    6XD I/O >> Issue solved
    5.4k
    • tecnoundefined
      tecno @droftarts
      @droftarts
      Pls repeate exactly what you want me to measure now that the board is in the open.
        droftarts administrators @tecno
        @tecno From the video I can see that you're using 3 of the pins of each driver connector: 5V_EXT, D#_STEP- and D#_DIR-. I can't clearly see Driver 5, but I assume it is the same as the others.
        With the multimeter, and the Duet powered, and being careful not to touch probe to the wrong pins (especially not to touch across 5V pins to 3.3V pins):
        • Test for 5V between 5V_EXT and GND on the driver 5 connector. This should read 5V.
        • Test for 5V between 5V_EXT and D5_DIR-. Send a command that moves the axis one way, then the other. You should get 5V in one direction, and 0V in the other direction.
        • It may be difficult to see a signal if you put the multimeter between 5V_EXT and D5_STEP-, because the step pulses happen faster than the multimeter can register them. You could try doing a fast move, which might register.
        • You could also do the tests on Driver 4, so you can see what the expected response is.
        Let me know how that goes.
        tecnoundefined 1 Reply Last reply Reply Quote 0
        • tecnoundefined
          tecno @droftarts
          @droftarts
          Hi Ian,
          Looks like the 3 wires original cable is not to par, brittle so crimps go bad. Will make new wireing to all motors.
          This el cheapo chinese cable, found also twisted wire splices with only shrink tubing loosely fitted.
          DMM test shows driver to be OK
          I hope I have enough crimpconnectors 🙂
          Cheers
          BEngt
            @tecno Okay, that's good news, I guess! But more work for you. Let me know how you get on.
            • tecnoundefined
              tecno @droftarts
              @droftarts
              Yes a lot of extra work to make new cables. Will report!
              • tecnoundefined
                tecno @tecno
                New set of cables ready.
                tecnoundefined 1 Reply Last reply Reply Quote 1
                • tecnoundefined
                  tecno @tecno
                  @droftarts
                  Hi Ian,
                  All axis are now moving 👍
                  Happy camper here
                  Bengt
                    @tecno Phew! Glad it's all working. Hopefully your faith in the 6XD is restored.
                    Edit: You weren't tempted to wire in the enable signal as well?
                    • tecnoundefined
                      tecno @droftarts
                      @droftarts
                      No need for enable as I see it. 6XD is a very nice controller.
                      Now I have to sort out further I/O
                        dc42 administrators @tecno
                        @tecno you only need the Enable connections to the drivers if you want the Duet to be able to turn off the motor current. If you leave them disconnected, the motors will be energized whenever power is applied to the drivers.
                        • tecnoundefined
                          tecno @dc42
                          @droftarts
                          Just finished cable from 8 LED circular strip from
                          Ali DC5V WS2812B Led Ring 5050 RGB Individul AddressabIe Round Lights Module 3Pin Black White PCB 8 16 24 35 45 Pixels BuiIt-in IC
                          Only one led lights up so my question is my settings OK?
                          M950 E0 C"led" Q3000000
                          M150 E0 R255 P128 S20 F1
                          Cheers
                          Bengt
                            @tecno In M150, the F parameter tells the firmware what to do next:
                            Fn Following command action. F0 (default) means this is the last command for the LED strip, so the next M150 command starts at the beginning of the strip. F1 means further M150 commands for the remainder of the strip follow this one.
                            So you need F0 to finish and send the command, eg:
                            M150 E0 R255 P128 S20 F0
                            This should set LED string 0 (E0) to 255 Red (R255) at brightness 128 (P128), 20 LEDs (S20 you only have 8 but doesn't matter) and no more commands (F0).
                            If the first LED is getting stuck on red or another colour, or you can't control any of the LEDs, what firmware version are you using?
                            • tecnoundefined
                              tecno @droftarts
                              @droftarts
                              Duet Web Control 3.5.1
                              Yes it is stuck on one LED no color change
                                @tecno RepRapFirmware 3.5.1 as well? Please update to 3.5.3 (RRF and DWC) and test, there have been some fixes for LEDs. https://github.com/Duet3D/RepRapFirmware/releases/tag/3.5.3
                                This was a fix in 3.5.2:
                                [Duet 3 MB6HC] [Duet 3 MB6XD] When a Neopixel LED strip was configured on a part other than the LED port, the first LED in the strip sometimes had the wrong colour (issue 996). This was a new bug in RRF 3.5.0.
                                It could also be the M950 Q parameter. We say:
                                The Qnn parameter sets the LED clock frequency. This is 4x the bit rate. Most datasheets for LEDs (at least SK6812 and WS2812B based LEDs) suggest a maximum data rate of 800Kbps, so 800000 * 4 = 3200000. The default of 3000000 appears to work well with most LEDs.
                                So try M950 E0 C"led" Q3200000, and M950 E0 C"led" Q2800000, but after you have updated the firmware.
                                Also, check your wiring!
                                • tecnoundefined
                                  tecno @droftarts
                                  @droftarts
                                  Wires OK
                                  Same lonly LED
                                  Sanity check
                                    @tecno I've just tested it on a 6HC, on RRF 3.5.1, and it's working for a 7-segment LED strip. All light up correctly. The fix in 3.5.2 was if you were using IO ports for LEDs. I don't have a 6XD to test, but it should be exactly the same as 6HC.
                                    Can you send M115 and post the response?
                                    Can you post a picture of the other side of the neopixel ring?
                                    Also, I'm not sure using the uninsulated wire as the high frequency data line is a good idea! Most likely it has higher resistance than a 'normal' wire, and may not be transmitting the signal effectively. Use a different wire.
                                    • tecnoundefined
                                      tecno @droftarts
                                      @droftarts
                                      m115
                                      FIRMWARE_NAME: RepRapFirmware for Duet 3 MB6XD FIRMWARE_VERSION: 3.5.3 ELECTRONICS: Duet 3 MB6XD v1.01 FIRMWARE_DATE: 2024-09-18 11:27:56
                                      This cable is a HQ Audio twisted pair with foil shield. Change White to shield.
                                        @tecno Ah, that looks like an RGBW ring. Try
                                        M950 E0 C"led" Q3000000 T2
                                        M950 T2 tells RRF that it's RGBW, not RGB.
                                        • tecnoundefined
                                          tecno @droftarts
                                          @droftarts
                                          Same same
                                          Will change LED ring to one with black PCB board. This a job for torrow 😉
                                          • tecnoundefined
                                            tecno @tecno
                                            @droftarts
                                            Morning Ian,
                                            Changed LED strip and only 1 of 8 is working on this one too.
                                            Any suggestions?
                                            Cheers
                                            Bengt
