    Recomendation of stepper motors…
    24
    5.7k
    • peirofundefined
      peirof
      i have a Tevo Little Monster, a delta printer…. i think similar question i have made time ago.... but i cant find
      This printer uses this steppers motors, for axis and extruder
      [[language]]
      Model: Nema 17
      Step Angle (deg):1.8A
      Motor Length(mm): 48MM
      Rated Current (A): 1.68A
      Phase Resistance (Ohm) :1.65Ω
      Phase Inductance(mH) :2.8mh
      Detent Torque (N.cm) : 24mm
      Voltage:2.8V
      I want buy some spare stepper motors, the question is
      • For extruder, i have see that no, but for axis. Are recommanble the use of 0,9 deg stepper motors?
      • The default stepper motors are suitable for use with DUET+Delta (axis).
      • The [c]motors[/c] in my [c]config.g[/c] is:
      [[language]]
      M350 E32 I0 ; Configure microstepping without interpolation
      M350 X16 Y16 Z16 I1 ; Configure microstepping with interpolation
      M92 X80 Y80 Z80 E837 ; Set steps per mm
      M566 X1200 Y1200 Z1200 E3000 ; Set maximum instantaneous speed changes (mm/min)
      M203 X39960 Y39960 Z39960 E3000 ; Set maximum speeds (mm/min)
      M201 X1000 Y1000 Z1000 E1500 ; Set accelerations (mm/s^2)
      M906 X1800 Y1800 Z1800 E1500 I30 ; Set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      its correct for that kind of stepper motor?
      In europe preferably. Where i can buy steppers? Amazon?
      Thanks
      • rkrammesundefined
        rkrammes
        There is a pretty comprehensive page in the wiki on choosing stepper motors. https://duet3d.com/wiki/Choosing_stepper_motors
        • peirofundefined
          peirof
          Yes….
          I haved read it... but there are some concepts i do not understand, the are:
          [[language]]
          Inductance
          Resistance and rated voltage
          Back emf due to rotation
          i see clear, the final recomendations:
          [[language]]
          General recommendations
          Unless you will be using external stepper motor drivers, choose motors with rated current of at least 1.2A, and at most 2.0A for the Duet 0.6 and Duet 0.8.5, or 3A for the Duet WiFi or Duet Ethernet.
          Plan to run each stepper motor at between 50% and 85% of its rated current.
          Size: Nema 17 is the most popular size used in 3D printers. Nema 14 is an alternative in a highly-geared extruder. Use Nema 23 motors if you cannot get sufficient torque from long Nema 17 motors.
          Avoid motors with rated voltage (or product of rated current and phase resistance) > 4V or inductance > 4mH.
          Choose 0.9deg/step motors where you want extra positioning accuracy, e.g. for the tower motors of a delta printer. Otherwise choose 1.8deg/step motors.
          If you use any 0.9deg/step motors, or high torque motors, use 24V power so that you will be able to maintain torque at higher speeds.
          If using a highly-geared extruder (for example, an extruder that uses a flexible drive cable to transmit the torque from the motor to a worm reduction gear), use a short low-inductance 1.8deg/step motor to drive it.
          So I ask for a recommendation for which engines are the most suitable for a delta, if I am clear, I would like to buy them for 0.9 deg.
          I only have doubts in the rest. XD
          • DjDemonDundefined
            DjDemonD
            Chose a motor with sufficient current handling. Generally in nema 17 size longer motors can handle more current. A Tevo LM is going to be easily driven by a 2A motor which you can nominally run at 1.6A or thereabout using duet (this keeps motor heat build up to manageable levels).
            Inductance is the motors abilitiy to act as a generator, as you turn it it generates power which counteracts your voltage being used to turn it, but since they generate low voltages at the sort of speeds 3d printers use, supplying them with 24v (powering your duet from 24v) gives you more overhead. So 24v gives faster speeds for any given motor but faster still for low inductance.
            The motors voltage rating is not important.
            Select the lowest inductance motor, which is the size and current rating you need to move your axes around. Going over 3A is a bit pointless as the duet can't supply more than 2.6A (approx).
            I went for these https://www.omc-stepperonline.com/hybrid-stepper-motor/nema-17-bipolar-09deg-44ncm-623ozin-168a-28v-42x42x47mm-4-wires-17hm19-1684s.html
            www.precisionpiezo.co.uk
            • peirofundefined
              peirof
              @DjDemonD:
              Perfect, thanks for the link…
                I use those motors in my delta, but I chose them when it had a Duet 085 in it. For the Duet WiFi or Duet Ethernet, I would choose the -2004 version of the same motor instead of the -1684.
                • peirofundefined
                  peirof
                  these?
                  https://www.omc-stepperonline.com/hybrid-stepper-motor/nema-17-bipolar-09deg-46ncm-651ozin-2a-28v-42x42x48mm-4-wires-17hm19-2004s.html?search=17HM19-2004S
                  • whosrdaddyundefined
                    whosrdaddy
                    @dc42:
                    Any reason why David?
                    I also have those 2004 motors on the XY stage on my coreXY, while they work just fine, I found they make more noise (high pitch whine) than my 2.4A 1.8deg Wantai stepper motor I use on the Z-axis.
                    • DjDemonDundefined
                      DjDemonD
                      I suppose the 2A motor just gives you a bit more torque than the 1.68A which are popular when using plug in drivers as that's about the biggest motor you can reliably drive without overheating the driver.
                      That being said I can move 400mm/s on my delta with the 1.68A motors.
                      I do also have some custom made wantai motors on my corexy (they just have dual shaft and are 0.9 deg which they didn't have in stock) and they are nicely made, quiet and accurate.
                        @peirof:
                        these?
                        Yes, those. They have lower inductance than the 1.68A version, so full torque should be maintained to a higher speed.
                        • MSquaredundefined
                          MSquared
                          Just curious what everyones thoughts on the Wantai 42BYGHM810 are? They seem to be almost perfect with the rated current at 2.4A and the inductance at 1.8mH. I feel like I am missing something here because all the other motors I have looked at the inductance is much higher.
                          Specs / Costs:
                          http://www.wantmotor.com/product/42byghm.html
                          https://garagedays3d.com/shop/mechanics/stepper-motor-nema17-wantai-42byghm810/
                          https://www.aliexpress.com/item/4-lead-Nema17-stepper-motor-42BYGHM810-68oz-in-48mm-2-4A-5mm-shaft-CE-ROHS-ISO/560349599.html
                          https://www.ebay.com/itm/Wantai-5PCS-Nema17-Stepper-Motor-42BYGHM810-0-9-4200g-cm-48mm-2-4A-3D-Printer-/321350696340
                          Any feedback / enlightenment would be appreciated…
                          -M
                          • DjDemonDundefined
                            DjDemonD
                            That wantai motor looks great, might get some myself.
                            • MSquaredundefined
                              MSquared
                              I know right! I already have some motors in route from steppers online but am considering getting these too. One can never have too many steppers….
                                The low inductance of that Wantai motor would make it an excellent choice for a Delta printer.
                                • João Bastosundefined
                                  João Bastos
                                  hello guys.. from what i read i will use the Wantai 42BYGHM810.. i have a question.. for a bowden setup what extruder motor should i use? the same? and for dual Z axis? thanks
                                    Phaedrux Moderator @whosrdaddy
                                    @whosrdaddy said in Recomendation of stepper motors…:
                                    @dc42:
                                    Interesting. I use the same 2004 motors for XY and Z on my corexy and notice no whine at all and they are set to 1700 current.
                                    • OBELIKSundefined
                                      OBELIKS
                                      So 17HM19-2004S or Wantai 42BYGHM810 are suitable for cartesian printers also (overkill?)?
                                      Or is there a more suitable ones? Especially with 12V power supply (24V is planned, but not at the moment).
                                      P3Steel Toolson mk2 - Duet 2 WiFi --> RatRig V-Core with Duet WiFi 1.03
                                      Original Prusa i3 MK3S
                                      • wilrikerundefined
                                        wilriker @OBELIKS
                                        @obeliks said in Recomendation of stepper motors…:
                                        I asked myself the same question, especially the overkill part, as I am in the same position.
                                        IIRC, we have both started with an Anet A8, right @OBELIKS?
                                        Manuel
                                        My Tool Collection
                                        • OBELIKSundefined
                                          OBELIKS
                                          Correct, the only difference is that I started with an older one. So the data on Wiki page is supposed be right.
                                          What did you choose for frame? I went with P3Steel Toolson mk2
                                          • wilrikerundefined
                                            wilriker @OBELIKS
                                            @obeliks I will answer that in another thread (that I am about to start) in the "My Duet controlled machine" category. Don't want to hijack this thread for it.
                                            Regarding these 0.9° motors definitely have a lower "Speed at which torque starts to drop" (EMF Calculator at https://reprapfirmware.org/) then all of my 1.8° candidates. I think I remember that this is normal but not sure on that. Maybe someone could elaborate on this part.
                                            Manuel
                                            My Tool Collection
