    Configurazione bl touch antclabs
    1.8k
    • perfettoundefined
      perfetto
      allego anche questo che fa parte della stessa conficonfig --.txt gurazione
        droftarts administrators @perfetto
        @perfetto said in Configurazione bl touch antclabs:
        I think this is it, now I have a million test folders but this is the first
        I also attach this which is part of the same configuration config.txt
        This configuration is a little different, but no problem, I'll check it through. I've run out of time today, so will do this tomorrow morning.
        perfettoundefined 1 Reply Last reply Reply Quote 0
        • perfettoundefined
          perfetto @droftarts
          @droftarts grazie solo una cosa la home deve essere x0 y-5
          ancora tanti grazie
          perfettoundefined droftartsundefined 2 Replies Last reply Reply Quote 0
          • perfettoundefined
            perfetto @perfetto
            @perfetto
            Buongiorno, ho provato a settare la macchina con il configuratore 3.5 ho caricato il file zippato tramite interfaccia web, il bl touch funziona le temperature vengono gestite, la macchina non esegue la home.
            Nei file system ci sono molte cose strane ti ivio i file
            M122.txt
            config.g.txt
            config. json vecchio.txt
            configtool (1).json
            grazie
              just one thing the home must be x0 y-5
              Here is an updated configuration: perfetto config.zip.txt
              Download this, delete the ".txt" from the end, and unzip the .zip file. (The forum does not allow .zip files to be uploaded.)
              I recommend you rename the existing 'sys' folder on the SD card to 'sys_old', and copy the contents of the .zip file above to a new 'sys' folder on the SD card.
              The config.g is quite similar to your "versione 3.5.1.txt", but I have changed a lot of the values so they are the same as your "config.g funzionante 2020.txt". See the differences here: https://www.diffchecker.com/gZTQOoak/
              After you restart the Duet, please follow the 'Commissioning' guide, to check everything is working, here: https://docs.duet3d.com/en/How_to_guides/Commissioning
              If anything is not working, let me know. Provide as much detail as possible.
                Good morning, I tried to set up the machine with the configurator 3.5 I uploaded the zipped file via web interface, the bl touch works the temperatures are managed, the machine does not run the home.
                In the file systems there are many strange things I send you the files
                Please see my post above. If there are problems, please explain each one clearly.
                • perfettoundefined
                  perfetto @droftarts
                  @droftarts Buonasera.
                  IL primo dettaglio è questo:
                  nella scheda sd mi ritrovo queste cartelle;
                  firmware
                  gcodes
                  macros
                  sys
                  www
                  se apro la cartella www all'interno ci trovo anche una cartella sys che contiene questo
                  confg1.txt
                  se apro la cartella sys che si trova tra gcode e www trovo questoconfig 2.txt
                  Con la prima prova che ho fatto ho annullata il sys-old situato nella cartella www, di seguito ho adattato il config della cartella sys quello che in effetti mi ritrovo nel system tramite web control,
                  la stampante è impazzita, quando ho lanciato home bltouch non funziona la x e la y vanno veso + e non verso gli interruttori di finecorsa 0, la z è sasita a razzo e poi e riscesa, ho fermto con emergenza per evitare collisione.
                  grazie
                    Good evening.
                    The first detail is this:
                    in the sd card I find these folders;
                    firmware
                    gcodes
                    macros
                    sys
                    www
                    if I open the www folder inside I also find a sys folder that contains this
                    confg1.txt
                    if I open the sys folder that is between gcode and www I find thisconfig 2.txt
                    With the first test I did I canceled the sys-old located in the www folder, then I adapted the config of the sys folder that I actually find in the system via web control,
                    the printer went crazy, when I launched home bltouch it doesn't work the x and the y go towards + and not towards the limit switches 0, the z went up like a rocket and then went down again, I stopped with emergency to avoid collision.
                    thanks
                    The config in the www folder will be ignored, only the one in sys is used. If you have changed the config.g I provided, you need to post it.
                    • perfettoundefined
                      perfetto @droftarts
                      @droftarts Buongiorno, avrei bisogno di un chiarimento, la procedura che mi indicasti riguardo la cartella sys da rinominare con old riguarda la la sys che trovo nella cartella www ?
                      grazie
                      droftartsundefined perfettoundefined 2 Replies Last reply Reply Quote 0
                        @perfetto
                        Good morning, I need some clarification, the procedure you indicated regarding the sys folder to be renamed with old concerns the sys that I find in the www folder?
                        No. It was for the /sys folder, so you could keep it as a back up, and create a new empty /sys folder. I didn’t know you had a sys folder in www, and also the firmware will ignore it. The www folder is not the correct place for the sys folder.
                        Please try the config files I supplied, and follow the Commissioning guide. If you change any configuration files, you need to post them so I can see what has changed.
                        • perfettoundefined
                          perfetto @perfetto
                          @perfetto Buongiorno, ho caricato la configurazione 3.5 tramite web control il bl touch rispone a m401 em402 ma quando eseguo home la x ri muove vero destra mente il punto zero è a sinistra.
                          Ho fatto una prova o estratto tutti file zippati della configurazione 3.5 nella sd e li ho ricaricati in macchina per eliminare il problema della seconda cartella sys.
                          la macchina adesso non si collega web control, tramite yat ho lanciato m552 ti allego la pubblicazione di quello che diceYAT.txt
                          ti pubblico anche il cofifg caricatoconfig.g.txt
                          Credo il problema sia la seconda sys che si trova all'interno di www in precedenza ho provato anche ad isolarla rinominandola 'sys-old' ma nulla cambia.
                          Penso che se si riuscisse a collegare a web control si può fare qualcosa?
                          grazie
                          • perfettoundefined
                            perfetto @droftarts
                            @droftarts Buongiorno, per ricollegarmi tramite web control ho ricaricato in sd la configurazione con cartella www contenente la vecchia sys che come mi hi spiegato non interferisce ,ho generato un nuovo config.g con il configuratore l'ho zippato e caricato tramite web control.
                            ho dovuto invertire in in S1 i motori X e Y perchè in fase home i due assi si spostavano al contrario, la zeta funziona con bl touch con motore settato in so.
                            Ho cabiato i parametri del termistore hot and valore beta e C come da dati tecnici.
                            la y quando esegue home si sposta a velocità normale ma non arriva al finecorasa se rilancio la home batte contro il finecora e il motore salta i passi.
                            La x in fase home si sposta di circa un Cm e si ferma ma quando tocca il finecorsa salta i passi, i finecorsa quado vengono coinvolti il led sulla scheda duet si accendono.
                            Quando avvio web control esce scritto ( error in stat-up file macro line 6: heater 2 not fond)
                            i riscaldatori bed e hot and funzionano e modulano bene.
                            Ho variato il setaggio dei fan perchè quello dell'hot and non partiva, adesso funziona.
                            Ti pubblico anche diagnostica M98 P"P config.g" e config.g attualediagnostica cong.g.txt
                            configurazione.txt
                            Spero di essere stato di aiuto per capire.
                            ti ringrazio anticipatamente
                            • perfettoundefined
                              perfetto @perfetto
                              grazie
                              configurazione.txt
                              I motori li ho riportati come in origine con M564 S0 H0 dalla verifica ho visto il verso giusto, ho anche verificato i segnali dei microinterruttori con M119 e sono corretti.
                              Forse non va qualcosa in homeall.g homex.g homey.g
