Firmware update bricked printer - SPI connection has been reset
Firmware installation
838
    jay_s_uk @p8blr
    @p8blr it looks like 3.5.3-rc1 isn't currently on the DSF package feed so you can't update to it in SBC mode
    undefined 1 Reply Last reply 3 Sept 2024, 19:12 Reply Quote 0
      p8blr @jay_s_uk
      @jay_s_uk Interesting. How did you check that so I know for future reference? Is there no manual way to update firmware in SBC mode?
      undefined 1 Reply Last reply 3 Sept 2024, 20:05 Reply Quote 0
        jay_s_uk @p8blr
        @p8blr was reported in the other thread. And you shouldn't manually update as there may be breaking changes between the firmware and DSF
          timschneider @p8blr
          @p8blr was the extended delay able to get rid of the unknown driver messages?
          the M122 looks normal to me.
          undefined 1 Reply Last reply 3 Sept 2024, 21:11 Reply Quote 0
            p8blr @timschneider
            @timschneider The delay didn't make a difference, however, changing the brake code to S10 from S1000 seems to have fixed that particular issue.
            M569.7 P0.2 C"out3" S10 ; driver 2 on board 6XD uses port out3 to control the brake
            M569.7 P0.3 C"out4" S10 ; driver 3 on board 6XD uses port out4 to control the brake
            M569.7 P0.4 C"out5" S10 ; driver 4 on board 6XD uses port out5 to control the brake
            M569.7 P0.5 C"out6" S10 ; driver 5 on board 6XD uses port out6 to control the brake
            Note that I was playing with increasing that value because my servos were getting position recovery errors.
            undefined 1 Reply Last reply 5 Sept 2024, 19:28 Reply Quote 0
              chrishamm administrators @p8blr
              @p8blr It's now available, looks like the GitHub Actions workflow for prereleases wasn't triggered correctly. Sorry for the inconvenience.
              Duet software engineer
              undefined 1 Reply Last reply 6 Sept 2024, 15:08 Reply Quote 2
                p8blr @chrishamm
                @chrishamm Didn't work.
                Process:
                Removed SD card from duet, connected RPI ribbon cable, powered on, M997 S2 F"unstable", sudo apt update, sudo apt full-upgrade
                undefined 1 Reply Last reply 9 Sept 2024, 12:00 Reply Quote 0
                  @p8blr /dev/gpiochip4 is correct for the Pi 5. Is it still the same board or did you replace it?
                  undefined 1 Reply Last reply 9 Sept 2024, 13:48 Reply Quote 0
                    p8blr @chrishamm
                    @chrishamm Exact same board. I'll reimage the pi and try again.
                    undefined 1 Reply Last reply 9 Sept 2024, 13:56 Reply Quote 0
                    • undefined p8blr referenced this topic 9 Sept 2024, 13:52
                      @p8blr If it's actually caused by a system update, don't use apt to install the latest system package versions, instead use M997 S2 only to update DSF. I'll investigate.
                      undefined undefined 2 Replies Last reply 9 Sept 2024, 15:10 Reply Quote 1
                        p8blr @chrishamm
                        @chrishamm new image with no updates works. M997 S2 F"unstable", M997 S2
                          oozeBot @chrishamm
                          @chrishamm said in Firmware update bricked printer - SPI connection has been reset:
                          @chrishamm - any updates one what has caused this behavior to start happening? We hadn't noticed it until a recent apt upgrade (not Duet related). Are there workarounds to get this back on the command line? Thanks
                          undefined 1 Reply Last reply 7 Apr 2025, 07:36 Reply Quote 0
                            chrishamm administrators @oozeBot
                            @oozeBot We have some more background information about the cause of this problem; it appears to affect the 6HC/6XD only. @dc42 is going to improve the upgrade mechanism in 3.6.0 stable.
