Smart Effector v4 z probe not lighting up
I have added the leading 0 to the config with no change and here are the resultsM122_Results.txt
The M98 p"config.g" returned
M98 P"config.g"
HTTP is enabled on port 80
FTP is disabled
TELNET is disabled -
Please try this
To revert to factory settings, send command M672 S131:131. The green LED will flash 5 times if the command is accepted. When you subsequently power up the Smart Effector, the green LED will flash twice to indicate that default settings are being used.
I sent the command and it did not flash at all. I had tried that earlier as well but got no LED response but in the console it looks like it was successful.
When and where did you purchase the smart effector?
Can you please disassemble the smart effector and test it with only the connection to the Duet? Also please provide a clear photo of both sides of the PCB.
Can you remove the mounting hardware as well so we can see the traces underneath?
If you have a multimeter, could you try measuring the voltage between each end of L1 and ground, or the voltage across ceramic capacitor C3?
On one side of L1 it reads 3.3v and on the other about 58mv and across C3 I read about 58mv as well.
@vmog23 is there actually a component in position L1? From your photos I think it's either missing, or it is very well camouflaged! (i.e. the same colour as the PCB).
Looking at it again you are correct. There is an outline and solder on L1 but no component.
@vmog23 thanks, as the SE was working before I think it must have been knocked off. The 3.3V power passes through L1 so that explains why the LED doesn't light up at all. Has the SE collided with anything?
Not at all especially not from I was testing to the following day when it stopped working. It just weird.
I'm guessing that would also stop it from send a response back to the duet when should trigger the z stop, is that correct?
@dc42 said in Smart Effector v4 z probe not lighting up:
Is L1 user replaceable?
@vmog23 said in Smart Effector v4 z probe not lighting up:
Yes,
@Phaedrux said in Smart Effector v4 z probe not lighting up:
It's not hard to replace for anyone used to soldering, it needs a soldering iron with a fairly fine tip. As it's probably been knocked off, the original part may be lying around somewhere near the bottom of the printer. If not, the part number we use is Wurth 742792641. However, almost any 0805 ferrite bead will do, and you could even get away with bridging the pads using a piece of wire.
@vmog23 if you don't think it could have got knocked off by some sort of sideways blow, please post a close-up photo of the L1 pads so that we can asses whether the soldering could have been faulty.
I just tried to jump it with a wire just to test it and I still did not get any lights or response.
@vmog23 I get sharper close-up photos from my camera if I move it a little farther away from the board and then zoom in.
