    Z-axis / tramming issues with 3.6.0-alpha2+3
    Beta Firmware
    2.5k
    • edspedundefined
      edsped @edsped
      @edsped Running a second tram immediately following the above resulted in my front left leadscrew ending ~4mm higher than the other two... FWIW, the front left side of my bed is also where my nozzle crashed due to that corner of the bed being too high. I should clarify, higher on my printer is actually - Z
      Edit:
      Powered down and back up and now get the following on G32...
      8/3/2024, 4:38:57 PM Error: Compensation or calibration cancelled due to probing errors
      8/3/2024, 4:38:52 PM Error: G30: Probe was not triggered during probing move
      • DonStaufferundefined
        DonStauffer @edsped
        @edsped Interesting. I was only having one of the three go in the wrong direction.
        edspedundefined 1 Reply Last reply Reply Quote 0
        • edspedundefined
          edsped @DonStauffer
          @DonStauffer That's what mine was doing the first time. I reverted to 3.5.2 then back to 3.6 a2+3 and added the M400 as suggested by @dc42 and what I posted above are my results. This time knowing what I was looking for I was able to bail before anything bad happened.
            dc42 administrators @edsped
            Currently, after performing probing a bed tramming move is executed with all Z motors moving simultaneously in different amounts and a mixture of directions. Would there be any problem if the Z motor moves were executed one at a time sequentially instead?
            gloomyandyundefined Exerqtorundefined 2 Replies Last reply Reply Quote 0
            • gloomyandyundefined
              gloomyandy @dc42
              @dc42 Could this in some situations cause a nozzle strike? I'm thinking of a situation with a very highly tilted bed and homing/probing in the middle portion of the bed, you could in theory end up with the nozzle lower then one edge of the bed and if you then raise the (currently) lower edge first the bed would hit the nozzle? The same situation with a simultaneous move may not cause the strike? Probably not very likely though.
              Possible mitigating actions: Perform any negative (moving the bed away from the nozzle) moves first? Limit the distance each motor moves in one operation and cycle through the motors until the move is complete?
                dc42 administrators @gloomyandy
                @gloomyandy said in Z-axis / tramming issues with 3.6.0-alpha2+3:
                If the probe had to make a deeper than normal move ton reach the lower edge, it will still rise to the dive height above the Z=0 reference afterwards. So I don't think this is a risk, provided that the maximum permitted correction is less than the dive height - which already needs to be the case if nozzle strikes are to be avoided.
                • Exerqtorundefined
                  Exerqtor @dc42
                  @dc42 said in Z-axis / tramming issues with 3.6.0-alpha2+3:
                  I don't know if this is possible, but is it possible to do it sequentially like you are proposing, but RRF "automatically" choose which axis/stepper to move 1st, 2nd, 3rd, etc. depending on the specified adjustmen that has to be made (taking my drive mapping as example)?
                  ; (While looking at the printer top down)
                  ;             0.0-----0.1
                  ;              |  0.2  |
                  ;              |0.3|0.4|
                  ;                Front
                  ;  Driver 0.1 & 0.2 is for the CoreXY motion, 0.2-0.4 is for the bed kinematics.
                  Example 1:
                  Adjustments needed after probing:
                  • Driver 0.2 = -0.5mm
                  • Driver 0.3 = -0.2mm
                  • Driver 0.4 = +0.9mm
                  To avoid potential nozzle craches RRF will move the driver/axis that needs to adjust TOWARDS the nozzle last, and the driver/axis that needs to move the most AWAY from the nozzle first:
                  1. Lower driver 0.4 by 0.9mm.
                  2. Raise driver 0.3 by 0.2mm.
                  3. Raise driver 0.2 by 0.5mm.
                  This should both put the least mechanical strain on the bed (depending on how the bed is built ofc.), and it would provide maximal clearance to the nozzle.
                  Example 2:
                  • Driver 0.2 = +3.7mm
                  • Driver 0.3 = -0.3mm
                  • Driver 0.4 = +1.1mm
                  Adjustment order:
                  1. Lower driver 0.2 by 3.7mm.
                  2. Lower driver 0.4 by 1.1mm.
                  3. Raise driver 0.3 by 0.3mm.
                  dc42undefined gloomyandyundefined 2 Replies Last reply Reply Quote 1
                    dc42 administrators @Exerqtor
                    @Exerqtor that's a good idea.
                      gloomyandy @Exerqtor
                      @Exerqtor said in Z-axis / tramming issues with 3.6.0-alpha2+3:
                      To avoid potential nozzle craches RRF will move the axis the driver/axis that needs to adjust TOWARDS the nozzle last, and the driver/axis that needs to move the most AWAY from the nozzle first:
                      Yes that's what I was suggesting with:
                      Exerqtorundefined 1 Reply Last reply Reply Quote 1
                      • Exerqtorundefined
                        Exerqtor @gloomyandy
                        @dc42 Got any builds I/we could test incorporating this commit?
                          @Exerqtor yes, is this for D3 Mini or another board?
                          Exerqtorundefined 1 Reply Last reply Reply Quote 0
                          • Exerqtorundefined
                            Exerqtor @dc42
                            Yes in my case it's for a D3 mini at least ☺️
                              I've put new RRF builds at https://www.dropbox.com/scl/fo/yc7mnauicu5vqw6yegeq7/AKnV4j8k1MCADG4VE4EIG6Y?rlkey=skjxh23i9c953yvxm2tb8qr36&dl=0. Some notes:
                              • The issue with bed tramming might be fixed. I don't have a suitable machine to test it on.
                              • Scanning Z probes are fixed (they didn't work in previous 3.6.0 alpha releases)
                              • Also included are 3.6.0 alpha versions of some expansion board firmware (not EXP1HCL or M23CL). You can revert to 3.5.2 versions if you have any issues with them.
                              See https://github.com/Duet3D/RepRapFirmware/wiki/Changelog-RRF-3.x-Beta#reprapfirmware-360-beta1-in-preparation for more details.
                              edspedundefined o_lampeundefined 3 Replies Last reply Reply Quote 3
                              • edspedundefined
                                edsped @dc42
                                @dc42 Still seeing accumulation on one of the leadscrews so I'm hesitant to test...
                                • edspedundefined
                                  edsped @dc42
                                  @dc42 Same iterations on 3.5.2
                                  • o_lampeundefined
                                    o_lampe @dc42
                                    IIRC, the problem was also seen on a Delta printer...that's why I hesitate to test 3.6.a+
                                      dc42 administrators @o_lampe
                                      @o_lampe no this issue does not affect deltas.
                                        @edsped thanks, looks like it's adjusting the 3rd leadscrew the wrong way on the second and subsequent iterations.
                                          dc42 administrators @dc42
                                          I have now reproduced and fixed this issue. I've prepared a new alpha release which I hope to make available tomorrow after some internal testing.
                                          Exerqtorundefined edspedundefined 2 Replies Last reply Reply Quote 2
                                          • Exerqtorundefined
                                            Exerqtor @dc42
                                            @dc42 Sweet, i just saw the commits and was about to ask for a build, but i'll wait til you've done the internal one 😃
