    My 6HC seems to think I have a CAN connected which I do not
    55
    2.3k
    • darylpriceundefined
      darylprice
      I have a simple config.g at the moment as I am testing each element:
      ; General setup
      ; Disable CAN bus if no expansion board is connected
      M569.1 P1.0 S0 ; Disable CAN on board 1
      M569.1 P1.1 S0 ; Disable CAN on board 2
      M569.1 P1.2 S0 ; Disable CAN on board 3
      M111 S0 ; Debugging off
      G21 ; Set units to millimeters
      G90 ; Use absolute positioning
      M83 ; Extruder relative mode
      M584 X0 Y1 Z2:3 ; Map drivers: X=Driver 0, Y=Driver 1, Z=Drivers 2 and 3
      M350 X16 Y16 Z16 I1 ; Set 16x microstepping with interpolation
      M92 X662 Y662 Z662 ; Set steps per mm (adjust for your setup)
      M566 X600 Y600 Z30 ; Set maximum instantaneous speed changes (mm/min)
      M203 X18000 Y18000 Z300 ; Set maximum speeds (mm/min)
      M201 X1000 Y1000 Z100 ; Set accelerations (mm/s²)
      M906 X1400 Y1400 Z1400 I30 ; Set motor currents (mA) and idle current percentage
      M84 S30 ; Idle timeout after 30 seconds
      M574 X1 S1 P"io8.in" ; X-axis endstop at minimum (NC switch)
      M574 Y1 S1 P"io6.in" ; Y-axis endstop at minimum (NC switch)
      ;M574 Z1 S1 P"io2.in" ; Z-axis endstop at minimum (NC switch)
      ;M564 H0 ; Allow movement without homing
      M501 ; Load any saved configuration
        T3P3Tony administrators @darylprice
        @darylprice said in My 6HC seems to think I have a CAN connected which I do not:
        M569.1 is used for closed loop control, and you are referencing 3 drivers on a CAN connected board at address 1.
        https://docs.duet3d.com/en/User_manual/Reference/Gcodes#m5691-stepper-driver-closed-loop-configuration
        Where did that config come from?
        If you delete those lines from the config the message will not be shown.
          darylprice
          @T3P3Tony said in My 6HC seems to think I have a CAN connected which I do not:
          I was trying to use AI. Clearly that does not work. My problem is I am getting CAN errors currently i have 23 million. I have never had a can on this duet. It thinks a can was attached at one time, but I purchased this new from one of Duets partners. Filestrudder.
            @darylprice please don't use AI to generate the config! You can use our config tool as a start point.
            https://configtool.reprapfirmware.org/
            Where are you seeing the CAN errors? A screen shot may help.
              darylprice
              In the M122 command. When I use M122 B1 I get: CAN response timeout: board 1, req type 6024, RID 0
              It is looking for a board that has never existed
              darylpriceundefined 1 Reply Last reply Reply Quote 0
                darylprice @darylprice
                @darylprice
                I am assuming that is why my status LED keeps blinking
                  darylprice
                    darylprice
                    Just a few minutes later and it is:
                      @darylprice the response from M122 B1 is as expected because there is no board on your bus.
                      The red led blinking is normal operation.
                      With those lines I asked you to remove out of your config.g, what does M122 report after a reset?
                        darylprice
                          darylprice
                          I am wondering if I have a bad board?
                            darylprice
                            My X,Y , and Z axis' all work. The endstops do not. They are setup for NC.
                            Any help would be appreciated
                              When and where did you purchase the 6HC?
                              Is this a new build? Has it ever worked correctly?
                              Can you send M122 and M98 P"config.g" in the gcode console of DWC and copy and paste the results here?
                                darylprice @Phaedrux
                                @Phaedrux
                                M122
                                RepRapFirmware for Duet 3 MB6HC version 3.5.3 (2024-09-18 11:27:36) running on Duet 3 MB6HC v1.02 or 1.02a (SBC mode)
                                Board ID: 0JD2M-9P9DA-F0PSD-6J1F6-3S46Q-14SM2
                                Used output buffers: 1 of 40 (17 max)
                                Static ram: 155352
                                Dynamic ram: 87412 of which 0 recycled
                                Never used RAM 103228, free system stack 214 words
                                Tasks: SBC(2,ready,0.3%,841) HEAT(3,nWait 6,0.0%,353) Move(4,nWait 6,0.0%,335) CanReceiv(6,nWait 1,0.0%,939) CanSender(5,nWait 7,0.0%,334) CanClock(7,delaying,0.0%,336) TMC(4,nWait 6,9.1%,67) MAIN(2,running,89.5%,444) IDLE(0,ready,1.1%,29), total 100.0%
                                Owned mutexes: HTTP(MAIN)
                                Last reset 00:00:54 ago, cause: power up
                                Last software reset at 2025-01-29 19:40, reason: User, Gcodes spinning, available RAM 103228, slot 0
                                Software reset code 0x6003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0x00000000 SP 0x00000000 Task SBC Freestk 0 n/a
                                Error status: 0x00
                                MCU temperature: min 21.3, current 31.0, max 31.0
                                Supply voltage: min 24.2, current 24.2, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes
                                12V rail voltage: min 12.1, current 12.3, max 12.5, under voltage events: 0
                                Events: 0 queued, 0 completed
                                Driver 0: standstill, SG min n/a, mspos 8, reads 39186, writes 14 timeouts 0
                                Driver 1: standstill, SG min n/a, mspos 8, reads 39186, writes 14 timeouts 0
                                Driver 2: standstill, SG min n/a, mspos 8, reads 39187, writes 14 timeouts 0
                                Driver 3: standstill, SG min n/a, mspos 8, reads 39187, writes 14 timeouts 0
                                Driver 4: standstill, SG min n/a, mspos 8, reads 39190, writes 11 timeouts 0
                                Driver 5: standstill, SG min n/a, mspos 8, reads 39190, writes 11 timeouts 0
                                Date/time: 2025-01-29 22:23:42
                                Slowest loop: 1.62ms; fastest: 0.08ms
                                === Storage ===
                                Free file entries: 20
                                DMs created 125, segments created 0, maxWait 0ms, bed compensation in use: none, height map offset 0.000, max steps late 0, min interval 0, bad calcs 0, ebfmin 0.00, ebfmax 0.00
                                no step interrupt scheduled
                                Moves shaped first try 0, on retry 0, too short 0, wrong shape 0, maybepossible 0
                                === DDARing 0 ===
                                === DDARing 1 ===
                                Bed heaters -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0
                                Telnet is idle in state(s) 0
                                File is idle in state(s) 0
                                USB is idle in state(s) 0
                                Aux is idle in state(s) 0
                                Queue is idle in state(s) 0
                                LCD is idle in state(s) 0
                                SBC is idle in state(s) 0
                                Daemon is idle in state(s) 0
                                Aux2 is idle in state(s) 0
                                File2 is idle in state(s) 0
                                Queue2 is idle in state(s) 0
                                Q0 segments left 0, axes/extruders owned 0x0000000
                                Code queue 0 is empty
                                Code queue 1 is empty
                                === CAN ===
                                Messages queued 275, received 0, lost 0, errs 261140, boc 0
                                Longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 50 (min 50), ts 275/0/0
                                Tx timeouts 0,0,274,0,0,0 last cancelled message type 30 dest 127
                                === SBC interface ===
                                Transfer state: 5, failed transfers: 0, checksum errors: 0
                                RX/TX seq numbers: 1297/1297
                                SPI underruns 0, overruns 0
                                State: 5, disconnects: 0, timeouts: 0 total, 0 by SBC, IAP RAM available 0x24d04
                                Buffer RX/TX: 0/0-0, open files: 0
                                === Duet Control Server ===
                                Duet Control Server version 3.5.3 (2024-09-19 12:16:06, 64-bit)
                                HTTP+Executed:
                                Executing M122
                                Code buffer space: 4096
                                Configured SPI speed: 8000000Hz, TfrRdy pin glitches: 0
                                Full transfers per second: 0.13, max time between full transfers: 66.8ms, max pin wait times: 43.4ms/3.7ms
                                Codes per second: 0.00
                                Maximum length of RX/TX data transfers: 4359/688
                                The M98 command ran and the block truned green. I assumed it worked correctly
                                  darylprice
                                  This is a new build, so it has never functioned. I purchased in December from :
                                  https://www.filastruder.com/collections/electronics
                                  I sent the files you requested. I am currently away from the machine and will not be back at the shop until tomorrow morning. USA,Oregon PST time
                                    dc42 administrators @darylprice
                                    @darylprice ignore the CAN errors, they just mean that the time sync messages being broadcast at regular intervals are not being acknowledged because there are no devices connected to the CAN bus.
                                      darylprice @dc42
                                      @dc42 thanks, I created a new config.g with the config tool. I will be able to test tomorrow about 11:00am.
                                        @dc42 @Phaedrux
                                        The following is my new config.g.
                                        After installing this, the only function I have is x,y,and z movements. No endstops, BLtouch does not work. I do not have any sensors or heaters attached yet. I am trying to get my endstops to work.
                                        I am beginning to think I have a bad board. If I let the machine run for 30 minutes, just setting the CAN errors raise to over 30 million.
                                        I will be away for two hours.
                                        ; Configuration file for RepRapFirmware on Duet 3 Main Board 6HC
                                        ; generated by RepRapFirmware Configuration Tool v3.5.10 on Wed Jan 29 2025 09:43:57 GMT-0800 (Pacific Standard Time)
                                        ; General
                                        G90 ; absolute coordinates
                                        M83 ; relative extruder moves
                                        M550 P"Duet 3" ; set hostname
                                        ; Smart Drivers
                                        M569 P0.0 S1 D2 ; driver 0.0 goes forwards (X axis)
                                        M569 P0.1 S1 D2 ; driver 0.1 goes forwards (Y axis)
                                        M569 P0.2 S1 D2 ; driver 0.2 goes forwards (Z axis)
                                        M569 P0.3 S1 D2 ; driver 0.4 goes forwards (z axis)
                                        M569 P0.4 S1 D2 ; driver 0.3 goes forwards (extruder 0)
                                        ; Motor Idle Current Reduction
                                        M906 I30 ; set motor current idle factor
                                        M84 S30 ; set motor current idle timeout
                                        ; Axes
                                        M584 X0.0 Y0.1 Z0.2 'z0.4 ; set axis mapping
                                        M350 X16 Y16 Z16 'z16 I1 ; configure microstepping with interpolation
                                        M906 X1400 Y3200 Z1400 'z1400 ; set axis driver currents
                                        M92 X662 Y662 Z662 'z662 ; configure steps per mm
                                        M208 X0:550 Y0:550 Z0:400 'z0:400 ; set minimum and maximum axis limits
                                        M566 X900 Y900 Z12 'z900 ; set maximum instantaneous speed changes (mm/min)
                                        M203 X1080000 Y1080000 Z60000 'z60000 ; set maximum speeds (mm/min)
                                        M201 X500 Y500 Z20 'z20 ; set accelerations (mm/s^2)
                                        ; Extruders
                                        M584 E0.3 ; set extruder mapping
                                        M350 E16 I1 ; configure microstepping with interpolation
                                        M906 E1400 ; set extruder driver currents
                                        M92 E420 ; configure steps per mm
                                        M566 E120 ; set maximum instantaneous speed changes (mm/min)
                                        M203 E3600 ; set maximum speeds (mm/min)
                                        M201 E250 ; set accelerations (mm/s^2)
                                        ; Kinematics
                                        M669 K0 ; configure Cartesian kinematics
                                        ; Probes
                                        M558 K0 P9 C"io3.in" H5 F120 T6000 ; configure BLTouch probe via slot #0
                                        G31 P500 X0 Y0 Z0.7 ; set Z probe trigger value, offset and trigger height
                                        M950 S0 C"!io3.out" ; create servo #0 for BLtouch
                                        M574 X2 P"io8.in" S1 ; configure X axis endstop
                                        M574 Y2 P"io6.in" S1 ; configure Y axis endstop
                                        M574 Z1 S2 ; configure Z axis endstop
                                        M574 'z1 S2 ; configure z axis endstop
                                        ; Sensors
                                        M308 S0 P"temp0" Y"thermistor" A"Heated Bed" T100000 B4725 C7.06e-8 ; configure sensor #0
                                        M308 S1 P"temp1" Y"thermistor" A"Nozzle" T100000 B4725 C7.06e-8 ; configure sensor #1
                                        M950 H0 C"out0" T0 ; create heater #0
                                        M143 H0 P0 T0 C0 S140 A0 ; configure heater monitor #0 for heater #0
                                        M307 H0 R2.43 D5.5 E1.35 K0.56 B1 ; configure model of heater #0
                                        M950 H1 C"out1" T1 ; create heater #1
                                        M143 H1 P0 T1 C0 S285 A0 ; configure heater monitor #0 for heater #1
                                        M307 H1 R2.43 D5.5 E1.35 K0.56 B0 ; configure model of heater #1
                                        M950 H2 C"out2" T1 ; create heater #2
                                        M143 H2 P0 T1 C0 S285 A0 ; configure heater monitor #0 for heater #2
                                        M307 H2 R2.43 D5.5 E1.35 K0.56 B0 ; configure model of heater #2
                                        ; Heated beds
                                        M140 P0 H0 ; configure heated bed #0
                                        M950 F0 C"out3" ; create fan #0
                                        M106 P0 S0 L0 X1 B0.1 ; configure fan #0
                                        M950 F1 C"out4" ; create fan #1
                                        M106 P1 S0 B0.1 H1 T45 ; configure fan #1
                                        M563 P0 D0 H1 F0 ; create tool #0
                                        M568 P0 R0 S0 ; set initial tool #0 active and standby temperatures to 0C
                                        jay_s_ukundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
                                          jay_s_uk @darylprice
                                          @darylprice can you post a photo of your wiring for each endstop please?
                                            darylprice @jay_s_uk
                                            This shows the two wires forthe micro switches for X and Y
                                            The other side is the BLTouch.
