RepRapFirmware-Obico
1.0k
    PrintMan @Sindarius
    @Sindarius said in RepRapFirmware-Obico:
    @Herve_Smith you can run a self hosted solution and not have to pay the cloud hosted fees but you would have to manage the instance.
    I have Obico Sever running locally on a Jetson Nano.
    This means we can create our server and at no cost, right?
    undefined 1 Reply Last reply 9 Sept 2023, 10:41 Reply Quote 1
      Sindarius @PrintMan
      @PrintMan that is correct their server solution is open source. You can find more information here.
      https://www.obico.io/obico-cloud-vs-self-hosted.html
      • undefined StanRyab referenced this topic 13 Mar 2024, 09:39
        Lachlan
        HI, I am trying to get Obico started, but I am having trouble with the codes on the github page.
        When I copy/paste the code into powershell, then I get the message as on the screenshot.Screenshot 2025-03-12 081607.png Screenshot 2025-03-12 081636.png
        The first image is when I put the main code in. The second is what happened when I tried to put the error code in.
        would anyone know what is going on?
        Thanks
        undefined 1 Reply Last reply 11 Mar 2025, 22:46 Reply Quote 0
          jay_s_uk @Lachlan
          @Lachlan you need to install git
            Sindarius
            Also it is worth mentioning that this repo was officially moved to
            https://github.com/TheSpaghettiDetective/reprapfirmware-obico
            undefined 1 Reply Last reply 14 Mar 2025, 00:54 Reply Quote 0
              Lachlan @Sindarius
              @Sindarius I have installed git, and used the new code, Obico appears to be installed, but I am not getting any of the prompts to fill in the printer information. IE (ip address, port type etc.) Do I need to put in another command after installation to put in the codes?
              undefined 1 Reply Last reply 14 Mar 2025, 12:13 Reply Quote 0
                Sindarius @Lachlan
                @Lachlan Normally doing the ./install.sh in the plugin should be enough to get the install going and you should get prompts that walk you through installation.
                undefined 1 Reply Last reply 16 Mar 2025, 22:23 Reply Quote 0
                  Lachlan @Sindarius
                  These are the files that are currently installed on my computer.
                  would I be able to upload any of these to DWC?
                  undefined 1 Reply Last reply 17 Mar 2025, 00:01 Reply Quote 0
                    Lachlan @Lachlan
                    @Sindarius This is what I get when I installed itScreenshot 2025-03-17 100043.png
                    undefined 1 Reply Last reply 17 Mar 2025, 18:02 Reply Quote 0
                      Sindarius @Lachlan
                      @Lachlan This is something that would normally be installed on a Raspberry Pi using SBC Mode and not necessarily on your desktop. This is not a DWC plugin because it is running python scripts and installing services.
                      undefined 1 Reply Last reply 17 Mar 2025, 23:22 Reply Quote 0
                        Lachlan @Sindarius
                        @Sindarius Ok, we have ordered a Raspberry. Do I link the camera to the raspberry or to the computer?
                        undefined 1 Reply Last reply 22 Mar 2025, 17:21 Reply Quote 0
                          Sindarius @Lachlan
                          @Lachlan said in RepRapFirmware-Obico:
                          You would put the camera on the raspberry pi since that is where it would be doing the processing.
                          16 out of 18
