    Z-axis / tramming issues with 3.6.0-alpha2+3
    Beta Firmware
    2.5k
    • edspedundefined
      edsped @Exerqtor
      @Exerqtor
      Nozzle, gammamaster, appears to be okay, No first layer or offset issues so I'm guessing the rapido is okay but I wouldn't be surprised if the heatbreak isn't a little tweaked. I've got thousands of toolchanges and the same with print starts and this is the first time, other than the initial commissioning of the printer that I had something like this happen. I'm definitely bummed but knew what I was getting into when I loaded an alpha firmware. Coarse tramming was definitely not as good on 3.6 as it is on 3.5.2 as can be seen in my screenshots.
      • edspedundefined
        edsped
        My bed.g is pretty basic but am posting just i case it helps..
        bed.g
        DonStaufferundefined 1 Reply Last reply Reply Quote 0
        • DonStaufferundefined
          DonStauffer @gloomyandy
          @gloomyandy
          ;	MoveZStepper Macro
          ;	Moves one Z stepper independently, for manual, coarse tramming. Creates
          ;	(or reuses) an A axis for the purpose, then hides it when done.
          ;	Parameters:
          ;		N	Stepper number (default: 7)
          ;		Z	Distance. which may be negative to move up (default: 1)
          ;		S	Speed (default: 150)
          ;	Don Stauffer					July, 2024
          ;if global.DebugLevel >= 1200
          ;	var This = "MoveZStepper"
          ;	set var.This = var.This^(exists(param.N) ? " N"^param.N : "")
          ;	set var.This = var.This^(exists(param.Z) ? " Z"^param.Z : "")
          ;	set var.This = var.This^(exists(param.S) ? " S"^param.S : "")
          ;	echo var.This
          ;	Parameters
          var StepperNum = (exists(param.N) ? param.N : 7)
          var Distance = (exists(param.Z) ? param.Z : 1)
          var Speed = (exists(param.S) ? param.S : 150)
          ;	Echo back what will be done
          echo "Moving Z stepper", var.StepperNum, "by", var.Distance
          ;	Create A axis if necessary; make it visible if it already exists
          var DoesAAxisExist = false
          while iterations < #move.axes
          	if move.axes[iterations].letter != "A"
          		continue
          	set var.DoesAAxisExist = true
          	break
          if var.DoesAAxisExist
          	M584 P4
          M584 A{var.StepperNum}
          ;	Configuration adapted from config.g. Not sure if everything is needed here
          M669 K1			    ;	CoreXY mode
          M350 A16 I1		    ;	16x microstepping for axes & extruder, w/interpolation
          M574 A1 S2			;	Set Endstop configuration (P"pin_name"); S2 = Z probe
          M906 A1500 I60		;	Set motor currents (mA)
          M203 A{var.Speed}	;	Maximum speeds (mm/min)
          M566 A12			;	Jerk
          M201 A90			;	Max acceleration
          M208 A635			;	Set axis maxima & high homing switch positions
          M208 A-0.5 S1		;	Set axis minima & low homing switch positions
          M92 A3200			;	Steps/mm
          ;	Move the Z stepper as the "A axis"
          G91
          G1 A{var.Distance} H2
          ;	Reset everything back to the same as config.g
          M584 X0 Y1 Z5:6:7	;	Map Z to drivers 5, 6, 7.
          M350 Z16 I1		    ;	16x microstepping for axes & extruder, w/interpolation
          M574 Z1 S2			;	Set Endstop configuration (P"pin_name"); S2 = Z probe
          M906 Z1500 I60		;	Set motor currents (mA)M203 Z600
          M203 Z600			;	Maximum speeds (mm/min)
          M566 Z12			;	Jerk
          M201 Z90			;	Max acceleration
          M208 Z635			;   set axis maxima & high homing switch positions
          M208 Z-0.5 S1		;   set axis minima & low homing switch positions
          M92 Z3200			;   Steps/mm
          ;	Hide A-axis by setting number of visible axes back to 3
          M584 P3
          ;	echo "Leaving MoveZStepper"
            @gloomyandy If you tell me the procedure I'll revert and then test it.
            It's possible that the direction problem is that when a negative adjustment is needed, it does a positive adjustment. That does happen. I don't know if it happens the other way around, but I have seen this.
              dc42 administrators @DonStauffer
              @DonStauffer @Exerqtor @edsped thanks for reporting this. I'm sorry for any damage caused.
              I don't have a system with multiple Z motors that I can test on, but I think I know what is causing this. It's to do with getting the motor direction wrong when switching between normal Z moves and leadscrew adjustment moves. Please can you identify for me which of the following is happening:
              1. When the first bed tramming move is executed, some of the motors move in the wrong direction.
              2. Immediately after the first bed tramming move is executed, when executing a normal Z move (which could be part of a new G32 probing sequence), some of the the Z motors move in the wrong direction.
              3. Both of the above.
              If the main problem is #2 then a workaround for now might be to insert M400 after the G32 call, to ensure motion stops before another Z move is executed.
              Exerqtorundefined DonStaufferundefined 3 Replies Last reply Reply Quote 0
              • Exerqtorundefined
                Exerqtor @dc42
                @dc42 said in Z-axis / tramming issues with 3.6.0-alpha2+3:
                It's part of the course with testing pre-release stuff imo! Win some loose some 😅
                Well, when I think back the first time it happened for me was during the Z homing routine before tramming start. I think it was between one of the "tolerance" moves when doing G30. Did the first move, went to lower the bed to specified dive height, but rather than switching over the two front axis to rise up again to "engage" the second probe once dive height was reached they contiuned on a downwards motion.
                The other times it happened it seemd to apply the axis adjustements wronlgy (in 1 or all axis) when it was done with the G30 moves for tramming.
                If that made sense?
                  DonStauffer @dc42
                  @dc42 I have not had bed tramming without one of the motors going the wrong direction since installing alpha 2. I will have to test for #2. I don't think I've seen it but I wasn't looking for it.
                    DonStauffer @edsped
                    @edsped Here's my bed.g, and the DefineBed macro you have to run to create the global Bed variable it uses for the data points:
                    ;	bed.g
                    ;	Bed leveling macro.
                    ;   Subscript Constants
                    var LEV = 1
                    ;   Other Constants
                    var ITERATION_COUNT_MAX = 15
                    var ERR_ALLOWED = 0.005
                    ;	Clear any existing bed transform and move up
                    M561
                    G1 H2 Z5
                    ;	Start NeoPixel progress meters
                    ;M98 P"0:/macros/Lights/NeoPixel/Progress/BedLeveling/StartProgressMeters" E{var.ERR_ALLOWED}
                    ;	Iteratively attempt to level the bed
                    var Raw = null
                    var Abs = null
                    var Sign = null
                    var x = null
                    var y = null
                    var z = null
                    var Err = pow(2, 31)		;	"infinity"
                    while iterations < var.ITERATION_COUNT_MAX && var.Err > var.ERR_ALLOWED
                    	;   Retrieve and probe the points
                    	while iterations < #(global.Bed[var.LEV])
                    		;   Decode probe point coordinates
                    		set var.Raw = mod(global.Bed[var.LEV][iterations], pow(2, 15))
                    		set var.Abs = mod(var.Raw, pow(2, 14))
                    		set var.Sign = floor((var.Raw - var.Abs) / pow(2, 14) + 0.5)
                    		set var.x = var.Abs * (1 - var.Sign * 2)
                    		set var.Raw = floor((global.Bed[var.LEV][iterations]-var.Raw)/pow(2, 15)+ 0.5)
                    		set var.y = var.Abs * (1 - var.Sign * 2)
                    		;	Moving this way updates move.axes[i].userPosition faster
                    		;	(Important for NeoPixel progress meter for index)
                    		set var.z =sensors.probes[0].diveHeights[0]-sensors.probes[0].offsets[2]
                    		;	Probe the point
                    		if iterations ==  #(global.Bed[var.LEV]) - 1
                    			G30 P{iterations} X{var.x} Y{var.y} Z-99999 S3
                    			;G30 P{iterations} X{var.x} Y{var.y} Z-99999 S{#(global.Bed[var.LEV])}
                    		else
                    	;	Calculate the error sum
                    	set var.Err = abs(move.calibration.initial.mean)
                    	set var.Err = var.Err + move.calibration.initial.deviation
                    	if global.DebugLevel > 1000
                    		echo "Error="^var.Err,"Mean="^move.calibration.initial.mean,"Dev="^move.calibration.initial.deviation
                    if var.Err > var.ERR_ALLOWED
                    	echo "Leveling didn't converge;",var.ITERATION_COUNT_MAX,"tries. Error="^var.Err
                    else
                    	echo "Leveling converged. Error="^var.Err
                    ;	Move to center (necessary for NeoPixel progress meters to detect done)
                    G53 G1 X150 Y150 F9000
                    ;	Wait for NeoPixel progress mweter processes to end themselves
                    ;M98 P"0:/macros/Lights/NeoPixel/Progress/WaitForEnd"
                    ;	DefineBed Macro
                    ;   Initializes global.Bed.
                    ;   global.Bed[var.LEV] contains the 3 probe points for bed leveling, encoded
                    ;   as bitmaps to save memory.
                    ;   This is intended to be called from config.g.
                    ;   The X and Y coordinates of each point are compressed into a single integer
                    ;   for memory conservation. The decoding routine is at the bottom of this file.
                    ;	echo "DefineBed"
                    var HTR = 0
                    var OM = 0
                    ;var STATE = 1
                    var LEV = 1
                    ;   Create global.Bed if necessary
                    if !exists(global.Bed)
                        global Bed = vector(2, null)
                        set global.Bed[var.HTR] = vector(2, null)
                        set global.Bed[var.LEV] = vector(3, null)
                    ;   Define probe points for bed leveling; bitmap encode to save memory
                    var x = {10, 10, 265}
                    var y = {12, 228, 100}
                    while iterations < 3
                        ;   Encode x and y coordinates into a single integer
                        var xEnc = abs(var.x[iterations]) + (var.x[iterations] < 0 ? pow(2, 14) : 0)
                        var yEnc = abs(var.y[iterations]) * pow(2, 15)
                        set var.yEnc = var.yEnc + (var.y[iterations] < 0 ? pow(2, 29) : 0)
                        set global.Bed[var.LEV][iterations] = var.xEnc + var.yEnc
                    ;   Set up bed heater information
                    while iterations < #heat.bedHeaters
                        if heat.bedHeaters[iterations] != -1
                            set global.Bed[var.HTR][var.OM] = iterations
                            break
                    ;	echo "Leaving DefineBed"
                    M99
                    ;   To decode bitmap-encoded probe points:
                        var P = global.Bed[var.LEV][iterations]
                        var xRaw = mod(var.P, pow(2, 15))
                        var yRaw = floor((var.P - var.xRaw) / pow(2, 15) + 0.5)
                        var xAbs = mod(var.xRaw, pow(2, 14))
                        var yAbs = mod(var.yRaw, pow(2, 14))
                        var xSign = floor((var.xRaw - var.xAbs) / pow(2, 14) + 0.5)
                        var ySign = floor((var.yRaw - var.yAbs) / pow(2, 14) + 0.5)
                        var xDec = var.xAbs * (1 - var.xSign * 2)
                        var yDec = var.yAbs * (1 - var.ySign * 2)
                        echo "("^var.xDec^",", var.yDec^")"
                    Exerqtorundefined 1 Reply Last reply Reply Quote 0
                    • Exerqtorundefined
                      Exerqtor @DonStauffer
                      Just slapped together a stripped down bed.g, hopefully i get time to test it either today or tomorrow.
                      bed.g
                        DonStauffer @dc42
                        @dc42 Here are my testing results.
                        In bed.g, I inserted immediately after my first G30:
                        		G1 Z25 F75
                        		M99
                        Then I homed and did a G32. Nothing that happened was unexpected. The motors all ran in the correct direction. So the only issue I can confirm is that the adjustment when the G30 with the S parameter executes goes in the wrong direction for one of the motors - and not always the same one. Initially it was #7. Then when I did my "manual" tramming with bed.g doing S-1 to report the correct adjustments, it was #6. I did that manual tramming over and over, making very conservative adjustments, and throughout several hours it remained #6. But it absolutely was a different motor than the problem started on. And there's no doubt it isn't just a simple reversal - it's conditional, only apparently happening on the G30 S adjustments.
                        So, my answer is "neither #1 nor #2".
                        • edspedundefined
                          edsped
                          Switched back to 3.6 alpha 2 +3 and for me at least it looks like it's applying the the leadscrew adjustments in the wrong direction. If you look at my screenshot the offsets pretty much double on each iteration. Note, for the initial print adjustments were similar to what I got on 3.5.2 but G32 after the print gave the wonky adjustments.
                          Disregard the bed.g warnings I inadvertently hit save when exiting out of the editor.
                          edspedundefined DonStaufferundefined 2 Replies Last reply Reply Quote 0
                          • edspedundefined
                            edsped @edsped
                            @edsped Running a second tram immediately following the above resulted in my front left leadscrew ending ~4mm higher than the other two... FWIW, the front left side of my bed is also where my nozzle crashed due to that corner of the bed being too high. I should clarify, higher on my printer is actually - Z
                            Edit:
                            Powered down and back up and now get the following on G32...
                            8/3/2024, 4:38:57 PM Error: Compensation or calibration cancelled due to probing errors
                            8/3/2024, 4:38:52 PM Error: G30: Probe was not triggered during probing move
                              DonStauffer @edsped
                              @edsped Interesting. I was only having one of the three go in the wrong direction.
                              edspedundefined 1 Reply Last reply Reply Quote 0
                              • edspedundefined
                                edsped @DonStauffer
                                @DonStauffer That's what mine was doing the first time. I reverted to 3.5.2 then back to 3.6 a2+3 and added the M400 as suggested by @dc42 and what I posted above are my results. This time knowing what I was looking for I was able to bail before anything bad happened.
                                  dc42 administrators @edsped
                                  Currently, after performing probing a bed tramming move is executed with all Z motors moving simultaneously in different amounts and a mixture of directions. Would there be any problem if the Z motor moves were executed one at a time sequentially instead?
                                  gloomyandyundefined Exerqtorundefined 2 Replies Last reply Reply Quote 0
                                  • gloomyandyundefined
                                    gloomyandy @dc42
                                    @dc42 Could this in some situations cause a nozzle strike? I'm thinking of a situation with a very highly tilted bed and homing/probing in the middle portion of the bed, you could in theory end up with the nozzle lower then one edge of the bed and if you then raise the (currently) lower edge first the bed would hit the nozzle? The same situation with a simultaneous move may not cause the strike? Probably not very likely though.
                                    Possible mitigating actions: Perform any negative (moving the bed away from the nozzle) moves first? Limit the distance each motor moves in one operation and cycle through the motors until the move is complete?
                                      dc42 administrators @gloomyandy
                                      @gloomyandy said in Z-axis / tramming issues with 3.6.0-alpha2+3:
                                      If the probe had to make a deeper than normal move ton reach the lower edge, it will still rise to the dive height above the Z=0 reference afterwards. So I don't think this is a risk, provided that the maximum permitted correction is less than the dive height - which already needs to be the case if nozzle strikes are to be avoided.
                                      • Exerqtorundefined
                                        Exerqtor @dc42
                                        I don't know if this is possible, but is it possible to do it sequentially like you are proposing, but RRF "automatically" choose which axis/stepper to move 1st, 2nd, 3rd, etc. depending on the specified adjustmen that has to be made (taking my drive mapping as example)?
                                        ; (While looking at the printer top down)
                                        ;             0.0-----0.1
                                        ;              |  0.2  |
                                        ;              |0.3|0.4|
                                        ;                Front
                                        ;  Driver 0.1 & 0.2 is for the CoreXY motion, 0.2-0.4 is for the bed kinematics.
                                        Example 1:
                                        Adjustments needed after probing:
                                        • Driver 0.2 = -0.5mm
                                        • Driver 0.3 = -0.2mm
                                        • Driver 0.4 = +0.9mm
                                        To avoid potential nozzle craches RRF will move the driver/axis that needs to adjust TOWARDS the nozzle last, and the driver/axis that needs to move the most AWAY from the nozzle first:
                                        1. Lower driver 0.4 by 0.9mm.
                                        2. Raise driver 0.3 by 0.2mm.
                                        3. Raise driver 0.2 by 0.5mm.
                                        This should both put the least mechanical strain on the bed (depending on how the bed is built ofc.), and it would provide maximal clearance to the nozzle.
                                        Example 2:
                                        • Driver 0.2 = +3.7mm
                                        • Driver 0.3 = -0.3mm
                                        • Driver 0.4 = +1.1mm
                                        Adjustment order:
                                        1. Lower driver 0.2 by 3.7mm.
                                        2. Lower driver 0.4 by 1.1mm.
                                        3. Raise driver 0.3 by 0.3mm.
                                        dc42undefined gloomyandyundefined 2 Replies Last reply Reply Quote 1
                                          dc42 administrators @Exerqtor
                                          @Exerqtor that's a good idea.
                                            gloomyandy @Exerqtor
                                            @Exerqtor said in Z-axis / tramming issues with 3.6.0-alpha2+3:
                                            To avoid potential nozzle craches RRF will move the axis the driver/axis that needs to adjust TOWARDS the nozzle last, and the driver/axis that needs to move the most AWAY from the nozzle first:
                                            Yes that's what I was suggesting with:
                                            Exerqtorundefined 1 Reply Last reply Reply Quote 1
