    RepRapFirmware 2.0 with RTOS in development
    Firmware installation
    18
    58
    9.6k
    • whosrdaddyundefined
      whosrdaddy
      @Danal:
      Sign me up for Alpha. I have a Duet that is not in a printer at the moment, and I've been "Playing with things" on that one… 🙂
      +1
      • klcjr89undefined
        klcjr89
        When will the Duet Maestro be announced for purchase?
        • Dougal1957undefined
          Dougal1957
          @Danal:
          +1
          • denkeundefined
            denke
            What upgrades will this new hardware have over the existing Duet 2 series?
            Will it be compatible with the existing accessories: panelDue, smart effector, duex5 / duex?
            • timcurtis67undefined
              timcurtis67
              I will try the Alpha on my DuetWifi IDEX printer. Sign me up.
                @klcjr89:
                When we can provide a shipping date for it. Currently there are only 3 prototypes in existence. Just to be clear, it is a lower-specification board than the Duet Ethernet.
                  Dougal1957
                  @dc42:
                  @klcjr89:
                  David
                  Can you share the basic specs of it it may interest some people out there as I assume the price will be reduced as well and may attract more people into the Duet Family so to speak.
                  Doug
                    The basic port to use RTOS is now working. Currently RepRapFirmware is running with just two tasks (one for heating control and one for everything else). The next step is to separate out the networking subsystem into a separate task, followed by GCode processing and movement. I've not yet decided whether to use a task for generating the step pulses or to leave that as an ISR.
                    The RTOS I chose is FreeRTOS. It is small and lightweight, ideally suited to embedded applications on ARM Cortex processors. It's coded to high standards - it claims compliance with the MISRA-C coding standard, which is the one used widely for critical C software in automotive, aerospace and other sectors.
                      T3P3Tony administrators
                      @Dougal1957:
                      @dc42:
                      @klcjr89:
                      David
                      Doug
                      We did the work with an OEM who is going to be releasing the information soon. They own the timeline for this!
                        Dougal1957
                        I was aware that the work was for an OEM shame they haven't announced anything yet wonder if they will try and keep it to themselves or let you guy's have it in your shop as well.
                        Good to hear that you have the initial port David very excited to actually give it a go
                        I have a Ethernet with Duex5 sitting here just ready for some testing to happen until I can get the CoreXY to a state ready to take the controller (That will have a Smart effector re-purposed for it) Carriage for that is already done
                        Keep up the excellent work.
                        Doug
                        • DADIYundefined
                          DADIY
                          @dc42:
                          Does this mean we might see the ability to upload a file at the same time as printing?
                            @DADIY:
                            @dc42:
                            Yes, I hope to support that. In the longer term more complicated stuff, like simulating newly uploaded files in the background so that an accurate print time is known.
                              timcurtis67
                              @dc42:
                              @DADIY:
                              @dc42:
                              Any chance on being able to store/recall variables and use if/then, addition/subtraction logic statements in macros?
                                That's planned, but not directly related to RTOS.
                                  Further progress yesterday and today. RepRapFirmware 2.0 alpha now has a thread-safe file system! This paves the way for splitting the code into more tasks. The next work item will be to make PrintMonitor and the interfaces between Network and the rest of the system thread-safe, after that the network subsystem can run as a separate task. That will allow more network stuff to happen in parallel with SD card access, which should speed things up a little.
                                  • ShadowXundefined
                                    ShadowX
                                    Does this mean that eventually we won't have the problem where the system pauses while the hot end is heating when using the PanelDue? The system becomes unresponsive to any commands until the heating is is complete. Any commands issued (ie: homing) during that period would only happen after the hot end heater reaches the temp.
                                      @ShadowX:
                                      The 'system' doesn't pause when the hot end is heating. The command channel that you sent the heating command from won't accept further commands if the heating command is defined to wait until temperature is reached of course, so if you send such a command from PanelDue then of course it will become unresponsive.
                                      • ShadowXundefined
                                        ShadowX
                                        Thanks for the clarification.
                                          I should add that:
                                          1. Setting temperatures in PanelDue on the Control and Print pages does not use commands that wait for temperature.
                                          2. Even if you do invoke a "set temperature and wait" command from PanelDue (e.g. in one of your own macro files, or by selecting a new tool when there is a set-and-wait command in one of the tool change macro files), the status will continue to update while waiting unless you are using very old main firmware.
                                            More progress yesterday and today. It turned out that there are a lot of chunks of code that are not thread-safe, especially in the older code - which is understandable, because it was written before using a RTOS was envisaged. Anyway, I've now made all the output channels thread safe, also the tool list and the mechanism used to extract print data from GCode files.
                                            I've started including a binary of the latest RTOS build for the Duet WiFi and Ethernet in the github commits. It's at https://github.com/dc42/RepRapFirmware/blob/v2-dev/EdgeRelease/Duet2CombinedFirmware.bin. If you like taking risks, follow that link and click Download. I've included a couple of bug fixes in this one too:
                                            • Fixed issue with G1 S1 Ennn on delta printers
                                            • The FileInfo parser now has a timeout if called from DWC, to prevent the connection being lost when getting info from a large file with a small SD card cluster size. You will no longer get disconnected, but you probably won't get object height or filament required information.
                                            It's compatible with version 1.21 of iap4e.bin, DuetWiFiServer.bin and DuetWebControl.zip.
