    3.6.0-beta.1 Breaking Homing Sequence
    Beta Firmware
    8
    28
    1.4k
    • adrianundefined
      adrian @Charlie
      @Charlie Does the iterations variable used in bed.g need to be defined?
      • oliofundefined
        oliof @adrian
        @adrian iterations is a builtin keyword for loops.
        • Charlieundefined
          Charlie
          Its looking like more of a stepper motor/driver issue. Increasing the X/Y stepper motor current to 2380 mA allows me to run the homing sequence and have 600mm/s travel speeds with 7000mm/s^2 accels.
          I think my biggest question now is what all the new parameters do. Im using the Forum, GCode Dictionary and the github changelogs to get most of my info.
          Any more info on what M970.1 and .2 do? My assumption is that the speed and accel "constant" is like the slope "m" on a y=mx+b style graph, where "b" is min stepper current (motor idle current set by M906?), and the actual current set is the maximum of either the 970.1 and 970.2 lookup values. Im really in the dark regarding this stuff though, so please let me know if I'm completely wrong.
          AndyE3Dundefined 2 Replies Last reply Reply Quote 0
          • AndyE3Dundefined
            AndyE3D @Charlie
            Hi @Charlie, I added the new phase stepping feature but it is still experimental. Phase stepping is disabled by default unless you run M970 {axis letter}1 (note that it is currently only supported on 6HC mainboard drivers).
            One of the benefits of phase stepping is lower motor noise. In the 3.6.0-beta1 release this is done my controlling the motor current based on speed and acceleration.
            M970.1, M970.2 & M917 allow setting the scaling factors for this equation. For example, you may find that you want higher current when accelerating/decelerating to prevent stalling but a lower current when moving at steady speed to reduce noise. M917 sets the minimum current percentage based on the M906 value. The current will never exceed the M906 value.
            If you want to use phase stepping then please do give feedback on how you find it performs. It should be safe to use but limited print comparisons have been done at this point.
            As for your issue, it sounds like increasing the motor current fixes it? If so my guess would be the new input shaper is causing a move to achieve slightly higher accelerations/speeds than it did in 3.5 which could have caused a motor stall.
            AndyE3Dundefined Charlieundefined 2 Replies Last reply Reply Quote 0
            • AndyE3Dundefined
              AndyE3D @AndyE3D
              @Charlie the easiest way to tune the phase step parameters is to connect a USB cable to the Duet with a program like YAT or Putty and enable debugging with M111 P4 S1 (disable it again after you are done). Then do a move with a phase stepped axis and it will print an output like this:
              The v is velocity, a is acceleration, and cf is current fraction (what the M906 value will be multiplied by for that point in the move.
              You can tweak the M970.1, M970.2 & M917 parameters untill you are happy with the max speed/acceleration and noise that the motors are making
              • AndyE3Dundefined
                AndyE3D @Charlie
                @Charlie one other thing to verify relating to you homing/motor stalling issue is the actual current that is being applied to the motors. Can you send the response from M569 P{driver_num} and M906 please. Make sure that M569 is sent soon after a move so that the current has not been reduced by the M906 idle current reduction
                • Charlieundefined
                  Charlie @AndyE3D
                  @AndyE3D First of all, thank you so much for your work on implementing this feature! Its been awesome for decreasing motor noise, as well as decreasing VFAs (especially below 100mm/s print speeds).
                  When I get the time, Ill be sure to do that. Im assuming that I would be able to run Serial Tools app from mac to do the same stuff on a Mac.
                  Im also getting one of the Vector 3D stepper motor analyzers. I don’t know if anyone has used that and has any input, but Ill be sure to report my findings.
                  • Charlieundefined
                    Charlie @AndyE3D
                    @AndyE3D This may sound simple, but how do I get the "v, a, cf" display in SBC mode? I enabled debugging using the M111 P4 S1 in dwc, plugged my computer into the USB port on the Duet, and I tried Serial Tools on a Mac, but I dont get any response. Im assuming that this may be correct for standalone mode, but not for SBC. Is this correct?
                    gloomyandyundefined 1 Reply Last reply Reply Quote 1
                    • Charlieundefined
                      Charlie @AndyE3D
                      @AndyE3D I also tried using YAT on a PC, and was unable to get a response from any commands that I made (like M122 or M115). Im assuming that this may have something to do with SBC mode, or Im making some other error in the setup.
                      • Notepadundefined
                        Notepad
                        @AndyE3D Do we know what the M970.1 default 1000 and the M970.2 5000 values are relative to?
                        The documentation is a bit sparse on how the math is calculated.
                        The real bamboo printer manufacturer
                        Charlieundefined 1 Reply Last reply Reply Quote 1
                        • Charlieundefined
                          Charlie @Notepad
                          @Notepad I completely agree. "Acceleration/Velocity constant." Does not help much when trying to tune settings. I was hoping to be able to report back how the calculations are made after doing some testing (and reverse calculating the current factor), but without being able to get a debugging output Im unable to help.
                          • Charlieundefined
                            Charlie
                            Does anyone have references to how this is implemented?
                            The only link I currently have is M970. Others with more info (particularly regarding how its calculated and tuned) would be greatly appreciated.
                            • gloomyandyundefined
                              gloomyandy @Charlie
                              @Charlie I don't think SBC mode will impact the USB interface to the Duet. You may need to try a different USB cable as for reasons I've never understood the Duet boards seem very sensitive to this. When you plug the cable into a windows PC do you see a new COM port being created (and hear the windows "new device" sound)? If you do you should see the device come and go in the windows device manager. I'd try opening that port using putty (rather than YAT as I've found YAT to be a little fussy with the terminal settings). If you use putty you will probably need to enable local echo (to see what you type) and also adjust the handling of newline to also perform a carriage return. See: https://teamgloomy.github.io/putty.html for more details (this is for the stm32 port of RRF firmware but pretty much all of it applies to the Duet).
                              • AndyE3Dundefined
                                AndyE3D
                                @Notepad @Charlie this is the equation that uses the acceleration & velocity constants
                                float PhaseStep::CalculateCurrentFraction() noexcept
                                	// Driver is in assisted open loop mode
                                	// In this mode the PID terms are not used and the A and V terms are independent of the loop time.
                                	constexpr float scalingFactor = 100.0;
                                	constexpr float scalingFactorSqr = scalingFactor * scalingFactor;
                                	PIDVTerm = mParams.speed * Kv * scalingFactor;
                                	PIDATerm = mParams.acceleration * Ka * scalingFactorSqr;
                                	PIDControlSignal = min<float>(fabsf(PIDVTerm) + fabsf(PIDATerm), 256.0);
                                	currentFraction = holdCurrentFraction + (1.0 - holdCurrentFraction) * min<float>(PIDControlSignal * (1.0/256.0), 1.0);
                                	if (reprap.GetDebugFlags(Module::Move).IsBitSet(MoveDebugFlags::PhaseStep))
                                		debugPrintf("v=%f, a=%f, cf=%f\n", (double)(mParams.speed * scalingFactor), (double)(mParams.acceleration * scalingFactorSqr), (double)currentFraction);
                                	return currentFraction;
                                The units, calculation, and tuning are almost identical to assisted open loop on the 1HCL board with the main difference being it does not have the encoder to warn about skipped steps (stall detect also does not work when phase stepping), and the Kp & Kd terms are not used.
                                In YAT make sure that you have enabled DTR if you are running the latest firmware as the USB code was changed recently. I don't know if there are other difference connecting to the Duet on MacOS
                                Charlieundefined 2 Replies Last reply Reply Quote 1
                                • Charlieundefined
                                  Charlie @AndyE3D
                                  @AndyE3D Thank you so much for posting this code. Im pretty new to code in general, but it looks like makes sense (unless im completely mistaken which is also possible). Looks like this is in GitHub: ReprapFirmware/src/Movement/PhaseStep.cpp, line 132 for others that may be looking.
                                  After trying to put some of this in a spreadsheet (which Im sure is not the best way to go about this, but its what I kinda know), and putting in some velocity and acceleration values, Im struggling to get the PIDControlSignal value to be anything other than the 256 max value, which will in turn set the currentFraction to the max of 1.
                                  Im not sure what Im missing here. Could be that the mParams arent actually as simple as the speed and accel in mm/sec(^2), I may have calculated holdCurrentFraction wrong (in PhaseStep.h as 0.71), or the default values are really conservative. Or something else that I cant think of.
                                  • Charlieundefined
                                    Charlie @AndyE3D
                                    @AndyE3D And yes, making sure that DTR was enabled solved my issue with connection! Thank you so much. I can now use YAT on the PC to send and receive commands using a direct USB connection to the Duet.
                                    Now my issue is that, although I can connect and send an M122 command and get an output, once I send M111 P4 S1, every time I send a move command (like G91 G1 H2 X10 F3000) I get a "Warning: Lost connection to Duet (Timeout while waiting for transfer ready pin)", and then a "Warning: SPI connection has been reset". Then it seems to restart, as the machine is no longer homed.
                                    gloomyandyundefined 1 Reply Last reply Reply Quote 0
                                      gloomyandy @Charlie
                                      @Charlie If you run M122 and post the output it may provide information that will allow Andy to see if the mcu reset or not (and why).
                                      Charlieundefined 1 Reply Last reply Reply Quote 0
                                      • Charlieundefined
                                        Charlie @gloomyandy
                                        @gloomyandy @AndyE3D I was under the (potentially incorrect) assumption that if the MCU reset, it would not be reflected in the M122 (since it restarted and reset). With that being said, here's the response to M111:
                                        M111 P4 S1
                                        Debugging enabled for modules: Move(4 - 0xffffffff)
                                        Debugging disabled for modules: Platform(0) Network(1) Webserver(2) Gcodes(3) Heat(5) Kinematics(6) InputShaping(7) unused(8) PrintMonitor(9) Storage(10) PortControl(11) DuetExpansion(12) FilamentSensors(13) WiFi(14) Display(15) SbcInterface(16) CAN(17) Expansion(18)
                                        Here's the M122 after sending M111 P4 S1, but before the move command:
                                        M122
                                        RepRapFirmware for Duet 3 MB6HC version 3.6.0-beta.1 (2024-09-24 10:07:51) running on Duet 3 MB6HC v1.01 (SBC mode)
                                        Board ID: 08DJM-956L2-G43S8-6J9DG-3S46T-KV2LF
                                        Used output buffers: 2 of 40 (23 max)
                                        Static ram: 136444
                                        Dynamic ram: 96212 of which 4652 recycled
                                        Never used RAM 90476, free system stack 156 words
                                        Tasks: SBC(2,nWait 7,0.9%,795) HEAT(3,nWait 6,0.0%,325) Move(4,nWait 6,0.0%,211) TMC(5,nWait 6,11.3%,283) CanReceiv(6,nWait 1,0.0%,794) CanSender(5,nWait 7,0.0%,334) CanClock(7,delaying,0.0%,348) MAIN(2,running,87.8%,101) IDLE(0,ready,0.0%,29) USBD(3,blocked,0.0%,134), total 100.0%
                                        Owned mutexes: USB(MAIN)
                                        Last reset 00:13:55 ago, cause: power up
                                        Last software reset at 2024-11-06 20:54, reason: AssertionFailed, Gcodes spinning, available RAM 90560, slot 1
                                        Software reset code 0x0123 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0x00000000 SP 0x20415a34 Task MAIN Freestk 2233 ok
                                        Stack: 00000001 00000000 0049941d 20426970 00000000 204207e8 20426970 ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff
                                        Error status: 0x00
                                        Aux0 errors 0,0,0
                                        MCU temperature: min 51.7, current 52.7, max 52.9
                                        Supply voltage: min 26.4, current 26.5, max 26.5, under voltage events: 0, over voltage events: 0, power good: yes
                                        12V rail voltage: min 12.0, current 12.1, max 12.1, under voltage events: 0
                                        Heap OK, handles allocated/used 99/4, heap memory allocated/used/recyclable 2048/88/8, gc cycles 0
                                        Events: 0 queued, 0 completed
                                        Date/time: 2024-11-07 12:46:12
                                        Slowest loop: 2.24ms; fastest: 0.07ms
                                        USB interrupts 161
                                        === Storage ===
                                        Free file entries: 20
                                        Segments created 38, maxWait 0ms, bed comp in use: none, height map offset 0.000, hiccups added 0 (0.00/0.00ms), max steps late 0, ebfmin 0.00, ebfmax 0.00
                                        Pos req/act/dcf: 26080.00/26080/0.00 1920.00/1920/0.00 2036.00/2036/0.00
                                        no step interrupt scheduled
                                        Driver 0: standstill, SG min n/a, mspos 8, reads 11116, writes 0 timeouts 0
                                        Driver 1: standstill, SG min n/a, mspos 8, reads 11116, writes 0 timeouts 0
                                        Driver 2: standstill, SG min n/a, mspos 520, reads 11117, writes 0 timeouts 0
                                        Driver 3: standstill, SG min n/a, mspos 520, reads 11116, writes 0 timeouts 0
                                        Driver 4: standstill, SG min n/a, mspos 520, reads 11116, writes 0 timeouts 0
                                        Driver 5: standstill, SG min n/a, mspos 520, reads 11116, writes 0 timeouts 0
                                        Phase step loop runtime (us): min=0, max=25, frequency (Hz): min=6410, max=10563
                                        === DDARing 0 ===
                                        Scheduled moves 12, completed 12, LaErrors 0, Underruns [0, 0, 0]
                                        === DDARing 1 ===
                                        Scheduled moves 0, completed 0, LaErrors 0, Underruns [0, 0, 0]
                                        Bed heaters 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamber heaters -1 -1 -1 -1 -1 -1 -1 -1, ordering erHeater 1 is on, I-accum = 0.0
                                        HTTP* is idle in state(s) 0
                                        Telnet is idle in state(s) 0
                                        File is idle in state(s) 0
                                        USB is ready with "M122" in state(s) 0
                                        Aux is idle in state(s) 0
                                        Queue is idle in state(s) 0
                                        LCD is idle in state(s) 0
                                        SBC is idle in state(s) 0
                                        Daemon is idle in state(s) 0
                                        Aux2 is idle in state(s) 0
                                        File2 is idle in state(s) 0
                                        Queue2 is idle in state(s) 0
                                        Q0 segments left 0, axes/extruders owned 0x80000007
                                        Code queue 0 is empty
                                        Code queue 1 is empty
                                        === Filament sensors ===
                                        check 0 clear 0
                                        Extruder 0: no data received, errs: frame 0 parity 0 ovrun 0 pol 0 ovdue 0
                                        === CAN ===
                                        Messages queued 1329, received 3024, lost 0, ignored 0, errs 0, boc 0
                                        Longest wait 0ms for reply type 0, peak Tx sync delay 6, free buffers 50 (min 50), ts 738/738/0
                                        Tx timeouts 0,0,0,0,0,0
                                        === SBC interface ===
                                        Transfer state: 5, failed transfers: 0, checksum errors: 0
                                        RX/TX seq numbers: 31603/31603
                                        SPI underruns 0, overruns 0
                                        State: 5, disconnects: 0, timeouts: 0 total, 0 by SBC, IAP RAM available 0x27f90
                                        Buffer RX/TX: 0/0-0, open files: 0
                                        ok
                                        The move command:
                                        G91
                                        G1 H2 X10 F3000
                                        And the M122 output after:
                                        M122
                                        Static ram: 136444
                                        Dynamic ram: 96104 of which 4652 recycled
                                        Never used RAM 91496, free system stack 180 words
                                        Tasks: SBC(2,nWait 7,0.8%,791) HEAT(3,nWait 6,0.0%,335) Move(4,nWait 6,0.0%,321) TMC(5,nWait 6,11.1%,379) CanReceiv(6,nWait 1,0.0%,794) CanSender(5,nWait 7,0.0%,334) CanClock(7,delaying,0.0%,350) MAIN(2,running,88.0%,101) IDLE(0,ready,0.0%,29) USBD(3,blocked,0.0%,134), total 100.0%
                                        Last reset 00:00:36 ago, cause: software
                                        Last software reset at 2024-11-07 12:49, reason: HeatTaskStuck, Gcodes spinning, available RAM 90476, slot 2
                                        Software reset code 0x4143 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0042780f BFAR 0x00000000 SP 0x2041d3d0 Task Move Freestk 958 ok
                                        Stack: 00000000 2041cd2c 10000000 e000e000 2041d4b8 0049a1d5 0049a9cc 61000000 204210a0 20432728 20432728 00000000 204326a0 00453cf9 001025cc 00456df5 20432728 204326a8 a5a5a5a5 a5a5a500 42576179 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5
                                        Error status: 0x00
                                        Aux0 errors 0,0,0
                                        MCU temperature: min 53.7, current 53.9, max 54.1
                                        12V rail voltage: min 12.1, current 12.1, max 12.1, under voltage events: 0
                                        Heap OK, handles allocated/used 99/4, heap memory allocated/used/recyclable 2048/80/0, gc cycles 0
                                        Date/time: 2024-11-07 12:50:35
                                        Slowest loop: 2.11ms; fastest: 0.08ms
                                        USB interrupts 185
                                        === Storage ===
                                        Segments created 0, maxWait 0ms, bed comp in use: none, height map offset 0.000, hiccups added 0 (0.00/0.00ms), max steps late 0, ebfmin 0.00, ebfmax 0.00
                                        Pos req/act/dcf: 0.00/0/0.00 0.00/0/0.00 0.00/0/0.00
                                        next step interrupt due in 11 ticks, disabled
                                        Driver 0: standstill, SG min n/a, mspos 8, reads 7814, writes 0 timeouts 0
                                        Driver 1: standstill, SG min n/a, mspos 8, reads 7814, writes 0 timeouts 0
                                        Driver 2: standstill, SG min n/a, mspos 520, reads 7814, writes 0 timeouts 0
                                        Driver 3: standstill, SG min n/a, mspos 520, reads 7814, writes 0 timeouts 0
                                        Driver 4: standstill, SG min n/a, mspos 520, reads 7813, writes 0 timeouts 0
                                        Driver 5: standstill, SG min n/a, mspos 520, reads 7814, writes 0 timeouts 0
                                        Phase step loop runtime (us): min=0, max=26, frequency (Hz): min=6465, max=10416
                                        === DDARing 0 ===
                                        === DDARing 1 ===
                                        HTTP is idle in state(s) 0
                                        Q0 segments left 0, axes/extruders owned 0x80000003
                                        check 0 clear 0
                                        === CAN ===
                                        Messages queued 227, received 518, lost 0, ignored 0, errs 0, boc 0
                                        Longest wait 0ms for reply type 0, peak Tx sync delay 6, free buffers 50 (min 50), ts 126/126/0
                                        Transfer state: 5, failed transfers: 3, checksum errors: 6
                                        RX/TX seq numbers: 41734/1414
                                        SPI underruns 4, overruns 4
                                        ok
                                          gloomyandy @Charlie
                                          @Charlie when the mcu resets RRF is able to capture (and store) some information about what was going on. Rather interestingly you seem to have had two on the face of it different resets the first was this:
                                          the second this:
                                          It sounds like the second reset may be the one caused by the phase stepping move with debug enabled, do you remember having any other sort of reset that may have generated the first case (looks like it was last night just before 9pm)?
                                          Either way hopefully @AndyE3D will be able to work out what may be happening here.
                                          • Charlieundefined
                                            Charlie @gloomyandy
                                            @gloomyandy Thats really good to know. I appreciate that info!
                                            Regarding the first crash, it could've either been the first attempt at capturing the debug data, me pulling the mains power in an attempt to "reset" the board, or something to do with me trying to connect to the board over YAT.
