    PanelDue7i
    PanelDue
    13
    17
    2.6k
    • JuJuDeltaundefined
      JuJuDelta
      This looks great, ordered one for my Kossel XL+
      Please let me know when/if you have a 3D printed case STL for it.
      T3DP3D Kossel XL+, Duet2Wifi, PanelDue 7i, RRF V3.2, Fl3xdrive, SmartEffector, Berd Air annulus, Cura 4.x, PrusaSlicer, RPi WiFi Camera, Heated Chamber
      • pogo1213undefined
        pogo1213
        Will there be a other sizes offered in this configuration?
          @pogo1213:
          Not in the near future. If our experience with the 7" version is good, we may eventually commission a 5" version.
          • Qdeathstarundefined
            Qdeathstar
            For us, is it better to buy from you or filastruder?
              T3P3Tony administrators
              @Qdeathstar:
              If you are US based then Filastruder, If UK then Duet3d.com otherwise check the shipping and exchange rates.
              • Danalundefined
                Danal
                Where would I find a mechanical drawing, and/or a .brd file, for the new PanelDue 7i?
                I have one, wanting to print a case/mount for it. I can measure it… but I'd rather work from a drawing.
                • Quadcellsundefined
                  Quadcells
                  Where can I find the physical dimensions and or drawings. I would like to design a case for it unless you have one already designed.
                  /quadcells
                  /quadcells
                  • elmoretundefined
                    elmoret
                    Drawings added to the Filastruder site:
                    https://www.filastruder.com/products/paneldue-7i
                      Quadcells
                      @elmoret:
                      Thank you!
                      /quadcells
                      • pabomanundefined
                        paboman
                        I need dimensions to get the 7" LCD into solidworks, maybe someone already did the 3D…?
                        • Drammyundefined
                          Drammy
                          Has anyone built a case for this yet?
                          If so, care to share? I'm a complete novice at 3d object design; wouldn't know where to start..
                          • Drammyundefined
                            Drammy
                            Scratch that last request - just found this…
                            https://www.thingiverse.com/thing:2818424
                            • LumberjackEngineeringundefined
                              There's a few PanelDue 7i cases out there. I myself am partial to this one (https://www.thingiverse.com/thing:2799628), but that's because I designed it heehee. It's not as thin as it could be though, so if that's what you're looking for the one you linked is probably a better fit for you.
                              • Drammyundefined
                                Drammy
                                @LumberjackEngineering:
                                Wish I'd seen this one first - looks great and I like the fact you have the mounting bracket included and button for the reset button. Hmmm, decision to make… throw away the already printed one and print this or stick with what I have...
