    Firmware update bricked printer - SPI connection has been reset
    Firmware installation
    842
    • p8blrundefined
      p8blr @p8blr
      @dc42 What am I doing wrong?
      I also tried the old method:
      sudo rm -f /etc/apt/sources.list.d/duet3d-unstable.list
      sudo bash -c "echo 'deb https://pkg.duet3d.com/ stable armv7' > /etc/apt/sources.list.d/duet3d.list"
      sudo apt update
      sudo apt dist-upgrade
      But that also didn't upgrade the firmware to 3.5.3-rc.1
      p8blrundefined 1 Reply Last reply Reply Quote 0
      • p8blrundefined
        p8blr @p8blr
        @chrishamm how do I update to 3.5.3-rc.1 in sbc mode? Can you please send me the exact commands? I’ve tried all possible combinations and it doesn’t work. I updated in standalone mode, but when I connected my pi and tried to audio apt update/upgrade it downgraded my 6xd without asking me. I also have no way of manually updating DWC.
          jay_s_uk @p8blr
          @p8blr it looks like 3.5.3-rc1 isn't currently on the DSF package feed so you can't update to it in SBC mode
          • p8blrundefined
            p8blr @jay_s_uk
            @jay_s_uk Interesting. How did you check that so I know for future reference? Is there no manual way to update firmware in SBC mode?
              jay_s_uk @p8blr
              @p8blr was reported in the other thread. And you shouldn't manually update as there may be breaking changes between the firmware and DSF
              • timschneiderundefined
                timschneider @p8blr
                @p8blr was the extended delay able to get rid of the unknown driver messages?
                the M122 looks normal to me.
                • p8blrundefined
                  p8blr @timschneider
                  @timschneider The delay didn't make a difference, however, changing the brake code to S10 from S1000 seems to have fixed that particular issue.
                  M569.7 P0.2 C"out3" S10 ; driver 2 on board 6XD uses port out3 to control the brake
                  M569.7 P0.3 C"out4" S10 ; driver 3 on board 6XD uses port out4 to control the brake
                  M569.7 P0.4 C"out5" S10 ; driver 4 on board 6XD uses port out5 to control the brake
                  M569.7 P0.5 C"out6" S10 ; driver 5 on board 6XD uses port out6 to control the brake
                  Note that I was playing with increasing that value because my servos were getting position recovery errors.
                  • chrishammundefined
                    chrishamm administrators @p8blr
                    @p8blr It's now available, looks like the GitHub Actions workflow for prereleases wasn't triggered correctly. Sorry for the inconvenience.
                    Duet software engineer
                    p8blrundefined 1 Reply Last reply Reply Quote 2
                    • p8blrundefined
                      p8blr @chrishamm
                      @chrishamm Didn't work.
                      Process:
                      Removed SD card from duet, connected RPI ribbon cable, powered on, M997 S2 F"unstable", sudo apt update, sudo apt full-upgrade
                        @p8blr /dev/gpiochip4 is correct for the Pi 5. Is it still the same board or did you replace it?
                        • p8blrundefined
                          p8blr @chrishamm
                          @chrishamm Exact same board. I'll reimage the pi and try again.
                          • p8blrundefined p8blr referenced this topic
                            @p8blr If it's actually caused by a system update, don't use apt to install the latest system package versions, instead use M997 S2 only to update DSF. I'll investigate.
                            p8blrundefined oozeBotundefined 2 Replies Last reply Reply Quote 1
                            • p8blrundefined
                              p8blr @chrishamm
                              @chrishamm new image with no updates works. M997 S2 F"unstable", M997 S2
                              • oozeBotundefined
                                oozeBot @chrishamm
                                @chrishamm said in Firmware update bricked printer - SPI connection has been reset:
                                @chrishamm - any updates one what has caused this behavior to start happening? We hadn't noticed it until a recent apt upgrade (not Duet related). Are there workarounds to get this back on the command line? Thanks
                                  chrishamm administrators @oozeBot
                                  @oozeBot We have some more background information about the cause of this problem; it appears to affect the 6HC/6XD only. @dc42 is going to improve the upgrade mechanism in 3.6.0 stable.
