Revo heater core, incorrect temperature?
M308 S1 P"20.temp0" Y"thermistor" T100000 B4725 C7.06e-8
Your B value is incorrect. Try this.
Thanks for that, the value does not significantly change the temperature displayed, maybe a degree or so. If I change the B value to something like 8000+ or so the ambient temperature displayed is closer to reality, but I would think that would mess with the scaling at higher temperatures.
@bug2k22 I would get in touch with where you brought it from as that resistance doesn't look right
@jay_s_uk I did check on the datasheet for the 104NT-4-R025H42G and this shows that the expected resistance at 10degC is 208.8Kohms which is about correct with what I measured. I purchased this from E3D.
@bug2k22 It looks like the roto board has the ability to load calibration data from NVM, I wonder if the values it is picking up are correct? Might be best to wait for one of the Duet folks to comment further before trying any recalibration though.
With a 2.2kohm pull up and cold temperatures resulting in 208kohms of resistance, you're asking the ADC to accurately measure about 0.03 volts relative to the 3.3v rail.
3D printer thermistors/boards are designed for accuracy around 200C, (at this point, thermistor and pull-up are similar so there's loads of accuracy/resolution), they don't have much accuracy at low temperatures. I wouldn't sweat it.
@elmoret Thanks, yes provided that accuracy is better in the operating termperature range. I just had not seen such a lower temperature accuracy issue on the 3 other printers I built using duet boards, this is the first tool board I've used so perhaps it's related.
@bug2k22 our automated test equipment checks the reading from the TEMP pins at three simulated temperatures. The lowest of these is 25C and the maximum error we allow at that temperature after calibration is 2C. At 10C the error will be higher, but I would not expect it to be as high as 10C.
The ADC reading code was changed at firmware version 3.5.3 and this affected the calibration (see https://github.com/Duet3D/RepRapFirmware/wiki/Changelog-RRF-3.x#reprapfirmware-353); therefore if your Roto tool board was shipped with firmware earlier than 3.5.3 but has subsequently been upgraded to 3.5.3 or later then it likely requires re-calibration.
I suggest you run the calibration procedure and see whether that gives you a more accurate reading at low temperatures. See the semi-automatic procedure at https://docs.duet3d.com/en/User_manual/Connecting_hardware/Temperature_connecting_thermistors_PT1000#semi-automatic-calibration.
@dc42 Thanks, that seems to have fixed the issue, it now reads within 1 degree of what my infra red thermometer reads.
@dc42 Thanks for this info. I know this is an old thread but you info helped me as well. I was having similar temp issues with my Revo. The bed would read 26 at ambient and the nozzle was reading 33. I know my bed it pretty close because I know the ambient temp in the room and I measured it at ambient and at temp with a heat probe and IR temp gun. My problem was that prints looked and felt like I was under temp when printing. Dull surfaces and sometimes what looked like dry under-extrusion. I imagine it is not a linear progression when getting to final temp so that could have resulted in quite an under-temp condition. The high reading would have just gotten higher resulting in the heater turning off earlyI followed the semi-automatic calibration and now it reads within .5 degrees between the bed and the hotend.
Again, thanks for putting this info out there.
