Purpose of Connectors in the Included Bag
Better still - what type of crimping device is used to remake these connectors ? I already loathe Duponts fiddly little buggerz … if these are same or similar ... imma pass ...
bootlace ferrule crimps are really easy. Stick the wire in, and crimp. Not fiddly at all. The crimper just squishes the metal tube into a compressed shape to firmly hold the wire. I wouldn't recommend plyers though, they pinch it, but don't compress it tightly like the crimper does.
Nah .. misunderstood … the ferrules are a dream - its the 5 billion other fiddly little JST / Dupont types i'm referring to ... ive got the Ferrules and the crimper for those
The HT225D crimper is suitable for the Molex KK compatible connectors and is widely available.
Those connectors can be quite fiddly, especially if one has had too much coffee. It took me about 15 - 20 of them before I finally got a system down that let me do them quickly. You also have to be careful to make sure you are using the right AWG slot on your crimper or you can create very fragile wires that tend to disconnect at in-opportune times.
Basically I use a pair of small needle nose to pinch the part of the connector that grips the insulation of the wire just enough that it won't fall off. Then I set it on the die of the crimper so that the insulation grabbing part is in the small side and the pin that holds it into the housing is on the outside of the die. Crimp, turn the connector around so that the part that bites into the exposed wire is now on the small side with the holding pin on the outside of the die and crimp again.
I honestly have no idea if this is the right way or not; however once I started doing this I had professional looking, solid connecting, and non wire breaking connections that only took me 15 - 20 seconds per wire to do. This resulted in far less cussing and swearing as well.
Using the crimper that DC42 recommended I find the easiest way is to:
- insert the molexkk crimp into the correct slot on the crimper and start to close it, just enough so that the crimp is held in place. The ratchet mechanism of the crimper holds the crimper at that point.
- insert the stripped wire so that the insulation is up to the central notch in the crimper. This makes the insulation line up with the larger part of the crimps and the stripped wire the smaller, tighter part.
- fully close the crimper so the ratchet releases.
interesting - took me a couple reads to sort out your process … what Crimping tool do you have ? I have an IWISS SN-28B. Due to its thickness/width - where the connector goes into the tool - 2 crimps is rather difficult and NOT smashing the whole lot up as trash ... Im suspecting maybe you have a different tool that is not as wide in the crimp holding area ...
Perhaps this is part of my issue ?
Here is the crimper that I use:
https://www.amazon.com/Engineer-PA-09-Micro-Connector-Crimpers/dp/B002AVVO7KIt has a crimp contact patch around 3mm thick, so I end up crimping the insulation retention and the contact crimps separately.
I have found that with the Engineer PA-09 crimper, it works best for me to just cut the strip that the little terminals are on between the contacts, bend the remaining tab down around 90°, and use that as a guide as to where the pin should rest in the crimp jaws.
The issue with the PA-09 is that it isn't a ratchet operated one so you can get poor crimps due to the hand pressure required to operate them and the best ones I have used (this is personal preference mind) is the one from Hobbyking https://hobbyking.com/en_us/hobbyking-jst-sh-connector-crimping-tool.html Cheap cheerful and works
Doug
I have been using the Engineer PA-09 crimpers for the molex connectors and have had 0 issues. No cutting or snips or other pliers needed. Does take two crimps as Allen mentioned - crimp the insulation and then crimp then then contacts.
That ratchet one looks easier on the pocket book though…
Nate
I've got that same crimper - and once you figure out which direction and orientation to insert the Dupont pins/sockets in, it actually makes some solid crimps. I'll snap a couple of pictures of the way I do it when I get home today. It definitely took me a couple dozens of attempts to get it down consistently.
Alright, got around to snagging some photos. I realized that I really don't have an account on a photo hosting site that's still around, so Instagram will have to do for the moment hah! Click the arrows within the picture to scroll to the different steps. Let me know if something doesn't make sense!
https://www.instagram.com/p/BfMrAR3H8GU/?taken-by=lumberjackengineering
Excellent work! thankyou very much.
