    RepRapFirmware-Obico
    1.1k
    • Sindariusundefined
      Sindarius @PrintMan
      @PrintMan that is correct their server solution is open source. You can find more information here.
      https://www.obico.io/obico-cloud-vs-self-hosted.html
      • StanRyabundefined StanRyab referenced this topic
      • Lachlanundefined
        Lachlan
        HI, I am trying to get Obico started, but I am having trouble with the codes on the github page.
        When I copy/paste the code into powershell, then I get the message as on the screenshot.Screenshot 2025-03-12 081607.png Screenshot 2025-03-12 081636.png
        The first image is when I put the main code in. The second is what happened when I tried to put the error code in.
        would anyone know what is going on?
        Thanks
          jay_s_uk @Lachlan
          @Lachlan you need to install git
            Sindarius
            Also it is worth mentioning that this repo was officially moved to
            https://github.com/TheSpaghettiDetective/reprapfirmware-obico
            Lachlanundefined 1 Reply Last reply Reply Quote 0
            • Lachlanundefined
              Lachlan @Sindarius
              @Sindarius I have installed git, and used the new code, Obico appears to be installed, but I am not getting any of the prompts to fill in the printer information. IE (ip address, port type etc.) Do I need to put in another command after installation to put in the codes?
              Sindariusundefined 1 Reply Last reply Reply Quote 0
                Sindarius @Lachlan
                @Lachlan Normally doing the ./install.sh in the plugin should be enough to get the install going and you should get prompts that walk you through installation.
                • Lachlanundefined
                  Lachlan @Sindarius
                  These are the files that are currently installed on my computer.
                  would I be able to upload any of these to DWC?
                  • Lachlanundefined
                    Lachlan @Lachlan
                    @Sindarius This is what I get when I installed itScreenshot 2025-03-17 100043.png
                      Sindarius @Lachlan
                      @Lachlan This is something that would normally be installed on a Raspberry Pi using SBC Mode and not necessarily on your desktop. This is not a DWC plugin because it is running python scripts and installing services.
                      • Lachlanundefined
                        Lachlan @Sindarius
                        @Sindarius Ok, we have ordered a Raspberry. Do I link the camera to the raspberry or to the computer?
                          Sindarius @Lachlan
                          @Lachlan said in RepRapFirmware-Obico:
                          You would put the camera on the raspberry pi since that is where it would be doing the processing.
