    Bug report: object cancellation causes ugly things to happen
    1.1k
    • gnydickundefined
      gnydick
      I have 3.5-rc2 with tool distribution board and tool boards on Core XY
      When I cancel an object with M486 C, the XY motors make a horrible GAAAAHHNKKKKKK sound and the gantry is flung a short distance.
      It makes that sound every time it skips an object.
      The position is lost as steps are obviously messed up.
      Then, after homing and resuming, the same thing happens with every skipped object.
      • oliofundefined
        oliof @gnydick
        @gnydick are you saying it happens whenever you emit the gcodes to skip another object, or whenever an already marked-to-skip object is being skipped? I assume the latter but just want to make sure.
        • gnydickundefined
          gnydick @oliof
          @oliof the latter, since when you emit the code, it will immediately do the skip.
          mballinundefined dc42undefined 2 Replies Last reply Reply Quote 0
          • mballinundefined
            mballin @gnydick
            @gnydick Any update on this, i want to use the object cancel plug in, i tried it, and now it really messes up the print, and changes the axis for what the printer is calibrated to.
              dc42 administrators @gnydick
              @gnydick is this still an issue with 3.5.3 and/or 3.6.0-beta.1 ?
              • gnydickundefined
                gnydick @dc42
                @dc42 Don't know, I'm not doing it because it nearly caused my printer to self destruct.
                  @gnydick have you checked that the maximum speeds you have set using M203 aren't higher than your printer can manage?
                  Tinchusundefined gnydickundefined 2 Replies Last reply Reply Quote 0
                  • Tinchusundefined
                    Tinchus @dc42
                    @dc42 I think not on 3.5.3, wich I have. I have cancelled objects and it works ok (duet3, 3.5.3, SBC mode)
                    • gnydickundefined
                      gnydick @dc42
                      @dc42 definitely. My printer never loses steps when used normally.
                        @gnydick is that the case even if you request very high speeds, e.g. G1 X150 Y150 F100000 ? I think RRF uses the maximum speed you have configured in M203 when doing moves to skip objects.
                        • gnydickundefined
                          gnydick @dc42
                          @dc42 yes, it is the case. I've used cancellation in the past without issue so I think this is a regression.
                          • gnydickundefined
                            gnydick @gnydick
                            @gnydick Any update here? This is still happening. I'm running even gentle prints with lower accel and speeds.
                            Duet 3 MB6HC	MB6HC	3.5.3
                            Duet 3 Expansion EXP3HC 	EXP3HC	3.5.3
                            Duet 3 Expansion TOOL1LC 	TOOL1LC	3.5.3
                            Duet Software Framework	DSF	3.5.3
                            Duet Web Control	DWC	3.5.3
                            dc42undefined droftartsundefined 3 Replies Last reply Reply Quote 0
                              @gnydick I've asked @droftarts to see of he can reproduce this.
                                droftarts administrators @gnydick
                                @gnydick I've tested object cancellation, seems to work fine for me on 3.6.0-rc.2.
                                I created a job with 7 small items on the bed, widely spaced out, and cancelled a couple of them during the print. Travel speed between the normal objects and skipped objects seems the same, at 150mm/s. Cancelled objects with M486 P4 and M486 C. It does seem to travel to the cancelled object, and then on to the next one, rather than direct from the previous active object to the next active one.
                                I haven't tested on 3.5.x, will do tomorrow morning.
                                  @gnydick I've tested on 3.5.4, same file, same result when objects are cancel: seems to work correctly, no sudden motor movements. What slicer are you using? Maybe it is not tagging each object correctly. If you can post a simple gcode file that exhibits the problem, then we can take a look. I sliced with Orcaslice, which puts in M486 S# commands in seemingly sane places.
                                  • gnydickundefined
                                    gnydick @droftarts
                                    @droftarts I'm using PrusaSlicer. I'll slice up a little print and upload it.
                                    • gnydickundefined
                                      gnydick @droftarts
                                      @droftarts amp coin v18 - PLA.gcode
                                        @gnydick said in Bug report: object cancellation causes ugly things to happen:
                                        I hadn't looked at the file you sent until now, as I was waiting until RRF 3.6.0-rc.3 was released before further testing. I have updated my test machine with this, and ran my test of object cancellation (cancelling with M486 C and M486 P#, uncancelling with M486 U#), without issue.
                                        I looked at the file you sent, but it seems to only have one object?
                                        I've attached my test gcode, in case you want to try it. It has a centre origin, currently sliced for PETG, 0.2mm layer height with 0.4mm nozzle.
                                        Belt anchor_PETG_9m33s.gcode
                                        • gnydickundefined
                                          gnydick @droftarts
                                          @droftarts yes, I realized that later, let me upload it again.
                                          • gnydickundefined
                                            gnydick @gnydick
                                            @droftarts here you go amp coin v18 x 12 - PLA.gcode
