Firmware update bricked printer - SPI connection has been reset
@jay_s_uk Interesting. How did you check that so I know for future reference? Is there no manual way to update firmware in SBC mode?
@p8blr was reported in the other thread. And you shouldn't manually update as there may be breaking changes between the firmware and DSF
@p8blr was the extended delay able to get rid of the unknown driver messages?
the M122 looks normal to me.
@timschneider The delay didn't make a difference, however, changing the brake code to S10 from S1000 seems to have fixed that particular issue.
M569.7 P0.2 C"out3" S10 ; driver 2 on board 6XD uses port out3 to control the brake
M569.7 P0.3 C"out4" S10 ; driver 3 on board 6XD uses port out4 to control the brake
M569.7 P0.4 C"out5" S10 ; driver 4 on board 6XD uses port out5 to control the brake
M569.7 P0.5 C"out6" S10 ; driver 5 on board 6XD uses port out6 to control the brakeNote that I was playing with increasing that value because my servos were getting position recovery errors.
@p8blr It's now available, looks like the GitHub Actions workflow for prereleases wasn't triggered correctly. Sorry for the inconvenience.
@chrishamm Didn't work.
Process:
Removed SD card from duet, connected RPI ribbon cable, powered on, M997 S2 F"unstable", sudo apt update, sudo apt full-upgrade -
@p8blr
/dev/gpiochip4
is correct for the Pi 5. Is it still the same board or did you replace it? -
@chrishamm Exact same board. I'll reimage the pi and try again.
undefined p8blr referenced this topic
@p8blr If it's actually caused by a system update, don't use
apt
to install the latest system package versions, instead useM997 S2
only to update DSF. I'll investigate. -
@chrishamm new image with no updates works. M997 S2 F"unstable", M997 S2
@chrishamm said in Firmware update bricked printer - SPI connection has been reset:
apt
only to update DSF. I'll investigate.@chrishamm - any updates one what has caused this behavior to start happening? We hadn't noticed it until a recent apt upgrade (not Duet related). Are there workarounds to get this back on the command line? Thanks
