    Problems from the second layer to the 7th layer
    1.2k
    • carlinicompetizioneundefined
      carlinicompetizione @oliof
      @oliof said in Problems from the second layer to the 7th layer:
      @carlinicompetizione A raspberry pi does not help here. There is some chance that this is not a software, but a hardware issue, i.e. the mechanism raising the nozzle (or lowering the bed) may be binding until it overcomes the early layers.
      You could try commanding the printer without issuing a full print, doing moves with the G0 and G1 commands after homing, to see how things behave.
      I would like to know if there is a possible solution to this problem that the system has that disregards the first layers?, the printer is industrial, and I have already spent too much time making it work with this Duet 3D 6HC card. I really need a solution, otherwise I have to change my motherboard to another brand that is less problematic and can print without so much hassle.
        droftarts administrators @carlinicompetizione
        @carlinicompetizione If we knew the answer to this issue, we would have told you already! We have to find out the information to try and solve it from you, so any information you can give us helps.
        it starts printing at Z=2 9 this value is the baby step
        I think you're saying that you are using 2mm of baby stepping. I'd guess this is the issue, and it's probably because you have not set the Z probe Z offset correctly. Baby stepping usually only needs to be a small adjustment, maybe +/- half a layer height. Much more than that, yes, odd things are likely to happen.
        Please set the Z probe Z offset again. Currently the X and Y offsets are set to 0 as well, so set them to. You're using a BLTouch I think, so there should definitely be an X, Y and Z offset. Your current probe offset is:
        G31 P500 Y0; definir valor de disparo da sonda Z, deslocamento e altura de disparo
        G31 P500 X0 Z0.85 ; definir valor de disparo da sonda Z, deslocamento e altura de disparo
        You can put this on one like together, like this:
        G31 P500 X0 Y0 Z0.85 ; definir valor de disparo da sonda Z, deslocamento e altura de disparo
        For setting Z probe X, Y and Z offset, see https://docs.duet3d.com/en/User_manual/Connecting_hardware/Z_probe_testing
        carlinicompetizioneundefined 1 Reply Last reply Reply Quote 0
          carlinicompetizione @droftarts
          @droftarts
          I believe we have discovered the problem. I started to slow down
          changing microsteps from 16 to 8 and Z began to move as programmed in the slicer. Without being satisfied with the result, I went back to 16 microsteps and lowered the instantaneous on Z by approximately 30%. Then I managed to print a piece with a higher quality than what I had until then. Even so, the first to second layer is not respecting the programmed distance.
          EX: the first layer starts at Z=0.40mm (this height is correct according to the baby step, also from 0.40mm or less. In the slicer, a layer height of 0.3mm was determined, so the second layer would start with Z=0.7mm , but it was only for 0.51mm, so I did a manual intervention just to understand if the next layers would maintain this flaw (I paused the printing and lowered the table manually to complete the 0.19 mm) when the second layer was finished and the third started. the value was already correct Z=0.81 mm. It seems to me like a bug in the firmware, it doesn't make sense to do that.
            @carlinicompetizione Did you try any of the things I suggested?
            • calibrate your Z probe offset - https://docs.duet3d.com/en/User_manual/Connecting_hardware/Z_probe_testing
            • try a print without baby stepping - set G92 Z0 with the nozzle just touching the bed before printing, don't home Z at the beginning of the print
            • try a print without mesh bed compensation
            And one more thing to try: yes, your Z jerk looks high to me, and so does your acceleration and maximum speed for Z, especially for the steps per mm on Z. I don't know the layout of your machine, how heavy the bed is, or even if the bed moves in Z, or if your gantry moves in Z. So the values you have might be okay, but might not be. Maybe post a picture of your printer so we can get a better idea of the size. For example, I have a bed slinger with 200x200mm bed and 2mm lead M8 leadscrews, and can only move them this fast before skipping (though they are quite small NEMA 17 motors):
            M92 Z800  ; set steps per mm
            M566 Z12  ; set maximum instantaneous speed changes (mm/min)
            M203 Z600 ; set maximum speeds (mm/min)
            M201 Z20  ; set accelerations (mm/s^2)
            Yours were set as:
            M92 Z1650.50
            M566 Z300.00
            M203 Z1000.00
            M201 Z250.00
            Though I'm not sure why your settings would not work to start with, and then work okay at later layers. If you can share a full Gcode file, that may help.
            I'd suggest setting low values for jerk, acceleration and maximum speed (ie like mine), and check if movement is correct. If it is, you can then increase them until you find the limit.
            carlinicompetizioneundefined 3 Replies Last reply Reply Quote 0
                @droftarts IMG_4889.MP4
                • tasundefined
                  tas @carlinicompetizione
                  I am wondering if commas and decimals are interchangeable in config.g.
                  Your M566 uses commas and the rest use decimals.
                  @carlinicompetizione said in Problems from the second layer to the 7th layer:
                  M566 X500,00 Y500,00 Z300,00 E1200,00 ; definir alterações instantâneas máximas de velocidade (mm/min)
                  M203 X3000.00 Y3000.00 Z1000.00 E1200.00 ; definir velocidades máximas (mm/min)
                  M201 X500.00 Y500.00 Z250.00 E1200.00 ; definir acelerações (mm/s^2)
                  carlinicompetizioneundefined 1 Reply Last reply Reply Quote 1
                    carlinicompetizione @tas
                    @tas
                    In the config.g in the file everything is with a dot, but I'll check, you'll see that something typing is getting in the way too
                      @droftarts
                      In these days I made several impressions to fine-tune the resolution that until then I could not make due to so much instability of operation. The last impressions with a 0.8 beak are getting good. using simplify3D that seems somewhat limited compared to Cura.
                      Even so, when starting the second layer, the table does not go down to the correct value. When it goes to third, it works normally. It's very strange. It doesn't make any sense. I lowered the Jerk values a lot from 500mm/min to 300mm/min. The z was at 110 I went to 60mm/min, but I will lower it more to see if it solves the problem of the second layer, it is interesting because it goes down only half the value stipulated by the slicer. But only in this layer that does this. Then take off cute.
                        Sounds like mechanical binding on the z axis. Are you able to turn the z axis by hand and feel for change in resistance?
                          carlinicompetizione @Phaedrux
                          @Phaedrux
                          @droftarts
                          I found some settings that really helped it work, but I believe that activating the M208 was the big point, because until then nothing was working, as if the machine didn't have a reference point, all the changes made up until now had already been done before but without realizing that the 208 was disabled. So I would like to contribute with the config.g file as it is and everything works.
                          ; Configuration file for Duet 3 MB 6HC (firmware version 3.3)
                          ; generated by RepRapFirmware Configuration Tool v3.3.16 on Sat Jun 24 2023 18:49:15 GMT-0300 (Horário Padrão de Brasília)
                          M83 ; but relative extruder moves
                          M550 P"UNO Print" ; set printer name
                          ; Wait a moment for the CAN expansion boards to start
                          G4 S2
                          M586 P0 S1 ; enable HTTP
                          M586 P1 S1 ; disable FTP
                          M586 P2 S0 ; disable Telnet
                          M569 P0.1 S0 ; physical drive 0.1 goes forwards
                          M569 P0.2 S0 ; physical drive 0.2 goes forwards
                          M569 P0.4 S0 ; physical drive 0.4 goes forwards
                          M569 P0.5 S0 ; physical drive 0.5 goes forwards
                          M584 X0.1 Y0.2:0.3 Z0.4:0.5 E0.0 ; set drive mapping
                          M92 X67.00 Y67.00 Z1650.50 E370.00 ; set steps per mm
                          M566 X300.00 Y300.00 Z15.00 E5500.00 ; set maximum instantaneous speed changes (mm/min)
                          M203 X3500.00 Y3500.00 Z1100.00 E5500.00 ; set maximum speeds (mm/min)
                          M201 X300.00 Y300.00 Z180.00 E100.00 ; set accelerations (mm/s^2)
                          M906 X1680 Y1600 Z1600 E920 I90 ; set motor currents (mA) and motor idle factor in per cent
                          M84 S75 ; Set idle timeout
                          M208 X700 Y400 Z400 S0 ; set axis maxima
                          M574 X1 S1 P"121.io2.in" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin io0.in
                          M574 Y1 S1 P"io1.in+io2.in" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin io1.in+io2.in
                          M574 Z2 S1 P"io4.in+io5.in" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin io3.in+io4.in
                          M574 Z1 S2
                          ;M574 X1 S1 P"121.io2.in" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin io0.in
                          ;M574 Y1 S1 P"io1.in+io2.in" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin io1.in+io2.in
                          ;M574 Z1 S1 P"io3.in+io4.in" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin io3.in+io4.in
                          ;M574 Z1 S2 ; configure Z-probe endstop for low end on Z
                          ;M574 Z1 S1 P"io3.in+io4.in" ; configure endstop for high end on Z
                          M308 S0 P"temp0" Y"pt1000" ; configure sensor 0 as PT1000 on pin temp0
                          M308 S1 P"121.temp0" Y"pt1000" ; configure sensor 1 as PT1000 on pin 121.temp0
                          M950 H1 C"121.out0" T1 ; create nozzle heater output on 121.out0 and map it to sensor 1
                          M950 F0 C"121.out1" Q500 ; create fan 0 on pin 121.out1 and set its frequency
                          M950 F1 C"121.out2" Q500 ; create fan 1 on pin 121.out2 and set its frequency
                          M106 P1 S1 H-1 ; set fan 1 value. Thermostatic control is turned off
                          M950 S0 C"121.io0.out" ; Duet 3 MB6HC
                          M558 P9 C"121.io0.in" H5 F120 T6000 ; Duet 3 MB6HC
                          G31 P500 Y0 ; set Z probe trigger value, offset and trigger height
                          G31 P500 X0 Z0.65 ; set Z probe trigger value, offset and trigger height
                          M557 X125:650 Y50:350 S262.5:150 ; define mesh grid
                          ;M374
                          ;M374 P"HeightMap.csv"
                          ;M375
                          ;M375 P"HeightMap.csv" ; Salva o mapa da grid do autolevel
                          M376 H10 ; corrige a sobre extrusão na compensaão até 5%
                          M575 P1 S1 B57600
                          ;M572 D0 S0.45 ; definir o avanço de pressão da extrusora 0 para 0,1 segundos
                          M950 D1 C"spi.cs0+spi.cs2" ; PanelDue
                          M591 D0 P3 C"io6.in" S1 R5:170 ; filament monitor connected to io6.in
                            Phaedrux Moderator @carlinicompetizione
                            ;M208 X0 Y0 Z0 S1 ; set axis minima
                            why was it commented out in the first place?
                              @carlinicompetizione I don't know why leaving out the M208 command would cause this issue, because if it is missing, the firmware sets a default of 0 (for minimum) and/or 200 (for maximum) in each axis. eg if I comment out all M208 commands in my config.g, then send M208 after a restart, it reports:
                              M208
                              Axis limits (mm) X0.0:200.0, Y0.0:200.0, Z0.0:200.0
