    Z-axis / tramming issues with 3.6.0-alpha2+3
    Beta Firmware
    2.5k
    • DonStaufferundefined
      DonStauffer @gloomyandy
      @gloomyandy If you tell me the procedure I'll revert and then test it.
      It's possible that the direction problem is that when a negative adjustment is needed, it does a positive adjustment. That does happen. I don't know if it happens the other way around, but I have seen this.
        dc42 administrators @DonStauffer
        @DonStauffer @Exerqtor @edsped thanks for reporting this. I'm sorry for any damage caused.
        I don't have a system with multiple Z motors that I can test on, but I think I know what is causing this. It's to do with getting the motor direction wrong when switching between normal Z moves and leadscrew adjustment moves. Please can you identify for me which of the following is happening:
        1. When the first bed tramming move is executed, some of the motors move in the wrong direction.
        2. Immediately after the first bed tramming move is executed, when executing a normal Z move (which could be part of a new G32 probing sequence), some of the the Z motors move in the wrong direction.
        3. Both of the above.
        If the main problem is #2 then a workaround for now might be to insert M400 after the G32 call, to ensure motion stops before another Z move is executed.
        Exerqtorundefined DonStaufferundefined 3 Replies Last reply Reply Quote 0
        • Exerqtorundefined
          Exerqtor @dc42
          @dc42 said in Z-axis / tramming issues with 3.6.0-alpha2+3:
          It's part of the course with testing pre-release stuff imo! Win some loose some 😅
          Well, when I think back the first time it happened for me was during the Z homing routine before tramming start. I think it was between one of the "tolerance" moves when doing G30. Did the first move, went to lower the bed to specified dive height, but rather than switching over the two front axis to rise up again to "engage" the second probe once dive height was reached they contiuned on a downwards motion.
          The other times it happened it seemd to apply the axis adjustements wronlgy (in 1 or all axis) when it was done with the G30 moves for tramming.
          If that made sense?
            DonStauffer @dc42
            @dc42 I have not had bed tramming without one of the motors going the wrong direction since installing alpha 2. I will have to test for #2. I don't think I've seen it but I wasn't looking for it.
              DonStauffer @edsped
              @edsped Here's my bed.g, and the DefineBed macro you have to run to create the global Bed variable it uses for the data points:
              ;	bed.g
              ;	Bed leveling macro.
              ;	Don Stauffer									July, 2024
              ;   Subscript Constants
              var LEV = 1
              ;   Other Constants
              var ITERATION_COUNT_MAX = 15
              var ERR_ALLOWED = 0.005
              ;	Clear any existing bed transform and move up
              M561
              G1 H2 Z5
              ;	Start NeoPixel progress meters
              ;M98 P"0:/macros/Lights/NeoPixel/Progress/BedLeveling/StartProgressMeters" E{var.ERR_ALLOWED}
              ;	Iteratively attempt to level the bed
              var Raw = null
              var Abs = null
              var Sign = null
              var x = null
              var y = null
              var z = null
              var Err = pow(2, 31)		;	"infinity"
              while iterations < var.ITERATION_COUNT_MAX && var.Err > var.ERR_ALLOWED
              	;   Retrieve and probe the points
              	while iterations < #(global.Bed[var.LEV])
              		;   Decode probe point coordinates
              		set var.Raw = mod(global.Bed[var.LEV][iterations], pow(2, 15))
              		set var.Abs = mod(var.Raw, pow(2, 14))
              		set var.Sign = floor((var.Raw - var.Abs) / pow(2, 14) + 0.5)
              		set var.x = var.Abs * (1 - var.Sign * 2)
              		set var.Raw = floor((global.Bed[var.LEV][iterations]-var.Raw)/pow(2, 15)+ 0.5)
              		set var.y = var.Abs * (1 - var.Sign * 2)
              		;	Moving this way updates move.axes[i].userPosition faster
              		;	(Important for NeoPixel progress meter for index)
              		set var.z =sensors.probes[0].diveHeights[0]-sensors.probes[0].offsets[2]
              		;	Probe the point
              		if iterations ==  #(global.Bed[var.LEV]) - 1
              			G30 P{iterations} X{var.x} Y{var.y} Z-99999 S3
              			;G30 P{iterations} X{var.x} Y{var.y} Z-99999 S{#(global.Bed[var.LEV])}
              		else
              	;	Calculate the error sum
              	set var.Err = abs(move.calibration.initial.mean)
              	set var.Err = var.Err + move.calibration.initial.deviation
              	if global.DebugLevel > 1000
              		echo "Error="^var.Err,"Mean="^move.calibration.initial.mean,"Dev="^move.calibration.initial.deviation
              if var.Err > var.ERR_ALLOWED
              	echo "Leveling didn't converge;",var.ITERATION_COUNT_MAX,"tries. Error="^var.Err
              else
              	echo "Leveling converged. Error="^var.Err
              ;	Move to center (necessary for NeoPixel progress meters to detect done)
              G53 G1 X150 Y150 F9000
              ;	Wait for NeoPixel progress mweter processes to end themselves
              ;M98 P"0:/macros/Lights/NeoPixel/Progress/WaitForEnd"
              ;	DefineBed Macro
              ;   Initializes global.Bed.
              ;   global.Bed[var.LEV] contains the 3 probe points for bed leveling, encoded
              ;   as bitmaps to save memory.
              ;   This is intended to be called from config.g.
              ;   The X and Y coordinates of each point are compressed into a single integer
              ;   for memory conservation. The decoding routine is at the bottom of this file.
              ;if global.DebugLevel >= 1200
              ;	echo "DefineBed"
              var HTR = 0
              var OM = 0
              ;var STATE = 1
              var LEV = 1
              ;   Create global.Bed if necessary
              if !exists(global.Bed)
                  global Bed = vector(2, null)
                  set global.Bed[var.HTR] = vector(2, null)
                  set global.Bed[var.LEV] = vector(3, null)
              ;   Define probe points for bed leveling; bitmap encode to save memory
              var x = {10, 10, 265}
              var y = {12, 228, 100}
              while iterations < 3
                  ;   Encode x and y coordinates into a single integer
                  var xEnc = abs(var.x[iterations]) + (var.x[iterations] < 0 ? pow(2, 14) : 0)
                  var yEnc = abs(var.y[iterations]) * pow(2, 15)
                  set var.yEnc = var.yEnc + (var.y[iterations] < 0 ? pow(2, 29) : 0)
                  set global.Bed[var.LEV][iterations] = var.xEnc + var.yEnc
              ;   Set up bed heater information
              while iterations < #heat.bedHeaters
                  if heat.bedHeaters[iterations] != -1
                      set global.Bed[var.HTR][var.OM] = iterations
                      break
              ;	echo "Leaving DefineBed"
              M99
              ;   To decode bitmap-encoded probe points:
                  var P = global.Bed[var.LEV][iterations]
                  var xRaw = mod(var.P, pow(2, 15))
                  var yRaw = floor((var.P - var.xRaw) / pow(2, 15) + 0.5)
                  var xAbs = mod(var.xRaw, pow(2, 14))
                  var yAbs = mod(var.yRaw, pow(2, 14))
                  var xSign = floor((var.xRaw - var.xAbs) / pow(2, 14) + 0.5)
                  var ySign = floor((var.yRaw - var.yAbs) / pow(2, 14) + 0.5)
                  var xDec = var.xAbs * (1 - var.xSign * 2)
                  var yDec = var.yAbs * (1 - var.ySign * 2)
                  echo "("^var.xDec^",", var.yDec^")"
              Exerqtorundefined 1 Reply Last reply Reply Quote 0
              • Exerqtorundefined
                Exerqtor @DonStauffer
                Just slapped together a stripped down bed.g, hopefully i get time to test it either today or tomorrow.
                bed.g
                  DonStauffer @dc42
                  @dc42 Here are my testing results.
                  In bed.g, I inserted immediately after my first G30:
                  		G1 Z25 F75
                  		M99
                  Then I homed and did a G32. Nothing that happened was unexpected. The motors all ran in the correct direction. So the only issue I can confirm is that the adjustment when the G30 with the S parameter executes goes in the wrong direction for one of the motors - and not always the same one. Initially it was #7. Then when I did my "manual" tramming with bed.g doing S-1 to report the correct adjustments, it was #6. I did that manual tramming over and over, making very conservative adjustments, and throughout several hours it remained #6. But it absolutely was a different motor than the problem started on. And there's no doubt it isn't just a simple reversal - it's conditional, only apparently happening on the G30 S adjustments.
                  So, my answer is "neither #1 nor #2".
                  • edspedundefined
                    edsped
                    Switched back to 3.6 alpha 2 +3 and for me at least it looks like it's applying the the leadscrew adjustments in the wrong direction. If you look at my screenshot the offsets pretty much double on each iteration. Note, for the initial print adjustments were similar to what I got on 3.5.2 but G32 after the print gave the wonky adjustments.
                    Disregard the bed.g warnings I inadvertently hit save when exiting out of the editor.
                    edspedundefined DonStaufferundefined 2 Replies Last reply Reply Quote 0
                    • edspedundefined
                      edsped @edsped
                      @edsped Running a second tram immediately following the above resulted in my front left leadscrew ending ~4mm higher than the other two... FWIW, the front left side of my bed is also where my nozzle crashed due to that corner of the bed being too high. I should clarify, higher on my printer is actually - Z
                      Edit:
                      Powered down and back up and now get the following on G32...
                      8/3/2024, 4:38:57 PM Error: Compensation or calibration cancelled due to probing errors
                      8/3/2024, 4:38:52 PM Error: G30: Probe was not triggered during probing move
                        DonStauffer @edsped
                        @edsped Interesting. I was only having one of the three go in the wrong direction.
                        edspedundefined 1 Reply Last reply Reply Quote 0
                        • edspedundefined
                          edsped @DonStauffer
                          @DonStauffer That's what mine was doing the first time. I reverted to 3.5.2 then back to 3.6 a2+3 and added the M400 as suggested by @dc42 and what I posted above are my results. This time knowing what I was looking for I was able to bail before anything bad happened.
                            dc42 administrators @edsped
                            Currently, after performing probing a bed tramming move is executed with all Z motors moving simultaneously in different amounts and a mixture of directions. Would there be any problem if the Z motor moves were executed one at a time sequentially instead?
                            gloomyandyundefined Exerqtorundefined 2 Replies Last reply Reply Quote 0
                            • gloomyandyundefined
                              gloomyandy @dc42
                              @dc42 Could this in some situations cause a nozzle strike? I'm thinking of a situation with a very highly tilted bed and homing/probing in the middle portion of the bed, you could in theory end up with the nozzle lower then one edge of the bed and if you then raise the (currently) lower edge first the bed would hit the nozzle? The same situation with a simultaneous move may not cause the strike? Probably not very likely though.
                              Possible mitigating actions: Perform any negative (moving the bed away from the nozzle) moves first? Limit the distance each motor moves in one operation and cycle through the motors until the move is complete?
                                dc42 administrators @gloomyandy
                                @gloomyandy said in Z-axis / tramming issues with 3.6.0-alpha2+3:
                                If the probe had to make a deeper than normal move ton reach the lower edge, it will still rise to the dive height above the Z=0 reference afterwards. So I don't think this is a risk, provided that the maximum permitted correction is less than the dive height - which already needs to be the case if nozzle strikes are to be avoided.
                                • Exerqtorundefined
                                  Exerqtor @dc42
                                  I don't know if this is possible, but is it possible to do it sequentially like you are proposing, but RRF "automatically" choose which axis/stepper to move 1st, 2nd, 3rd, etc. depending on the specified adjustmen that has to be made (taking my drive mapping as example)?
                                  ; (While looking at the printer top down)
                                  ;             0.0-----0.1
                                  ;              |  0.2  |
                                  ;              |0.3|0.4|
                                  ;                Front
                                  ;  Driver 0.1 & 0.2 is for the CoreXY motion, 0.2-0.4 is for the bed kinematics.
                                  Example 1:
                                  Adjustments needed after probing:
                                  • Driver 0.2 = -0.5mm
                                  • Driver 0.3 = -0.2mm
                                  • Driver 0.4 = +0.9mm
                                  To avoid potential nozzle craches RRF will move the driver/axis that needs to adjust TOWARDS the nozzle last, and the driver/axis that needs to move the most AWAY from the nozzle first:
                                  1. Lower driver 0.4 by 0.9mm.
                                  2. Raise driver 0.3 by 0.2mm.
                                  3. Raise driver 0.2 by 0.5mm.
                                  This should both put the least mechanical strain on the bed (depending on how the bed is built ofc.), and it would provide maximal clearance to the nozzle.
                                  Example 2:
                                  • Driver 0.2 = +3.7mm
                                  • Driver 0.3 = -0.3mm
                                  • Driver 0.4 = +1.1mm
                                  Adjustment order:
                                  1. Lower driver 0.2 by 3.7mm.
                                  2. Lower driver 0.4 by 1.1mm.
                                  3. Raise driver 0.3 by 0.3mm.
                                  dc42undefined gloomyandyundefined 2 Replies Last reply Reply Quote 1
                                    dc42 administrators @Exerqtor
                                    @Exerqtor that's a good idea.
                                      gloomyandy @Exerqtor
                                      @Exerqtor said in Z-axis / tramming issues with 3.6.0-alpha2+3:
                                      To avoid potential nozzle craches RRF will move the axis the driver/axis that needs to adjust TOWARDS the nozzle last, and the driver/axis that needs to move the most AWAY from the nozzle first:
                                      Yes that's what I was suggesting with:
                                      Exerqtorundefined 1 Reply Last reply Reply Quote 1
                                      • Exerqtorundefined
                                        Exerqtor @gloomyandy
                                        @dc42 Got any builds I/we could test incorporating this commit?
                                          @Exerqtor yes, is this for D3 Mini or another board?
                                          • Exerqtorundefined
                                            Exerqtor @dc42
                                            Yes in my case it's for a D3 mini at least ☺️
