi(NETWORK)
            Last reset 06:12:54 ago, cause: software
            Last software reset at 2024-05-01 11:43, reason: HardFault imprec, Expansion spinning, available RAM 9612, slot 1
            Software reset code 0x4072 HFSR 0x40000000 CFSR 0x00000400 ICSR 0x00000803 BFAR 0xe000ed38 SP 0x20012008 Task NETW Freestk 489 ok
            Stack: 2002c5e0 200310b8 200014e8 00000000 ffffffff 0002ff99 0002feb0 610f6000 20036600 2002c5c8 200187fc 2002c41e 200187fc 2001e9f8 0003011f 00000000 00000000 00000000 200120a0 00000014 468eb2f2 00000002 53d70050 8c01a8c0 08000164 00000001 000347e1
            Error status: 0x04
            Aux0 errors 0,0,0
            MCU revision 3, ADC conversions started 22374384, completed 22374384, timed out 0, errs 0
            MCU temperature: min 32.2, current 32.5, max 32.7
            Supply voltage: min 23.8, current 23.9, max 23.9, under voltage events: 0, over voltage events: 0, power good: yes
            Heap OK, handles allocated/used 99/0, heap memory allocated/used/recyclable 2048/16/16, gc cycles 0
            Events: 0 queued, 0 completed
            Driver 0: standstill, SG min 2, read errors 0, write errors 0, ifcnt 142, reads 24000, writes 0, timeouts 0, DMA errors 0, CC errors 0
            Driver 1: standstill, SG min 0, read errors 0, write errors 0, ifcnt 142, reads 24000, writes 0, timeouts 0, DMA errors 0, CC errors 0
            Driver 2: standstill, SG min 0, read errors 0, write errors 0, ifcnt 142, reads 24001, writes 0, timeouts 0, DMA errors 0, CC errors 0
            Driver 3: standstill, SG min 0, read errors 0, write errors 0, ifcnt 142, reads 24001, writes 0, timeouts 0, DMA errors 0, CC errors 0
            Driver 4: standstill, SG min 2, read errors 0, write errors 0, ifcnt 142, reads 24000, writes 0, timeouts 0, DMA errors 0, CC errors 0
            Driver 5: standstill, SG min 2, read errors 0, write errors 0, ifcnt 136, reads 24000, writes 0, timeouts 0, DMA errors 0, CC errors 0
            Driver 6: standstill, SG min 0, read errors 0, write errors 0, ifcnt 111, reads 24001, writes 0, timeouts 0, DMA errors 0, CC errors 0
            Date/time: 2024-05-01 17:56:19
            Slowest loop: 8.62ms; fastest: 0.16ms
            I dont know yet what means...
            gloomyandyundefined 1 Reply Last reply Reply Quote 0
            • gloomyandyundefined
              gloomyandy @CorvoConV
              @CorvoConV Please post the full m122 output
                CorvoConV @gloomyandy
                @gloomyandy
                Here is:
                m122
                RepRapFirmware for Duet 3 Mini 5+ version 3.5.1 (2024-04-19 14:41:25) running on Duet 3 Mini5plus WiFi (standalone mode)
                Board ID: 82XA5-A296U-D65J0-40KMN-3L03Z-Z53U1
                Used output buffers: 3 of 40 (40 max)
                Static ram: 103232
                Error status: 0x04
                Aux0 errors 0,0,0
                === Storage ===
                Free file entries: 19
                SD card longest read time 3.5ms, write time 0.9ms, max retries 0
                DMs created 83, segments created 29, maxWait 0ms, bed compensation in use: none, height map offset 0.000, max steps late 0, min interval 0, bad calcs 0, ebfmin 0.00, ebfmax 0.00
                no step interrupt scheduled
                Moves shaped first try 0, on retry 0, too short 0, wrong shape 0, maybepossible 0
                === DDARing 0 ===
                Scheduled moves 115546, completed 115546, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
                === DDARing 1 ===
                Bed heaters 0 -1 -1 -1, chamber heaters 3 4 -1 -1, ordering errs 0
                Heater 0 is on, I-accum = 0.1
                Heater 1 is on, I-accum = 0.4
                HTTP is idle in state(s) 0
                Telnet is idle in state(s) 0
                File is idle in state(s) 0
                USB is idle in state(s) 0
                Aux is idle in state(s) 0
                Trigger is idle in state(s) 0
                Queue is idle in state(s) 0
                LCD is idle in state(s) 0
                SBC is idle in state(s) 0
                Daemon is idle in state(s) 0
                Aux2 is idle in state(s) 0
                File2 is idle in state(s) 0
                Queue2 is idle in state(s) 0
                Q0 segments left 0, axes/extruders owned 0x0000a0f
                Code queue 0 is empty
                Code queue 1 is empty
                === CAN ===
                Messages queued 2377, received 10560, lost 0, errs 0, boc 0
                Longest wait 0ms for reply type 0, peak Tx sync delay 6, free buffers 26 (min 26), ts 1320/1320/0
                Tx timeouts 0,0,0,0,0,0
                === Network ===
                Slowest loop: 206.32ms; fastest: 0.06ms
                Responder states: MQTT(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
                HTTP sessions: 1 of 8
                === WiFi ===
                Interface state: active
                Module is connected to access point
                Failed messages: pending 0, notrdy 0, noresp 0
                Firmware version 2.1.0
                MAC address f0:08:d1:03:81:66
                Module reset reason: Power up, Vcc 3.34, flash size 2097152, free heap 42936
                WiFi IP address 192.168.1.137
                Signal strength -41dBm, channel 11, mode 802.11n, reconnections 0
                Clock register 00002001
                Thanks
                  @CorvoConV Thanks.
                  @dc42 this looks similar to: https://forum.duet3d.com/topic/35616/3-5-1-firmware-last-reset-08-29-26-ago-cause-software
                  Aurimasundefined Nate.Nygrenundefined 2 Replies Last reply Reply Quote 0
                  • Aurimasundefined
                    Aurimas @gloomyandy
                    @gloomyandy @dc42
                    I have another one with 3.5.1 - this machine was running on older versions for over year now and didn't skip the beat and also the first one did the same (second 122 output below) even after downgrading to 3.4.1
                    Board ID: 44BBP-1N6KL-K65J0-409N2-1BW1Z-RD9N1
                    Static ram: 103232
                    Dynamic ram: 123000 of which 12 recycled
                    Never used RAM 15172, free system stack 190 words
                    Tasks: NETWORK(2,nWait 7,13.1%,204) HEAT(3,nWait 6,0.0%,326) Move(4,nWait 6,0.0%,341) CanReceiv(6,nWait 1,0.1%,772) CanSender(5,nWait 7,0.0%,336) CanClock(7,delaying,0.0%,348) TMC(4,nWait 6,0.8%,102) MAIN(1,running,84.6%,665) IDLE(0,ready,0.5%,30) AIN(4,delaying,0.8%,260), total 100.0%
                    Owned mutexes:
                    Last reset 09:20:02 ago, cause: software
                    Last software reset at 2024-05-03 21:57, reason: HardFault imprec, Expansion spinning, available RAM 10956, slot 1
                    Stack: 2002c5e0 20031218 200014e8 00000000 200333ee 0002ff99 0002feb0 610f6000 20035f48 2002c5c8 200187fc 2002c41e 200187fc 2001e9f8 0003011f 00000000 00000000 00000000 200120a0 00000014 b5dde3ac 00000002 cf560050 6a01a8c0 08000162 00000001 000347e1
                    Error status: 0x04
                    Aux0 errors 0,0,0
                    MCU revision 3, ADC conversions started 33602069, completed 33602068, timed out 0, errs 0
                    MCU temperature: min 20.3, current 20.8, max 21.0
                    Supply voltage: min 24.3, current 24.4, max 24.5, under voltage events: 0, over voltage events: 0, power good: yes
                    Driver 0: standstill, SG min 26, read errors 0, write errors 0, ifcnt 35, reads 16155, writes 0, timeouts 0, DMA errors 0, CC errors 0
                    Driver 1: standstill, SG min 30, read errors 0, write errors 0, ifcnt 35, reads 16155, writes 0, timeouts 0, DMA errors 0, CC errors 0
                    Driver 2: standstill, SG min 38, read errors 0, write errors 0, ifcnt 39, reads 16156, writes 0, timeouts 0, DMA errors 0, CC errors 0
                    Driver 3: standstill, SG min 14, read errors 0, write errors 0, ifcnt 39, reads 16155, writes 0, timeouts 0, DMA errors 0, CC errors 0
                    Driver 4: standstill, SG min 0, read errors 0, write errors 0, ifcnt 25, reads 16155, writes 0, timeouts 0, DMA errors 0, CC errors 0
                    Driver 5: not present
                    Driver 6: not present
                    Date/time: 2024-05-04 07:17:36
                    Slowest loop: 15.55ms; fastest: 0.14ms
                    === Storage ===
                    SD card longest read time 4.8ms, write time 0.0ms, max retries 0
                    DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, height map offset 0.000, max steps late 0, min interval 0, bad calcs 0, ebfmin 0.00, ebfmax 0.00
                    === DDARing 0 ===
                    === DDARing 1 ===
                    Heater 0 is on, I-accum = 0.0
                    Heater 1 is on, I-accum = 0.0
                    Daemon is idle in state(s) 0 0, running macro
                    Q0 segments left 0, axes/extruders owned 0x0000803
                    === Filament sensors ===
                    check 0 clear 0
                    Extruder 1: no data received, errs: frame 0 parity 0 ovrun 0 pol 0 ovdue 0
                    === CAN ===
                    Messages queued 2763, received 12434, lost 0, errs 0, boc 0
                    Longest wait 0ms for reply type 0, peak Tx sync delay 6, free buffers 26 (min 26), ts 1535/1535/0
                    === Network ===
                    Slowest loop: 19.78ms; fastest: 0.07ms
                    HTTP sessions: 7 of 8
                    === WiFi ===
                    MAC address c4:5b:be:ce:9c:81
                    Module reset reason: Power up, Vcc 3.36, flash size 2097152, free heap 42776
                    WiFi IP address 192.168.1.99
                    Signal strength -51dBm, channel 2, mode 802.11n, reconnections 0
                    RepRapFirmware for Duet 3 Mini 5+ version 3.5.0-rc.4 (2024-04-09 09:45:40) running on Duet 3 Mini5plus WiFi (standalone mode)
                    Board ID: AGMAV-AR6KL-K65J0-409N6-LGW1Z-7XF1B
                    Used output buffers: 21 of 40 (40 max)
                    Static ram: 103232
                    Dynamic ram: 123608 of which 24 recycled
                    Never used RAM 14552, free system stack 192 words
                    Tasks: NETWORK(2,nWait 7,11.8%,214) HEAT(3,nWait 6,0.0%,326) Move(4,nWait 6,0.0%,341) CanReceiv(6,nWait 1,0.1%,772) CanSender(5,nWait 7,0.0%,336) CanClock(7,delaying,0.0%,348) TMC(4,nWait 6,1.4%,102) MAIN(1,running,85.6%,665) IDLE(0,ready,0.2%,30) AIN(4,delaying,0.9%,260), total 100.0%
                    Last reset 06:34:45 ago, cause: software
                    Last software reset at 2024-05-04 00:45, reason: HardFault imprec, Platform spinning, available RAM 10364, slot 0
                    Software reset code 0x4060 HFSR 0x40000000 CFSR 0x00000400 ICSR 0x0047d803 BFAR 0xe000ed38 SP 0x20012008 Task NETW Freestk 489 ok
                    Stack: 2002c5e0 200324d0 200014e8 00000000 2003366e 00030019 0002ff30 61016000 200361d0 2002c5c8 200187fc 2002c41e 200187fc 2001e9f8 0003019f 00000000 00000000 00000000 200120a0 00000014 46c577d2 00000002 dbe60050 6a01a8c0 08000162 00000001 00034861
                    Error status: 0x04
                    Aux0 errors 0,0,0
                    MCU revision 3, ADC conversions started 23685999, completed 23685999, timed out 0, errs 0
                    MCU temperature: min 20.6, current 21.3, max 21.5
                    Supply voltage: min 23.8, current 23.9, max 24.0, under voltage events: 0, over voltage events: 0, power good: yes
                    Driver 0: standstill, SG min 110, read errors 0, write errors 0, ifcnt 31, reads 61823, writes 0, timeouts 0, DMA errors 0, CC errors 0
                    Driver 1: standstill, SG min 116, read errors 0, write errors 0, ifcnt 31, reads 61824, writes 0, timeouts 0, DMA errors 0, CC errors 0
                    Driver 2: standstill, SG min 6, read errors 0, write errors 0, ifcnt 27, reads 61824, writes 0, timeouts 0, DMA errors 0, CC errors 0
                    Driver 3: standstill, SG min 26, read errors 0, write errors 0, ifcnt 27, reads 61823, writes 0, timeouts 0, DMA errors 0, CC errors 0
                    Driver 4: standstill, SG min 8, read errors 0, write errors 0, ifcnt 27, reads 61823, writes 0, timeouts 0, DMA errors 0, CC errors 0
                    Driver 5: standstill, SG min 112, read errors 0, write errors 0, ifcnt 31, reads 61824, writes 0, timeouts 0, DMA errors 0, CC errors 0
                    Driver 6: standstill, SG min 116, read errors 0, write errors 0, ifcnt 31, reads 61824, writes 0, timeouts 0, DMA errors 0, CC errors 0
                    Date/time: 2024-05-04 07:20:39
                    Slowest loop: 23.19ms; fastest: 0.14ms
                    === Storage ===
                    SD card longest read time 4.9ms, write time 2.0ms, max retries 0
                    === DDARing 0 ===
                    === DDARing 1 ===
                    Bed heaters 0 -1 -1 -1, chamber heaters 4 -1 -1 -1, ordering errs 0
                    check 0 clear 0
                    Extruder 0: no data received, errs: frame 0 parity 0 ovrun 0 pol 0 ovdue 0
                    === CAN ===
                    Messages queued 6121, received 27891, lost 0, errs 0, boc 0
                    Longest wait 0ms for reply type 0, peak Tx sync delay 261, free buffers 26 (min 26), ts 3400/3400/0
                    === Network ===
                    Slowest loop: 21.11ms; fastest: 0.07ms
                    HTTP sessions: 2 of 8
                    === WiFi ===
                    MAC address e8:68:e7:e5:b1:d7
                    Module reset reason: Power up, Vcc 3.37, flash size 2097152, free heap 34872
                    WiFi IP address 192.168.1.87
                    Signal strength -39dBm, channel 2, mode 802.11n, reconnections 0
                    Australian design and build large scale 3d printers
                    https://aurarum.com.au
                    Aurimasundefined 1 Reply Last reply Reply Quote 0
                      CorvoConV
                      Before the upgrade to 3.5.1 i was in 3.5.0R3 and never happens…
                      I dont know what means expansion spinning…
                      • Aurimasundefined
                        Aurimas @Aurimas
                        @dc42 @gloomyandy any comments on this issue would be nice rather than keeping us in the dark
                        and one more - this is on RC3. 48 hours of print 3+KG of filament.
                        Slicer is Orca - can this be related to the reboots?
                        RepRapFirmware for Duet 3 Mini 5+ version 3.5.0-rc.3 (2024-01-24 17:56:48) running on Duet 3 Mini5plus WiFi (standalone mode)
                        Board ID: PA279-4N6KL-K65J0-409N0-4Z02Z-HWYBD
                        Used output buffers: 20 of 40 (34 max)
                        Static ram: 103200
                        Dynamic ram: 121928 of which 12 recycled
                        Never used RAM 16276, free system stack 198 words
                        Tasks: NETWORK(2,nWait 7,11.5%,204) HEAT(3,nWait 6,0.0%,326) Move(4,nWait 6,0.0%,312) CanReceiv(6,nWait 1,0.1%,796) CanSender(5,nWait 7,0.0%,337) CanClock(7,delaying,0.0%,349) TMC(4,nWait 6,1.4%,102) MAIN(1,running,86.1%,667) IDLE(0,ready,0.0%,30) AIN(4,delaying,0.8%,260), total 100.0%
                        Last reset 00:31:03 ago, cause: software
                        Last software reset at 2024-05-06 07:38, reason: HardFault invState, Platform spinning, available RAM 12220, slot 2
                        Software reset code 0x4060 HFSR 0x40000000 CFSR 0x00020000 ICSR 0x00000803 BFAR 0xe000ed38 SP 0x20011fd8 Task NETW Freestk 483 ok
                        Stack: 00000180 00000002 200014e8 00000000 ffffffff 0009eeaf 00000000 600f0000 00000000 00000000 00000000 00000000 20031dc4 00000800 20035ab8 2002c3b8 200187dc 2002c216 200187dc 2001e9d8 0002fcf7 00000000 00000000 00000000 20012088 00000014 ffffffff
                        Error status: 0x00
                        Aux0 errors 0,0,0
                        MCU revision 3, ADC conversions started 1863198, completed 1863198, timed out 0, errs 0
                        MCU temperature: min 28.0, current 28.0, max 32.9
                        Supply voltage: min 23.9, current 24.0, max 24.0, under voltage events: 0, over voltage events: 0, power good: yes
                        Driver 0: standstill, SG min 2, read errors 0, write errors 1, ifcnt 40, reads 38269, writes 10, timeouts 0, DMA errors 0, CC errors 0
                        Driver 1: standstill, SG min 218, read errors 0, write errors 1, ifcnt 40, reads 38269, writes 10, timeouts 0, DMA errors 0, CC errors 0
                        Driver 2: standstill, SG min 0, read errors 0, write errors 1, ifcnt 32, reads 38268, writes 10, timeouts 0, DMA errors 0, CC errors 0
                        Driver 3: standstill, SG min 106, read errors 0, write errors 1, ifcnt 40, reads 38268, writes 10, timeouts 0, DMA errors 0, CC errors 0
                        Driver 4: standstill, SG min 106, read errors 0, write errors 1, ifcnt 41, reads 38269, writes 10, timeouts 0, DMA errors 0, CC errors 0
                        Driver 5: standstill, SG min 96, read errors 0, write errors 1, ifcnt 41, reads 38269, writes 10, timeouts 0, DMA errors 0, CC errors 0
                        Driver 6: standstill, SG min 108, read errors 0, write errors 1, ifcnt 40, reads 38268, writes 10, timeouts 0, DMA errors 0, CC errors 0
                        Date/time: 2024-05-06 08:09:43
                        Cache data hit count 3309093393
                        Slowest loop: 12.44ms; fastest: 0.14ms
                        === Storage ===
                        SD card longest read time 3.4ms, write time 1.5ms, max retries 0
                        DMs created 83, segments created 0, maxWait 287ms, bed compensation in use: none, height map offset 0.000, max steps late 0, ebfmin 0.00, ebfmax 0.00
                        === DDARing 0 ===
                        Scheduled moves 1, completed 1, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
                        === DDARing 1 ===
                        Daemon is assembling a command in state(s) 0 0, running macro
                        === CAN ===
                        Messages queued 16802, received 74559, lost 0, errs 0, boc 0
                        Longest wait 2ms for reply type 6053, peak Tx sync delay 276, free buffers 26 (min 25), ts 9316/9315/0
                        === Network ===
                        Slowest loop: 12.42ms; fastest: 0.00ms
                        === WiFi ===
                        Firmware version 2.1beta6
                        MAC address e8:68:e7:e1:4e:a5
                        Module reset reason: Power up, Vcc 3.41, flash size 2097152, free heap 33180
                        WiFi IP address 192.168.1.110
                        Signal strength -50dBm, channel 2, mode 802.11n, reconnections 0
                          gloomyandy @Aurimas
                          @Aurimas I think you will have to wait for DC42 to get back to you on this, I'm really not that familiar with the duet version of RRF (I look after the stm32 version). This weekend is a public holiday here in the UK so folks may be not be looking at the forum.
                          • Aurimasundefined
                            Aurimas @gloomyandy
                            @gloomyandy thank you for the response and explanation.
                            it is really worrying that I had few issues with no response.
                            We install the boards in to the printers we sell and if stuff like this is hapenning without any feedback and/or remedy is not good at all.
                            • Nate.Nygrenundefined
                              Nate.Nygren @gloomyandy
                              I'm having the same issue: https://forum.duet3d.com/topic/35647/hardfault-causing-failed-prints
                                dc42 administrators @Nate.Nygren
                                To those of you experiencing this issue, please send the following command after power up, before you start printing:
                                M122 P500 S0
                                This will reduce performance a little, however it should change the imprecise Hard Fault resets that I see in your M122 reports to precise ones, which will make this easier for me to diagnose. Then post M122 reports if the problem happens again.
                                Aurimasundefined 4 Replies Last reply Reply Quote 1
                                • dc42undefined dc42 referenced this topic
                                • Phaedruxundefined Phaedrux moved this topic from Firmware installation
                                • Aurimasundefined
                                  Aurimas @dc42
                                  I have enabled M122 P500 S0 but can't really see any difference in the output```
                                  M122
                                  M122
                                  Used output buffers: 2 of 40 (37 max)
                                  Static ram: 103200
                                  Tasks: NETWORK(2,nWait 7,11.4%,212) HEAT(3,nWait 6,0.0%,326) Move(4,nWait 6,0.0%,312) CanReceiv(6,nWait 1,0.1%,773) CanSender(5,nWait 7,0.0%,337) CanClock(7,delaying,0.0%,349) TMC(4,delaying,1.4%,102) MAIN(1,running,86.2%,667) IDLE(0,ready,0.0%,30) AIN(4,delaying,0.8%,260), total 100.0%
                                  Last reset 00:15:06 ago, cause: software
                                  Last software reset at 2024-05-09 09:18, reason: HardFault invState, Gcodes spinning, available RAM 12104, slot 0
                                  Software reset code 0x4063 HFSR 0x40000000 CFSR 0x00020000 ICSR 0x00000803 BFAR 0xe000ed38 SP 0x20011fd8 Task NETW Freestk 483 ok
                                  Stack: 00000180 00000002 200014e8 00000000 ffffffff 0009eeaf 00000000 600f0000 00000000 00000000 00000000 00000000 200305dc 00000800 20035b18 2002c3b8 200187dc 2002c216 200187dc 2001e9d8 0002fcf7 00000000 00000000 00000000 20012088 00000014 ffffffff
                                  Error status: 0x00
                                  Aux0 errors 0,0,0
                                  MCU revision 3, ADC conversions started 906550, completed 906549, timed out 0, errs 0
                                  MCU temperature: min 29.1, current 29.5, max 29.9
                                  Driver 0: standstill, SG min 0, read errors 0, write errors 0, ifcnt 40, reads 42095, writes 0, timeouts 0, DMA errors 0, CC errors 0
                                  Driver 1: standstill, SG min 206, read errors 0, write errors 0, ifcnt 40, reads 42095, writes 0, timeouts 0, DMA errors 0, CC errors 0
                                  Driver 2: standstill, SG min 0, read errors 0, write errors 0, ifcnt 21, reads 42095, writes 0, timeouts 0, DMA errors 0, CC errors 0
                                  Driver 3: standstill, SG min 2, read errors 0, write errors 0, ifcnt 40, reads 42096, writes 0, timeouts 0, DMA errors 0, CC errors 0
                                  Driver 4: standstill, SG min 20, read errors 0, write errors 0, ifcnt 41, reads 42095, writes 0, timeouts 0, DMA errors 0, CC errors 0
                                  Driver 5: standstill, SG min 30, read errors 0, write errors 0, ifcnt 41, reads 42095, writes 0, timeouts 0, DMA errors 0, CC errors 0
                                  Driver 6: standstill, SG min 18, read errors 0, write errors 0, ifcnt 40, reads 42096, writes 0, timeouts 0, DMA errors 0, CC errors 0
                                  Date/time: 2024-05-09 09:33:57
                                  Cache data hit count 1609260691
                                  Slowest loop: 9.87ms; fastest: 0.15ms
                                  === Storage ===
                                  DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, height map offset 0.000, max steps late 0, ebfmin 0.00, ebfmax 0.00
                                  === DDARing 0 ===
                                  === DDARing 1 ===
                                  === CAN ===
                                  Messages queued 4168, received 18525, lost 0, errs 0, boc 0
                                  Longest wait 0ms for reply type 0, peak Tx sync delay 269, free buffers 26 (min 26), ts 2316/2316/0
                                  === Network ===
                                  Slowest loop: 21.21ms; fastest: 0.07ms
                                  === WiFi ===
                                  Module reset reason: Power up, Vcc 3.41, flash size 2097152, free heap 40932
                                  Signal strength -59dBm, channel 2, mode 802.11n, reconnections 0
                                  • Aurimasundefined
                                    Aurimas @dc42
                                    @Phaedrux not sure why you moved it to Beta section.
                                    the issue is happening with the official release and not the Beta
                                      Phaedrux Moderator @Aurimas
                                      @Aurimas said in My printer reboots alone…. 3.5.1:
                                      Bugs in the current release will get addressed in the coming betas.
                                      • Aurimasundefined
                                        Aurimas @dc42
                                        @dc42 look at the output I got. Printer didn't reset, but was super jerky and was pausing when moving diagonally.
                                        it is CORE XY
                                        after rebooting it went back to normal
                                        look at the tasks TOTAL and also MOVES section
                                        M122
                                        Static ram: 103232
                                        Dynamic ram: 123388 of which 12 recycled
                                        Never used RAM 10584, free system stack 112 words
                                        Tasks: NETWORK(2,nWait 7,486.2%,174) HEAT(3,nWait 6,8.4%,326) Move(4,nWait 6,426.8%,235) CanReceiv(6,nWait 1,29.9%,564) CanSender(5,nWait 7,9.7%,327) CanClock(7,delaying,2.3%,348) TMC(4,nWait 6,242.4%,68) MAIN(1,running,275.2%,641) IDLE(0,ready,197.6%,30) AIN(4,delaying,251.9%,256), total 1930.5%
                                        Owned mutexes:
                                        Last reset 47:53:44 ago, cause: software
                                        Last software reset at 2024-05-08 17:20, reason: HardFault invState, Gcodes spinning, available RAM 11680, slot 2
                                        Stack: 0000017f 00000002 200014e8 00000000 2003312b 0009eeaf 00000000 600f0000 00000000 00000000 00000000 00000000 2003073c 00000800 20035c78 2002c3b8 200187dc 2002c216 200187dc 2001e9d8 0002fcf7 00000000 00000000 00000000 20012088 00000014 244a4226
                                        Error status: 0x04
                                        Aux0 errors 0,0,0
                                        MCU revision 3, ADC conversions started 172431441, completed 172431441, timed out 0, errs 0
                                        MCU temperature: min 23.4, current 25.1, max 38.4
                                        Supply voltage: min 24.2, current 24.4, max 24.5, under voltage events: 0, over voltage events: 0, power good: yes
                                        Heap OK, handles allocated/used 99/0, heap memory allocated/used/recyclable 2048/1408/1408, gc cycles 0
                                        Driver 0: standstill, SG min 0, read errors 0, write errors 1, ifcnt 232, reads 23715, writes 44, timeouts 0, DMA errors 0, CC errors 0
                                        Driver 1: standstill, SG min 0, read errors 0, write errors 1, ifcnt 232, reads 23714, writes 44, timeouts 1, DMA errors 0, CC errors 0, failedOp 0x72
                                        Driver 2: standstill, SG min 0, read errors 0, write errors 1, ifcnt 4, reads 23711, writes 48, timeouts 0, DMA errors 0, CC errors 0
                                        Driver 3: standstill, SG min 0, read errors 0, write errors 1, ifcnt 4, reads 23710, writes 48, timeouts 0, DMA errors 0, CC errors 0
                                        Driver 4: standstill, SG min 0, read errors 0, write errors 1, ifcnt 107, reads 23745, writes 14, timeouts 0, DMA errors 0, CC errors 0
                                        Date/time: 2024-05-11 07:41:20
                                        Slowest loop: 314.69ms; fastest: 0.10ms
                                        === Storage ===
                                        SD card longest read time 16.6ms, write time 207.9ms, max retries 0
                                        DMs created 83, segments created 56, maxWait 44492174ms, bed compensation in use: mesh, height map offset 0.071, max steps late 0, min interval 0, bad calcs 0, ebfmin 0.00, ebfmax 0.00
                                        Moves shaped first try 95159, on retry 26820, too short 101316, wrong shape 1560516, maybepossible 24107
                                        === DDARing 0 ===
                                        Scheduled moves 128820, completed 128820, hiccups 0, stepErrors 0, LaErrors 0, Underruns [18, 0, 66], CDDA state -1
                                        === DDARing 1 ===
                                        Q0 segments left 0, axes/extruders owned 0x0000807
                                        check 0 clear 0
                                        === CAN ===
                                        Messages queued 3506442, received 6984385, lost 0, errs 1, boc 0
                                        Longest wait 2ms for reply type 6053, peak Tx sync delay 498, free buffers 26 (min 24), ts 862123/862122/0
                                        === Network ===
                                        Slowest loop: 310.39ms; fastest: 0.00ms
                                        === WiFi ===
                                        Module reset reason: Power up, Vcc 3.36, flash size 2097152, free heap 43040
                                        Signal strength -52dBm, channel 2, mode 802.11n, reconnections 0
                                        • Aurimasundefined
                                          Aurimas @dc42
                                          @dc42 @gloomyandy @Phaedrux
                                          guys got a question - does rolling back firmware completelly reinstalls it? I am having issues with 3 machines that worked find on RC2-RC4, but since I have installed 3.5.1 all of them have issues - reboots, overloads and so on. none of the machines work reliablly anymore.
                                            droftarts administrators @Aurimas
                                            Yes, it does, so long as all CAN connected boards and/or SBC are downgraded to the same firmware version.
                                            There’s very little difference between rc4 and 3.5.1. It’s mostly some small changes around multiple motion systems, but this can affect the functioning of macros. Without some user testing between versions, it’s impossible for us to account for all the wide and varied implementations of RRF. So please bear with us while we resolve issues. The alternative is that you stick with whatever version works, and don’t get the benefit of newer versions, and we never know that a change or bug causes an issue for a certain group of users.
