    Firmware update bricked printer - SPI connection has been reset
    Firmware installation
    838
      jay_s_uk @p8blr
      @p8blr was reported in the other thread. And you shouldn't manually update as there may be breaking changes between the firmware and DSF
      • timschneiderundefined
        timschneider @p8blr
        @p8blr was the extended delay able to get rid of the unknown driver messages?
        the M122 looks normal to me.
        p8blrundefined 1 Reply Last reply Reply Quote 0
        • p8blrundefined
          p8blr @timschneider
          @timschneider The delay didn't make a difference, however, changing the brake code to S10 from S1000 seems to have fixed that particular issue.
          M569.7 P0.2 C"out3" S10 ; driver 2 on board 6XD uses port out3 to control the brake
          M569.7 P0.3 C"out4" S10 ; driver 3 on board 6XD uses port out4 to control the brake
          M569.7 P0.4 C"out5" S10 ; driver 4 on board 6XD uses port out5 to control the brake
          M569.7 P0.5 C"out6" S10 ; driver 5 on board 6XD uses port out6 to control the brake
          Note that I was playing with increasing that value because my servos were getting position recovery errors.
          • chrishammundefined
            chrishamm administrators @p8blr
            @p8blr It's now available, looks like the GitHub Actions workflow for prereleases wasn't triggered correctly. Sorry for the inconvenience.
            Duet software engineer
            p8blrundefined 1 Reply Last reply Reply Quote 2
            • p8blrundefined
              p8blr @chrishamm
              @chrishamm Didn't work.
              Process:
              Removed SD card from duet, connected RPI ribbon cable, powered on, M997 S2 F"unstable", sudo apt update, sudo apt full-upgrade
                @p8blr /dev/gpiochip4 is correct for the Pi 5. Is it still the same board or did you replace it?
                • p8blrundefined
                  p8blr @chrishamm
                  @chrishamm Exact same board. I'll reimage the pi and try again.
                  • p8blrundefined p8blr referenced this topic
                    @p8blr If it's actually caused by a system update, don't use apt to install the latest system package versions, instead use M997 S2 only to update DSF. I'll investigate.
                    p8blrundefined oozeBotundefined 2 Replies Last reply Reply Quote 1
                    • p8blrundefined
                      p8blr @chrishamm
                      @chrishamm new image with no updates works. M997 S2 F"unstable", M997 S2
                      • oozeBotundefined
                        oozeBot @chrishamm
                        @chrishamm said in Firmware update bricked printer - SPI connection has been reset:
                        @chrishamm - any updates one what has caused this behavior to start happening? We hadn't noticed it until a recent apt upgrade (not Duet related). Are there workarounds to get this back on the command line? Thanks
                          chrishamm administrators @oozeBot
                          @oozeBot We have some more background information about the cause of this problem; it appears to affect the 6HC/6XD only. @dc42 is going to improve the upgrade mechanism in 3.6.0 stable.
