Duet3MB6HC with Duet3 scanning Z probe
Hey,
I am confused. How do I configure the Duet 3 MB6HC with the Duet 3 scanning Z probe? Which pin should I use? Can I use any I/O pins?
I want to connect it to io7.in, Is this possible?
@R006 it used CAN-FD, not io pins
Okay, thanks.
In my setup, I am using 2 EXP1XD boards. Could you please help me configure this?
@R006 you would connect it to the out of the second 1XD. That would be easiest. Or get a tool distribution board and connect that to the out of the 1XD and connect the SZP to that. Would make the wiring slightly easier. Then you would just need to find a source for the 5v supply. You could take that from one of the 1XD, from the 6HC or connect a bucket converter
@jay_s_uk
thanks.
and configure like this?
M558 K1 P11 C"120.i2c.ldc1612" F36000 T36000
M308 A"SZP coil" S10 Y"thermistor" P"120.temp0"
G31 K1 Z2 Y-17
M558.2 K1 S15 R101133
M557 X-140:140 Y-90:80 S10But I have only one Z probe for leveling, so I do not need to use the K parameter, right?
How does auto-levelling work with this? Do I have to use a BLTouch for auto-levelling?
@R006 said in Duet3MB6HC with Duet3 scanning Z probe:
G31 K1 Z2 Y-17
Correct.
I've only used one to scan the bed. You may be able to set it up for auto levelling
okay.
this is my bed.g. it's correct or i have to change it?
; P 1 G30 P0 X150 Y150 Z-9999 ; P 2 G30 P1 X150 Y450 Z-9999 ; P 3 G30 P2 X450 Y450 Z-9999 ; P 4 G30 P3 X450 Y150 Z-9999 S4
auto-levelling done with scan probe? or i have to use bl-touch for that?
@R006 looks fine to me
@R006 Like all inductive probes, the SZP coil reading changes with temperature, so you need another probe to set the Z offset each time, unless you are always using it at the exact same temperature.
I think you have used the gcode from the SZP wiki page to configure your probe, but you need to calibrate it for you specific machine, see https://docs.duet3d.com/User_manual/Tuning/scanning_z_probe_calibration#calibration
Once the Z offset is set, and the SZP is calibrated, you should be able to use it for auto-levelling. Use G30 with the K parameter to tell it what probe to use, in your case K1, eg
G30 K1 P0 X150 Y150 Z-9999 ; P1 G30 K1 P1 X150 Y450 Z-9999 ; P2 G30 K1 P2 X450 Y450 Z-9999 ; P3 G30 K1 P3 X450 Y150 Z-9999 S4 ; P4
@droftarts
okay, thanks.I am having trouble selecting the input port for the scan probe in the RRF configuration tool.
I am only using a scanning Z probe for auto-levelling and mesh bed compensation, but I am confused about how to configure it. (it's possible with scan Z probe?)
Could you please explain how to set this up and provide example files for bed.g and config.g?
and which input pin i have to used from Duet3 EXP1XD?
The SZP is CAN connected, so it should have a CAN address. If your CAN wiring is correct, and you haven't changed the CAN address on the SZP, it should be 120. You can check in DWC if it is showing up, in Settings > Machine-Specific, or look under 'boards' in the Object Model plugin.
Could you please explain how to set this up and provide example files for bed.g and config.g?The example I gave above is the bed.g file, using the second probe. You already have it set up in config.g. However...
This makes me think you haven't understood how to wire the SZP. Please post a picture of your wiring to the SZP.
You need to connect:
- the CAN wires from the CAN OUT of the EXP1XD to the SZP. This will be an RJ11 connector from the 1XD, wired to the 4-pin JST PA connector on the SZP. Make sure you connect CAN_L from the 1XD to CAN_L on the SZP, and CAN_H from the 1XD to CAN_H on the SZP
- the power wires, which require 5V and GND. You could connect these from IO0, IO1 or IO2 on the 1XD, to the 4-pin JST PA connector on the SZP.
Lastly, CAN termination. Assuming you have the termination jumpers on the last 1XD on the CAN bus, then:
- if then CAN wire to the SZP is LESS than 1m, you should be able to connect the SZP as a 'stub', and leave the CAN termination jumpers on the 1XD.
- if the CAN wire between the 1XD and SZP is MORE than 1m, you will need to remove the CAN termination jumpers from the 1XD, and solder the CAN termination jumper on the back of the SZP, see https://docs.duet3d.com/Duet3D_hardware/Duet_3_family/Duet_3_Scanning_Z_Probe#terminating-resistor
@droftarts
Thank you for the explanation.
Please check the code below.M558 P11 C"41.EXP1XD" F36000 T36000 G31 Z2 Y0 X0 M558.2 S15 R101133 M557 X0:550 Y0:550 S20
This is incorrect. The SZP is a completely separate CAN board from the 1XD, so the C parameter should reference the SZP directly, not the 1XD. Your C parameter isn't even a real pin. The SZP should show up in the list of CAN boards in DWC > Settings > Machine-specific. Please show how you have wired it.
If you have another probe, eg BLTouch, you need to specify the SZP as another probe with the K parameter. So it should look like the documentation https://docs.duet3d.com/Duet3D_hardware/Duet_3_family/Duet_3_Scanning_Z_Probe#scanning-z-probe ie:
@droftarts @dc42
hey, sorry for the late reply.I have attached an image of the wiring for the SZP with the Duet3 and its configuration.
SZP configuration in config.g
M558 K0 P11 C"120.i2c.ldc1612" F36000 T36000 ; Configure SZP as probe 1, type 11, on CAN address 120 M308 A"SZP coil" S10 Y"thermistor" P"120.temp0" ; Thermistor on SZP coil G31 K0 Z2 Y-17 ; Define probe 1 offsets and trigger height M558.1 K0 S1.7. M558.2 K0 S15 R101133 ; Set drive current and reading offset
I am doing the following steps using DWC. Please check this. However, when I run G30 K0 S-1, it gives the following error:
G30 K0 S-1
Error: M300: Probe already triggered at start of probing moveDWC Commands & it's output:
G30 K0 S-1 Error: M300: Probe already triggered at start of probing move M558.1 K0 Scanning probe coefficients [-4.805e+0, -3.410e+0, 0.000e+0, 0.000e+0] Scanning probe coefficients [-4.805e+0, -3.410e+0, 0.000e+0, 0.000e+0], reading at trigger height 9050, RMS error 4.143mm M558.2 K0 S-1 Calibration successful, sensor drive current is 15, offset is 135750 M558.2 K0 Sensor drive current is 15, offset is 101133 M558 Z Probe 0: type 11, input pin 120.i2c.ldc1612, min interval 2ms, dive heights 5.0,5.0mm, probe speeds 36000,36000,36000mm/min, travel speed 36000mm/min, recovery time 0.00 sec, heaters normal, max taps 1, max diff 0.03
I have some questions:
1. Is it necessary to connect the BL-Touch the first time to calibrate the Z height?
2. I am doing tabletop testing. Is this the correct way to calibrate the SZP, or should it be done on the machine?
3. Please check my configuration and wiring of the SZP. Is it correct?
4. Could you please explain a simpler way to calibrate it? I have read the documentation, but it is quite difficult to understand. -
No, but you need to set the Z height somehow. As we say here https://docs.duet3d.com/en/User_manual/Tuning/scanning_z_probe_calibration#calibration
Set the Z datum (Z=0), either by homing Z using another probe, or by moving the nozzle to just touch the bed and send G92 Z0.
It should be done on the machine. The SZP coil needs to be set at the correct height ie 4-5mm above the bed surface for calibration.
There's an extra full stop after the M558.1 line in your config.g. Probably not that important:
M558.1 K0 S1.7.
I can't tell regarding the wiring. Have you soldered the SZP 5V, GND and CAN wires to the back of the 1XD? Do the CAN synchronisation LEDs flash in time? Does the SZP show up in the list of boards in DWC, and are the firmware versions the same? Do you get a response if you send
M122 B120
?I can't see the coil. Is it under the SZP board? If so, most likely it is picking up the SZP board, and is too close, which is why you get the 'already triggered' message.
It's going to be impossible to calibrate it fully in a bench set up. It needs to be mounted to a machine. See the mounting instructions here: https://docs.duet3d.com/en/User_manual/Tuning/scanning_z_probe_calibration#mounting
You might just be able to do the M558.2 calibration (drive level and reading offset) on a bench setup, if you can hold the coil securely 4mm above a surface that mimics the bed (it must be metallic). But the M558.1 calibration (height vs reading) will be impossible unless you have it set up on a Z stage for accurate movement. And, most likely, both of these calibrations will change once you put it on the machine.
If there's a specific part you are struggling with, please let me know.
Thank you @droftarts
M558.1 K0 S1.7.
it's typing mistake.
In my setup, I am using only the SZP. When I run G30 K0 S-1, it gives me the error "Probe already triggered at start of probing move."
Can I use G30 K0 S-1 to measure the height from the bed to the SZP?
I have mounted the SZP 4mm above the bed, and at X0 Y0 Z0, the calibration data is:
"Scanning probe coefficients [4.546e-1, -3.829e-4, -8.222e-10, 1.247e-15]"Where should I set this calibration data?
@droftarts @dc42 @Phaedrux -
@droftarts, I am waiting for your response.
Please check my config.g file:
M558 K0 P11 C"100.i2c.ldc1612" F36000 T36000 ; configure SZP as probe 1, type 11, on CAN address 120 M308 A"SZP coil" S10 Y"thermistor" P"100.temp0" ; thermistor on SZP coil G31 P500 K0 Z3 Y-17 H10 ; define probe 1 offsets and trigger height M558.2 K0 S23 R164530 M558.1 K0 S2
Let me know if I am doing something wrong.
At some points, I get trigger heights like 3.00, -2.55, or -2.99.
In DWC, my Z-probe value is not steady; it fluctuates between 0, 9097, and 999999.
Additionally, I am using a proximity sensor for homing the Z-axis.
provide me solution for that.
