    Can't connect Duet 3 6HC v1.0 after updating to RRF 3.5.2
    Firmware installation
    909
    • Mr Yodundefined
      Mr Yod
      I loaded the firmware zip file via web interface, it supposedly install but, after rebooting it wasn't able to connect at all.
      Even USB wasn't able to connect via Pronterface (in windows device manager it says "Serial USB device (COM3)" when I connect it via USB).
      Already tried to delete all files under /firmware and /www and replace them with new files, but nothing.
      EDIT: stand alone, no SBC
        jay_s_uk @Mr Yod
        @Mr-Yod sounds like its BOSSA time
        https://docs.duet3d.com/en/User_manual/RepRapFirmware/Updating_firmware#all-other-duet-boards
        Mr Yodundefined 1 Reply Last reply Reply Quote 0
        • Mr Yodundefined
          Mr Yod @jay_s_uk
          @jay_s_uk
          Yeah: too bad BOSSA stays at 0% forever... 😬
          And for the DIAG LED: where TF is it?
            jay_s_uk @Mr Yod
            Mr Yodundefined 1 Reply Last reply Reply Quote 1
            • Mr Yodundefined
              Mr Yod @jay_s_uk
              @jay_s_uk in the 1.02, but, as I said, I have the 1.0: it's not there.
                droftarts administrators @Mr Yod
                @Mr-Yod said in Can't connect Duet 3 6HC v1.0 after updating to RRF 3.5.2:
                I have the 1.0
                It's in the same place, marked 'DIAG' on the PCB. For some reason it's not actually marked on the V1.0 and V1.01 schematic: https://docs.duet3d.com/duet_boards/duet_3_mb6hc/duet_3_mb6hc_wiring_diagram_v1.0_v1.01.png
                (You can find this on the tabs, here https://docs.duet3d.com/Duet3D_hardware/Duet_3_family/Duet_3_Mainboard_6HC_Hardware_Overview#wiring-diagram)
                The DIAG LED may light up dimly, or it may be off. If you haven't already, erase the firmware with a jumper as described in the instructions, before attempting to flash.
                • Mr Yodundefined
                  Mr Yod @droftarts
                  @droftarts said in Can't connect Duet 3 6HC v1.0 after updating to RRF 3.5.2:
                  Already tried, might try again later.
                    @Mr-Yod I’ve updated the instructions to make it clearer how to erase, and the state of the LED.
                    • Mr Yodundefined
                      Mr Yod @droftarts
                      Ok: found the DIAG LED, it's dim but it's on.
                      And BOSSA stays on "Writing page 0 (0%)" without any progress... 😬
                      But it's connected: "Device: ATSAME70x20"
                      • Mr Yodundefined
                        Mr Yod
                        After more than an hour: still 0%
                        • Mr Yodundefined
                          Mr Yod @Mr Yod
                          YAY!
                          I managed to flash the firmware!
                          I had to buy a 75cm long micro-USB cable graded for 480Mb/s to be able to do it, but it worked!
                          Then I tried something: I loaded again the firmware zip file ad told to update (it already was at 3.5.2) and it bricked again forcing me to re-flash the firmware...
                            What version is/was your DWC running?
                            Can you re-download 3.5.2 zip?
                            • Mr Yodundefined
                              Mr Yod @Phaedrux
                              @Phaedrux said in Can't connect Duet 3 6HC v1.0 after updating to RRF 3.5.2:
                              Now it's 3.5 (it was 3.4.5 on the first brick but it was 3.5 on the second)
                              I have only the uncompressed version, but I don't see how it can be useful, since it contains the same file I flashed with BOSSA. 🤔
                                You can only upload the zip file itself. DWC takes care of the rest. If you're uploading anything else that's probably the problem.
                                • Mr Yodundefined
                                  Mr Yod @Phaedrux
                                  I always uploaded the zip.
                                  I used the single uncompressed file only when flashing with BOSSA.
                                    What browser are you using?
                                    • Mr Yodundefined
                                      Mr Yod @Phaedrux
                                      @Phaedrux Web interface via Orca Slicer
                                        I'm not very familiar with Orca slicer. How does that work? It has a built in browser?
                                        What browser are you using to upload the firmware zip file?
                                        • Mr Yodundefined
                                          Mr Yod @Phaedrux
                                          So it seems. 🤔
                                          I told you: Web interface via Orca Slicer
                                            Phaedrux Moderator @Mr Yod
                                            Can you try chrome?
