    Out of Sync for sync motors (same Axis)
    741
      droftarts administrators @maor3degem.co.il
      @maor3degem-co-il said in Out of Sync for sync motors (same Axis):
      in the second, the Z motor also turning different length , the same symptom as with the X axis. and the Z connected to the main board
      It is possible interference on the SPI bus via the ribbon cable, or poor ground between the Duet and DueX, could affect the drivers on the main board as well. Please look at my previous message for advice. Please post a picture of the wiring if that doesn't help.
      in addition we face this problem with a few machines we have (5) and it is occur also in the main boards drivers.
      Maybe they are all wired the same way? What is different about these 5 machines compared to the other 15?
      please advice what else can help us to solve this problems
      At the moment, I don't have any other theory about what is wrong based on the information you have give, or I'd tell you.
      • maor3degem.co.ilundefined
        maor3degem.co.il @maor3degem.co.il
        @maor3degem-co-il
        we have 15 machine that look pretty much the same.
        we used them for 4 years without any problem like this,
        this start happen in the last 4 months...
        can heavy dust cause this?
          @maor3degem-co-il I also note on your last image there is an error on the PanelDue:
          I think this says "Driver 3 error: Phase A short to ground phase B short to ground". Is that correct? Did the Y axis wires cut when the carriage fell?
          Do you mean on the Duet boards, or on the mechanical components? However, I don't think either would cause these kind of problems, because something is causing the configuration of the driver chip to change without the firmware knowing. Though it wouldn't hurt to use compressed air to clean off the boards, if there's a lot of dust on the boards. If there's dust in the mechanics, I'd expect skipped steps rather than a change in the driver configuration.
          After 4 years, it's probably time to check/replace wiring, check contact especially in screw terminals, etc.
          maor3degem.co.ilundefined 1 Reply Last reply Reply Quote 0
            maor3degem.co.il @droftarts
            @droftarts
            The driver error is due to the carriage fall cut the wire.
            by the way, the machine is on pause right now and I can see the problem of the motors. if I will restart the machine the problem will go a way till next time.
            and before restart the is no evidence of changing in the configuration
              maor3degem.co.il @Maestro
              @Maestro
              I double checked it and
              the motor doesn't move 1/16 cycles than the other
              both motors are define in the same axis so it is impossible to define different micro stepping for each motor. and when I typed M584 the machine return 1:16 micro stepping for those X axis drivers/motors
              Regards
              Maor
                @maor3degem-co-il @Maestro
                Regards
                Maor
                Maestroundefined droftartsundefined 2 Replies Last reply Reply Quote 0
                • Maestroundefined
                  Maestro @maor3degem.co.il
                  @maor3degem-co-il
                  I'm not sure what you mean by "the motor doesn't move 1/16 cycles than the other"? Irrespective of whatever values are read from firmware or anywhere else, that first video you loaded shows one motor moving 1/16 the speed of the other, at least within the resolution of the video to quantify.
                  Even it if is not possible to deliberately set different microstepping for 2 motors on the same axis in the firmware, that doesn't negate @droftarts's point that the drivers themselves could potentially decide that they've been given a different value due to noisy instruction sets.
                    @maor3degem-co-il Sorry you are continuing to have issues.
                    To reiterate, I believe the problem is caused by the interference on the SPI bus causing one or more stepper drivers to reset its configuration, usually on the Duex, independently of the firmware. I think there are three possible reasons for this:
                    1. Interference caused by poor grounding between Duet and Duex boards, causing a potential difference in signalling on the SPI bus. Check/replace the grounding between the Duet and Duex, as described here https://docs.duet3d.com/Duet3D_hardware/Duet_2_family/DueX2_and_DueX5#power-wiring. Check for good contact of power and ground wires, especially in screw terminals.
                    2. Interference caused by other wires. Check there are no other wires running close to or across the ribbon cable between the Duet and Duex. Ribbon cables are quite susceptible to interference; wrapping them in foil can help, but better to remove any close source of interference.
                    3. Interference caused by ESD (Electro Static Discharge). You mentioned dust in the environment. Is it a particularly low humidity time of year? This could cause more static shocks that usual. How is the rest of the machine grounded? Is the hot end grounded (we recommend doing this)? Have you changed to a different type of filament that may be more susceptible to static build up?
                    As I asked before, please post pictures of the wiring cabinet, and the wiring around the Duet and Duex in particular.
                      @droftarts
                      Hi.
                      another event.
                      it is certainly looks like 1 driver out of 4 of X axis lost his microsteping definition.
                      [M350 Lost for 1 of 4 X axis drivers.
                      M122.txt config.g M350 Lost for 1 of 4 X axis drivers.mp4
                      attached is a video nd config + M122 output.
                      please advice.
                      this happen with multiple FW version (3.3 + 3.4.5 + 3.5.2)
                      this happen with drivers from the duet/duex
                      ; generated by RepRapFirmware Configuration Tool v3.2.3 on Sun Jun 06 2021 20:45:39 GMT+0300 (Israel Daylight Time)
                      G90                                            ; send absolute coordinates...
                      M83                                            ; ...but relative extruder moves
                      M550 P"FT6_7"                                    ; set printer name
                      M552 S1                                        ; enable network
                      M586 P0 S1                                     ; enable HTTP
                      M586 P1 S0                                     ; disable FTP
                      M586 P2 S0                                     ; disable Telnet
                      M584 X3:4:5:6 Y0 Z8:7 E1:2
                      M671 X-220:740 Y175:175 S15 ; leadscrews at left (connected to Z) and right (connected to E1) of X axis
                      M569 P0 S0                               ; Drive 0 goes forwards
                      M569 P1 S1                               ; Drive 1 goes backwards
                      M569 P2 S1                               ; Drive 2 goes backwards
                      M569 P3 S1                               ; Drive 3 goes forwards
                      M569 P4 S0                               ; Drive 4 goes backwards
                      M569 P5 S0                               ; Drive 5 goes forwards
                      M569 P6 S1                               ; Drive 6 goes forwards
                      M569 P7 S0                               ; Drive 7 goes forwards
                      M569 P8 S0                               ; Drive 8 goes forwards
                      M569 P9 S0                               ; Drive 9 goes forwards
                      M350 X16 Y16 Z16 E16 I1                  ; Configure microstepping with interpolation
                      M92 X80.00 Y80.00 Z1440 E400        ; Set steps per mm
                      M566 X900 Y900 Z24 E1200.00              ; Set maximum instantaneous speed changes (mm/min)
                      M203 X12000.00 Y12000.00 Z720 E7200.00  ; Set maximum speeds (mm/min)
                      M201 X1000.00 Y1000.00 Z500.00 E10000.00 ; Set accelerations (mm/s^2)
                      M906 X1600.00 Y1200.00 Z1600.00 E750.00 I30; Set motor currents (mA) and motor idle factor in per cent
                      M84 S30                                  ; Set idle timeout
                      ; switch motor
                      M950 P0 C"spi.cs1"
                      M950 P1 C"spi.cs2"
                      M950 P2 C"spi.cs3"
                      M208 X0 Y0 Z0 S1                               ; set axis minima
                      M208 X750 Y350 Z750 S0                         ; set axis maxima
                      M574 X1 S1 P"!xstop"                            ; configure active-high endstop for low end on X via pin xstop
                      M574 Y1 S1 P"!ystop"                            ; configure active-high endstop for low end on Y via pin ystop
                      M574 Z1 S2                                      ; configure Z-probe endstop for low end on Z
                      ;M591 D0 P3 C"e0_stop" S1 R70:130 L24.8 E1000 ; Duet3D rotating magnet sensor for extruder drive 0 is connected to E0 endstop input, enabled, sensitivity 24.8mm.rev, 70% to 130% tolerance, ;3mm detection length
                      M591 D0 ; display filament sensor parameters for extruder drive 0
                      ;M591 P3 C"e0_stop" S1 D3 L3 E4                          ; filament monitor connected to E0_stop
                      M558 P1 C"zprobe.in" H5 F500:50 T6000             ; set Z probe type to unmodulated and the dive height + speeds
                      G31 P500 X-10 Y25 Z0                       ; set Z probe trigger value, offset and trigger height
                      M557 X15:700 Y30:320 p20:14                      ; define mesh grid
                      M376 H50
                      M308 S0 P"bedtemp" Y"thermistor" T100000 B4092     ; configure sensor 0 as thermistor on pin bedtemp
                      M950 H0 C"bedheat" T0                              ; create bed heater output on bedheat and map it to sensor 0
                      M307 H0                                            ; enable bang-bang mode for the bed heater and set PWM limit
                      M140 H0                                            ; map heated bed to heater 0
                      M143 H0 S150                                       ; set temperature limit for heater 0 to 150C
                      M308 S1 P"e0temp" Y"thermistor" T100000 B4580 C7.06e-8      ; configure sensor 1 as thermistor on pin e0temp
                      M950 H1 C"e0heat" T1                               ; create nozzle heater output on e0heat and map it to sensor 1
                      M307 H1 B0 S1.00                                   ; disable bang-bang mode for heater  and set PWM limit
                      M143 H1 S400                                       ; set temperature limit for heater 1 to 275C
                      M308 S2 P"e0temp" Y"thermistor" T100000 B4580 C7.06e-8      ; configure sensor 2 as thermistor on pin e1temp
                      M950 H2 C"e0heat" T2                               ; create nozzle heater output on e1heat and map it to sensor 2
                      M307 H2 B0 S1.00                                   ; disable bang-bang mode for heater  and set PWM limit
                      M143 H2 S400                                       ; set temperature limit for heater 2 to 275C
                      M308 S3 P"e0temp" Y"thermistor" T100000 B4580 C7.06e-8      ; configure sensor 3 as thermistor on pin duex.e2temp
                      M950 H3 C"e0heat" T3                               ; create nozzle heater output on duex.e2heat and map it to sensor 3
                      M307 H3 B0 S1.00                                   ; disable bang-bang mode for heater  and set PWM limit
                      M143 H3 S400                                       ; set temperature limit for heater 3 to 275C
                      M308 S4 P"e0temp" Y"thermistor" T100000 B4580 C7.06e-8      ; configure sensor 4 as thermistor on pin duex.e2temp
                      M950 H4 C"e0heat" T4                               ; create nozzle heater output on duex.e2heat and map it to sensor 4
                      M307 H4 B0 S1.00                                   ; disable bang-bang mode for heater  and set PWM limit
                      M143 H4 S400                                       ; set temperature limit for heater 4 to 275C
                      M308 S5 P"e0temp" Y"thermistor" T100000 B4580 C7.06e-8      ; configure sensor 5 as thermistor on pin duex.e2temp
                      M950 H5 C"e0heat" T5                               ; create nozzle heater output on duex.e2heat and map it to sensor 5
                      M307 H5 B0 S1.00                                   ; disable bang-bang mode for heater  and set PWM limit
                      M143 H5 S400                                       ; set temperature limit for heater 5 to 275C
                      M950 F0 C"fan0" Q500                           ; create fan 0 on pin fan0 and set its frequency
                      M106 P0 S0 H-1                                 ; set fan 0 value. Thermostatic control is turned off
                      M950 F1 C"fan1" Q500                           ; create fan 1 on pin fan1 and set its frequency
                      M106 P1 S1 H1 T45                              ; set fan 1 value. Thermostatic control is turned on
                      M563 P0 D0:1 H1 F0                                  ; define tool 0
                      M567 P0 E1.0:1.0
                      M563 P1 D0:1 H1 F0                                   ; define tool 1
                      M567 P1 E1.0:1.0
                      M563 P2 D0:1 H1 F0                                   ; define tool 2
                      M567 P2 E1.0:1.0
                      M563 P3 D0:1 H1 F0                                   ; define tool 3
                      M567 P3 E1.0:1.0
                      M563 P4 D0:1 H1 F0                                   ; define tool 4
                      M567 P4 E1.0:1.0
                      M563 P5 D0:1 H1 F0                                   ; define tool 5
                      M567 P5 E1.0:1.0
                      G10 P0 X0 Y0 Z0                                    ; set tool 0 axis offsets
                      G10 P1 X0 Y0 Z0                                    ; set tool 1 axis offsets
                      G10 P2 X0 Y0 Z0                                    ; set tool 2 axis offsets
                      G10 P3 X0 Y0 Z0                                    ; set tool 3 axis offsets
                      G10 P4 X0 Y0 Z0                                    ; set tool 4 axis offsets
                      G10 P5 X0 Y0 Z0                                    ; set tool 5 axis offsets
                      G10 P0 R0 S0                                       ; set initial tool 0 active and standby temperatures to 0C
                      G10 P1 R0 S0                                       ; set initial tool 1 active and standby temperatures to 0C
                      G10 P2 R0 S0                                       ; set initial tool 2 active and standby temperatures to 0C
                      G10 P3 R0 S0                                       ; set initial tool 2 active and standby temperatures to 0C
                      G10 P4 R0 S0                                       ; set initial tool 2 active and standby temperatures to 0C
                      G10 P5 R0 S0                                       ; set initial tool 2 active and standby temperatures to 0C
                      M575 P1 S1 B57600                              ; enable support for PanelDue
                      M501                                                            ; load saved parameters from non-volatile memory
                      M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000"              ; set voltage thresholds and actions to run on power loss
                      jay_s_ukundefined droftartsundefined 2 Replies Last reply Reply Quote 0
                        jay_s_uk @maor3degem.co.il
                        @maor3degem-co-il please post the information @droftarts requested in his previous post
                          maor3degem.co.il @jay_s_uk
                            @maor3degem-co-il Thank you for adding the pictures of the wiring.
                            The M122.txt file you posted seems to be blank.
                            I've added your config.g to your post, to make it easier to check, but I don't think that is causing the issue.
                            It would be helpful if you could answer questions, rather than restating the issue each time.
                            Currently, we think:
                            • The issue is not caused by firmware or config. It's happening across all firmware versions you have tried, with firmware versions up to 3 years old (RRF 3.3). We would have other reports of this if it was a firmware issue. You have other machines that are not affected, running the same firmware and config.
                            • The issue is unlikely to be caused by the Duet hardware. You could try swapping the Duet and Duex from a machine that has no issue, if you wanted to rule this out. But it would be very strange that 5 Duet/Duex boards suddenly have the same issue at the same time.
                            • It is by far the most likely cause is that interference on the SPI bus via the ribbon cable is causing this issue.
                            • It is also possible it is caused by an environmental issues (high heat and/or humidity), or a change in process (different filament), causing a change in static electricity build up. The issue seems to occur after an extended period of time printing, I think?
                            I have already explained how to mitigate these issues:
                            1. Check/replace GND wire between Duet and Duex. A poor ground wire causes a potential difference on the GND pin between the Duet and Duex, and can cause interference. Your image shows the VIN/GND wire being longer than necessary. Wire a shorter ground wire, with a thicker gauge of wire, between the Duet and Duex.
                            2. Route other wires away from the ribbon cable. These ones seem close:
                            3. For static/ESD issues, make sure the hot end and extruder are grounded.
