    6XD I/O >> Issue solved
    5.4k
    • tecnoundefined
      tecno @droftarts
      @droftarts
      Now suddenly the OUT2 works, so go figure what is going on. Cold soldering seems far away but could be.
      Been take out plugs and inserted them testing.
      Whole day yesterday I did not see the LED light up but OUT1 and OUT0 was working.
      So DRIVER5 is still an issue here.
      tecnoundefined 1 Reply Last reply Reply Quote 0
      • tecnoundefined
        tecno @tecno
        @dc42 @droftarts
        Driver 5 is still DEAD !! How do you want to solve this?
        Cheers
        Bengt
          droftarts administrators @tecno
          @tecno Can you post a good picture of both sides of the board, please. There's so very little to go wrong with these ports, I feel like it's something obvious. Did you check it with a multimeter, like I asked you to?
          out2 is still working correctly? Does the LED come on when active?
          Also, please send M586 and post the response, to see what network protocols are enabled, because your config doesn't have any set.
          • tecnoundefined
            tecno @droftarts
            @droftarts
            Hi Ian,
            Re multimeter = no as you can see it is not so accessible in the video. Later on today.
            https://photos.app.goo.gl/L56Zn79kaww26Q4U6
            out2 is OK
            2024-09-25 09:26:27 m586
            CORS disabled
            HTTP is enabled on port 80
            FTP is disabled
            TELNET is disabled
            Multicast Discovery is disabled
            MQTT is disabled
            Cheers
            Bengt
            • tecnoundefined
              tecno @tecno
              Pictures of 6XD board https://photos.app.goo.gl/6ME2iY7CesXBjeKPA
                @tecno Were you able to do any tests with a multimeter? I can't see anything obvious from the pictures.
                • tecnoundefined
                  tecno @droftarts
                  @droftarts
                  Pls repeate exactly what you want me to measure now that the board is in the open.
                    @tecno From the video I can see that you're using 3 of the pins of each driver connector: 5V_EXT, D#_STEP- and D#_DIR-. I can't clearly see Driver 5, but I assume it is the same as the others.
                    With the multimeter, and the Duet powered, and being careful not to touch probe to the wrong pins (especially not to touch across 5V pins to 3.3V pins):
                    • Test for 5V between 5V_EXT and GND on the driver 5 connector. This should read 5V.
                    • Test for 5V between 5V_EXT and D5_DIR-. Send a command that moves the axis one way, then the other. You should get 5V in one direction, and 0V in the other direction.
                    • It may be difficult to see a signal if you put the multimeter between 5V_EXT and D5_STEP-, because the step pulses happen faster than the multimeter can register them. You could try doing a fast move, which might register.
                    • You could also do the tests on Driver 4, so you can see what the expected response is.
                    Let me know how that goes.
                    • tecnoundefined
                      tecno @droftarts
                      @droftarts
                      Hi Ian,
                      Looks like the 3 wires original cable is not to par, brittle so crimps go bad. Will make new wireing to all motors.
                      This el cheapo chinese cable, found also twisted wire splices with only shrink tubing loosely fitted.
                      DMM test shows driver to be OK
                      I hope I have enough crimpconnectors 🙂
                      Cheers
                      BEngt
                        @tecno Okay, that's good news, I guess! But more work for you. Let me know how you get on.
                        • tecnoundefined
                          tecno @droftarts
                          @droftarts
                          Yes a lot of extra work to make new cables. Will report!
                          • tecnoundefined
                            tecno @tecno
                            New set of cables ready.
                            tecnoundefined 1 Reply Last reply Reply Quote 1
                            • tecnoundefined
                              tecno @tecno
                              @droftarts
                              Hi Ian,
                              All axis are now moving 👍
                              Happy camper here
                              Bengt
                                @tecno Phew! Glad it's all working. Hopefully your faith in the 6XD is restored.
                                Edit: You weren't tempted to wire in the enable signal as well?
                                • tecnoundefined
                                  tecno @droftarts
                                  @droftarts
                                  No need for enable as I see it. 6XD is a very nice controller.
                                  Now I have to sort out further I/O
                                    dc42 administrators @tecno
                                    @tecno you only need the Enable connections to the drivers if you want the Duet to be able to turn off the motor current. If you leave them disconnected, the motors will be energized whenever power is applied to the drivers.
                                    • tecnoundefined
                                      tecno @dc42
                                      @droftarts
                                      Just finished cable from 8 LED circular strip from
                                      Ali DC5V WS2812B Led Ring 5050 RGB Individul AddressabIe Round Lights Module 3Pin Black White PCB 8 16 24 35 45 Pixels BuiIt-in IC
                                      Only one led lights up so my question is my settings OK?
                                      M950 E0 C"led" Q3000000
                                      M150 E0 R255 P128 S20 F1
                                      Cheers
                                      Bengt
                                        @tecno In M150, the F parameter tells the firmware what to do next:
                                        Fn Following command action. F0 (default) means this is the last command for the LED strip, so the next M150 command starts at the beginning of the strip. F1 means further M150 commands for the remainder of the strip follow this one.
                                        So you need F0 to finish and send the command, eg:
                                        M150 E0 R255 P128 S20 F0
                                        This should set LED string 0 (E0) to 255 Red (R255) at brightness 128 (P128), 20 LEDs (S20 you only have 8 but doesn't matter) and no more commands (F0).
                                        If the first LED is getting stuck on red or another colour, or you can't control any of the LEDs, what firmware version are you using?
                                        • tecnoundefined
                                          tecno @droftarts
                                          @droftarts
                                          Duet Web Control 3.5.1
                                          Yes it is stuck on one LED no color change
                                            @tecno RepRapFirmware 3.5.1 as well? Please update to 3.5.3 (RRF and DWC) and test, there have been some fixes for LEDs. https://github.com/Duet3D/RepRapFirmware/releases/tag/3.5.3
                                            This was a fix in 3.5.2:
                                            [Duet 3 MB6HC] [Duet 3 MB6XD] When a Neopixel LED strip was configured on a part other than the LED port, the first LED in the strip sometimes had the wrong colour (issue 996). This was a new bug in RRF 3.5.0.
                                            It could also be the M950 Q parameter. We say:
                                            The Qnn parameter sets the LED clock frequency. This is 4x the bit rate. Most datasheets for LEDs (at least SK6812 and WS2812B based LEDs) suggest a maximum data rate of 800Kbps, so 800000 * 4 = 3200000. The default of 3000000 appears to work well with most LEDs.
                                            So try M950 E0 C"led" Q3200000, and M950 E0 C"led" Q2800000, but after you have updated the firmware.
                                            Also, check your wiring!
