    Suitable webcams for displaying progress in the webui?
    43
    7.2k
    • briangilbertundefined
      briangilbert
      Hi All
      With the sannce camera you can add the user/pass in the url field in DWC as follows:
      http://user:pass@camip:port/snapshot.cgi
      if you have an @ symbol in your password change it to %40
      Works on Firefox anyway..
      Co-creator of the Zesty Nimble direct drive extruder
      • 3DTyroundefined
        3DTyro
        Based on DC42's experience with the Sannce camera, I bought 2 to test. I finally, after a little fiddling, got it to work just using the URL DC42 provided.
        The port varies, as mine was different than DC42's example. I'm not sure if that's because the camera was on a different firmware revision, or if it is random. In any case, the app linked to showed not only the IP but the port as well.
        I wasn't able to use the solution briangilbert suggested, though I am running Chrome, not FF.
        • Dougal1957undefined
          Dougal1957
          yes that is true for chrome try adding this to the end of your Chrome URL
          ?loginuse=xxxxxxx&loginpas=xxxxxxxxx&resolution=32
          such as 192.168.0.120:18912/snapshot.cgi?loginuse=xxxxx&loginpas=xxxxxxxx&resolution=32 (still need the http preamble)
          Doug
          PS change the IP and Port to match yours.
          • Mikeundefined
            Mike
            You can also get one of those ELP 1280 * 720p IP cameras. Fairly cheap, decent resolution and works reasonably well with DWC. Configuring it was a bit of a pain in the neck though…
            • ect2undefined
              ect2
              Mike, how do you hook up and configure the ELP 1280? This is exactly what I've been looking for as I do not want to use WiFi.
              • Mikeundefined
                Mike
                Took me a while to figure that one out. First, you'll need to connect to it - by default (for some reason) it has a fixed IP 192.168.1.10. So if your router assigns IPs in that range, make sure that it's not taken, otherwise just connect directly to the PC. After that you should log into the machine, but you'll need a browser with ActiveX support. In my case, I ended up installing old Internet Explorer just for that. Further setup is fairly trivial - you can switch the language to English, enable the DHCP support (seriously, why isn't it on by default…) and toy with the settings. The static jpeg image would be available at "http://your camera's IP/webcapture.jpg/command=snap&channel=0" and you should also check "Do not append extra HTTP qualifier".
                • ect2undefined
                  ect2
                  Thank Mike. Something like this?
                  https://www.aliexpress.com/item/Audio-Mini-Type-HD-1280-x-720P-1-0MP-IP-Camera-Metal-Indoor-Security-Camera-ONVIF/32822170249.html?spm=2114.search0104.3.79.49f5ffacQ7JAJ3&ws_ab_test=searchweb0_0,searchweb201602_4_10065_10344_10130_10068_10342_10547_10343_10340_10548_10341_10084_10083_10618_10615_10307_10131_10132_10133_10313_10059_10534_100031_10103_441_10624_442_10623_10622_10621_10620_10142,searchweb201603_2,ppcSwitch_3&algo_expid=9f721937-67e2-4d39-8fdc-480a18e0d51a-12&algo_pvid=9f721937-67e2-4d39-8fdc-480a18e0d51a&priceBeautifyAB=3
                  • ect2undefined
                    ect2
                    This one is probably more suitable:
                    https://www.aliexpress.com/item/1280-720P-1-0MP-mini-IP-Camera-ONVIF-2-8-12mm-manual-varifocal-zoom-lens-P2P/32684641752.html
                    What focal length do you use for sharpest image?
                    • Mikeundefined
                      Mike
                      Got something similar to the 1st one, although I've got mine from Amazon. Can't say anything on the focal length - I ended up just adjusting the lens manually until my printbed was in focus.
                      • ect2undefined
                        ect2
                        Thanks Mike
                        • Danalundefined
                          Danal
                          maybe I'm just not searching correctly, but I'm having a heck of a time finding a camera that is suitable, and:
                          1. On Amazon (USA)
                          2. Wireless
                          All the ones I find are "too smart".
                          • martinsundefined
                            martins
                            another solution here is Raspberry Pi zerow or rpi3 or any (zerow+cam = cheapest option)
                            all you need is to install motioneyeos https://github.com/ccrisan/motioneyeos/wiki/Supported-Devices
                            after you connect to you network with it , just open IP asigned by dhcp for you
                            log in username admin password empty
                            few steps to setup fast network cam
                            after set fast network cam hit Apply button
                            copy url displayed in step 5
                            fill in DWC
                            and you get at the end
                            hope this helps someone 🙂
                            • fmaundefined
                              fma
                              I'm using this solution too!
                              Frédéric
                              • webdadundefined
                                webdad
                                I've got the Zerow and the camera, just haven't had the time to start working on it. What case(s) are you using?
                                • fmaundefined
                                  fma
                                  This one:
                                  https://www.thingiverse.com/thing:2300226
                                  Frédéric
                                  • webdadundefined
                                    webdad
                                    Oh I am so printing that. Thanks!
                                    • fmaundefined
                                      fma
                                      Be aware that the nut trap seems to be made for 1/8" or 3/8" (photo standard), and not M8… But you can use M6 (you will have to maintain the nut while screwing).
                                      Frédéric
                                      • Scott_Hundefined
                                        Scott_H
                                        I'm using the Sannce ip camera mentioned on the wiki - $40 delivered to Australia, so cheaper than the pi+camera.
                                        I was using the snapshot cgi method, but changed to using http://192.168.1.6:16325/videostream.cgi?loginuse=MyUserName&loginpas=MyPassword, and ticking the embed webcam stream under DWC settings.
                                        Can confirm that this method works perfectly under chrome on windows.
                                        If it doesn't work for you, changing the webcam update interval to, ie, 0.1 seconds may be a workaround.
                                        I couldn't find the ip camera page on the new wiki, so am posting here.
                                        • JuJuDeltaundefined
                                          JuJuDelta
                                          I have found my RPi Zero W solution to be quite prone to uSD card corruption with power on/off.
                                          I will try the Sannce Wireless IP camera.
                                          Found it here £25 UK free delivery.
                                          https://www.manomano.co.uk/cctv-camera/sannce-720p-smart-wireless-ip-camera-remote-access-4134074
                                          T3DP3D Kossel XL+, Duet2Wifi, PanelDue 7i, RRF V3.2, Fl3xdrive, SmartEffector, Berd Air annulus, Cura 4.x, PrusaSlicer, RPi WiFi Camera, Heated Chamber
                                            We missed the webcam page when we migrated the wiki, but it's now at https://duet3d.dozuki.com/Wiki/How_to_include_a_web_camera_image_in_Duet_Web_Control.
