    Recomendation of stepper motors…
    24
    5.8k
    • peirofundefined
      peirof
      these?
      https://www.omc-stepperonline.com/hybrid-stepper-motor/nema-17-bipolar-09deg-46ncm-651ozin-2a-28v-42x42x48mm-4-wires-17hm19-2004s.html?search=17HM19-2004S
      • whosrdaddyundefined
        whosrdaddy
        @dc42:
        I use those motors in my delta, but I chose them when it had a Duet 085 in it. For the Duet WiFi or Duet Ethernet, I would choose the -2004 version of the same motor instead of the -1684.
        Any reason why David?
        I also have those 2004 motors on the XY stage on my coreXY, while they work just fine, I found they make more noise (high pitch whine) than my 2.4A 1.8deg Wantai stepper motor I use on the Z-axis.
        • DjDemonDundefined
          DjDemonD
          I suppose the 2A motor just gives you a bit more torque than the 1.68A which are popular when using plug in drivers as that's about the biggest motor you can reliably drive without overheating the driver.
          That being said I can move 400mm/s on my delta with the 1.68A motors.
          I do also have some custom made wantai motors on my corexy (they just have dual shaft and are 0.9 deg which they didn't have in stock) and they are nicely made, quiet and accurate.
          www.precisionpiezo.co.uk
            @peirof:
            these?
            Yes, those. They have lower inductance than the 1.68A version, so full torque should be maintained to a higher speed.
            • MSquaredundefined
              MSquared
              Just curious what everyones thoughts on the Wantai 42BYGHM810 are? They seem to be almost perfect with the rated current at 2.4A and the inductance at 1.8mH. I feel like I am missing something here because all the other motors I have looked at the inductance is much higher.
              Specs / Costs:
              http://www.wantmotor.com/product/42byghm.html
              https://garagedays3d.com/shop/mechanics/stepper-motor-nema17-wantai-42byghm810/
              https://www.aliexpress.com/item/4-lead-Nema17-stepper-motor-42BYGHM810-68oz-in-48mm-2-4A-5mm-shaft-CE-ROHS-ISO/560349599.html
              https://www.ebay.com/itm/Wantai-5PCS-Nema17-Stepper-Motor-42BYGHM810-0-9-4200g-cm-48mm-2-4A-3D-Printer-/321350696340
              Any feedback / enlightenment would be appreciated…
              -M
              • DjDemonDundefined
                DjDemonD
                That wantai motor looks great, might get some myself.
                • MSquaredundefined
                  MSquared
                  I know right! I already have some motors in route from steppers online but am considering getting these too. One can never have too many steppers….
                    The low inductance of that Wantai motor would make it an excellent choice for a Delta printer.
                    • João Bastosundefined
                      João Bastos
                      hello guys.. from what i read i will use the Wantai 42BYGHM810.. i have a question.. for a bowden setup what extruder motor should i use? the same? and for dual Z axis? thanks
                        Phaedrux Moderator @whosrdaddy
                        @whosrdaddy said in Recomendation of stepper motors…:
                        @dc42:
                        Interesting. I use the same 2004 motors for XY and Z on my corexy and notice no whine at all and they are set to 1700 current.
                        • OBELIKSundefined
                          OBELIKS
                          So 17HM19-2004S or Wantai 42BYGHM810 are suitable for cartesian printers also (overkill?)?
                          Or is there a more suitable ones? Especially with 12V power supply (24V is planned, but not at the moment).
                          P3Steel Toolson mk2 - Duet 2 WiFi --> RatRig V-Core with Duet WiFi 1.03
                          Original Prusa i3 MK3S
                          • wilrikerundefined
                            wilriker @OBELIKS
                            @obeliks said in Recomendation of stepper motors…:
                            I asked myself the same question, especially the overkill part, as I am in the same position.
                            IIRC, we have both started with an Anet A8, right @OBELIKS?
                            Manuel
                            My Tool Collection
                            • OBELIKSundefined
                              OBELIKS
                              Correct, the only difference is that I started with an older one. So the data on Wiki page is supposed be right.
                              What did you choose for frame? I went with P3Steel Toolson mk2
                              • wilrikerundefined
                                wilriker @OBELIKS
                                @obeliks I will answer that in another thread (that I am about to start) in the "My Duet controlled machine" category. Don't want to hijack this thread for it.
                                Regarding these 0.9° motors definitely have a lower "Speed at which torque starts to drop" (EMF Calculator at https://reprapfirmware.org/) then all of my 1.8° candidates. I think I remember that this is normal but not sure on that. Maybe someone could elaborate on this part.
                                Manuel
                                My Tool Collection
                                • taconiteundefined
                                  taconite
                                  It seems like a trade-off:
                                  0.9°/step --> higher resolution than 1.8°/step
                                  0.9°/step --> lower speed where the torque drops than 1.8°/step
                                  low inductance --> "less Back-EMF" so higher speed where the torque drops
                                  low inductance --> motor is more expensive
                                  Custom ANET A8
                                  Custom Delta: D-PATCH (Delta Printer with Automatic Tool CHanging) https://forum.duet3d.com/topic/16082/d-patch?_=1596131234754
                                  All I do here is under this license: CC BY-NC-SA
                                  • wilrikerundefined
                                    wilriker
                                    Another thing that I found out and cannot explain (and I hijack this thread a little but it is still related): all motors I researched, independent of all specs always have a temperature rise of 80-85°C. What does this number depend on? All they had in common was being Nema 17 but they were different lengths, different torque, different voltage, different current, different inductance, different resistance.
                                    How can this be?
                                    Manuel
                                    My Tool Collection
                                    • taconiteundefined
                                      taconite
                                      my suggestion:
                                      different length = different torque
                                      same torque but lower voltage = high current = same power (P=U*I (formula for DC))
                                      same torque but higher voltage = low current = same power
                                      but the temperature they have is because of what heat they can emit and this depends on the surface area --> so they have all the same emitting "factor" per length (thats why the longer motors have the same temperature)
                                      Custom ANET A8
                                      • wilrikerundefined
                                        wilriker @taconite
                                        @taconite I also thought that this might be a function of power vs. length but here are two particular motors where it does not fit:
                                        • https://www.omc-stepperonline.com/nema-17-stepper-motor/nema-17-bipolar-18deg-18ncm-255ozin-07a-29v-42x42x25mm-4-wires-17hs10-0704s.html
                                          Lenght: 25mm
                                          Power: 2.1W
                                        • https://www.omc-stepperonline.com/nema-17-stepper-motor/nema-17-bipolar-18deg-13ncm-184ozin-1a-35v-42x42x20mm-4-wires-17hs08-1004s.html
                                          Length: 20mm
                                          Power: 3.5W
                                        As you can see the second motor is shorter but has over 50% more power but they both have a max temperature rise of 80°C. I am clueless here. Also it is always stated that this temperature will be reached at full current in stand-still with both coils fully energized.
                                        Manuel
                                        My Tool Collection
