6XD I/O >> Issue solved
Hi Ian,
Looks like the 3 wires original cable is not to par, brittle so crimps go bad. Will make new wireing to all motors.
This el cheapo chinese cable, found also twisted wire splices with only shrink tubing loosely fitted.DMM test shows driver to be OK
I hope I have enough crimpconnectors
Cheers
BEngt -
@tecno Okay, that's good news, I guess! But more work for you. Let me know how you get on.
Yes a lot of extra work to make new cables. Will report!
New set of cables ready.
@tecno Phew! Glad it's all working. Hopefully your faith in the 6XD is restored.
Edit: You weren't tempted to wire in the enable signal as well?
No need for enable as I see it. 6XD is a very nice controller.
Now I have to sort out further I/O
@tecno you only need the Enable connections to the drivers if you want the Duet to be able to turn off the motor current. If you leave them disconnected, the motors will be energized whenever power is applied to the drivers.
Just finished cable from 8 LED circular strip from
Ali DC5V WS2812B Led Ring 5050 RGB Individul AddressabIe Round Lights Module 3Pin Black White PCB 8 16 24 35 45 Pixels BuiIt-in ICOnly one led lights up so my question is my settings OK?
M950 E0 C"led" Q3000000
M150 E0 R255 P128 S20 F1Cheers
Bengt -
@tecno In M150, the F parameter tells the firmware what to do next:
Fn Following command action. F0 (default) means this is the last command for the LED strip, so the next M150 command starts at the beginning of the strip. F1 means further M150 commands for the remainder of the strip follow this one.
So you need F0 to finish and send the command, eg:
M150 E0 R255 P128 S20 F0
This should set LED string 0 (E0) to 255 Red (R255) at brightness 128 (P128), 20 LEDs (S20 you only have 8 but doesn't matter) and no more commands (F0).If the first LED is getting stuck on red or another colour, or you can't control any of the LEDs, what firmware version are you using?
@droftarts
Duet Web Control 3.5.1Yes it is stuck on one LED no color change
@tecno RepRapFirmware 3.5.1 as well? Please update to 3.5.3 (RRF and DWC) and test, there have been some fixes for LEDs. https://github.com/Duet3D/RepRapFirmware/releases/tag/3.5.3
This was a fix in 3.5.2:
[Duet 3 MB6HC] [Duet 3 MB6XD] When a Neopixel LED strip was configured on a part other than the LED port, the first LED in the strip sometimes had the wrong colour (issue 996). This was a new bug in RRF 3.5.0.
It could also be the M950 Q parameter. We say:
The Qnn parameter sets the LED clock frequency. This is 4x the bit rate. Most datasheets for LEDs (at least SK6812 and WS2812B based LEDs) suggest a maximum data rate of 800Kbps, so 800000 * 4 = 3200000. The default of 3000000 appears to work well with most LEDs.
So try M950 E0 C"led" Q3200000, and M950 E0 C"led" Q2800000, but after you have updated the firmware.
Also, check your wiring!
@tecno I've just tested it on a 6HC, on RRF 3.5.1, and it's working for a 7-segment LED strip. All light up correctly. The fix in 3.5.2 was if you were using IO ports for LEDs. I don't have a 6XD to test, but it should be exactly the same as 6HC.
Can you send M115 and post the response?
Can you post a picture of the other side of the neopixel ring?
Also, I'm not sure using the uninsulated wire as the high frequency data line is a good idea! Most likely it has higher resistance than a 'normal' wire, and may not be transmitting the signal effectively. Use a different wire.Ian
m115
FIRMWARE_NAME: RepRapFirmware for Duet 3 MB6XD FIRMWARE_VERSION: 3.5.3 ELECTRONICS: Duet 3 MB6XD v1.01 FIRMWARE_DATE: 2024-09-18 11:27:56This cable is a HQ Audio twisted pair with foil shield. Change White to shield.
@tecno Ah, that looks like an RGBW ring. Try
M950 E0 C"led" Q3000000 T2 M150 E0 R255 P128 S20 F0
M950 T2 tells RRF that it's RGBW, not RGB.
Morning Ian,
Changed LED strip and only 1 of 8 is working on this one too.
M150 E0 R255 P128 S20 F0Any suggestions?
Cheers
Bengt -
@tecno I've just tested both RGB and RGBW LEDs on my 6HC, both worked without issue. I've asked someone with a 6XD to test.
Can you post a link to the white LED ring you bought? And post a picture of the current wiring?
