Configurazione bl touch antclabs
@perfetto Thanks. Of these three configurations, which one is on the Duet now?
config.g funzionante 2020.txt
configurazione con firmware 2.0.5.1.txt
versione 3.5.1.txtIan
buongiorno, la versione attuale è la 2.0.5.1, una volta sistemato il tutto, potrò passare al 3.5 ? o non conviene.
grazie -
good morning, the current version is 2.0.5.1, once everything is fixed, can I switch to 3.5? or is it not worth it.
Okay, you have 2.05.1 firmware, and are using a config.g for 2.05.1.
Your deployprobe.g and retractprobe.g should be correct for 2.05.1.However, there are differences between your original, working, config and this new one. For a summary, see https://www.diffchecker.com/ul6ULyLQ/ (original on left, 2.05.1 version on right).
- The extruder motor is set to go the wrong direction. Change
M569 P3 S1
toM569 P3 S0
- There are errors in the steps per mm (M92 Z is x10 wrong), max instantaneous speed change (M566 - these are set impossibly high), speeds (M203 also probably too fast), and accelerations (M201). Revert all of these to the previous values. The extruder steps per mm is set later in the original configuration, as
M92 E 95.245
- The BLTouch configuration looks okay, except for G31 X and Y offset. This is the offset of the probe from the nozzle. Change
G31 P500 X220 Y165 Z3.65
toG31 P500 X0 Y0 Z3.65
. To set this properly, see https://docs.duet3d.com/User_manual/Connecting_hardware/Z_probe_testing - Hot end thermistor settings are different. This may not be an issue, if you have correctly identified your thermistor.
- Fan settings: usually the first fan is the part cooling fan, and the speed can be set with M106 during printing. You have this as a temperature-controlled fan.
- You have M501 at the end of the new config.g. This will use settings for the heaters from sys/config-override.g. Have you tried to tune the heaters with M303, and saved the results with M500 to config-override.g? See https://docs.duet3d.com/en/How_to_guides/Commissioning#h-7-tune-heaters
NOTE you can't tune a hot end as a tool in RRF 2.x, so useM303 H1 S...
, notM303 T0 S...
You can make the changes directly in config.g, or change in the configuration tool, and upload the new version to the Duet. When you test and reply, please be specific about what is not working, how you tested to show it is not working, and any error messages that are produced.
Please post your updated config.g, config-override.g, homeall.g and homez.g from the /sys folder on the SD card. If you want, please post the config.json file as well.
Once we get everything working, we'll think about moving to firmware 3.x!
Buongiorno, ho eseguito quello che me mi hai illustrato, sembrava di avere risolto, ma per assicurarmi che il bltouch non uscisse fuori da beb ho spostato il finecorsa e ho variato il confgi.g accedendo web control, si è sballato tutto e non si riconnetteva tramite ethernet a webcontrol.
A questo punto ho ricaricato la configurazione da sd ma non vuole accedere a web control e su panel2 dice porta 80 ftp non configurata ma effettivamente credo che non serva ti invio config,g di quello installato sulla sdconfig.g.txtSto letteralmente impazzendo, tanti ringraziamenti per la tua disponibilità, attendo come proseguire.
Resettare tutto e cominciare da zero non è indispensabile? -
@perfetto said in Configurazione bl touch antclabs:
Good morning, I did what you explained to me, it seemed to have solved it, but to make sure that the bltouch did not come out of beb I moved the limit switch and changed the confgi.g by accessing web control, everything went haywire and it did not reconnect via ethernet to webcontrol.
At this point I reloaded the configuration from sd but it does not want to access web control and on panel2 it says port 80 ftp not configured but actually I think it is not necessary I send you config.g of the one installed on sd config.g.txtI am literally going crazy, many thanks for your availability, I await how to proceed.
Resetting everything and starting from scratch is not essential?New config.g (from your last post):
; Configuration file for Duet WiFi (firmware version 2.03) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v3.4.1 on Sat May 10 2025 14:17:36 GMT+0200 (Ora legale dell’Europa centrale) ; General preferences M575 P1 S1 B57600 ; enable support for PanelDue G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"BAY PRINT EUGENIO" ; set printer name ; Network M552 P192.168.1.18 S1 ; enable network and set IP address M553 P255.255.255.0 ; set netmask M554 P192.168.1.254 ; set gateway M586 P0 S1 ; enable HTTP M586 P1 S0 ; disable FTP M586 P2 S0 ; disable Telnet ; Drives M569 P0 S0 ; physical drive 0 goes backwards M569 P1 S0 ; physical drive 1 goes backwards M569 P2 S0 ; physical drive 2 goes backwards M569 P3 S1 ; physical drive 3 goes forwards M584 X0 Y1 Z2 E3 ; set drive mapping M350 X32 Y32 I0 ; configure microstepping without interpolation M350 Z16 E16 I1 ; configure microstepping with interpolation M92 X160.00 Y160.00 Z400.00 E415.00 ; set steps per mm M566 X600.00 Y600.00 Z18.00 E900.00 ; set maximum instantaneous speed changes (mm/min) M203 X9000.00 Y9000.00 Z240.00 E1200.00 ; set maximum speeds (mm/min) M201 X1000.00 Y1000.00 Z100.00 E3000.00 ; set accelerations (mm/s^2) M906 X800 Y800 Z500 E800 I30 ; set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout ; Axis Limits M208 X0 Y-5 Z0 S1 ; set axis minima M208 X310 Y310 Z450 S0 ; set axis maxima ; Endstops M574 X1 Y1 Z1 S0 ; set active low and disabled endstops ; Z-Probe M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed M557 X20:250 Y20:250 S40 ; define mesh grid ; Heaters M307 H0 B0 S1.00 ; disable bang-bang mode for the bed heater and set PWM limit M305 P0 T100000 B4138 R4700 ; set thermistor + ADC parameters for heater 0 M143 H0 S120 ; set temperature limit for heater 0 to 120C M305 P1 T100000 B4138 R4700 ; set thermistor + ADC parameters for heater 1 M143 H1 S275 ; set temperature limit for heater 1 to 275C ; Fans M106 P0 S0 I0 F500 H-1 ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off M106 P1 S1 I0 F500 H1 T45 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on ; Tools M563 P0 D0 H1 F0 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C ; Custom settings are not defined ; Miscellaneous M501 ; load saved parameters from non-volatile memory M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss T0 ; select first tool
I think this will probably be an issue with the SD card, or the contents of the SD card.
It's possible that the config.g was deleted when you saved it (this was an occasional problem in old versions of DWC and RRF), or the Duet is not able to read the SD card. Connect via USB, send
M122
and post the response in your reply. If you can't connect to DWC, sendM552 P192.168.1.18 S1
to enable networking, then you should be able to connect. However, if it is not reading the SD card or config.g, this will only work until you restart the Duet.If the Duet can't read the SD card, it is usually best to copy the configuration files from the SD card, reformat the SD card, then put the configuration files back on. For SD card formatting and testing, see https://docs.duet3d.com/en/User_manual/RepRapFirmware/SD_card
Check that the SD card has config.g in the /sys folder. The config.g you posted seems to be a new version. I've created another diffchecker page to show the differences between your original (working) config and this one, see https://www.diffchecker.com/C4yqjCEV/. This doesn't have the Z-probe set up for BLTouch, so you will need to do that again.
Buonasera, quello che sto per dirti ti farà arrabbiare, la prima cosa che ho scoperto è che il connettore del filo ethernet era ballerino e l'ho sostituito.
tutto questo è stao causa di mille prove e adesso mi ritrovo caricato firmware 3.0
sono riuscito a riconnettermi soltanto ricaricando il primo file funzionante del 2020 ti allego config.g . m120 non risponde ma sono collegato a web controlconfig.g.txt .ho fatto un bel casino
Good evening, what I'm about to tell you will make you angry, the first thing I discovered is that the ethernet wire connector was loose and I replaced it.
That's good, at least it was easy to fix.
all this was the cause of a thousand tests and now I find myself loaded with firmware 3.0
I managed to reconnect only by reloading the first working file of 2020 I attach config.g .
m120 does not respond but I am connected to web control config.g.txt .Send M122, not M120. Either update the firmware to the latest version (3.5.4) and we will fix the config.g, or downgrade back to v2.05.1. The config.g you linked won't work with v3.x, and does not have the BLTouch defined. Also make sure you update DWC with the version provided with the firmware; the version of DWC should match the firmware version. DWC version is shown in DWC Settings > General.
@perfetto buonasera ho scaricato la versione 3.5.4 firmware e quella duet2CombinedFirmware, quale è la differenza? la versione combined aggiorna anche panel2 i7.
ultima domanda per schiarirmi le idee, se attualmente è caricata la versione firmware 3.0, se da web control ricarico la versione firmware 2.05.1 si ricarica o accetta solo versioni successive?
Grazie.
"Questa stressante esperienza mi sta facendo capire e crescere tanto grazie alla tua disponibilità.
Tengo molto a questa stampante in quanto l'ho realizzata da zero in circa due anni e la equipaggiai con questa scheda duet2 e nonostante sia una cartesiana mi ha dato tante soddisfazioni a livelli qualitativi di stampa non riesco ad accettare la sconfitta." -
good evening I downloaded the 3.5.4 firmware version and the duet2CombinedFirmware, what is the difference?
From https://github.com/Duet3D/RepRapFirmware/releases/tag/3.5.4 download the "Duet2and3Firmware-3.5.4.zip" file. Upload this to the Duet without unzipping. This will update the firmware and DWC. You don't need to download the "Duet2CombinedFirmware.bin" file separately, it is in the zip file. If you upload just this file, it will update the firmware only. See https://docs.duet3d.com/User_manual/RepRapFirmware/Updating_firmware#usual-procedure
the combined version also updates panel2 i7.
No, you need to update the PanelDue separately. Get the latest file from https://github.com/Duet3D/PanelDueFirmware/releases/latest. See https://docs.duet3d.com/en/User_manual/RepRapFirmware/Updating_PanelDue for instructions.
last question to clarify my ideas, if the firmware version 3.0 is currently loaded, if I reload the firmware version 2.05.1 from web control does it reload or does it only accept later versions?
If you want do revert to 2.05.1, download the "Duet2Firmware-2.05.1.zip" from https://github.com/Duet3D/RepRapFirmware/releases/tag/2.05.1, and upload it to the Duet without unzipping. This should revert the firmware and DWC.
Buongiorno, quado provo a caricare il firmware 2.02.1 o 3.4.4 caricando da web control al momento che mi chiede vuoi installarlo quado do la conferma appare errore
grazie
Good morning, when I try to load the firmware 2.02.1 or 3.4.4 by loading from web control at the moment it asks me do you want to install it when I give the confirmation an error appears
Error: In-app programming binary "Duet2CombinedIAP.bin" not found in (m997 s0)
The IAP file is the 'In App Programmer'; it is the program that updates the firmware, and needs to be accessible on the SD card. See https://docs.duet3d.com/User_manual/RepRapFirmware/Updating_firmware#required-files
Please send
M122
and post the response, so I can see what firmware version you are currently running. If you can access DWC, please also look in the 'Settings > General' menu option, and post what version of DWC you are running.I guess you are using RRF 3.0 or 3.1. The "Duet2CombinedIAP.bin" is specific to these versions. Download it from https://github.com/Duet3D/RepRapFirmware/releases/tag/3.0 and put it in the /sys folder on the SD card.
With all firmware versions up to RRF v3.2.2, all firmware update files (including the IAP file) are stored in the ‘0:/sys/’ directory.
From RRF v3.3, to avoid too many files in this folder, all firmware update files are stored in ‘0:/firmware/’ directory.Ian
DWC 2.0.4
FIRMWARE 3.0
DWC 2.0.4
FIRMWARE 3.0Okay, that's fine. You need to upload "Duet2CombinedIAP.bin" from https://github.com/Duet3D/RepRapFirmware/releases/tag/3.0 to the /sys folder on the SD card.
I suggest you update to 3.5.4, and we'll fix the configuration there. Download "Duet2and3Firmware-3.5.4.zip" from https://github.com/Duet3D/RepRapFirmware/releases/tag/3.5.4 and upload the whole zip file (don't unzip it) to the Duet in DWC.
Then send M122 again, to check it is updated.
Ho caricato il file IAP nella cartella sys siè ricaricato il firmware 2.05.1 nei file di configurazione escono codici incomprensibili allego m122
m 122 -.txtin seguito al tuo consiglio ho lanciato il firmware 3.5.4 adesso non si collega al web control dice versione incompatibile
I uploaded the IAP file in the sys folder, the firmware 2.05.1 was reloaded, incomprehensible codes come out in the configuration files, I attach m122
"incomprehensible codes come out in the configuration files"? Please give me an example.
following your advice I launched the firmware 3.5.4, now it does not connect to the web control, it says incompatible version
When you upgrade, you MUST go from 2.05.1 to 3.0 first. You can go from 3.0 to 3.5.4. But you cannot go from 2.05.1 to 3.5.4. I assumed you were on 3.0, and would update to 3.5.4.
Most likely, the firmware is still 2.05.1, but DWC is 3.5.4. So you need to go back to DWC 2.0.4. Download "DuetWebControl-SD-2.04.zip" from https://github.com/Duet3D/RepRapFirmware/releases/tag/3.0 and unzip. Replace the contents of the www folder on the SD card with the files and folders from the zip.
I suggest you pick a firmware version, either 2.05.1 or 3.5.4, and stick to it. I recommend 3.5.4. We can fix configuration errors.
@droftarts Ho ricominciato da zero:
caricato la prima configurazione funzionante del 2020
sono passato al firmware 2.05.1 poi alla 3.0 poi alla 3.5.4attualmente in web control, impostazioni generali mi ritrovo:
Duet 2 2Ethernet versione 3.5.4
Duet Web Control DWC 3.5.4allego m122 e config.g
Spero di aver fatto bene
Grazie
I started from scratch:
loaded the first working configuration of 2020
I switched to firmware 2.05.1 then to 3.0 then to 3.5.4currently in web control, general settings I find myself:
Duet 2 2Ethernet version 3.5.4
Duet Web Control DWC 3.5.4Okay, great! Currently, your configuration is for firmware 2.05.1. We need to update this for v3.x.
From your post here https://forum.duet3d.com/post/354792, you had a configuration for 3.5.1 (versione 3.5.1.txt). This is close to the configuration you need. If you have the configtool.json file for this (created by the configuration tool), can you upload it please? I can adjust it for you to match your original RRF v2.x configuration.
credo sia questo, ormi ho un milione di cartelle di prova ma questo è il primo
grazie
allego anche questo che fa parte della stessa conficonfig --.txt gurazione
