    Suitable webcams for displaying progress in the webui?
    43
    7.2k
      Not all IP cameras provide the facility to return a jpeg still image. We'd love to support RTSP streams, but it's not possible since Google removed the support from Chrome. The programs that camera makers supply to access your camera from a browser send the RTSP stream to a cloud server, which then provides a HTML5 stream for your browser. That's why they make you open a cloud account first.
      • RGN01undefined
        RGN01
        Thanks, David. These cameras supply RTSP and a series of still images over port 80, 81, or various other ports. To confirm this is a browser issue, I set up the Blue Iris webserver to stream video as a series of images. Although very CPU intensive on the Blue Iris server and not a permanent solution, it allows me to configure things rather than guess what the camera is sending.
        Opening the web page displays the image in a series of jpg files as this snippet of code from the Inspect element option shows (the 'time' number increments too fast to read as the 'video' is displaying):
        [[language]]
        ![](/image/Camera1?time=116339)
        Despite this, if I try to capture this stream in my browser direct, it tries to save it. Using the same page URL in DWC does not work - it just shows a blank white box where the video should be.
        I've taken the path of least resistance, though, and ordered a Sannce camera!
        • briangilbertundefined
          briangilbert
          Hi All
          With the sannce camera you can add the user/pass in the url field in DWC as follows:
          http://user:pass@camip:port/snapshot.cgi
          if you have an @ symbol in your password change it to %40
          Works on Firefox anyway..
          Co-creator of the Zesty Nimble direct drive extruder
          • 3DTyroundefined
            3DTyro
            Based on DC42's experience with the Sannce camera, I bought 2 to test. I finally, after a little fiddling, got it to work just using the URL DC42 provided.
            The port varies, as mine was different than DC42's example. I'm not sure if that's because the camera was on a different firmware revision, or if it is random. In any case, the app linked to showed not only the IP but the port as well.
            I wasn't able to use the solution briangilbert suggested, though I am running Chrome, not FF.
            • Dougal1957undefined
              Dougal1957
              yes that is true for chrome try adding this to the end of your Chrome URL
              ?loginuse=xxxxxxx&loginpas=xxxxxxxxx&resolution=32
              such as 192.168.0.120:18912/snapshot.cgi?loginuse=xxxxx&loginpas=xxxxxxxx&resolution=32 (still need the http preamble)
              Doug
              PS change the IP and Port to match yours.
              • Mikeundefined
                Mike
                You can also get one of those ELP 1280 * 720p IP cameras. Fairly cheap, decent resolution and works reasonably well with DWC. Configuring it was a bit of a pain in the neck though…
                • ect2undefined
                  ect2
                  Mike, how do you hook up and configure the ELP 1280? This is exactly what I've been looking for as I do not want to use WiFi.
                  • Mikeundefined
                    Mike
                    Took me a while to figure that one out. First, you'll need to connect to it - by default (for some reason) it has a fixed IP 192.168.1.10. So if your router assigns IPs in that range, make sure that it's not taken, otherwise just connect directly to the PC. After that you should log into the machine, but you'll need a browser with ActiveX support. In my case, I ended up installing old Internet Explorer just for that. Further setup is fairly trivial - you can switch the language to English, enable the DHCP support (seriously, why isn't it on by default…) and toy with the settings. The static jpeg image would be available at "http://your camera's IP/webcapture.jpg/command=snap&channel=0" and you should also check "Do not append extra HTTP qualifier".
                    • ect2undefined
                      ect2
                      Thank Mike. Something like this?
                      https://www.aliexpress.com/item/Audio-Mini-Type-HD-1280-x-720P-1-0MP-IP-Camera-Metal-Indoor-Security-Camera-ONVIF/32822170249.html?spm=2114.search0104.3.79.49f5ffacQ7JAJ3&ws_ab_test=searchweb0_0,searchweb201602_4_10065_10344_10130_10068_10342_10547_10343_10340_10548_10341_10084_10083_10618_10615_10307_10131_10132_10133_10313_10059_10534_100031_10103_441_10624_442_10623_10622_10621_10620_10142,searchweb201603_2,ppcSwitch_3&algo_expid=9f721937-67e2-4d39-8fdc-480a18e0d51a-12&algo_pvid=9f721937-67e2-4d39-8fdc-480a18e0d51a&priceBeautifyAB=3
                      • ect2undefined
                        ect2
                        This one is probably more suitable:
                        https://www.aliexpress.com/item/1280-720P-1-0MP-mini-IP-Camera-ONVIF-2-8-12mm-manual-varifocal-zoom-lens-P2P/32684641752.html
                        What focal length do you use for sharpest image?
                        • Mikeundefined
                          Mike
                          Got something similar to the 1st one, although I've got mine from Amazon. Can't say anything on the focal length - I ended up just adjusting the lens manually until my printbed was in focus.
                          • ect2undefined
                            ect2
                            Thanks Mike
                            • Danalundefined
                              Danal
                              maybe I'm just not searching correctly, but I'm having a heck of a time finding a camera that is suitable, and:
                              1. On Amazon (USA)
                              2. Wireless
                              All the ones I find are "too smart".
                              • martinsundefined
                                martins
                                another solution here is Raspberry Pi zerow or rpi3 or any (zerow+cam = cheapest option)
                                all you need is to install motioneyeos https://github.com/ccrisan/motioneyeos/wiki/Supported-Devices
                                after you connect to you network with it , just open IP asigned by dhcp for you
                                log in username admin password empty
                                few steps to setup fast network cam
                                after set fast network cam hit Apply button
                                copy url displayed in step 5
                                fill in DWC
                                and you get at the end
                                hope this helps someone 🙂
                                • fmaundefined
                                  fma
                                  I'm using this solution too!
                                  Frédéric
                                  • webdadundefined
                                    webdad
                                    I've got the Zerow and the camera, just haven't had the time to start working on it. What case(s) are you using?
                                    • fmaundefined
                                      fma
                                      This one:
                                      https://www.thingiverse.com/thing:2300226
                                      Frédéric
                                      • webdadundefined
                                        webdad
                                        Oh I am so printing that. Thanks!
                                        • fmaundefined
                                          fma
                                          Be aware that the nut trap seems to be made for 1/8" or 3/8" (photo standard), and not M8… But you can use M6 (you will have to maintain the nut while screwing).
                                          Frédéric
                                          • Scott_Hundefined
                                            Scott_H
                                            I'm using the Sannce ip camera mentioned on the wiki - $40 delivered to Australia, so cheaper than the pi+camera.
                                            I was using the snapshot cgi method, but changed to using http://192.168.1.6:16325/videostream.cgi?loginuse=MyUserName&loginpas=MyPassword, and ticking the embed webcam stream under DWC settings.
                                            Can confirm that this method works perfectly under chrome on windows.
                                            If it doesn't work for you, changing the webcam update interval to, ie, 0.1 seconds may be a workaround.
                                            I couldn't find the ip camera page on the new wiki, so am posting here.
